Results 1 to 3 of 3
Thread: 2018 Audi A5 1.4tfsi virtual speedometer retrofitting
    Jul 2019
    Sheffield, UK
    Hi
    This is my first post I've installed a used virtual cluster in a 2018 Audi A5 1.4 Tfsi automatic the speedometer was from a 2018 audi RS5. Everything seems to be working as it should but for some reason i cannot change the wheel circumference coding. it says request out of range. also the cluster displays gearbox malfunction. i atatch full vcds scan of the car. any help appreciated
    Saturday,14,September,2019,11:58:40:06187
    VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
    VIN: WAUZZZF5XJA087435 License Plate: YY18CXV
    Mileage: 14048km-8729mi Repair Order:
    Chassis Type: F5-AU49 (8W5)
    Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 81 A5
    BB BC D6 D7
    VIN: WAUZZZF5XJA087435 Mileage: 14048km-8729miles
    Address 01: Engine (J623-CVNA) Labels:. 04E-907-309-V1.clb
    Part No SW: 04E 906 022 B HW: 04E 907 309 R
    Component: R4 1.4l TFS H22 4032
    Revision: 44H22000
    Coding: 022500324324150834080000000000000000000000000000
    Shop #: WSC 06314 790 00001
    ASAM Dataset: EV_ECM14TFS01104E906022B 002002
    ROD: EV_ECM14TFS01104E906022B.rod
    VCID: 1E65224DC0365747D85-804A
    23734 - Implausible Data Received from Instrument Panel Control Module
    U0423 00 [038] - -
    [Invalid Data Received FromInstrument Panel Cluster Control Module]
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:53:55
    Coolant temperature: 80 °C
    Intake air temperature: 24 °C
    Voltage terminal 30: 12.380 V
    Outside air temperature: 19 °C
    Absolute intake pressure: 103 kPa abs
    Engine torque: 0.0 Nm
    Fuel level: 327.67 l
    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
    Intake camshaft bank1 active operating mode-Bits 0-7: 0
    Overrun cut-off-Bits 0-7: 0
    4715 - No Communication with Instrument Cluster
    U0155 00 [038] - -
    [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:53:05
    Coolant temperature: 81 °C
    Voltage terminal 30: 12.460 V
    Fuel level: 34.00 l
    Readiness: 0110 0001
    Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
    Part No SW: 8W2 927 155 AD HW: 0CJ 927 156
    Component: 0CK 14TFSIRdW H05 0002
    Revision: --H05--- Serial number: 0000002232
    Coding: 000001
    Shop #: WSC 05761 780 00200
    ASAM Dataset: EV_TCMDL382021 002027
    ROD: EV_TCMDL382021_AU49.rod
    VCID: 035373394B949AAFD7B-8056
    Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
    Component: V553 MTFP 003 0576
    Serial number: 75145041180040000142
    20995 - Control Module in Instrument Cluster
    U100E 00 [167] - Wheel Circumference Implausible
    [Control module for instrument panel insert Wheel circumference implausible]
    Mileage: 14047 km
    Date: 2019.09.14
    Time: 10:56:37
    Engine speed: 0 /min
    Driving position: P
    Transmission fluid temperature: 21 °C
    Transmission output speed: 0 /min
    Voltage terminal 30: 11.7 V
    Engine torque: -20 Nm
    selected gear: 1
    Ctrl. mod.: operating condition: regular operation
    Auxiliary pump for transmission: requesting function: Preloading
    Auxiliary hydraulic pump for transmission oil: current: 0 A
    Oil pressure reservoir: pressure: 17.3 bar
    Pressure of clutch 1: actual value: 0.0 bar
    Pressure of clutch 2: actual value: 0.0 bar
    Clutch status: Neutral
    Occurrence_counter_over_length_of_life: 8
    ESP_Wheel_circumference: 2068
    Safety_interface_expected_wheel_circumference: 2012
    21021 - No Communication with Instrument Cluster
    U0155 00 [038] - -
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:53:05
    Driving position: P
    Transmission fluid temperature: 31 °C
    Voltage terminal 30: 12.5 V
    Engine torque: -12 Nm
    selected gear: 1
    Oil pressure reservoir: pressure: 18.2 bar
    Occurrence_counter_over_length_of_life: 5
    Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
    Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
    Component: ESP9 Plus H10 0766
    Coding: 04AA049A10AA0A9D11A2489400825292F4A5D2202008508812 004A492FA54B
    Shop #: WSC 06334 790 00001
    ASAM Dataset: EV_ESP9BOSCHCMP 002013
    ROD: EV_ESP9BOSCHCMP_002.rod
    VCID: 4DC79501DD509CDF71F-8018
    496896 - Databus
    U1121 00 [046] - Missing Message
    [ComScl:_PDU_Kombi_01-_Timeout_error]
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:53:05
    7D 00 80 00 C2 00 00 00 00 00
    Unlearning counter according OBD-OBD unlearning counter: 28
    Address 08: Auto HVAC (E87) Labels:* Redir Fail!
    Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
    Component: Klima Zone 3 H60 0210
    Coding: 140800095544040D0200010088000000000000000000000000 0000000000
    Shop #: WSC 06335 790 00001
    ROD: EV_AirCondiBHTCAU491.rod
    VCID: 44D1B0250E1A5D97AE1-8010
    Subsystem 1 - Part No SW: 4M2 820 021 B HW: 4M2 820 021 B
    Component: J126 FLuftV H09 0003
    Serial number: 00000000000002134524
    Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
    Component: AQ_Hum_Sensor H02 0007
    Serial number: 4461501900PAG0MUFU02
    Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
    Component: E265 Kli Fond H40 0080
    459013 - Databus
    Reset counter: 45
    Mileage: 14047 km
    Date: 2019.09.14
    Time: 10:49:38
    Address 09: Cent. Elect. (J519) Labels:* None
    Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
    Component: BCM1 MLBevo H13 0267
    Coding: 07501143E11800CD050551181BAC80F9110B31080000000000 00000020001A810A450122025601
    VCID: 025D763D548E93A7DCD-8056
    Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
    Component: 494 RL 120118 036 0471
    Serial number: 00000001801100300026
    Coding: 5FC7F7
    Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
    Serial number: 21160496X81A955555A0
    Coding: 02005D
    Light switch:
    Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
    Component: E1 - LDS H06 0008
    Serial number: 15 01 2018 01262886
    Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
    Component: Y7_Innenspieg H09 0002
    Serial number: GX1CE116121723811295
    Coding: 210000
    Interior Light Module:
    Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
    Component: J528-Dachele H14 0130
    Serial number: B00688754
    Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
    Component: SL-B9/Q5NF H17 0010
    Serial number: 2817000305327004
    Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
    Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
    Component: Airbag10.44 H03 0107
    Serial number: 003UP00D26SL
    Coding: AACCF0C00C800000585400F3D0CC00000000
    ASAM Dataset: EV_AirbaAU10BPAAU736 006016
    ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
    VCID: 4CC19805264A95D7661-8018
    Subsystem 1 - Part No SW: ----------- HW: 442 061 002 18
    Serial number: 3577Y00A52711E41E15Z
    Subsystem 2 - Part No SW: ----------- HW: 442 061 002 18
    Serial number: 3587Y00A32711E41E31W
    Subsystem 3 - Part No SW: ----------- HW: 442 0B2 901 18
    Component: SideSensor_Dr 1C7 0148
    Serial number: 3517700A12943BE1E208
    Subsystem 4 - Part No SW: ----------- HW: 442 0B2 901 18
    Serial number: 3527700A12943BE222B9
    Subsystem 5 - Part No SW: ----------- HW: 442 0C3 001 18
    Component: FrontSensor_D 1C5 014A
    Serial number: 35575009B29736A5C2AP
    Front Sensor Passenger:
    Subsystem 6 - Part No SW: ----------- HW: 442 0C3 001 18
    Component: FrontSensor_P 1C5 014A
    Serial number: 35675009B29736A540CI
    Pedestrian Protection Center:
    Subsystem 7 - Part No SW: ----------- HW: 442 0C2 401 18
    Component: PedP_Sensor_C 1C5 014A
    Serial number: 2307500A7291FA138030
    Subsystem 8 - Part No SW: ----------- HW: 442 432 201 18
    Component: PedPSensor_D2 256 0887
    Serial number: I0M9M00B726ADCD3603S
    Subsystem 9 - Part No SW: ----------- HW: 442 432 201 18
    Component: PedPSensor_P2 256 0887
    Serial number: I0N9M009F26ADCD4E424
    1051904 - Databus
    [NWD: 0x30B Kombi_01Timeout]
    Reset counter: 45
    Mileage: 14047 km
    Date: 2019.09.14
    Time: 10:49:38
    Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
    Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
    Component: Lenks.Modul H11 0009
    ROD: EV_SMLSKLOAU736_006.rod
    VCID: 76B51AED0846BF07E05-8022
    Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
    Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
    Component: FBenRDW H18 0371
    Coding: 25A440DE288006000120E9601000000000000000
    ASAM Dataset: EV_DashBoardAU736 001027
    VCID: 43D3B3390B145AAF97B-8016
    U1014 00 [008] - -
    [ECU incorrectly coded]
    Reset counter: 45
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:51:56
    13636609 - Control module
    U110E 00 [008] - implausible coding
    [ECU incorrectly coded (number of fuel level sender BCM2/Kombi implausible)]
    Reset counter: 45
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:53:54
    16776982 - Databus
    [SWA_01 communication error can_error_timeout]
    Reset counter: 45
