Results 1 to 10 of 12
Thread: Golf 2018 Hybrid 26623 - Crash Shut-Down Activated P1609 00 [167]
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Hi All,
    Got this vehicle in as non start after been involved in an accident and its been now repaired but, the new owner doesn't know what was damaged as its been bought from the auction so can't explain more about the damage......
    Scanned vehicle and had Crash Shut-Down Activated faults in few modules managed to clear them by using the basic settings but, the one in Address 8C: Hybrid Battery (J840) can't be cleared as there is no security access code in drop bar for basic settings I have tried 20103 which does accept but, when I select basic settings option it says (Not Running).
    Can please any one help with the right security code or, any way to clear this fault code, please see the attached full scan below.....
    Friday,13,September,2019,13:50:55:29912
    VCDS Version: 19.6.1.0
    VIN: WVWZZZAUZJW803777   License Plate: GOLG H/B SANKAR
    Mileage: 31112km-19332mi   Repair Order:
    Chassis Type  AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 23 42 44 4B 51 52 5F 75 8C
              A9 C6
    VIN: WVWZZZAUZJW803777   Mileage: 31112km-19332miles
    23-Brake Booster -- Status: Malfunction 0010
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    51-Electric Drive -- Status: Malfunction 0010
    8C-Hybrid Battery -- Status: Malfunction 0010
    C6-Batt. Chrg. -- Status: Malfunction 0010
    Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 BN    HW: 04E 907 309 F
       Component: 1.4l TFSI hy  H22 4518
       Revision: X3H22---
       Coding: 011D0012636405082008
       ASAM Dataset: EV_ECM14TFS01104E906023BN 008006
       ROD: EV_ECM14TFS01104E906023BN.rod
       VCID: 6DD78C75BCE5262742-8038
    17158 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 23:29:23
                        Coolant temperature: 17 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 9.520 V
                        Acceleration: 0.000 m/s²
                        Cruise Control System (CCS): status-Bits 0-7: 1
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
    8221 - System Voltage
              P0562 00 [038] - Too Low
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:49:52
                        Coolant temperature: 16 °C
                        Voltage terminal 30: 9.000 V
              U0428 00 [039] - -
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:46:08
                        Voltage terminal 30: 9.980 V
                        Outside air temperature: 19 °C
                        Absolute intake pressure: 102 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 22.00 l
                        E-machine torque actual value: 0.0 Nm
                        Operating mode control expanded electrical driving: False result
                        Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
                        High-volt. battery: charge state: abs. value: 26.19 %
    Readiness: 1110 0001
       Part No SW: 0DD 300 046     HW: 0DD 927 770 C
       Component: GSG DQ400E    H32 1601
       Revision: 00032056    Serial number: TFK01708250161
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021_VW37.rod
       VCID: 65C7F45564151E670A-8030
    10821 - System Voltage
              P0562 00 [046] - Too Low
                        Fault Frequency: 7
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:50:25
                        Engine speed: 6.25 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 58 km/h
                        Control Module temperature: 52 °C
                        CURRENT pressure: -9.5 bar
                        Clutch: primary stat: Driving
                        selected gear: GANG_6
                        Driving position: N
                        Accelerator position: 0.0 %
                        DTC memory status: 40192
    10779 - System Voltage
                        Fault Frequency: 9
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:49:54
                        Control Module temperature: 65 °C
                        Driving position: N
                        Accelerator position: 0.4 %
                        DTC memory status: 13824
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
       Component: ESC           H62 0855
       Revision: 00000000    Serial number: 62497000000284
       Coding: 01FA80A13820216F477E060741CA2980011C84E26082947338B15078C20203
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
       ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
       VCID: 7CF1B131F79FBFAFC5-8028
    0128 - Function Restricted due to Insufficient Voltage
              U1400 00 [046] - -
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:07
    0295 - Steering angle sensor
              B1168 54 [167] - Missing Calibration / Basic Setting
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:46:08
    8277 - Databus
              U1122 00 [047] - Implausible Message
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:46:08
    16412 - Display for Tire Pressure Monitoring
              C1146 02 [175] - Signal Failure
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:46:19
    16413 - Display for Tire Pressure Monitoring
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:46:19
       Part No SW: 5GE 907 044 AM    HW: 5GE 907 044 AM
       Component: Climatronic   H04 1702
