Results 1 to 10 of 14
Thread: 2013 VW CC almost everything short to ground HELP!
    Sep 2019
    Hello people!
    Im a new member and seeking for advise or guide how to fix this issue with my CC. Almost everything is shorted to ground on this car. We bought it with engine problem, Ive fixed numerous tiguans but its my first CC pretty much same engine. Following job done on it:
    1 Timing chain and tensioner replaced (yes, timing set correctly)
    2 Valve job done, valve steams replaced.
    3 Intake manifold replaced with new fromVW dealership
    4 Turbo wastegate flapper replaced (yes, we do repair them instead of replacing the whole turbo)
    5 rear main seal replaced
    6 injectors cleaned
    After all of this work done we were super excided itll run with no issues, however the car still having a hard time starting on cold start with black smoke from tailpipe and chek engine light is on. once its warmed up it runs great.
    We found that the wire behind the brake booster was melted, and 5 wires were shorting, so to be on safe side we split open all wiring harness under the hood with extra caution not to cut any wires and inspected them so, no other shorting wires found. Put everything back together and took it local mechanic and he advised the ECM is toasted. so we ordered a used ECM from ebay and had the dealer swap it but the problem is still there.
    Any thoughts highly appreciated! the auto scan results below.
    Friday,13,September,2019,09:33:18:26593
    Chassis Type: AN-VW46 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 55 56
              62 65 72 77
    VIN: WVWBP7AN7DE510121   Mileage: 216640km-134613miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 027 FE    HW: 06J 907 309 B
       Component: MED17.5.2 TFSI 2    3952
       Revision: PAH04---    Serial number: VWZCZ000000000
       Coding: 0404010A1C070160
       Shop #: WSC 02503 444 04883
       VCID: 73A6CB5012D2C9D794-8026
    8 Faults Found:
    001112 - Evap System Purge Control Valve (N80)
                   P0458 - 000 - Short to Ground - MIL ON
                        Fault Status: 11100000
                        Mileage: 216639 km
                        Date: 2014.02.02
                        Time: 17:23:54
                        Temperature: 95.0C
                        Temperature: 35.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 14.224 V
    004501 - Fuel Pressure Regulator Valve (N276)
                   P1195 - 000 - Open or Short to Ground - MIL ON
                        Mileage: 216639 km
                        Date: 2014.02.02
                        Time: 17:23:54
                        Temperature: 95.0C
                        Temperature: 35.0C
                        Voltage: 14.224 V
    012423 - Voltage Supply Relay for Engine Components
                   P3087 - 000 - Electrical Malfunction - MIL ON
                        Mileage: 216639 km
                        Date: 2014.02.02
                        Time: 17:23:54
                        Temperature: 95.0C
                        Temperature: 35.0C
                        Voltage: 14.224 V
    008201 - Intake Manifold Flap; Bank 1
                   P2009 - 000 - Short to Ground - MIL ON
                        Mileage: 216639 km
                        Date: 2014.02.02
                        Time: 17:23:59
                        RPM: 288 /min
                        Load: 51.0 %
                        Temperature: 95.0C
                        Temperature: 35.0C
                        Voltage: 11.811 V
    008328 - Bank 1 Camshaft A (Intake) Position Actuator
                   P2088 - 000 - Short to Ground - MIL ON
                        Mileage: 216639 km
                        Date: 2014.02.02
                        Time: 17:23:59
                        RPM: 288 /min
                        Load: 51.0 %
                        Temperature: 95.0C
                        Temperature: 35.0C
                        Voltage: 11.811 V
    000581 - Solenoid Valve  for Boost Pressure Control (N75)
                   P0245 - 000 - Short to Ground - MIL ON
                        Mileage: 216639 km
                        Date: 2014.02.02
                        Time: 17:23:59
                        RPM: 288 /min
                        Load: 51.0 %
                        Temperature: 95.0C
                        Temperature: 35.0C
                        Voltage: 11.811 V
    000052 - Turbocharger Bypass Valve Control Circuit
                   P0034 - 000 - Low
                        Mileage: 216639 km
                        Date: 2014.02.02
                        Time: 17:23:59
                        RPM: 288 /min
                        Load: 51.0 %
                        Temperature: 95.0C
