Results 1 to 8 of 8
Thread: 2018 Audi A5 virtual cluster install
    Jul 2019
    Sheffield, UK
    Iver installed a virtual cluster ina 2018 Audi A5 everything works as it should but for some reason i cannot change the wheel circumference coding. it says request out of range. also the cluster displays gearbox malfunction. i atatch full vcds scan of the car. any help appreciated
    Saturday,14,September,2019,11:58:40:06187
    VIN: WAUZZZF5XJA087435   License Plate: YY18CXV
    Mileage: 14048km-8729mi   Repair Order:
    Chassis Type: F5-AU49 (8W5)
    Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 81 A5
              BB BC D6 D7
    VIN: WAUZZZF5XJA087435   Mileage: 14048km-8729miles
    Address 01: Engine (J623-CVNA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 022 B    HW: 04E 907 309 R
       Component: R4 1.4l TFS   H22 4032
       Revision: 44H22000
       Coding: 022500324324150834080000000000000000000000000000
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM14TFS01104E906022B 002002
       ROD: EV_ECM14TFS01104E906022B.rod
       VCID: 1E65224DC0365747D85-804A
    23734 - Implausible Data Received from Instrument Panel Control Module
              U0423 00 [038] - -
              [Invalid Data Received FromInstrument Panel Cluster Control Module]
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:53:55
                        Coolant temperature: 80 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 12.380 V
                        Outside air temperature: 19 °C
                        Absolute intake pressure: 103 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 327.67 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Overrun cut-off-Bits 0-7: 0
    4715 - No Communication with Instrument Cluster
              U0155 00 [038] - -
              [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:53:05
                        Coolant temperature: 81 °C
                        Voltage terminal 30: 12.460 V
                        Fuel level: 34.00 l
    Readiness: 0110 0001
       Part No SW: 8W2 927 155 AD    HW: 0CJ 927 156
       Component: 0CK 14TFSIRdW H05 0002
       Revision: --H05---    Serial number: 0000002232
       Coding: 000001
       Shop #: WSC 05761 780 00200
       ASAM Dataset: EV_TCMDL382021 002027
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 035373394B949AAFD7B-8056
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041180040000142
    20995 - Control Module in Instrument Cluster
              U100E 00 [167] - Wheel Circumference Implausible
              [Control module for instrument panel insert Wheel circumference implausible]
                        Mileage: 14047 km
                        Date: 2019.09.14
                        Time: 10:56:37
                        Engine speed: 0 /min
                        Driving position: P
                        Transmission fluid temperature: 21 °C
                        Transmission output speed: 0 /min
                        Voltage terminal 30: 11.7 V
                        Engine torque: -20 Nm
                        selected gear: 1
                        Ctrl. mod.: operating condition: regular operation
                        Auxiliary pump for transmission: requesting function: Preloading
                        Auxiliary hydraulic pump for transmission oil: current: 0 A
                        Oil pressure reservoir: pressure: 17.3 bar
                        Pressure of clutch 1: actual value: 0.0 bar
                        Pressure of clutch 2: actual value: 0.0 bar
                        Clutch status: Neutral
                        Occurrence_counter_over_length_of_life: 8
                        ESP_Wheel_circumference: 2068
                        Safety_interface_expected_wheel_circumference: 2012
    21021 - No Communication with Instrument Cluster
              U0155 00 [038] - -
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:53:05
                        Driving position: P
                        Transmission fluid temperature: 31 °C
                        Voltage terminal 30: 12.5 V
                        Engine torque: -12 Nm
                        selected gear: 1
                        Oil pressure reservoir: pressure: 18.2 bar
                        Occurrence_counter_over_length_of_life: 5
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
       Part No SW: 8W0 907 379 K    HW: 8W0 907 379 J
       Component: ESP9 Plus     H10 0766
       Coding: 04AA049A10AA0A9D11A2489400825292F4A5D2202008508812004A492FA54B
       Shop #: WSC 06334 790 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 4DC79501DD509CDF71F-8018
    496896 - Databus
              U1121 00 [046] - Missing Message
              [ComScl:_PDU_Kombi_01-_Timeout_error]
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:53:05
                        7D 00 80 00 C2 00 00 00 00 00
                        Unlearning counter according OBD-OBD unlearning counter: 28
