Results 1 to 10 of 13
Thread: Audi A6 C7 FL Traffic Sign Recognition retrofit guide
    Jul 2019
    Trondheim, Norway
    Hi. My name is Rizzio, and i'm from North europe
    I am going to try to guide you trough the process of installing the Vze system in an Audi A6 C7 facelift.
    I'm going to take my car as basis for the installation, but i do have som knowledge with other spec/pre facelift cars.
    My car does not come with matrix led lights, no side assist system, or any other equipment that uses the front camera, so this is a full retrofit.
    My car does come with the 7UG Mib2 High Mmi (4G)
    First, some usefull websites, so you can check your PR codes, and what parts your car needs regarding upgrades
    PR codes checker, Partscatalog, Wirediagrams etc
    Part 1: Hardware/installation
    If you have Acc, you might just need softwarecoding to install the vze (might need the vze cable from 85)
    Laneassist do have all needed hardware, just coding needed
    Matrix led lights have the camera, so wiring and imageprocessor needed
    So scan your car and compare the parts to my scan regarding partnumbers.
    My partslist include, A new front windscreen, front camera, cameracover, image processor, Sensor Electronic module, (steering wheel stalk (i wanted the lane assist as well), image processor bracket, cables, tools, tesa tape!!
    I needed:
    A new front Windscreen: 4G0 845 099 G NVB
    Camera Control Module J852 (VCDS ECU 85) Camera: 4H0 907 217 F
    Image Processing Control Module J851 (VCDS ECU 8E) Image processor: 4G0 907 107 H
    Sensor Electronic module J849 (VCDS ECU 3B) Not compatible: Do not use 4G0 907 637 H!, upgrade to Compatible unit: 4G0 907 637 K
    Steering wheel unit J527 was 4H0 953 568 K, upgraded to 4H0 953 568 H (for the lane assist)
    Cameracover: 4G0 907 299 AB 4PK and 4G0 907 225 C 4PK
    Image processor bracket: 8K0907731
    Cables: i used Lane assist anc traffic sign recognition
    if you want lane assist:
    Without ACC: Steering Column Lever Assembly: 4G0 953 502 S (this one have avant rear viper, cruicecontroll and lane assist)
    With ACC: Steering Column Lever Assembly: 4G8 953 502 S (this one have avant rear viper, acc and lane assist)
    Tesa tape so you avoid rattling (get more than one )
    Tools: Vag Com, Vag Can Pro
    I would install the parts needed in this order if your going to do this retrofit. Check what equipment your car, and whats missing.
    1:
    Get the sensor electronic module first, and upgrade this part if your unit ends with suffix H. Its located under the armrest
    When installed, enter adress 3B and choose basic settings, Calibration, press go, and your set.
    Sara 3D is now upgraded to handle image signals.
    If you skip this part, you will end up with the error "Function Restricted due to Missing Message(s)"
    2:
    Imageprocessor. Remember to get correct one for your car, facelift version 4G0 907 107 H, its located in the front footwell in front of the passenger seat
    The short version is, find the wires from the gateway (pin 7 and 23) that goes to the abs unit, cut the wires, and extend them to the imageprocessor. And pin them correctly (pin 3 and 4, 9 and 10)
    If you mess up the wiring (use the *4) from the Gateway J533 via the Imageprocessor J8501 to the abs J104, this happens, happy hunting faultcodes.
    My ABS unit 4G0 907 379 Q have the code AJ (No acc)
    3:
    Get a new windscreen installed by your prefferd workshop. I went with hud/camera/coated/heated (se partscatalog for prefferd windscreen) or ask dealer/workshop.
    Install the camera and wires.
    Note!! Route the power wires to the Terminal 15 (left side fuse box). Use fuse nr 11 in fuse panel A Black for the Imageprocessor
    You could take the easy route and choose to put the wires (both camera and imageprocessor) in the floor going trough the B pilars and under the back seats
    Do NOT USE the right side fuse box. This will result in no connection
    4:
    If you want lane assist, see this article
    Part 2: Software/Coding
    You might need to go to you local workshop for a camera calibration
    2:
    You might need the Vag can pro tool to update the software in the camera and imageprocessor
    There is a lot of different setups from the factory. Supported : Jap, Uk, Rest of the world. with or without trafficsign recognition, and with or without lane assist. The USA have a new updatefile with vag can pro that states it has lane assist, and traffic sign recognition.
