ACC Retrofit Working (module good), but Not Working (no ACC)
Nuje
Canada
C?ID=120875
Admittedly, I'm a unique case, with a 2015 Mk7 GSW TDI, retrofitted with MIB2 unit from APG last year, then an Active Info Display / Virtual Cockpit earlier this year. Car came with factory "Front Assist", which is the flat bumper radar that only warns of near-imminent impact.
Car does NOT have the "lane assist" camera in the windshield.
Everything worked, but ever since getting the MIB2 unit installed, I've had a Component Protection error in 19-CAN GATEWAY. (But again, everything worked).
Taking inspiration from a few folks here, as well as mqb.pl explanation, i bought a round radar (5Q0 907 567 G). Did most of the coding ahead of time while the 13-AutoDistReg module was locked in component protection, according to the instructions laid out in the Xagico's Spanish-language .pdf.
After I took it to dealer (1.5 hours to get CP removed), everything seemed to work (ACC icons showed up properly, buttons did what they're ostensibly supposed to do; centre button of ACC controls moved the follow distance; +/- changed the ACC speed).
The problem: When I'm driving, and turn "on" ACC...nothing happens. Take foot off the pedal and...I just keep slowing down to a stop. SET and RES buttons change the icon view a bit, but don't SET the speed, nor "resume" (given that it never actually gets into a "set" speed).
Autoscan below; I've spent at least six hours myself so far trying to troubleshoot this; and have gotten a lot of info from darkchina811 (much thanks!) on some steps, but still....nothing. :(
Help (?). Any ideas, thoughts, suggestions, welcomed.
Friday,13,September,2019,13:22:43:51218
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: 3VWCA7AUXFM500299   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 2B 42 44 52 55 5F
VIN: 3VWCA7AUXFM500299   Mileage: 72827km-45252miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9459
   Revision: 85X23---
   Coding: 011D0012834410081000
   Shop #: WSC 91489 999 12345
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B36FBF0B2ADB2978C-806F
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 03253104    Serial number: TFK01410290291
   Shop #: WSC 00066 790 00221
   ROD: EV_TCMDQ250021.rod
   VCID: 230623902A1DEA57A4-8077
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 53184000002387
   Coding: 04FA6AA12420096C0079020981CC2520562490004081A4B214635050C002
   Shop #: WSC 05065 002 104857
   VCID: 47DE9700FE65E67718-8013
   Revision: 00021000    Serial number: 0349846601
   Coding: 030C0C
   Shop #: WSC 01383 790 50316
   VCID: 3A38FEF4BD978B9F97-806F
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 02020124200100010005000000101400
   VCID: 42C88614D547C35FCF-8017
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86580412141206
   Coding: 00511B464041A2E949E44000091407001800000000000000000000000000
   Shop #: WSC 00066 790 07031
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4AD8AE34ED771B1F07-801F
   Component: WWS    140824  043 0581
   Serial number:         141224033541
   Component: RLHS  037 0059
   Serial number: S5Y14M12D09H11M16S22
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591     HW: 7P0 959 591 C
   Component: J245 PS22.018  H01 0008
   Serial number:     WOO33584535
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591     HW: 7P0 959 591 C
   Component: J394 PS22.018  H01 0008
   Serial number:     WOO33583141
   Coding: 191800
131586 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 72826 km
                    Date: 2019.09.13
                    Time: 11:28:29
                    Reset counter: 167
                    Mileage: 72826 km
                    Date: 2019.09.12
                    Time: 22:09:46
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 14021376110493
   Coding: 00001000FE030B
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3FCE8FE0A6B5AEB7A0-806B
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01GHAM
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51EAB958002128C746-8005
   Occupant Detection:
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J14000233FP0W
   Coding: 303136
   Subsystem 2 - Part No SW: -----------    HW: 480 000 511 14
   Serial number: 3570000000049398811F
   Subsystem 3 - Part No SW: -----------    HW: 480 000 511 14
   Serial number: 35800000000831388116
   Subsystem 4 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3510002A91811BA1809.