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
       Component: Klima Zone 3  H60 0210
       Coding: 140800095544040D02000100880000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 44D1B0250E1A5D97AE1-8010
       Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
       Component: J126 FLuftV  H09 0003
       Serial number: 00000000000002134524
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 4461501900PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: E265 Kli Fond  H40 0080
    459013 - Databus
                        Reset counter: 45
                        Mileage: 14047 km
                        Date: 2019.09.14
                        Time: 10:49:38
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Coding: 07501143E11800CD050551181BAC80F9110B3108000000000000000020001A810A450122025601
       VCID: 025D763D548E93A7DCD-8056
       Subsystem 1 - Part No SW: 8W6 955 119 A    HW: 8W6 955 119 A
       Component: 494 RL 120118  036 0471
       Serial number: 00000001801100300026
       Coding: 5FC7F7
       Serial number: 21160496X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
       Component: E1 - LDS  H06 0008
       Serial number: 15 01 2018  01262886
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE116121723811295
       Coding: 210000
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B00688754
       Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2817000305327004
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
       Component: Airbag10.44   H03 0107
       Serial number: 003UP00D26SL
       Coding: AACCF0C00C800000585400F3D0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006016
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: 4CC19805264A95D7661-8018
       Subsystem 1 - Part No SW: -----------    HW: 442 061 002 18
       Serial number: 3577Y00A52711E41E15Z
       Subsystem 2 - Part No SW: -----------    HW: 442 061 002 18
       Serial number: 3587Y00A32711E41E31W
       Subsystem 3 - Part No SW: -----------    HW: 442 0B2 901 18
       Serial number: 3517700A12943BE1E208
       Subsystem 4 - Part No SW: -----------    HW: 442 0B2 901 18
       Serial number: 3527700A12943BE222B9
       Subsystem 5 - Part No SW: -----------    HW: 442 0C3 001 18
       Serial number: 35575009B29736A5C2AP
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C3 001 18
       Component: FrontSensor_P  1C5 014A
       Serial number: 35675009B29736A540CI
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 401 18
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A7291FA138030
       Subsystem 8 - Part No SW: -----------    HW: 442 432 201 18
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00B726ADCD3603S
       Subsystem 9 - Part No SW: -----------    HW: 442 432 201 18
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M009F26ADCD4E424
    1051904 - Databus
              [NWD: 0x30B Kombi_01Timeout]
                        Reset counter: 45
                        Mileage: 14047 km
                        Date: 2019.09.14
                        Time: 10:49:38
       Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 76B51AED0846BF07E05-8022
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
       Component: FBenRDW       H18 0371
       Coding: 25A440DE288006000120E9601000000000000000
       ASAM Dataset: EV_DashBoardAU736 001027
       VCID: 43D3B3390B145AAF97B-8016
              U1014 00 [008] - -
              [ECU incorrectly coded]
                        Reset counter: 45
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:51:56
    13636609 - Control module
              U110E 00 [008] - implausible coding
              [ECU incorrectly coded (number of fuel level sender BCM2/Kombi implausible)]
                        Reset counter: 45
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:53:54
    16776982 - Databus
              [SWA_01 communication error can_error_timeout]
                        Reset counter: 45
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:53:56
    16776985 - Databus
              [QSP_03 communication error can_error_timeout]
                        Reset counter: 45
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:53:55
    16777007 - Databus
              [Fahrwerk_Anzeige_01 communication error can_error_timeout]
                        Reset counter: 45
                        Mileage: 14048 km
                        Date: 2019.09.14
                        Time: 11:53:55
       Part No SW: 8W5 907 468 F    HW: 8W5 907 468 E
       Component: Gateway       H43 0123
       Revision: 7A000002    Serial number: 0287A777918221
       Coding: 03010001000086402607000000590012C8180007100000000175078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 003111
       ROD: EV_CGateCONTIAU491_003_AU49.rod
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0004
       Serial number: 20180214131246 21599
