i was attempting to get the coding for NA to work as ROW but after changing the coding on my rear lights my outer bulbs turn all the way off and on when I signal (when the lights are on) rather than dim and get brighter like they normally do.
I tried putting everything back to the stock values i found but it didn’t have any affect on the outer blinkers so I’m at a loss
3 questions:
1) does anyone know what channels I need to change to adjust this back to normal
2) can you point me to the reference table that you use that explains how to decipher the meaning of the decimal/hex values?
3) the coding I used disabled rear fog lights. Not a big deal but if anyone know how to fix that would be great as well.
Here are my channels and current values (if I recall correctly)
195: 10760 (stock 10753+7)
196: 10792 (stock 10785+7)
203: 8782 (stock 8778+4)
204: 8814 (stock 8810+4)
If needed I can pull up the values for the rest of the channels tomorrow.
Thanks a lot
edit: Found all the changes i made in the debug log:
3 questions:
Thanks a lot
Address 46,8K0 907 064 F,channel 197,adapted from,11272,to,11268,Friday,13,September,2019,19:32:25:63170
Address 46,8K0 907 064 F,channel 198,adapted from,11304,to,11300,Friday,13,September,2019,19:32:53:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8778,to,7754,Friday,13,September,2019,19:33:41:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8810,to,7786,Friday,13,September,2019,19:34:04:63170
Address 46,8K0 907 064 F,channel 195,adapted from,10753,to,5251,Friday,13,September,2019,19:37:06:63170
Address 46,8K0 907 064 F,channel 196,adapted from,10785,to,5283,Friday,13,September,2019,19:37:48:63170
Address 46,8K0 907 064 F,channel 197,adapted from,11268,to,3588,Friday,13,September,2019,19:38:18:63170
Address 46,8K0 907 064 F,channel 198,adapted from,11300,to,3620,Friday,13,September,2019,19:38:38:63170
Address 46,8K0 907 064 F,channel 195,adapted from,5251,to,10753,Friday,13,September,2019,19:40:42:63170
Address 46,8K0 907 064 F,channel 197,adapted from,3588,to,11272,Friday,13,September,2019,19:41:15:63170
Address 46,8K0 907 064 F,channel 198,adapted from,3620,to,11304,Friday,13,September,2019,19:41:51:63170
Address 46,8K0 907 064 F,channel 203,adapted from,7754,to,8778,Friday,13,September,2019,19:42:26:63170
Address 46,8K0 907 064 F,channel 196,adapted from,5283,to,10785,Friday,13,September,2019,19:46:13:63170
Address 46,8K0 907 064 F,channel 204,adapted from,7786,to,8810,Friday,13,September,2019,19:53:48:63170
Address 46,8K0 907 064 F,channel 193,adapted from,6,to,0,Friday,13,September,2019,19:55:51:63170
Address 46,8K0 907 064 F,channel 194,adapted from,7,to,0,Friday,13,September,2019,19:56:02:63170
Address 46,8K0 907 064 F,channel 193,adapted from,0,to,6,Friday,13,September,2019,19:59:42:63170
Address 46,8K0 907 064 F,channel 194,adapted from,0,to,7,Friday,13,September,2019,19:59:57:63170
Address 46,8K0 907 064 F,channel 195,adapted from,10753,to,10759,Friday,13,September,2019,21:08:49:63170
Address 46,8K0 907 064 F,channel 196,adapted from,10785,to,10791,Friday,13,September,2019,21:09:10:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8778,to,8775,Friday,13,September,2019,21:09:29:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8810,to,8807,Friday,13,September,2019,21:09:46:63170
Address 46,8K0 907 064 F,channel 195,adapted from,10759,to,10760,Friday,13,September,2019,21:11:45:63170
Address 46,8K0 907 064 F,channel 196,adapted from,10791,to,10792,Friday,13,September,2019,21:11:55:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8775,to,8773,Friday,13,September,2019,21:13:19:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8807,to,8805,Friday,13,September,2019,21:13:33:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8805,to,8807,Friday,13,September,2019,21:14:38:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8773,to,8775,Friday,13,September,2019,21:14:50:63170
Address 46,8K0 907 064 F,channel 197,adapted from,11272,to,11273,Friday,13,September,2019,21:17:51:63170
Address 46,8K0 907 064 F,channel 197,adapted from,11273,to,11272,Friday,13,September,2019,21:18:33:63170
Address 46,8K0 907 064 F,channel 197,adapted from,11272,to,11271,Friday,13,September,2019,21:19:01:63170
Address 46,8K0 907 064 F,channel 197,adapted from,11271,to,11272,Friday,13,September,2019,21:20:09:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8775,to,8781,Friday,13,September,2019,21:30:31:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8807,to,8814,Friday,13,September,2019,21:32:21:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8781,to,8785,Friday,13,September,2019,21:34:14:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8814,to,8817,Friday,13,September,2019,21:34:32:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8817,to,8814,Friday,13,September,2019,21:38:23:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8785,to,8782,Friday,13,September,2019,21:38:35:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8814,to,8807,Friday,13,September,2019,21:40:15:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8807,to,8808,Friday,13,September,2019,21:41:42:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8782,to,8783,Friday,13,September,2019,21:41:47:63170
Address 46,8K0 907 064 F,channel 203,adapted from,8783,to,8782,Friday,13,September,2019,21:43:46:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8808,to,8807,Friday,13,September,2019,21:43:54:63170
Address 46,8K0 907 064 F,channel 204,adapted from,8807,to,8814,Friday,13,September,2019,21:48:12:63170