    If you get the error "outside operational area ", you need to update the software in your imageprocessor
    And the fastest way to get the Vze, is to use the vze script in vag can pro
    Vagcom:
    I ended up wit the following codes, Yours might be different regarding equipment:
    Instrumentpanel(17): 03AF12000B550008020000
    Mmi unit(5F): 01750201FF0A000013110001000A00132F0006E5F1700100DF
    Adaptations:
    Lane assist:
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning : Activated
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high : Activated
    Traffic sign:
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification : Activated
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high : Activated
    Lane assist:
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19: Activated
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus : Terminal 15
    Traffic sign:
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 : Activated
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus : Terminal 15
    Headup display(82): AF0000
    Camera (85): 71060000
    Imageprocessor(8E): 0440A9181111
    Adaptations:
    IDE04733-Road Sign detection fusion mode : Road sign fusion
    IDE04734-Display general maximum speed : Always
    IDE04736-Display end of speed limit symbol : 1
    IDE04737-Display no passing allowed : Activated
    IDE04815-Display valid additional signs : Activated
    IDE04816-Prioritize additional wetness signs : Activated
    This fault is ok, just take a drive and you should be ok
    If all is done correctly, this happens.
    Thanks for reading, Regards Rizzio
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 42 44 46 52 53 5F 62
              69 6C 6D 72 82 85 8E 8F 90 AC
    VIN: WAUZZZ4G5FN064973   Mileage: 97885km-60822miles
    17-Instruments -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CRTE)       Labels: Redir Fail!
       Part No SW: 4G2 907 311 C    HW: 4G2 907 401
       Component: 3.0TDI EDC17  X33 0007
       Revision: 92X33---
       Coding: 12254012053601030000
       Shop #: WSC 26214 051 00000
       ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
       ROD: EV_ECM30TDI0114G2907311C.rod
       VCID: 2502E37C24149867CA-8070
       Part No SW: 4G0 927 166 A    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0009
       Revision: --H03---
       Coding: 100001
       ASAM Dataset: EV_TCMDL501021 001021
       ROD: EV_TCMDL501021.rod
       VCID: 2B16154442F0AE171C-807E
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 17A69E41E8657982BB00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3FCE5114A68822B7A0-806A
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01A9700E000000000000
       VCID: 7AB8E000F52AC79FD7-802E
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 30011500041629
       Coding: 360211B8210000
       VCID: 6386BD646AA02657E4-8036
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00001002845902
       Coding: 2600001500349FE08181408380001D0CCF9CE60826090201000008206101150200400025030000
       VCID: 71AAC72CA85C84C766-8024
       Component: WWS57X 150124  H37 0080
       Serial number:         150130081946
       Coding: 0045F7
       Serial number: 23704895
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
       Component: E1 - LDS  H07 0044
       Serial number: 28 02 2014  00001000
       Serial number: DBD80197000000000001
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P10033D6B
       Coding: 30333130313730323736554A304C34473053
       VCID: 3B362504B2903E978C-806E
       Serial number: 3575HRB405P33HNGA0R-
       Serial number: 3585HRB405D33RVK81T5
       Serial number: 3515JRB4016533VUN1QW
       Serial number: 3525JRB4006534EADOSB
       Serial number: 3554VRB400S52RDAI1CY
       Serial number: 3564VRB401052RDAO269
       Revision: C0068538    Serial number: 90862OB500081
       Coding: 000015
       VCID: 3B362504BA903E978C-806E
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 17 12 2014  E0064336
       Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
       Component: TDieRdw       H07 0043
       Revision: 03001036    Serial number: 658050215596016
       Coding: 03AF12000B550008020000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3E302C10A1822BBFAB-806A
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001719911
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 75A2F33CD434A8E7BA-8020
       Serial number: 3565135603
       Voltage stabilizer:
       Serial number: 14112700000000000490
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0112
       Serial number: 04021500040558
       Coding: 20
       Revision: AA000000    Serial number: 00000134103691
       Coding: 0058130000006001000001010101102030303232203232
       VCID: 77BEF934C638DAF7A8-8022
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA820BD7D5
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3620343089B2E3FF73-8062
       Coding: 011F17014E00628002080002
       VCID: 47DE49F4F6586A7718-8012
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0008397702
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 33260D249AC0F6D754-8066
       Revision: 00002001    Serial number: 0359813205
       Coding: 0100063820B930008320090028010F470000000000000000000000000000
       VCID: 46C044F0F152737FE3-8012
       Revision: --------    Serial number: 00000001356261
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D121B5C7CE4A02702-8078
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 044 D    HW: 4G1 035 044
       Component: MU-H-LN-EU    041 0389
       Serial number: A589B0F7507774
       Coding: 01750201FF0A000013110001000A00132F0006E5F1700100DF
       VCID: 200CF2683B367D4FB9-8074
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9FY8013QG