       Serial number: 0353566804
    8913154 - Databus
              [Signal_Error_Tank_Level_High_Resolution]
                        Reset counter: 45
                        Mileage: 14047 km
                        Date: 2019.09.14
                        Time: 10:49:05
    8531970 - Quiescent Current
              U1406 00 [008] - Too High
              [Electric_current_Upper_Limit_Value_Exceeded]
                        Reset counter: 44
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 23:16:36
                        Total static current-current total quiescent current: 135 mA
                        Total static current-Total time quiescent current exceeded: 1.0 H
                        EM_vehicle_state: 00 00
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0024
       VCID: 77AB17E90F4CC60FFB3-8022
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 18000056471017
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 323DE6FDA4AEE3270CD-8066
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
       Component: TSG FS        005 0129
       Serial number: 0000304943975
       Coding: 001DCA624001000000001482
       VCID: 4FFB8F09D75CAECF033-801A
    196660 - Motor for Window Regulator
              B1487 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 3
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 18:38:41
       Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0410
       Coding: 09000380008000
       ASAM Dataset: EV_EPSZFAU49X 003023
       ROD: EV_EPSZFAU49X_003.rod
       VCID: 42DDB63D140E53A79CD-8016
       Part No SW: 8W0 907 064 EB    HW: 8W0 907 064 DB
       Component: BCM2 MLBevo   025 0387
       Coding: 013500002FB100406301A0000600080231020010804306502F04000000040030001F0001000000
       Shop #: WSC 00200 935 01530
       ASAM Dataset: EV_BCM2HellaAU736 014014
       ROD: EV_BCM2HellaAU736_014_AU49.rod
       VCID: 00597C355A8281B7CA9-8054
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY1735539WN
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000099797282
    65896 - Databus
              [Climatronic control module: Klima_03: no signal/communication]
                        Reset counter: 44
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 21:09:49
                        Supply voltages-Supply voltage: Terminal 30: 12.120 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.187 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
                        general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                        general_additional_freeze_frame-coprocessor_spi_status: 00000000
                        general_additional_freeze_frame-dataflash_status: 00000000
                        general_additional_freeze_frame-interior_temperature: -50.0 °C
                        general_additional_freeze_frame-Operating_Status: 00000000 00000000
                        general_additional_freeze_frame-production_mode: not active
                        general_additional_freeze_frame-reset_cause: 00000000
                        general_additional_freeze_frame-Reset_counter: 0
                        general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                        general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                        general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                        general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 10 04 80
                        general_additional_freeze_frame-Transport_Mode: not active
                        general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                        can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
       Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
       Component: TSG BFS       005 0129
       Serial number: 0000304611841
       Coding: 001DCA224001000000001480
       VCID: 4EC5920DD056A7C7085-801A
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
       Part No SW: 8W0 035 192 H    HW: 8W0 035 192 A
       Component: MU-HS-LND-EU  050 0213
       Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 3B23CBD973E4226FDFB-806E
       Subsystem 1 - Part No SW: 8W0 919 866 AB    HW: -----------
       Component: ECE 2018  --- 0032
       Subsystem 2 - Part No SW: 8W8 919 604     HW: 8W8 919 604
       Component: DU Std AU49x  H32 0170
       Serial number: TPO00107111700720292
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 N    HW: 8W0 919 614 N
       Component: ControlUnit_B  H22 0134
       Serial number: APVAK110021800020257
    11 Faults Found:
    0513 - Rear Right Treble Speaker
              B1068 13 [009] - Open Circuit
              [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                        Reset counter: 4
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:13:20
                        Voltage terminal 30: 12.0 V
              B1066 13 [009] - Open Circuit