                        Temperature: 35.0C
                        Voltage: 11.811 V
    001681 - Fan 1 Control Circuit
                   P0691 - 000 - Short to GND
                        Mileage: 216639 km
                        Date: 2014.02.02
                        Time: 17:24:03
                        RPM: 942 /min
                        Load: 16.1 %
                        Temperature: 95.0C
                        Temperature: 34.0C
                        Voltage: 14.097 V
    Readiness: 1110 0101
       Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3509
       Revision: 05551213    Serial number: 00001204132398
       Shop #: WSC 05311 000 00000
       VCID: 2502E508EC86E767CA-8070
       Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
       Component: J104   C2 450M V45C 0023
       Revision: --H07---    Serial number: 00000005693371
       Coding: 0004495
       VCID: 71AAC15868CEFBC766-8024
       Part No SW: 3AA 907 044 J    HW: 3AA 907 044 J
       Component: Climatronic   H03 0101
       Revision: 00001K03
       Coding: 0010001008
       Shop #: WSC 00015 115 00000
       VCID: 373E3F408E2A65F768-8062
    13701888 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Motorsteuergert - bitte Fehlerspeicher auslesen]
                        Fault Frequency: 47
                        Reset counter: 92
                        Mileage: 216621 km
                        Date: 2019.08.30
                        Time: 17:03:46
              B10AB F0 [009] - Too Low
                        Reset counter: 88
                        Mileage: 216621 km
                        Date: 2019.08.30
                        Time: 17:03:46
       Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
       Component: BCM PQ47 H++  421 0465
       Revision: BD421001
       Coding: 0008000000000000008802819400094C2055000840200D20E484402400C0
       VCID: 41CA5198D8EE2B47D6-8014
       Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
       Component: WWS464 120412  010 0604
       Serial number: 120412
       Coding: 00B795
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0024
       Serial number: Y12M04D23h08m20s09S4
       Coding: 0280DD
       Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
       Component: J234__713 VW10 HI   2118
       Revision: 24017000    Serial number: 003LDP8URR3S
       Coding: 0012595
       VCID: 4ED07AA4D9B0C43F5B-801A
       Subsystem 1 - Part No: 3C8 959 339 A
       Subsystem 2 - Serial number: 000000000087MA
       Subsystem 3 - Serial number: 0031.03.120000300000850020†63
       Subsystem 4 - Serial number: 850020†6332MTS690810932 †63
       Subsystem 5 - Serial number: 10932 †6342MTS695460902 †63
       Subsystem 6 - Serial number: 60902 †6351HTS65DL82BKJ †63
       Subsystem 7 - Serial number: 82BKJ †6361HTS63GE65BKJ †63
       Subsystem 8 - Serial number: 65BKJ †63727TS6PGAN1BKR †63
       Subsystem 9 - Serial number: N1BKR †63827TS6SDQM1BKR
       Subsystem 10 - Serial number: M1BKR
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Revision: FF010041    Serial number: 20120504200566
       Coding: 098A270000
       VCID: 6B96D33082E211175C-803E
       Coding: E20000
       Part No SW: 3C8 920 970 T    HW: 3C8 920 970 T
       Component: KOMBI         H04 0609
       Coding: 240F00
       Shop #: WSC 05314 115 00000
       VCID: 3D322D68AC164FA7B2-8068
       Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
       Component: J533  Gateway H41 1623
       Revision:   H41       Serial number: 280412F1000512
       Coding: 469006
       Shop #: WSC 05314 000 00000
       VCID: 3E302A64A91054BFAB-806A
       Part No SW: 3C8 919 965     HW: 3C8 919 965
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1614128R33NZ03
       VCID: 75A2F5481CA6D7E7BA-8020
       Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
       Component:    IMMO         042 0400
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 00395 444 21201
       VCID: 373E3F40462A65F768-8062
       Revision: A1001003    Serial number: 7662439425
       VCID: 291AE938409EC307EE-807C
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0551
       Revision: 12110009    Serial number: 0004840636
       Coding: 0004B7
       Shop #: WSC 05311 115 00000
       VCID: 6D92DD28BCF61F2742-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0501
       Serial number: 00000002872047
       Coding: 010490
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 130
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.302 1002
       Revision: 1AH03734    Serial number: 00121050056401
       Coding: 0000258
       VCID: 3C34206C7F0C46AF85-8068
       Component:    KSG PQ47 ELV 042 0634
       Coding: 1B910F8001862E521204141FF08A0F0E105801
       Component: EZE_2         H41 1623
