Hello all,
I could use a bit of help or consideration. I pulled a stupid a couple weekends ago and left the drain plug open on my cooler that I put on my front seat. Needless to say I got quite a bit of water soaked into the seat cushion and carpet. I have since removed the seat and pulled the cover back and had the cushion dry out in the sun for a few hours and left it in the garage to air dry the rest of the time. The air bag light came during my short ride with the cooler. Carpet and seat are now dry but I have faults. I have disconnected the harness under the seat and from the module, sprayed the connections with electrical cleaner and applied some DeoxIT Gold to the pins on the harness with no help. I honestly didn't think it would work but it was worth a shot. I am suspecting I shorted the module or the seat sensor itself but want to get your opinion before I surf the web for parts. I am not sure if I would get an occupied sensor fault? The Missing Calibration is me. I did that screwing around in the Vag-Com. Thank You in advance. Here is my Autoscan:
Monday,09,September,2019,21:22:21:59350
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 19.6.1.0 (x64)
VIN: 3VWLL7AJ6CM393621 License Plate:
Mileage: 234450km-145680mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
VIN: 3VWLL7AJ6CM393621 Mileage: 234450km-145680miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 M HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
VCID: 387F62E34BB45D8F61-806C
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001112151651
VCID: 1427F653379C59EF2D-8040
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: B14B400C492B00FD8D1102E6921A0042A71000
VCID: 7DF1B3F7E416B8A7F2-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00085000 Serial number: 0162918823
Coding: 030C0C
VCID: 346756D39FDCB9EF4D-8060
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000838963
VCID: 6FED99BF7E7ADA3770-803A
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0257
Revision: B2066001 Serial number: 04371070120025
Coding: 7A994B9A08AB0B0008382000240884C50082502E6000000030A000000000
Shop #: WSC 28600 002 1048576
VCID: 2F6D59BF7EFA9A3730-807A
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Serial number: WRH0004CCWU
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0105934
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM04XSKQ
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000CNUE06
Coding: 303036
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME3225506AZZZQ
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME116C536AZZZ
Serial number: 3516KSME39464217ZZZP
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME3C045B17ZZZX
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME151B2515ZZZP
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME40612515ZZZJ
9445972 - Seat occupied recognition control module
B1022 54 [137] - Missing Calibration / Basic Setting
Reset counter: 28
Mileage: 234451 km
Date: 2019.09.09
Time: 05:20:43
9445892 - Seat occupied recognition control module
B1022 04 [137] - Internal System Fault
Mileage: 234451 km
Date: 2019.09.09
Time: 05:20:44
Part No SW: 5C6 920 951 A HW: 5C6 920 951 A
Component: KOMBI H04 0604
Coding: 270A01
Shop #: WSC 00066 000 00123
VCID: 2959B7A7481EF407EE-807C
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0257
Revision: B2066001
Coding: 102200
VCID: 70EF9AC3A344C5CF69-8024
Component: IMMO H04 0604
Coding: 000007
VCID: 6ADB88AB8D983F1F27-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000227901003
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E5344BB71F0933F3B-807A
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661874335
Coding: 020000
VCID: 2959B7A7401EF407EE-807C
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 E HW: 1K0 035 274 E
Component: RNS315-NAR H62 0319
Serial number: VWZAZ2N0556613
Coding: 06090001010006000000100A
Shop #: WSC 64522 123 104857
ROD: EV_RNS315NARV2UDS.rod
VCID: 2643BC9B5900DB7FC3-8072
Component: NAR_V3_(0037) 0037
1048630 - CD Changer
B1101 31 [009] - No Signal
Reset counter: 28
Mileage: 234451 km
Date: 2019.09.09
Time: 05:20:42
1048669 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 28
Mileage: 234451 km
Date: 2019.09.09
Time: 05:20:42
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
VCID: 377D61DF46AA52F768-8062
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K H06 0362
Revision: -------- Serial number: BP225311013876
VCID: 306F5AC36BC485CF29-8064
End-------------------------(Elapsed Time: 03:57)--------------------------
