Car is stuck in the lowest position in the front. I log into vcds 34 and it won't allow me to make any adaptations. I get the green wait and then error.
Friday,13,September,2019,17:03:18:60736
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WA1YD64B85N012746 License Plate:
75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 T
Component: 2.7L V6/5VT G 0010
Coding: 07755
Shop #: WSC 02334
VCID: 54F17CED87E59BA73E1-5160
WA1YD64B85N012746 AUZ7Z0D2644103
8 Faults Found:
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 35-00 - Open or Short to Plus
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 35-10 - Open or Short to Plus - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 35-00 - Insufficient Flow
17819 - Secondary Air Injection System; Bank 2
P1411 - 35-00 - Insufficient Flow
17884 - EVAP Leak Detection Pump
P1476 - 35-00 - Malfunction / Insufficient Vacuum
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-00 - System too Lean
16555 - Fuel Trim; Bank 1
P0171 - 35-00 - System Too Lean
Readiness: 0000 1100
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 T
Component: AG5 01V 2.7l5VT USA 0404
Coding: 0001002
Shop #: WSC 02334 785 00200
VCID: 57EB8BE19313B0BFDB3-5160
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D66
Coding: 06497
Shop #: WSC 02334
VCID: 4ACD629555A1DD5754D-5160
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00010
Shop #: WSC 02335
VCID: 6A8DC21535513D5774D-2586
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 N
Component: Airbag 8.4EP 1000
Coding: 0000607
VCID: 5AED92D5E001ADD7E4D-5184
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02334
VCID: 2F3B1301CE33987F633-5184
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 F
Component: KOMBI+WEGFAHRS. VDO D16
Coding: 20264
Shop #: WSC 00050
VCID: 2B030711FA1BE45F4FB-5160
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 02334
VCID: 48C9589D4BAD2F47429-513C
01437 - Control Position not Learned
35-00 - -
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 02335
VCID: 33331F71221BBC9F07B-4F0C
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
VCID: 2C01040DFF25E367461-4B3C
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02334
VCID: 04518CAD3735CB27EE1-4B3C
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 N
Component: symphony II PM6 0410
Coding: 00205
Shop #: WSC 70656
VCID: 2B030711FA2BE45F4FB-5066
End----------(Elapsed Time: 04:49, VBatt start/end: 13.7V/13.6V)-----------
