Results 1 to 8 of 8
Thread: Audi Allroad 2005 2.7 Level Control
    Sep 2019
    Car is stuck in the lowest position in the front. I log into vcds 34 and it won't allow me to make any adaptations. I get the green wait and then error.
    Friday,13,September,2019,17:03:18:60736
    VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4513.4
    VIN: WA1YD64B85N012746   License Plate:
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
              75 76 77
    Address 01: Engine        Labels: 078-907-551-AZA.lbl
       Part No: 4Z7 907 551 T
       Component: 2.7L V6/5VT     G   0010
       Coding: 07755
       Shop #: WSC 02334
       VCID: 54F17CED87E59BA73E1-5160
       WA1YD64B85N012746     AUZ7Z0D2644103
    8 Faults Found:
    17865 - Exhaust Gas Temp Sensor 2 (G236)
                P1457 - 35-00 - Open or Short to Plus
    17861 - Exhaust Gas Temp Sensor 1 (G235)
                P1453 - 35-10 - Open or Short to Plus - Intermittent
                P1602 - 35-10 - Voltage too Low - Intermittent
    17831 - Secondary Air Injection System; Bank 1
                P1423 - 35-00 - Insufficient Flow
    17819 - Secondary Air Injection System; Bank 2
                P1411 - 35-00 - Insufficient Flow
    17884 - EVAP Leak Detection Pump
                P1476 - 35-00 - Malfunction / Insufficient Vacuum
    17544 - Fuel Trim: Bank 1 (Add)
                P1136 - 35-00 - System too Lean
    16555 - Fuel Trim; Bank 1
                P0171 - 35-00 - System Too Lean
    Readiness: 0000 1100
       Part No: 4Z7 927 156 T
       Component: AG5 01V 2.7l5VT USA 0404
       Coding: 0001002
       Shop #: WSC 02334 785 00200
       VCID: 57EB8BE19313B0BFDB3-5160
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389 A
       Component: ABS/ESP allrad      D66
       Coding: 06497
       Shop #: WSC 02334
       VCID: 4ACD629555A1DD5754D-5160
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AR
       Component: A6-Klimavollautomat 0208
       Coding: 00010
       Shop #: WSC 02335
       VCID: 6A8DC21535513D5774D-2586
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 N
       Component: Airbag 8.4EP        1000
       Coding: 0000607
       VCID: 5AED92D5E001ADD7E4D-5184
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01002
       Shop #: WSC 02334
       VCID: 2F3B1301CE33987F633-5184
       Part No: 4B0 920 983 F
       Component: KOMBI+WEGFAHRS. VDO D16
       Coding: 20264
       Shop #: WSC 00050
       VCID: 2B030711FA1BE45F4FB-5160
    Address 34: Level Control        Labels: 4Z7-907-553.lbl
       Part No: 4Z7 907 553 F
       Component:  - 2C1A1          D060
       Coding: 25500
       Shop #: WSC 02334
       VCID: 48C9589D4BAD2F47429-513C
    01437 - Control Position not Learned
                35-00 - -
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15885
       Shop #: WSC 02335
       VCID: 33331F71221BBC9F07B-4F0C
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0204
       Coding: 00001
       VCID: 2C01040DFF25E367461-4B3C
       Part No: 4Z7 907 357
       Coding: 00030
       Shop #: WSC 02334
       VCID: 04518CAD3735CB27EE1-4B3C
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 4B0 035 195 N
       Component: symphony II PM6    0410
       Coding: 00205
       Shop #: WSC 70656
       VCID: 2B030711FA2BE45F4FB-5066
    End----------(Elapsed Time: 04:49, VBatt start/end: 13.7V/13.6V)-----------
    Does the compressor run at all?
    Blown fuses?
    Verified VCDS User Gremling's Avatar
    Dec 2017
    Norway, Nordland
    Hi, you most likely have this file, but I recommend Audi SSP 243, this is Audi training program regarding air suspension for the Allroad link: http://www.volkspage.net/technik/ssp/ssp/SSP_243.pdf
    As Uwe asked, blown fuse S110, a 40amp fuse, or relay J403, controlling compressor, see link below for easy access to compressor, for direct faultfinding.
    This video, from Arnott, shows how to remove/install compressor, and might help you in faultfinding, link: https://www.youtube.com/watch?v=zKxFRRV-T7U.
    Has the original EGT senders been replaced, or wiring checked?
    Regards
    Gremling
  5. Likes Uwe, Jack@European_Parts liked this post
    Sep 2019
    Some times
    Sep 2019
    I will check fuse and relay. Not real sure on the EGT senders and or wiring.
    Thanks for the info.
    Verified Coal Cracker
    Mar 2014
    Wilkes-Barre, PA
    EGT sensors are pricey and common only come in pairs and are needed.
    Also check for Vac. leak SAI Kombi or noid controlling them.
    Good Luck
  9. #8
    Sep 2019
    Just a follow up to my issue. Threw some BC Coilovers on it.....problem solved.
    Thanks for all the input. This was my least expensive route to take on this 05 Allroad.