       Multimedia Operating Unit:
       Serial number: 90349OB2000V5
       Component: Gracenote2  --- 1012
       Coding: 010F15004000628002080002
       VCID: 49DA4FCCE04C9C070E-801C
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: Anhaenger     H14 0137
       Revision: 7B001001    Serial number: 0359195306
       Coding: 0100000202000000
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556 A    HW: 5Q0 980 556 B
       Component: RVC Compact   H12 0201
       Coding: 0275000103002007000040
       Shop #: WSC 17873 123 50804
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
       ROD: EV_CamSysRVRVCPANAAU57X_002_AU57.rod
       VCID: 393A3F0CB8AC0C879E-806C
    10489856 - No Basic Setting
              B2010 00 [009] - -
              [RearView system not calibrated]
                        Reset counter: 79
                        Mileage: 97885 km
                        Date: 2019.09.12
                        Time: 21:30:05
                        passive
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0150
       Revision: 14005001    Serial number: 022501421
       Coding: 093205C011
       ROD: EV_HDSGAu571.rod
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
       Component: HeadUpDisplay H07 0304
       Coding: AF0000
       ASAM Dataset: EV_HUDContiC7 001025
       ROD: EV_HUDContiC7.rod
       VCID: 3522333C94B4E8E77A-8060
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 71060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C14165847FEA92F15-8078
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Serial number: 005000620809157
       Coding: 0440A9181111
       Shop #: WSC 05745 128 28888
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 312A072C60DCC4C726-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 3228082065DAFFDF5F-8066
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 150090361
       ROD: EV_RDCMA00100_008.rod
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.4V)-----------
    Thursday,12,September,2019,21:39:35:62878
    UDS Adaptation Channel (1B): IDE04734-Display general maximum speed
    Stored value Always
    UDS Adaptation Channel (1B): IDE04736-Display end of speed limit symbol
    Stored value 1
    UDS Adaptation Channel (1B): IDE04737-Display no passing allowed
    Stored value activated
    UDS Adaptation Channel (1B): IDE04815-Display valid additional signs
    UDS Adaptation Channel (1B): IDE04816-Prioritize additional wetness signs
    UDS Adaptation Channel (60B): ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning
    UDS Adaptation Channel (60B): ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high
    UDS Adaptation Channel (60B): ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification
    UDS Adaptation Channel (60B): ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high
    UDS Adaptation Channel (64B): ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19
    UDS Adaptation Channel (64B): ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus
    Stored value Terminal 15
    UDS Adaptation Channel (64B): ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21
    UDS Adaptation Channel (64B): ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus
    Audi A6 C7.5 FL 2015
    Retrofited: Hud, Back up cam, dab+, Vze
    In progress: Lane assist, Nvc
    Sep 2018
    Spain
    very good work....
    Jun 2017
    Just a few words in addition:
    Retrofitting TSR by coding is possible if you already have image processing unit 8E.
    If you online have Matrix LED, you just have the camera unit 85!
    You have to have either ACC or Lane Assist to have the image processing unit.
    Then you can upload TSR parameters with another tool, and so on....
  4. Likes Uwe, Bogdan.audi, myounus liked this post
    Aug 2019
    NW Florida
    Is Traffic Sign Recognition (TSR) possible with 3Q0-980-654-A Camera - NAR Atlas
    Hadez16: Can you give me some advise? Am I just banging my head against the wall with TSR...using VCDS, I've tried coding, un-coding, re-coding, switching individual setting, rebooting, etc; just can’t get Traffic Sign Recognition (TSR) to work with the modules in my 2019 Atlas SEL. All I get is “Error: Dynamic Road Sign Display” and “No road signs available” messages on the digital cockpit display. I have the 3Q0-980-654-A camera in my 2019 Atlas SEL, the same setup others have said works; but so far, not for me. Is this a case of the module requiring coding beyond VCDS capabilities, i.e., vag can pro? Or, am I just not getting it right? Any advise would be most appreciated.
    Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
    Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
    Component: MQB_B_MFK H09 1272
    Here’s what I tried…
    Address 5F Adaptations:
    1. Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 (activated)
    2. Car_Function_Adaptations_Gen2-menu_display_road_sign_identification (activated)
    3. Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high – (activated and not activated)
    Address 5F Long Coding:
    4. Byte 24, Bit 6 >byte_24_ vza,0=not activated / 1=activated (activated and not activated)
    Address A5 Long Coding:
    5. Security Code 20103 >Byte 16, Bit 4 >VZE,0=not coded*/ 1=coded (coded and not coded)
    Address A5 Adaptation:
    7. Road sign detection fusion mode > “Road sign detection” and “Road sign fusion”
    8. Reboot, reboot, reboot...no joy!
    TW
    2019 Atlas SEL-R FWD
    Sep 2018
    Spain
    http://imgur.com/gallery/77bUj8e
    Hi. I have audi a6 c7 of 2016. I made vze. I only see a signal only speed limits. I want to also have three signals such as photo and signs prohibited forward. Someone can help. Thank you
    Apr 2015
    Atlanta, GA USA
    What steps did you take to enable VZE?
