Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: ACC Retrofit Working (module good), but Not Working (no ACC)
Hybrid View
    Jan 2017
    Canada
    Admittedly, I'm a unique case, with a 2015 Mk7 GSW TDI, retrofitted with MIB2 unit from APG last year, then an Active Info Display / Virtual Cockpit earlier this year. Car came with factory "Front Assist", which is the flat bumper radar that only warns of near-imminent impact.
    Car does NOT have the "lane assist" camera in the windshield.
    Everything worked, but ever since getting the MIB2 unit installed, I've had a Component Protection error in 19-CAN GATEWAY. (But again, everything worked).
    Taking inspiration from a few folks here, as well as mqb.pl explanation, i bought a round radar (5Q0 907 567 G). Did most of the coding ahead of time while the 13-AutoDistReg module was locked in component protection, according to the instructions laid out in the Xagico's Spanish-language .pdf.
    After I took it to dealer (1.5 hours to get CP removed), everything seemed to work (ACC icons showed up properly, buttons did what they're ostensibly supposed to do; centre button of ACC controls moved the follow distance; +/- changed the ACC speed).
    The problem: When I'm driving, and turn "on" ACC...nothing happens. Take foot off the pedal and...I just keep slowing down to a stop. SET and RES buttons change the icon view a bit, but don't SET the speed, nor "resume" (given that it never actually gets into a "set" speed).
    Autoscan below; I've spent at least six hours myself so far trying to troubleshoot this; and have gotten a lot of info from darkchina811 (much thanks!) on some steps, but still....nothing.
    Help (?). Any ideas, thoughts, suggestions, welcomed.
    Friday,13,September,2019,13:22:43:51218
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
    VCDS Version 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: 3VWCA7AUXFM500299   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 2B 42 44 52 55 5F
    VIN: 3VWCA7AUXFM500299   Mileage: 72827km-45252miles
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 997 022 N    HW: 04L 907 309
       Component: R4 2.0l TDI   X23 9459
       Revision: 85X23---
       Coding: 011D0012834410081000
       Shop #: WSC 91489 999 12345
       ASAM Dataset: EV_ECM20TDI01104L997022N 004002
       ROD: EV_ECM20TDI01104L997022N.rod
       VCID: 3B36FBF0B2ADB2978C-806F
       Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4512
       Revision: 03253104    Serial number: TFK01410290291
       Shop #: WSC 00066 790 00221
       ROD: EV_TCMDQ250021.rod
       VCID: 230623902A1DEA57A4-8077
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 53184000002387
       Coding: 04FA6AA12420096C0079020981CC2520562490004081A4B214635050C002
       Shop #: WSC 05065 002 104857
       VCID: 47DE9700FE65E67718-8013
       Revision: 00021000    Serial number: 0349846601
       Coding: 030C0C
       Shop #: WSC 01383 790 50316
       VCID: 3A38FEF4BD978B9F97-806F
       Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
       Revision: 00001K01
       Coding: 02020124200100010005000000101400
       VCID: 42C88614D547C35FCF-8017
       Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
       Air quality sensor:
       Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86580412141206
       Coding: 00511B464041A2E949E44000091407001800000000000000000000000000
       Shop #: WSC 00066 790 07031
       ROD: EV_BCMBOSCH_014.rod
       VCID: 4AD8AE34ED771B1F07-801F
       Component: WWS    140824  043 0581
       Serial number:         141224033541
       Component: RLHS  037 0059
       Serial number: S5Y14M12D09H11M16S22
       Coding: 06A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5G0 959 591     HW: 7P0 959 591 C
       Component: J245 PS22.018  H01 0008
       Serial number:     WOO33584535
       Coding: 191800
       Roof Blind:
       Subsystem 4 - Part No SW: 5G0 959 591     HW: 7P0 959 591 C
       Component: J394 PS22.018  H01 0008
       Serial number:     WOO33583141
       Coding: 191800
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 167
                        Mileage: 72826 km
                        Date: 2019.09.13
                        Time: 11:28:29
    329480 - Heated Passenger Seat
              B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
                        Reset counter: 167
                        Mileage: 72826 km
                        Date: 2019.09.12
                        Time: 22:09:46
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
       Component: ACC3          H08 0390
       Serial number: 14021376110493
       Coding: 00001000FE030B
       Shop #: WSC 00028 028 00024
       ASAM Dataset: EV_ACCBoschMQB 001021
       ROD: EV_ACCBoschMQB_VW37.rod
       VCID: 3FCE8FE0A6B5AEB7A0-806B
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM01GHAM
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 51EAB958002128C746-8005
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J14000233FP0W
       Coding: 303136
       Subsystem 2 - Part No SW: -----------    HW: 480 000 511 14
       Serial number: 3570000000049398811F
       Subsystem 3 - Part No SW: -----------    HW: 480 000 511 14
       Serial number: 35800000000831388116
       Subsystem 4 - Part No SW: -----------    HW: 480 402 210 14
       Serial number: 3510002A91811BA1809.
