Results 1 to 6 of 6
Thread: Seat Ibiza (Strange Door Control Problem)
    Oct 2016
    60 reg. problem is electric windows not working. if I unplug door looms on drivers door for a few seconds,window on drivers door starts working, if I turn off igniton for a few seconds window will not work again. it is same on passenger side, unplug pass door loom and starts working,until ignition off for a few seconds. there is 2 faults which keep coming back. no communication with drivers door module and passenger door module. I posted full scan of car if someone can help. please check all coding is correct, thanks
    Friday,13,September,2019,14:47:51:42542
    VCDS Version: 19.6.1.0
    VIN: VSSZZZ6JZBR011181   License Plate: SK60LZR
    Mileage: 126270km-78460mi   Repair Order: NICKMOT
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
    VIN: VSSZZZ6JZBR011181   Mileage: 126270km-78460miles
    Address 01: Engine        Labels: 03C-906-024-BXW.lbl
       Part No SW: 03C 906 024 CD    HW: 03C 906 024 CD
       Component:       CGGB  MM4HV G 7950
       Revision: --H09---    Serial number:
       Coding: 0000071
       Shop #: WSC 06402 785 00200
       VCID: 62CB7B2DBEE99F5FEF-5140
    Readiness: 0110 0001
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 AB    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Coding: 100200DB006E00B3082600EA00D200000000
       Shop #: WSC 04941 000 00000
       VCID: 7EF32F5DED515BBFEB-802A
    Address 08: Auto HVAC        Labels: 6J0-820-045.clb
       Part No SW: 6J0 820 045     HW: 6J0 820 045
       Component: J301  Klimaanlage   0280
       Revision: 00 23 08    Serial number: 0000000767765-
       VCID: 63C57E29A2F39657E4-8036
       Part No SW: 6R0 937 087 F    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0221
       Revision: BF046001    Serial number: 0345 152101391
       Coding: 248829E888612500922000007E0B1CC800C1400F608C0000200000000000
       Shop #: WSC 09550 758 180955
       VCID: 408F91A5D325ED4FD9-8014
       Subsystem 1 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
       Subsystem 2 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
       Subsystem 3 - Part No: 1K8 951 171 A
                        Reset counter: 102
                        Mileage: 126275 km
                        Date: 2014.02.03
                        Time: 03:51:59
                        Reset counter: 102
                        Mileage: 126275 km
                        Date: 2014.02.03
                        Time: 03:51:59
       Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
       Component: VW10AirbagA05 H09 0018
       Revision: --------    Serial number: 003DW00FZUJI
       Coding: 003035
       Shop #: WSC 06401 785 00200
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 428B9BADD529FF5FCF-8016
       Serial number: 3496GRB401LAGVMR0SBW
       Serial number: 3506GRB402TF2NSL7SAM
       Part No SW: 6J0 920 902     HW: 6J0 920 902
       Component: KOMBI         H05 0404
       Coding: 410A00
       VCID: 66C3673D99C1E37F03-8032
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 0221
       Coding: 422100
       VCID: 70EF0165A3053DCF69-8024
       Component: IMMO          H05 0404
       VCID: 6ADB130D8DD9C71F27-803E
       Part No SW: 6J0 035 342 C    HW: 6J0 035 342 C
       Revision: A1001003    Serial number: 7668098071
       Coding: 020000
       Shop #: WSC 64564 324 38760
       VCID: 24473D35277DD16FDD-8070
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10121
       Shop #: WSC 06402
       VCID: 2F6DC219EABB623730-807A
    Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
       Part No: 6J0 959 441 A
       Component: MF-Modul       0007 0001
       Shop #: WSC 77005 000 00000
       VCID: 3169C461A88F74C726-8064
    Address 56: Radio (J503)       Labels: None
       Part No SW: 6J2 035 153 C    HW: 6J2 035 153 C
       Component: Radio         H05 0107
       Revision: R0000000    Serial number: SEZAZ2K9503688
       Coding: 0001040002
       VCID: 2643273D5141237FC3-8072
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668103927
       Coding: 0200000001010110
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 326BCB6D65894FDF5F-8066
    End-------------------------(Elapsed Time: 02:59)--------------------------
    Address 17: DTCs cleared
    Address 01: DTCs cleared
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 15: DTCs cleared
    Address 19: DTCs cleared
    Address 25: DTCs cleared
    Address 2E: DTCs cleared
    Address 44: DTCs cleared
    Address 4B: DTCs cleared
    Address 56: DTCs cleared
    Address 77: DTCs cleared
    Address 09,6R0 937 087 F,recoded (Long Coding),from,248829E888612500922000007E0B1CC800C1400F608C0000200000000000,to,24882DE888612500922000007E0B1CC800C1400F608C0000200000000000,(09550/758/180955),
    Address 09,6R0 937 087 F,recoded (Long Coding),from,24882DE888612500922000007E0B1CC800C1400F608C0000200000000000,to,248829E888612500922000007E0B1CC800C1400F608C0000200000000000,(09550/758/180955),
    Oct 2016
    Can anyone help please
    Have you checked the fuse(s) that supply the door modules and the wiring between the Cent Elect module and the door modules.
    If you don't have a wiring diagram you can logon to erWin and get one relevant to your car.
  4. Likes Uwe liked this post
    Oct 2016
    Checked all fuses and wiring from doors. I have one 12 v at each module is this correct.
    Oct 2016
    Just a update, I try a bcm module and door modules, but fault still there. Can anyone help
    Oct 2016
    just to let users no. problem was the car was accident damage and dash had been replaced,the wiring on the diagrams did not match with car. I found were lin wire came out bcm and cut it and tagged new lin bus wires to both doors. it now works perfectly. thanks for all help
  8. Likes Uwe liked this post