       Revision: 00001K01
       Coding: 0012100420011001040500000010102A
       VCID: 071BDEDDBE59EC77D8-8052
       Subsystem 3 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
       Component: J848 HV-PTC  200 0204
       Serial number: -00103.7U.3A20340267
    H02
              B10CD 00 [009] - -
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:45:32
                        Voltage terminal 30: 10.0 V
                        CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
    1048839 - Function limitation due to crash signal
              B1397 00 [009] - -
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:45:32
       Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H36 0253
       Serial number: 01001726301716
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0819DDE1B347E30FD1-805C
       Component: WWS    170819  042 0551
       Serial number:         170904064606
       Component: RLHS  047 0105
       Serial number: S4Y17M09D18H17M28S37
       Coding: 00A8DD
       Serial number: 000000000ZY172280YYE
       Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
       Serial number: 00002856223972143389
    131330 - Supply voltage
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:52:24
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:29
       Serial number: 000308418617257
       Coding: 1471051811
       VCID: 4B9322EDE2B1C8173C-801E
              U1400 00 [008] - -
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:50:44
    13637426 - Databus
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:44:22
       Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
       Component: ACC BOSCH MQB H10 0620
       Coding: 5500678159FFC728949C810580400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002005
       VCID: 3C717131B71F7FAF85-8068
    2055 - Databus
              U1122 00 [009] - Implausible Message
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:45:49
                        Control Module temperature: 33 °C
                        Voltage terminal 15: 9.9 V
                        Status_ACC_System: ACC_irreversible error
    2101 - Databus
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:45:49
    0928 - Databus
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:45:49
    2068 - Databus
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:45:49
    1389 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:49:52
                        Control Module temperature: 35 °C
                        Voltage terminal 15: 8.9 V
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    010 0870
       Serial number: 003MFR03FV1V
       Coding: 98CCC000002000005C0000CF00C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 50A935810B97EBCF49-8004
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E15091750937
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E17091791453
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 609 17
       Serial number: 35700000000D1A51D72O
       Subsystem 4 - Part No SW: -----------    HW: 480 001 804 18
       Serial number: 35800000000F6B7C5E22
       Subsystem 5 - Part No SW: -----------    HW: 480 401 409 17
       Serial number: 35100019B269FFC5C1DY
       Subsystem 6 - Part No SW: -----------    HW: 480 401 109 17
       Serial number: 3520001A9269FFC2E2CX
       Subsystem 7 - Part No SW: -----------    HW: 480 402 009 17
       Serial number: 3550001A924A4334B27/
    9634838 - Control Module for Front Left Belt Tensioner
              B1304 16 [008] - Voltage Too Low
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:50:21
    9635094 - Control Module for Front Right Belt Tensioner
              B1305 16 [008] - Voltage Too Low
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:50:08
    1050117 - Databus
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:44:59
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 10091708491419
       Coding: 0410
       VCID: 020DCFC9957BC95F8F-8056
       Part No SW: 5G1 920 794 A    HW: 5G1 920 794 A
       Component: KOMBI         407 3194
       Coding: 27AC7B082FC0060001886B111601030000000000
       VCID: 2D574C757C65E62702-8078
    13635840 - Supply voltage
                        Reset counter: 40
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:52
       Part No SW: 3Q0 907 530 H    HW: 3Q0 907 530 D
       Component: GW MQB EV     618 6305
       Serial number: 22081710803300
       Coding: 020100176EF11000FB00527C5C1D00000001070100010000000300000000
       ROD: EV_GatewNF.rod
       VCID: 346159119F4FB7EF4D-8060
       Subsystem 1 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
       Serial number: 29170001921730027355
       Coding: 2DFFFF
       Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
       Serial number: 9317815004
    1282 - Supply voltage
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:52:40
                        Supply voltage: Terminal 30: 8.4 V
                        Terminal 15: OFF
    8526361 - LV Energy Management
              B1802 F1 [009] - Warning Triggered
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:44:18
                        Supply voltage: Terminal 30: 10.0 V
                        Terminal 15: On
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
       Component: EBKV          H14 0211
       Serial number:   085460011686
       Coding: 02720100331900000002060500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
       ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
       VCID: 52AD3F89059B99DF7F-8006
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0155
       Serial number: 05802861010917213849
    6 Faults Found:
    173568 - Voltage Supply 2
              C1205 00 [046] - Voltage too Low
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:48:34
    173312 - Voltage Supply 2
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:10
    180736 - Implausible Data Received from Engine Control Module
              U0401 00 [175] - -
                        Mileage: 31112 km
                        Date: 2019.07.11
                        Time: 00:06:42
    202752 - Supply Voltage for Brake Pressure Accumulator
              C120A 00 [038] - Implausible Signal
                        Mileage: 31112 km
                        Date: 2019.08.19
                        Time: 00:10:44
    11008 - Supply Voltage for Brake Pressure Accumulator
              C120A 00 [046] - Implausible Signal
                        Mileage: 31112 km
                        Date: 2019.08.19
                        Time: 00:10:44
    250112 - Implausible Data Received from Engine Control Module
              U0401 00 [047] - -
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:46:08
       Serial number: 170717EGH04731
       Coding: 003F0620D001048000001000
       VCID: 43830ACDCAE10057C4-8016
       Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000016413001
       Coding: 0D0000
    65548 - Supply voltage
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:53:54
    65649 - Lamp for Ambient Illumination
              B1325 13 [008] - Open Circuit
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 23:29:23
    589829 - Window Regulator; Rear Driver side
              B131F F5 [008] - Supply Voltage too Low
                        Fault Frequency: 10
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:10
       Component: EPS_MQB_ZFLS  129 1072
       Coding: 0002
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 458714D5C4D53E67EA-8010
    15873 - Steering angle sensor
                        Reset counter: 75
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:44:32
                        Motor status: 00
                        Supply voltage: 10.00 V
                        Temperature: 26.0 °C
                        KFC: 3E
                        KFA: 00 01
                        Environmental conditions: 5F
                        uAdSensI_U1V2Filtered_gdu16: 1.19 V
                        uioUdNotFilt_xdu16: 9.92 V
                        uAdSensI_SwitchedKl30_xdu16: 9.92 V
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    11776 - Supply voltage
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:23
                        Motor status: 00
                        Supply voltage: 8.50 V
                        Temperature: 27.0 °C
                        KFC: 2E
                        KFA: 00 00
                        Environmental conditions: 25
                        uioUdNotFilt_xdu16: 8.75 V
                        uAdSensI_SwitchedKl30_xdu16: 8.75 V
    Address 4B: Multifunc. Module
    Interface not compatible.
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
       Component: LE Gen 3.3H11 1032
       Revision: 00H11000
       Coding: C0020000000000000000
       ASAM Dataset: EV_DMCM08530115G0907080E 001008
       ROD: EV_DMCM08530115G0907080E.rod
       VCID: 295FB865488DFA07EE-807C
    31789 - System Voltage
                        Fault Frequency: 11
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:49:53
                        Voltage terminal 30: 8.794 V
                        Drive control condition: DisCharge
                        Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 13
    37308 - System Voltage
                        Fault Frequency: 30
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:31
                        Voltage terminal 30: 6.984 V
       Serial number: 250817EHP08107
       Coding: 003F0020DE01048000801000
       VCID: 428D0FC9D5FB095FCF-8016
       Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000016431479
       Coding: 150000
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:53:54
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.19
                        Time: 00:11:37
    589845 - Window Regulator; Front Passenger side
              B1320 F5 [008] - Supply Voltage too Low
                        Fault Frequency: 10
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:10
       Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
       Component: MU-S-ND-ER    851 0842
       Coding: 02731001FF0000005111010100880A001F0509E601200000CE
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 326D5F09655BB9DF5F-8066
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZHT2533257
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:38
                        Voltage terminal 30: 6.9 V
       Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
       Component: OCULowMQBLGE  H17 0718
       Revision: --------
       Coding: 02739001EA42980D3FFCBE000045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004044
       ROD: EV_OCULowMQBLGE_004_VW37.rod
    0041 - Databus
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 03:25:11
                        Voltage terminal 30: 12.6 V
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
       Component: BECM          H05 0921