       Subsystem 5 - Part No SW: -----------    HW: 480 402 210 14
       Serial number: 3520002B31811BA4D24
       Subsystem 6 - Part No SW: -----------    HW: 480 401 810 14
       Serial number: 35500029D175A8E2E2DR
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 810 14
       Serial number: 35600029D175A8E4236C
       Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20141031400890
       Coding: 0410
       Shop #: WSC 12345 123 12345
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 0444400C8FD30D6FBD-8051
    227355 - Windshield Wiper/Washer Switch
              B1149 13 [008] - Open Circuit
                        Reset counter: 167
                        Mileage: 72826 km
                        Date: 2019.09.12
                        Time: 22:09:02
                        Ubat 30 Voltage: 11.10 V
                        Ignition State: On
                        Terminal 15: 10.30 V
                        A/D #1: 96.86 %
                        A/D #2: 50.20 %
                        A/D #3: 0.00 %
       Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
       Component: KOMBI         409 3197
       Coding: 03A551082D80880A02807B201C00000000000000
       Shop #: WSC 58161 001 104857
       VCID: 2A18CEB44D373B1FE7-807F
              U1014 00 [009] - -
                        Reset counter: 127
                        Mileage: 72826 km
                        Date: 2019.09.13
                        Time: 11:30:01
    16776996 - Databus
              [FCW_01 keine Kommunikation]
                        Reset counter: 127
                        Mileage: 72826 km
                        Date: 2019.09.13
                        Time: 11:30:01
    16777034 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_DoorLocking_0x0D keine Kommunikation]
                        Reset counter: 167
                        Mileage: 72826 km
                        Date: 2019.09.13
                        Time: 11:30:04
       Revision: --------    Serial number: 12111410001103
       Coding: 0901000800087300FF00020A1C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewConti_011.rod
       VCID: 72A816D4A56733DF9F-8027
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150001901890095392
       Coding: 2DFFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: WECHSELRICHTE  H53 0041
       Serial number: 0000431
              U1101 00 [009] - Active
                        Reset counter: 127
                        Mileage: 72826 km
                        Date: 2019.09.12
                        Time: 22:03:18
                        Supply voltage: Terminal 30: 10.5 V
                        Terminal 15: On
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 5G0 857 511 D    HW: 5G0 857 511
       Component: FLA           H04 0002
       Revision: AA001001
       Coding: 02018864727264565625393E01
       ASAM Dataset: EV_HighBeamAssisAU37X 001009
       ROD: EV_HighBeamAssisAU37X.rod
       VCID: 2B16CBB042CD22171C-807F
       Revision: 00000000    Serial number: 14000317831004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424D0CC9FF37DEF4D-8061
              U1400 00 [008] - -
              [Under voltage (temporary)]
                        Reset counter: 167
                        Mileage: 72826 km
                        Date: 2019.09.13
                        Time: 11:28:26
                        ELV State: 04
                        Information Clamps: 77 64
                        CoCo State: A0 01
                        WFS State: 17 0E
                        Vehicle speed: 0.00 km/h
                        Voltage: 3D
                        AD-Value H-bridge: 1B
                        Clamp15 flip flop: SSTx: button contacts: 06
                        CAN signals: 00
    13637389 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
              [Invalid SMLS_P_verriegelt]
                        Reset counter: 166
                        Mileage: 72823 km
                        Date: 2019.09.12
                        Time: 20:26:03
                        ELV State: 04
                        Information Clamps: 77 60
                        CoCo State: A0 01
                        WFS State: 17 06
                        Voltage: 6B
                        AD-Value H-bridge: 34
                        CAN signals: 00
       Serial number: 2611140605045J