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:53:56
    16776985 - Databus
    [QSP_03 communication error can_error_timeout]
    Reset counter: 45
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:53:55
    16777007 - Databus
    [Fahrwerk_Anzeige_01 communication error can_error_timeout]
    Reset counter: 45
    Mileage: 14048 km
    Date: 2019.09.14
    Time: 11:53:55
    Part No SW: 8W5 907 468 F HW: 8W5 907 468 E
    Component: Gateway H43 0123
    Revision: 7A000002 Serial number: 0287A777918221
    Coding: 03010001000086402607000000590012C81800071000000001 75078E10000000
    ASAM Dataset: EV_CGateCONTIAU491 003111
    ROD: EV_CGateCONTIAU491_003_AU49.rod
    Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
    Component: J453 MFL H04 0004
    Serial number: 20180214131246 21599
    Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
    Serial number: 0353566804
    8913154 - Databus
    [Signal_Error_Tank_Level_High_Resolution]
    Reset counter: 45
    Mileage: 14047 km
    Date: 2019.09.14
    Time: 10:49:05
    8531970 - Quiescent Current
    U1406 00 [008] - Too High
    [Electric_current_Upper_Limit_Value_Exceeded]
    Reset counter: 44
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 23:16:36
    Total static current-current total quiescent current: 135 mA
    Total static current-Total time quiescent current exceeded: 1.0 H
    EM_vehicle_state: 00 00
    Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
    Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
    Component: LCM_MLBevoH05 0024
    VCID: 77AB17E90F4CC60FFB3-8022
    Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
    Component: ELV-MLBevo H05 0032
    Serial number: 18000056471017
    Coding: 8800000000000000
    ROD: EV_ELVMarquMQBB.rod
    VCID: 323DE6FDA4AEE3270CD-8066
    Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
    Address 42: Door Elect, Driver (J386) Labels:* None
    Part No SW: 8W0 959 593 H HW: 8W0 959 593 F
    Component: TSG FS 005 0129
    Serial number: 0000304943975
    Coding: 001DCA624001000000001482
    VCID: 4FFB8F09D75CAECF033-801A
    196660 - Motor for Window Regulator
    B1487 54 [009] - Missing Calibration / Basic Setting
    Reset counter: 3
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 18:38:41
    Address 44: Steering Assist (J500) Labels:* None
    Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
    Component: EPS_MLBEVO_ZF H08 0410
    Coding: 09000380008000
    ASAM Dataset: EV_EPSZFAU49X 003023
    ROD: EV_EPSZFAU49X_003.rod
    VCID: 42DDB63D140E53A79CD-8016
    Address 46: Central Conv. (J393) Labels:* None
    Part No SW: 8W0 907 064 EB HW: 8W0 907 064 DB
    Component: BCM2 MLBevo 025 0387
    Coding: 013500002FB100406301A0000600080231020010804306502F 04000000040030001F0001000000
    Shop #: WSC 00200 935 01530
    ASAM Dataset: EV_BCM2HellaAU736 014014
    ROD: EV_BCM2HellaAU736_014_AU49.rod
    VCID: 00597C355A8281B7CA9-8054
    Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
    Serial number: 000000000ZY1735539WN
    Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
    Serial number: 00000000000099797282
    65896 - Databus
    [Climatronic control module: Klima_03: no signal/communication]
    Reset counter: 44
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 21:09:49
    Supply voltages-Supply voltage: Terminal 30: 12.120 V
    Supply voltages-Supply voltage Terminal 30 - 2: 12.187 V
    Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
    general_additional_freeze_frame-coprocessor_spi_status: 00000000
    general_additional_freeze_frame-dataflash_status: 00000000
    general_additional_freeze_frame-interior_temperature: -50.0 °C
    general_additional_freeze_frame-Operating_Status: 00000000 00000000
    general_additional_freeze_frame-production_mode: not active
    general_additional_freeze_frame-reset_cause: 00000000
    general_additional_freeze_frame-Reset_counter: 0
    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
    general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 10 04 80
    general_additional_freeze_frame-Transport_Mode: not active
    general_additional_freeze_frame-Vehicle speed: 0.00 km/h
    can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
    Part No SW: 8W0 959 592 H HW: 8W0 959 592 F
    Component: TSG BFS 005 0129
    Serial number: 0000304611841
    Coding: 001DCA224001000000001480
    VCID: 4EC5920DD056A7C7085-801A
    Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGS2.clb