              [Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
                        Reset counter: 4
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:13:20
    0532 - Subwoofer
              B106C 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 5: Unterbrechung (DC-Diagnose)]
                        Reset counter: 4
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:13:15
    0005 - Antenna Amplifier 1 for Radio
              B126D 13 [009] - Open Circuit
                        Reset counter: 4
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:13:09
                        Status of antenna 1 for radio-Antenna current: 0 mA
                        Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
    0006 - Antenna Amplifier 2 for Radio
              B126E 13 [009] - Open Circuit
                        Reset counter: 4
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:13:08
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 2 for radio-Reception level antenna 2: 12 dBµV
    3073 - Cellular Antenna
              B1053 13 [009] - Open Circuit
              [GSM/UMTS aerial - open circuit]
                        Reset counter: 4
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:13:08
    3084 - GSM antenna 2
              B1533 13 [009] - Open Circuit
                        Reset counter: 4
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:13:09
    6666 - Optical data bus
              U1049 00 [008] - Open circuit
                        Reset counter: 44
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:14:15
                        Temperature of MOST transceiver-max.value: -50 °C
                        Temperature of MOST transceiver-min.value: -4 °C
                        Temperature of MOST transceiver-Current: 48 °C
    6698 - Optical data bus
              [Optical data bus: open circuit: wakeup]
                        Reset counter: 44
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:14:30
    6667 - Optical Data Bus for Information Electronics 1
              U10CA 00 [009] - Intermittent Disruption
              [Optical data bus: sporadic open circuit in central processor]
                        Reset counter: 5
                        Mileage: 14047 km
                        Date: 2019.09.14
                        Time: 10:49:52
                        Voltage terminal 30: 11.8 V
                        Temperature of MOST transceiver-Current: 33 °C
    6672 - Optical Data Bus for Display in Instruments
              U10CF 00 [008] - Intermittent Disruption
              [Optical data bus: sporadic open circuit in instrument cluster display]
                        Reset counter: 44
                        Mileage: 14047 km
                        Date: 2019.09.13
                        Time: 20:16:32
                        Temperature of MOST transceiver-Current: 49 °C
       Part No SW: 8W8 959 107 B    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0163
       Revision: --------    Serial number: 31792481200000
       Coding: 0610
       ASAM Dataset: EV_DeckLidCONTIAU736 001015
       VCID: 48C9A415323279F7429-801C
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W2 713 041 G    HW: 8W2 713 041 J
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 18013045792093
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 3829D4D542D20977329-806C
    Address A5: Frt Sens. Drv. Assist
       Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
       Component: TSG HFS       005 0129
       Serial number: 0000303432968
       Coding: 000DC8220001000000001080
       VCID: 51FF8971C168B83F157-8004
    Address BC: Door Rear Pass
    Address D6: Light Ctrl Left 2
    Address D7: Light Ctrl Right 2
    End----(Elapsed Time: 01:31, VBatt start/end: 12.4V/12.3V. VIgn 0.3V)------
    Jul 2019
    Sheffield, UK
    The speedometer was out of a audi RS5
    Starting 2 threads on the same topic isn't a great idea as it splits replies - the Benevolent Dictator will be along soon to merge them I reckon...
    Edit - I saw 3 posts and (my bad) assumed 3 threads - sorry!
  4. Likes Boki Ar, Uwe liked this post
    Oct 2014
    Arandjelovac, Serbia
    Because of same post we have 3X, thread lock until further notice.
    Quote Originally Posted by Boki Ar View Post
    I only see two, but this is the right place for a retrofit, so I've closed the other one and re-opened this one.
    Jul 2019
    Sheffield, UK
    Sorry I'm new to this forum and after posting here read the section where it says newbie users post here. That's why I posted in two sections
    Oct 2014
    Arrow
    I temporarily closed the thread based on the email report.
    Thank You Uwe, it's OK now, let's move on.
  9. #8
    Quote Originally Posted by Flashdash View Post
    That would have been fine too. What we object to is opening two different threads with the same question(s).
  10. Likes PetrolDave, andyhud liked this post