       Coding: 007F1320D000040000000000
       VCID: 40CC8C1CDB4BD14FD9-8015
       Serial number: 00000000000000332757
       Coding: 011000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: 43C68310CA5DCA57C4-8017
       Serial number: 021214060508AH
       Coding: 007F1320DC00040000000000
       Serial number: 00000000000000390612
       Coding: 091000
       Coding: 060A00000B000400
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
    5275926 - Power Output Module for Left Headlamp
              C1081 16 [008] - Voltage Too Low
                        Reset counter: 167
                        Mileage: 72826 km
                        Date: 2019.09.12
                        Time: 22:05:37
    5276182 - Power Output Module for Right Headlamp
              C1082 16 [008] - Voltage Too Low
                        Reset counter: 167
                        Mileage: 72826 km
                        Date: 2019.09.12
                        Time: 22:05:45
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 047 B    HW: 3G0 035 047
       Component: MU-H-LND-EU   043 0703
       Serial number: A578C0GB003368
       Coding: 027302020000000001220002001B00102F0100F571700000DE
       Shop #: WSC 00046 123 12345
       VCID: 1F0E2F600675CEB780-804B
       Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZHT3233336
       Subsystem 2 - Part No SW: V03 959 806 CD    HW: -----------
       Component: NAR 2018/2019  --- 0066
       Component: Gracenote2---  --- 1011
    9 Faults Found:
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 61
                        Mileage: 66866 km
                        Date: 2019.04.01
                        Time: 20:54:43
                        Voltage terminal 30: 12.1 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
              B201A 00 [009] - -
              [Check software version management]
                        Reset counter: 121
                        Mileage: 66866 km
                        Date: 2019.04.01
                        Time: 20:54:48
                        Voltage terminal 30: 12.0 V
                        Status_Software_Version_Management-module_name: MDUV612/Main
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
                        Reset counter: 61
                        Mileage: 66866 km
                        Date: 2019.04.01
                        Time: 20:54:59
                        Software module: status-SW_Status_Consistency: 00 40 00
                        Software module: status-SW_Status_Device:
    13697024 - Component Protection
              U1100 00 [009] - No Basic Setting
              [Anti-theft protection - component protection: no basic setting or basic setting incorrect]
                        Reset counter: 61
                        Mileage: 66866 km
                        Date: 2019.04.01
                        Time: 20:54:43
    15361024 - Component Protection
              [Anti-theft protection - component protection active (0xEA6400)]
                        Reset counter: 61
                        Mileage: 66866 km
                        Date: 2019.04.01
                        Time: 20:54:43
    7173 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 164
                        Mileage: 72807 km
                        Date: 2019.09.10
                        Time: 15:31:41
                        BAP-BAP_Function_ID: 02
    7178 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 61
                        Mileage: 66866 km
                        Date: 2019.04.01
                        Time: 20:54:45
    7219 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 61
                        Mileage: 66866 km
                        Date: 2019.04.01
                        Time: 20:54:45
    7223 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 61
                        Mileage: 66866 km
                        Date: 2019.04.01
                        Time: 20:54:45
    End----------(Elapsed Time: 01:39, VBatt start/end: 12.4V/12.3V)-----------
    May 2017
    Your ABS probably does not support ACC with auto trans. MK100ESP ABS usually doesn’t you would need IPB ABS module.
    Jan 2017
    Canada
    Ahhh - that would explain a lot of things. In Byte 24 of ABS, I'm supposed to change it to F8, but that coding is "out of range request" or something to that effect.
    Do you have a part number?