       Serial number: V4140073
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006041
       ROD: EV_BECM09620115Q0915182.rod
       Battery Junction Box:
       Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
       Component: BJB  H28 0240
       Cell module: control module 1:
       Subsystem 2 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D1  H14 0481
       Serial number: V013C1751130382
       Cell module: control module 2:
       Subsystem 3 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D2  H14 0481
       Serial number: V013C1751130399
       Cell module: control module 3:
       Subsystem 4 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D3  H14 0481
       Serial number: V013C1751130381
       Cell module: control module 4:
       Subsystem 5 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D4  H14 0481
       Serial number: V013C1751130384
       Cell module: control module 5:
       Subsystem 6 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D5  H14 0481
       Serial number: V013C1751130400
       Cell module: control module 6:
       Subsystem 7 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D6  H14 0481
       Serial number: V013C1751130398
       Cell module: control module 7:
       Subsystem 8 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D7  H14 0481
       Serial number: V013C1751130405
       Cell module: control module 8:
       Subsystem 9 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D8  H14 0481
       Serial number: V013C1751130408
              P1609 00 [167] - -
                        Mileage: 31112 km
                        Date: 2019.06.09
                        Time: 16:28:52
                        Pack Voltage: 346.6 V
                        Pack Current: -0.00 A
                        Isolation Resistance: 5080 kOhm
                        Maxumum charge current limit: 0 A
                        Maximum discharge current limit: 0.0 A
                        Contactor Voltage: 334 V
                        OBD unlearned counter: 40
                        Crash status: 01
                        Pilot Line Status: 00
                        Fuse Status: 00
                        (Minus) Contactor Status: 00
                        (Plus) Contactor Status: 00
                        Terminal 15 status: 01
                        Max Cell Temperature: 33 °C
                        Min Cell Temperature: 32 °C
                        Air inlet temperature: 30 °C
                        Air outlet temperature: 30 °C
                        LV Battery Voltage: 12.6 V
                        Min.cell voltage: 3.627 V
                        Max.cell Voltage: 3.654 V
                        Max.cell SOC: 27 %
                        Min.cell SOC: 26 %
                        Hybrid Battery Pack Remaining Life: 25.9 %
                        Max Charge Pack Current(10s duration): 67 A
                        Max Discharge Pack Current(10s duration): 277.5 A
                        Max Pack Voltage(10s duration): 352 V
                        Min Pack Voltage(10s duration): 314 V
                        Max.cell Voltage(10s duration): 3.672 V
                        Min.cell Voltage(10s duration): 3.285 V
                        Accelerator Pedal Position D: 14.5 %
                        Calculated LOAD Value: 11.0 %
                        Engine coolant temperature: 84 °C
                        Engine RPM: 3857.00 /min
                        Vehicle Speed Sensor: 95 km/h
                        Ambient Air Temperature: 215 °C
                        Hybrid Battery Pack Remaining Life: 25.88 %
                        control module system voltage: 12.629 V
                        absolute load: 21.6 %
                        Time After Engine Start: 3604 s
    26633 - 14V Power System Voltage
              P0A8D 00 [038] - too Low
                        Fault Frequency: 14
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:14
                        Pack Voltage: 340.4 V
                        Contactor Voltage: 20 V
                        Crash status: 01
                        Fuse Status: 00
                        Max Cell Temperature: 17 °C
                        Min Cell Temperature: 16 °C
                        Air inlet temperature: 17 °C
                        Air outlet temperature: 17 °C
                        LV Battery Voltage: 8.4 V
                        Min.cell voltage: 3.537 V
                        Max.cell Voltage: 3.551 V
                        Max.cell SOC: 27 %
                        Min.cell SOC: 26 %
                        Max Charge Pack Current(10s duration): 0 A
                        Max Discharge Pack Current(10s duration): 0.0 A
                        Max Pack Voltage(10s duration): 340 V
                        Min Pack Voltage(10s duration): 340 V
                        Max.cell Voltage(10s duration): 3.551 V
                        Min.cell Voltage(10s duration): 3.536 V
                        Accelerator Pedal Position D: 14.9 %
                        Calculated LOAD Value: 0.0 %
                        Engine coolant temperature: 16 °C
                        Engine RPM: 0.00 /min
                        Vehicle Speed Sensor: 0 km/h
                        control module system voltage: 8.478 V
                        absolute load: 0.0 %
                        Time After Engine Start: 0 s