   Subsystem 5 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3520002B31811BA4D24
   Subsystem 6 - Part No SW: -----------    HW: 480 401 810 14
   Serial number: 35500029D175A8E2E2DR
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 810 14
   Serial number: 35600029D175A8E4236C
   Revision: FF032032    Serial number: 20141031400890
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0444400C8FD30D6FBD-8051
          B1149 13 [008] - Open Circuit
                    Reset counter: 167
                    Mileage: 72826 km
                    Date: 2019.09.12
                    Time: 22:09:02
                    Ubat 30 Voltage: 11.10 V
                    Ignition State: On
                    Terminal 15: 10.30 V
                    A/D #1: 96.86 %
                    A/D #2: 50.20 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         409 3197
   Coding: 03A551082D80880A02807B201C00000000000000
   Shop #: WSC 58161 001 104857
   VCID: 2A18CEB44D373B1FE7-807F
          U1014 00 [009] - -
                    Reset counter: 127
                    Mileage: 72826 km
                    Date: 2019.09.13
                    Time: 11:30:01
16776996 - Databus
          [FCW_01 keine Kommunikation]
                    Reset counter: 127
                    Mileage: 72826 km
                    Date: 2019.09.13
                    Time: 11:30:01
16777034 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_DoorLocking_0x0D keine Kommunikation]
                    Reset counter: 167
                    Mileage: 72826 km
                    Date: 2019.09.13
                    Time: 11:30:04
   Revision: --------    Serial number: 12111410001103
   Coding: 0901000800087300FF00020A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti_011.rod
   VCID: 72A816D4A56733DF9F-8027
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001901890095392
   Coding: 2DFFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0000431
          U1101 00 [009] - Active
                    Reset counter: 127
                    Mileage: 72826 km
                    Date: 2019.09.12
                    Time: 22:03:18
                    Supply voltage: Terminal 30: 10.5 V
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 02018864727264565625393E01
   VCID: 2B16CBB042CD22171C-807F
   Revision: 00000000    Serial number: 14000317831004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424D0CC9FF37DEF4D-8061
          U1400 00 [008] - -
          [Under voltage (temporary)]
                    Reset counter: 167
                    Mileage: 72826 km
                    Date: 2019.09.13
                    Time: 11:28:26
                    ELV State: 04
                    Information Clamps: 77 64
                    CoCo State: A0 01
                    WFS State: 17 0E
                    Vehicle speed: 0.00 km/h
                    Voltage: 3D
                    AD-Value H-bridge: 1B
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
13637389 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
          [Invalid SMLS_P_verriegelt]
                    Reset counter: 166
                    Mileage: 72823 km
                    Date: 2019.09.12
                    Time: 20:26:03
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: A0 01
                    WFS State: 17 06
                    Voltage: 6B
                    AD-Value H-bridge: 34
                    CAN signals: 00
   Serial number: 2611140605045J
   Coding: 007F1320D000040000000000
   VCID: 40CC8C1CDB4BD14FD9-8015
   Serial number: 00000000000000332757
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43C68310CA5DCA57C4-8017
   Serial number: 021214060508AH
   Coding: 007F1320DC00040000000000
   Serial number: 00000000000000390612
   Coding: 091000
   Coding: 060A00000B000400
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
5275926 - Power Output Module for Left Headlamp
          C1081 16 [008] - Voltage Too Low
                    Reset counter: 167
                    Mileage: 72826 km
                    Date: 2019.09.12
                    Time: 22:05:37
5276182 - Power Output Module for Right Headlamp
          C1082 16 [008] - Voltage Too Low
                    Reset counter: 167
                    Mileage: 72826 km
                    Date: 2019.09.12
                    Time: 22:05:45
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 047 B    HW: 3G0 035 047
   Component: MU-H-LND-EU   043 0703
   Serial number: A578C0GB003368
   Coding: 027302020000000001220002001B00102F0100F571700000DE
   Shop #: WSC 00046 123 12345
   VCID: 1F0E2F600675CEB780-804B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT3233336
   Subsystem 2 - Part No SW: V03 959 806 CD    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Component: Gracenote2---  --- 1011
9 Faults Found:
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 61
                    Mileage: 66866 km
                    Date: 2019.04.01
                    Time: 20:54:43
                    Voltage terminal 30: 12.1 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
          B201A 00 [009] - -
                    Reset counter: 121
                    Mileage: 66866 km
                    Date: 2019.04.01
                    Time: 20:54:48
                    Voltage terminal 30: 12.0 V
                    Status_Software_Version_Management-module_name: MDUV612/Main
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
                    Reset counter: 61
                    Mileage: 66866 km
                    Date: 2019.04.01
                    Time: 20:54:59
                    Software module: status-SW_Status_Consistency: 00 40 00
                    Software module: status-SW_Status_Device:
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
          [Anti-theft protection - component protection: no basic setting or basic setting incorrect]
                    Reset counter: 61
                    Mileage: 66866 km
                    Date: 2019.04.01
                    Time: 20:54:43
15361024 - Component Protection
          [Anti-theft protection - component protection active (0xEA6400)]
                    Reset counter: 61
                    Mileage: 66866 km
                    Date: 2019.04.01
                    Time: 20:54:43
          U1111 00 [008] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 164
                    Mileage: 72807 km
                    Date: 2019.09.10
                    Time: 15:31:41
                    BAP-BAP_Function_ID: 02
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 61
                    Mileage: 66866 km
                    Date: 2019.04.01
                    Time: 20:54:45
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 61
                    Mileage: 66866 km
                    Date: 2019.04.01
                    Time: 20:54:45
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 61
                    Mileage: 66866 km
                    Date: 2019.04.01
                    Time: 20:54:45
End----------(Elapsed Time: 01:39, VBatt start/end: 12.4V/12.3V)-----------
downtime
C?ID=280813
Your ABS probably does not support ACC with auto trans. MK100ESP ABS usually doesn’t you would need IPB ABS module.