    What's involved in swapping the ABS module? Disconnecting all the brake lines into it and swapping in new one?
    Would there be component protection on the ABS module?
    Thanks for the quick insight!
    May 2017
    It’s a shitty job unfortunately. I had to do it to our Leon as I did the same retrofit as you.
    Brake lines and ABS holder are the same BUT the electrical connector is different. MK100ESP has 38pin connector and IPB has 46pin. To make things worse the pins in the connector are also different
    The pins you need are these : https://rover.ebay.com/rover/0/0/0?m...2F172358314532
    You’ll get 2 from each repair wire. I ordered 10 repair wires just to make sure I have enough.
    I should have the connector pin differences file somewhere. I’ll check it and I can provide it by email for example.
    Oh and the ABS part number. If you want the best look for 3Q0 907 379 AB. That supports everything.
    This is my ABS block :
    Address 03: ABS Brakes (J104)       Labels: User\5Q0-907-379-IPB-V1.lbl
       Revision: 00000000    Serial number: 60246000001255
       Coding: 20EE6A9224231175007A060441C7240456248800608224F23621F070C0A8
       Shop #: WSC 12345 124 12345
       VCID: 7AC27CA2FD97919A95-802E
    Jan 2017
    Canada
    So, is there a way to determine whether the part number I'm looking at is MK100ESP, or my desired/needed IPB? The 46 pins...are they arranged in three rows? Four rows?
    Shipping from Europe is always slow, but I can get US parts delivered to a US address much more quickly and easily. Like, would a 3Q0 907 379 T work? How about 3Q0 907 379 F?
    (Asking because I can get one of those within five days for under $100, vs. close to double that cost-wise - and probably triple the time of one from Europe.)
    Did these come on specific cars? Like, GTI or R instead of Golf-Golf?
    Also, your pin-out will work great for me because my Canadian car similarly did not come with electronic parking brake; speaking of which, did your car come with Lane Assist camera? Did you add that? Or are you just running with the ACC bumper sensor?
  6. #6
    Apr 2018
    ITALY
    that's something I never thought of. but if true, I would understand how the car cannot brake to adapt the speed of a slower car in front... but why don't it lock speed like regular cruise control?
    as a side note, if the dealer took care of CP, why is it still in the gateway? since the steering wheel buttons are handled by the gateway, I would give that a try (CP in the 5F is "actually ok" since it's a hacked unit).
  7. #7
    May 2017
    It is true. You need PR 8T8 support and MK100ESP only supports 8T3.
    The CP is caused by hacked MIB. It does not have the cars VIN. Instead the hacker used some generic VIN in 5F unit which flags CP. It does not affect anything though.
    Edit : and word of warning. DO NOT try and remove CP from the hacked MIB unit. It’s bye bye for the unit.
  8. #8
    Apr 2018
    ITALY
    I guess I was lucky to have the right ABS module from the start then
  9. #9
    May 2017
    Found the excel file I made for the swap.
    For Golf this is not 100% as it's missing electronic parking brake pins. Our Leon is 2013 and it did not have EPB yet at that time
    I've shared the file through Google drive :
    https://drive.google.com/file/d/1SDG...ew?usp=sharing
    And here's one quite nicely priced AB pump for sale in UK:
    https://www.ebay.co.uk/itm/2016-Skod...EAAOSwHOtcmhXZ
  10. Likes jyoung8607, Uwe liked this post
  11. #10
    Jan 2017
    Canada
    This looks great, downtime! Thank you very much for compiling this.
    Just to be sure I understand the process: Both ABS modules make use of 20 pins; the harness that is in my car only has 38 pins (to match the 38 pins on my stock ABS module), whereas my new ABS module has 46 pins - correct?
    So, what needs to happen is that I need to move the wire on my 38-pin harness and to the position that corresponds to proper position for the 48-pin module.
    So, for example: My car will be sending 12V/7.5A on wire SB17 down pin 2. But I have to move that to position 31 to match up with my new ABS module
    ...unless I'm misunderstanding, and in addition to the actual ABS module itself, i need the whole connector that slides into/onto the ABS (?).