    Part No SW: 8W0 035 192 H HW: 8W0 035 192 A
    Component: MU-HS-LND-EU 050 0213
    Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
    ASAM Dataset: EV_MUHigScl6C3DELP 001011
    ROD: EV_MUHigScl6C3DELP.rod
    VCID: 3B23CBD973E4226FDFB-806E
    Subsystem 1 - Part No SW: 8W0 919 866 AB HW: -----------
    Component: ECE 2018 --- 0032
    Subsystem 2 - Part No SW: 8W8 919 604 HW: 8W8 919 604
    Component: DU Std AU49x H32 0170
    Serial number: TPO00107111700720292
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
    Component: ControlUnit_B H22 0134
    Serial number: APVAK110021800020257
    11 Faults Found:
    0513 - Rear Right Treble Speaker
    B1068 13 [009] - Open Circuit
    [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
    Reset counter: 4
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:13:20
    Voltage terminal 30: 12.0 V
    B1066 13 [009] - Open Circuit
    [Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
    Reset counter: 4
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:13:20
    0532 - Subwoofer
    B106C 13 [009] - Open Circuit
    [Tieftonlautsprecher Kanal 5: Unterbrechung (DC-Diagnose)]
    Reset counter: 4
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:13:15
    0005 - Antenna Amplifier 1 for Radio
    B126D 13 [009] - Open Circuit
    Reset counter: 4
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:13:09
    Status of antenna 1 for radio-Antenna current: 0 mA
    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
    0006 - Antenna Amplifier 2 for Radio
    B126E 13 [009] - Open Circuit
    Reset counter: 4
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:13:08
    Status of antenna 2 for radio-Antenna current: 0 mA
    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
    Status of antenna 2 for radio-Reception level antenna 2: 12 dBµV
    3073 - Cellular Antenna
    B1053 13 [009] - Open Circuit
    [GSM/UMTS aerial - open circuit]
    Reset counter: 4
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:13:08
    3084 - GSM antenna 2
    B1533 13 [009] - Open Circuit
    Reset counter: 4
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:13:09
    6666 - Optical data bus
    U1049 00 [008] - Open circuit
    Reset counter: 44
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:14:15
    Temperature of MOST transceiver-max.value: -50 °C
    Temperature of MOST transceiver-min.value: -4 °C
    Temperature of MOST transceiver-Current: 48 °C
    6698 - Optical data bus
    [Optical data bus: open circuit: wakeup]
    Reset counter: 44
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:14:30
    6667 - Optical Data Bus for Information Electronics 1
    U10CA 00 [009] - Intermittent Disruption
    [Optical data bus: sporadic open circuit in central processor]
    Reset counter: 5
    Mileage: 14047 km
    Date: 2019.09.14
    Time: 10:49:52
    Voltage terminal 30: 11.8 V
    Temperature of MOST transceiver-Current: 33 °C
    6672 - Optical Data Bus for Display in Instruments
    U10CF 00 [008] - Intermittent Disruption
    [Optical data bus: sporadic open circuit in instrument cluster display]
    Reset counter: 44
    Mileage: 14047 km
    Date: 2019.09.13
    Time: 20:16:32
    Temperature of MOST transceiver-Current: 49 °C
    Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
    Part No SW: 8W8 959 107 B HW: 8W8 959 107
    Component: HDSG-Modul H13 0163
    Revision: -------- Serial number: 31792481200000
    Coding: 0610
    ASAM Dataset: EV_DeckLidCONTIAU736 001015
    VCID: 48C9A415323279F7429-801C
    Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
    Part No SW: 8W2 713 041 G HW: 8W2 713 041 J
    Component: GSM-LL H09 0077
    Revision: 0L0D5012 Serial number: 18013045792093
    ROD: EV_GSMWaehlZFAU736.rod
    VCID: 3829D4D542D20977329-806C
    Address A5: Frt Sens. Drv. Assist
    Part No SW: 8W0 959 595 H HW: 8W0 959 595 F
    Component: TSG HFS 005 0129
    Serial number: 0000303432968
    Coding: 000DC8220001000000001080
    VCID: 51FF8971C168B83F157-8004
    Address BC: Door Rear Pass
    Address D6: Light Ctrl Left 2
    Address D7: Light Ctrl Right 2
    End----(Elapsed Time: 01:31, VBatt start/end: 12.4V/12.3V. VIgn 0.3V)------
    Starting 2 threads on the same topic isn't a great idea as it splits replies - the Benevolent Dictator will be along soon to merge them I reckon...
  3. Likes Uwe liked this post
    Thread closed. Please continue in the thread in the Retrofits section.
    https://forums.ross-tech.com/showthr...luster-install