       Coding: 00000008
       VCID: 6FAEC720BEFAED3770-803A
       Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0003
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0551
       Revision: 14110009    Serial number: 0004870797
       Coding: 0004B6
       VCID: 6E90DA24B1F0E43F7B-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0501
       Serial number: 00000002882748
       Coding: 010490
       Revision:   H19       Serial number: 00000000175606
       Coding: 0022156
       VCID: 3620324441209CFF73-8062
       Component: AFS-ECU       H04 0111
       Coding: 071200010B000400
       Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0007
       Coding: 350000
       Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0007
       Coding: 350000
    5276691 - Stationary Cornering Lamp Right
              C1084 13 [009] - Open Circuit
                        Reset counter: 89
                        Mileage: 216631 km
                        Date: 2019.09.01
                        Time: 00:58:07
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7M1116764
       Coding: 0100040004000F
       VCID: 6386BB1062325957E4-8036
                        Reset counter: 88
                        Mileage: 216621 km
                        Date: 2014.01.20
                        Time: 17:03:46
       Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
       Component: RDKBERU30     H09 0010
       Serial number: 10000000120754
       ASAM Dataset: EV_RDKBERU30 003012
       ROD: EV_RDKBERU30_003.rod
       VCID: 35223548942697E77A-8060
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661339550
       Coding: 0A10040000010110
       Shop #: WSC 22503 444 103858
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 271EEF005E8AF577F8-8072
    End----------(Elapsed Time: 01:45, VBatt start/end: 12.6V/12.5V)-----------
    May 2017
    Looking at the error codes I would say you still have shorting wire somewhere in the engine bay.
    Do you have factory wiring diagram for your car? If not buy 1 hour from Erwin and print the engine bay wiring diagrams. Especially check the wiring from the modules giving the errors. They most likely have common feed which is shorted at some point.
    Sep 2019
    I do not have a wiring diagram, however all wires has been checked for each module.....
    Dec 2016
    Amsterdam
    Not experienced with this model, but did you remove any engine mounts? If so, were there any 'oh shit forgot to unplug this wire' moments? Aka did any wiring come under mechanical stress. If so any spot theyre mounted to a bracket or feeded through the firewall should be checked.
    Current:
    May 2017
    Quote Originally Posted by Silkrauto View Post
    I do not have a wiring diagram, however all wires has been checked for each module...…..
    I’m sorry but I’ve heard this comment so many times and then when they’re checked against the diagrams, oops, broken or shorted wire
    Anyway, with the diagrams you are able to pinpoint from which pins you should have what and then debug using good old fashioned multimeter.
    Then one thing, check the relays in the engine fuse box. The short might be in the relay as well.
    Jan 2018
    Cheshire UK
    What caused the wires to melt in the first place? Definitely looks like a wiring issue where there could be more damaged wiring further up/down in the loom. I would suggest getting hold of a engine bay wiring loom and refitting that and not waste time trying to repair the original unless you are ok with unwrapping big sections of it
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  7. #7
    "Short to GND" can also be caused by a lack of +12V on the other side of the actuator. Most actuators are low-side switched, in other words they have +12V on the one side all the time and the ECU switches the other side to GND in order to turn on that actuator. If there's no +12 on the ECU's input when the switching element is off, it will report "Short to GND".
    Check wiring diagram for a common source of +12 for these actuators. The problem may be as simple as a blown fuse or a relay that isn't closing.
  8. #8
    Sep 2019
    Uwe, you might be right. Here is the one code for battery terminal..... 012423 -
    (Voltage Supply Relay for Engine Components P3087 - 000 - Electrical Malfunction - MIL ON)
  9. #9
    Sep 2019
    Downtime, there is only two relays in the engine bay fuse box. Ive tried to replace them but nothing....
  10. #10
    Sep 2019
    Quote Originally Posted by morski View Post
    Im not sure what caused it to melt, that was right behind the break booster pump (same on all 2.0 tsi between 09-14- Tiguan, passat, jetta, GTI, golf) Ive replaced so many booster gaskets but never seen the wire damage at that place.