    26624 - Crash Shut-Down Activated
              P1609 00 [167] - -
                        Mileage: 31112 km
                        Date: 2019.06.09
                        Time: 16:28:52
                        Pack Voltage: 351.1 V
                        Pack Current: 78.60 A
                        Isolation Resistance: 3220 kOhm
                        Maxumum charge current limit: 126 A
                        Maximum discharge current limit: 285.0 A
                        Contactor Voltage: 350 V
                        Crash status: 00
                        Fuse Status: 00
                        (Minus) Contactor Status: 01
                        (Plus) Contactor Status: 01
                        LV Battery Voltage: 13.0 V
                        Min.cell voltage: 3.651 V
                        Max.cell Voltage: 3.662 V
                        Max.cell SOC: 27 %
                        Min.cell SOC: 26 %
                        Calculated LOAD Value: 11.4 %
                        Engine RPM: 4331.50 /min
                        Vehicle Speed Sensor: 96 km/h
                        control module system voltage: 13.076 V
                        absolute load: 21.2 %
    26644 - System Voltage
                        Fault Frequency: 12
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:51:01
                        Crash status: 01
                        Fuse Status: 00
                        LV Battery Voltage: 8.7 V
                        Max.cell SOC: 27 %
                        Min.cell SOC: 26 %
                        control module system voltage: 8.763 V
       Part No SW: 5G0 907 159 C    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0017
       Serial number: 170811200565
       VCID: 2E554B7971639D3F3B-807A
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 AF    HW: 5QE 915 682 AF
       Component: OBC KOSTAL    H40 4013
       Revision: --------    Serial number: 0409170I400098
       Coding: 115068222000
       ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
       ROD: EV_OBCSinglPhaseKLOMQB12P.rod
       VCID: 112FF085C01DA2C706-8044
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:53:17
              U1400 00 [008] - -
                        Reset counter: 115
                        Mileage: 31112 km
                        Date: 2019.08.18
                        Time: 22:50:57
    End-------------------------(Elapsed Time: 05:46)--------------------------
    Jan 2018
    Cheshire UK
    1st thing is you need to fully charge the battery! Everything is pointing to a very low voltage on the battery. Dont even bother running diagnostic scans when you have a low battery or at least use a battery maintainer.
    Who repaired the car?
    As its a hybrid, 99.9% chance is the HV system has been shut down by VW tech as its standard procedure for a HV car thats been in an accident. Safety procedures for anyone working on the car and usually its by someone who hasnt got a clue about HV systems and its dangers.
    ODIS has shut down and reactivation procedure for the audi/VW hybrids, not sure if VCDS has it.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  3. Likes Ashraf6119 liked this post
    Dec 2015
    I am not sure who repaired it, VCDS could de active in all other modules only in this 8C Hybrid Module could not run the basic settings as I said the 20103 security code was accepted in all other module and also could run the basic settings and it did clear the fault codes but, only in 8C Hybrid module could not run the basic settings..
    Jan 2018
    Cheshire UK
    No; basic settings is not the same as shutting down/reactivating the hybrid battery system. Its a strict procedure in ODIS that you have to follow in order to reactivate the battery system. Ive repaired a few of the them and always used ODIS to do it.
    A6 BiTdi Avant MTM
  6. Likes Ashraf6119 liked this post
    Quote Originally Posted by morski View Post
    Been through that procedure with ODIS on a 2018 Audi A3 e-tron, which has essentially the same drivetrain. There was nothing wrong with the car, we just wanted to understand what ODIS was doing. Well ODIS runs you through an crazy number of checks and tests ("CYA"). In the end, what actually shuts down the hybrid battery is not some mysterious thing that the scan tool does, but rather pulling the little plug on the 12V control circuit to the battery's contractor. Guess what re-activates it? Yep, re-inserting that plug.
    Oh, and without sufficient power from the 12V system, the contactor cant close even with the plug in place.
    Jan 2018
    Cheshire UK
    Yes exactly but i didnt want to say that about the little connector plug as dealing with HV systems one never knows how a certain individual might approach these systems. Ive see them with the fuse pulled and the main HV connector to the battery removed as well.
    A6 BiTdi Avant MTM
  9. Likes Ashraf6119 liked this post
  10. #7
    Dec 2015
    Could you please tell me where about is this plug to look at...........?
  11. #8
    Jan 2018
    Cheshire UK
    Back of the engine bay on the firewall; passenger side. Should have a tag attached to it.
    A6 BiTdi Avant MTM
  12. Likes Ashraf6119, Uwe liked this post
  13. #9
    Jan 2018
    Cheshire UK
    here you go...
    A6 BiTdi Avant MTM
  14. #10
    Tartu, Estonia
    You'd really need to use odis to re-enable HV system.
    The world is my oyster...