Nuje
Canada
C?ID=120875
Ahhh - that would explain a lot of things. In Byte 24 of ABS, I'm supposed to change it to F8, but that coding is "out of range request" or something to that effect.
Do you have a part number?
What's involved in swapping the ABS module? Disconnecting all the brake lines into it and swapping in new one?
Would there be component protection on the ABS module?
Thanks for the quick insight!
downtime
C?ID=280813
It’s a shitty job unfortunately. I had to do it to our Leon as I did the same retrofit as you.
Brake lines and ABS holder are the same BUT the electrical connector is different. MK100ESP has 38pin connector and IPB has 46pin. To make things worse the pins in the connector are also different :(
The pins you need are these : https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/172358314532
You’ll get 2 from each repair wire. I ordered 10 repair wires just to make sure I have enough.
I should have the connector pin differences file somewhere. I’ll check it and I can provide it by email for example.
Oh and the ABS part number. If you want the best look for 3Q0 907 379 AB. That supports everything.
This is my ABS block :
Address 03: ABS Brakes (J104)       Labels: User\5Q0-907-379-IPB-V1.lbl
   Revision: 00000000    Serial number: 60246000001255
   Coding: 20EE6A9224231175007A060441C7240456248800608224F23621F070C0A8
   Shop #: WSC 12345 124 12345
   VCID: 7AC27CA2FD97919A95-802E
darkchina811
ITALY
C?ID=333184
that's something I never thought of. but if true, I would understand how the car cannot brake to adapt the speed of a slower car in front... but why don't it lock speed like regular cruise control?
as a side note, if the dealer took care of CP, why is it still in the gateway? since the steering wheel buttons are handled by the gateway, I would give that a try (CP in the 5F is "actually ok" since it's a hacked unit).
downtime
C?ID=280813
It is true. You need PR 8T8 support and MK100ESP only supports 8T3.
The CP is caused by hacked MIB. It does not have the cars VIN. Instead the hacker used some generic VIN in 5F unit which flags CP. It does not affect anything though.
Edit : and word of warning. DO NOT try and remove CP from the hacked MIB unit. It’s bye bye for the unit.
darkchina811
ITALY
C?ID=333184
I guess I was lucky to have the right ABS module from the start then :)
downtime
C?ID=280813
Nuje
Canada
C?ID=120875
Great stuff. Thanks for all the help, downtime and again darkchina811!
darkchina811
ITALY
C?ID=333184
sorry about the ABS thing man. I believe you're on a roll now and you better just keep on going. I am almost sure module 03 has no CP. I am not sure if you can use the actual coding, maybe downtime will clarify.
tomorrow I'll give you the part number for the connector, which you can buy at the dealer.
if you have a crimper, buy the pins on ebay, because repair wires are stupid expensive.
downtime
C?ID=280813
ABS module has no CP. You might be able to use your current coding or not. But that’s not an issue. I’m sure we will have a collective effort and generate the code for you :)
I know repair wires are expensive but the problem was that at that time I did this (2 years ago) I could not find the pins anywhere on ebay. Dealer priced them as expensive as the repair wires so all the same for me. Luckily the connector wasn’t very expensive. Less than 20€.
And I can add the EPB pins to the document as I have Elsa on my desktop machine.
darkchina811
ITALY
C?ID=333184
ebay object 223487907520
Nuje
Canada
C?ID=120875
Absolutely! Chasing sunk costs has never deterred me before, so why start now? :D
Nuje
Canada
C?ID=120875
So, is there a way to determine whether the part number I'm looking at is MK100ESP, or my desired/needed IPB? The 46 pins...are they arranged in three rows? Four rows?
Shipping from Europe is always slow, but I can get US parts delivered to a US address much more quickly and easily. Like, would a 3Q0 907 379 T work? How about 3Q0 907 379 F?
(Asking because I can get one of those within five days for under $100, vs. close to double that cost-wise - and probably triple the time of one from Europe.)
Did these come on specific cars? Like, GTI or R instead of Golf-Golf?
Also, your pin-out will work great for me because my Canadian car similarly did not come with electronic parking brake; speaking of which, did your car come with Lane Assist camera? Did you add that? Or are you just running with the ACC bumper sensor?
darkchina811
ITALY
C?ID=333184
you can probably use my ABS also, it's a 46 pins, I did all sorts of retrofits and everything works great... but I do have the Electronic Parking Brake, and I don't know if that can be coded out.
Nuje
Canada
C?ID=120875
Problem solved. Found a US eBay seller who took my offer on an 3Q0 907 379 AB. :D
So - as for what I'm in for once I get this: Correct me where I'm wrong here.
1. Figure out the wiring (I think I have a bunch of repair wires right now / and or some wire-ends that I've pulled out of other harnesses)
Question: Given that I currently have only 38(?) wires in my ABS harness, where do the extra 8 wires plug in? I get that one end goes into the connector that attaches to the ABS module itself; what does the other end plug into?
2. Pull out the airbox and whatnot to gain access to the ABS module
3. Disconnect brake lines from old one, connect to new one. (make a huge mess of brake fluid, no doubt)
4. Do the VCDS ABS bleed exercise 3-10 times (?)
5. Figure out the ABS coding (from what I can discern, it's just going to be a matter of flipping Byte 24 from 10 (what it is/was stock) to F8 (for my DSG), and Byte26 to 50).
6. Take it for a drive an enjoy ACC nirvana.
(Please fill in what any/all things I'm missing.)
downtime
C?ID=280813
If I remember correctly there is only one GND wire that is extra on 46pin connector. You can see the differences in the document I shared. I don't understand why they did the connector change to IPB pumps because they don't populate the pins not even close to full.
What comes to your installation. Pretty much like you described. Before you start to detach brake lines, jam something to brake pedal to keep it pressed. This prevents any excess brake fluid from coming out of the brake lines. Trust me, this is the way how official instructions also tell you to do it.
And coding. First try to fit your current coding to the new pump. DO NOT make ANY changes to it as it is now. When you have successfully inputted the code and made all the basic settings, then start to add ACC bits to the code.
Hey by the way, one other thing. Did you check that you have suitable rear ABS sensors for ACC? If not, you need to change them as well because the "default" ones won't work for ACC. If you have PLA park assist on your car, you have suitable sensors.
Correct sensors with ACC are WHT003864A. Default ones that are NOT suitable are WHT003864.
Those are luckily quite cheap and easy to change. You just need to code them to the ABS block after change.
And I did have lane assist camera on our Leon from factory. Basically it only affects how you connect the ACC radar as you need to connect it to the camera. Camera and ACC sensor form a so called sensor fusion network. There's a separate connection between the ACC and camera for this.
darkchina811
ITALY
C?ID=333184
I told him long ago about ABS sensors :) but he never confirmed he looked at them...
Nuje
Canada
C?ID=120875
Yes - I have the new sensors and they are installed. Interesting that in the ABS coding, my OEM coding won't work with the new sensors (all sorts of errors - from tire pressure, adaptive lighting, etc.). Changed byte 26 to 50, though, and all those errors immediately go away.
Edit: I initially typo'd that I'd changed byte 29; the proper byte to change (for me) was byte 26.
downtime
C?ID=280813
Yep. That’s how it goes. For me even the 50 did not work, I had to change the coding to F0. 50 worked under 80km/h speeds but as soon as I passed that speed it immediately flagged an error.