    __________________
    2017 A5 2dr Coupe Quattro Tiptronic Sepang Blue Pearl Effect Carbon Optics 2.0T TFSI Premium Sport
    2014 RS7 4dr Sportback Quattro Tiptronic Phantom Black Pearl Effect Carbon Optics 4.0L TFSI V8 Prestige
    2009 A4 4dr Sdn Quattro Tiptronic Phantom Black Pearl Effect 2.0T Premium Plus
    2004 S4 5dr Avant Quattro Tiptronic Light Silver Metallic 4.2L V8
    Sep 2018
    Spain
    coding with vcds and parameterization Unit 8E with VCP ..
  9. #8
    Oct 2019
    Hi Rizzio and other members,
    I am curious if I can activate the TRS on my car? I have adaptive cruise control and lane assist on my car.
    The only different hardwarecomponent in comparison to Rizzio's is the Steering wheel unit. See also the scan log beneath.
    I have an original Hex-net cable and did the following coding according to the post of Rizzio:
    Traffic sign:
    Traffic sign:
    Imageprocessor(8E)
    Adaptations:
    But it doesn't work (I see nothing in the BIS) and I get the fault code beneath:
    1 Fault code Found:
    16776980 - Function Restricted due to Missing Message(s)
    U1111 00 [008] --
    [VZE_01 keine Kommunikation]
    Intermittent - Confirmed - tested since memory clear
    So do I have all the necessary hardware en do I miss something in the coding, or do I have to do some firmware update?
    Do I need to reboot the MMI?
     Wednesday,09,October,2019,20:25:03:08876
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ4G6FN06xxxx
    Mileage: 113435km-70485mi   Repair Order:
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 34 36 3B 3C 42 44 46
              52 53 55 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
    VIN: WAUZZZ4G6FN06xxxx   Mileage: 113435km-70485miles
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FQ    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 0655
       Revision: 85H23---
       Coding: 12254012244401080000
       ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
       ROD: EV_ECM20TDI01104L906021FQ_002.rod
       VCID: 79F9217FF8FBFE87E0-802C
       Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
       Component: 0CK 20TDI RdW H01 0002
       Revision: --H01---    Serial number: 0000000108
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002014
       ROD: EV_TCMDL382021_AU57.rod
       VCID: 326BD653650DCDDF61-8066
       Coding: 06A2DE4960457B929B00
       VCID: 3F8D8F67A65F10B79E-806A
       Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
       Coding: 05A96F0E000000000000
       VCID: 7CF7386BFFC9CBAFFB-8028
       Serial number: 07021500040007
       Coding: 340209B8250000
       VCID: 63C563176A771457DA-8036
       Revision: 15020001    Serial number: 00001004928002
       Coding: 0105001440349FE2C9014083A0001800CF9CC7082E08020100000894E10116020040003D030000
       VCID: 71E9195FA88BB6C758-8024
       Component: WWS57X 150125  H37 0080
       Serial number:         150128160109
       Coding: 0045F7
       Serial number: 23700082
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Serial number: 31 01 2015  00000118
       Serial number: 3B59C097000000000001
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 2959313F48DB8E07D0-807C
       Revision: --------    Serial number: 003P10035B5A
       Coding: 30333130313630323532554A304C34473053
       VCID: 3B75FB77B2470C97B2-806E
       Serial number: 3575HRB401050SE2817G
       Serial number: 3585HRB40692UMTMDHKZ
       Serial number: 3515JRB400A53590G14%
       Serial number: 3525JRB400C53590AH9H
       Serial number: 3554VRB401053406R0OV
       Serial number: 3564VRB401053406P8N.
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372OB4000KO
       Coding: 0000FD
       VCID: 377DE747866F28F756-8062
       Serial number: 14 01 2015  E0040184
       Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
       Component: TDieRdwAcc    H07 0043
       Revision: 03001036    Serial number: 658050215596006
       Coding: 138F12001F5100080D0000
       VCID: 3365D3579A17C4D76A-8066
       Revision: --------    Serial number: 00000001725880
       Coding: C0CD074418
       VCID: 75E12D4FD4E39AE784-8020
       Serial number: 5577125603
       Voltage stabilizer:
       Serial number: 14112700000000000463
       Revision: AA001002
       Serial number: 04021500040745
       Coding: 20
       VCID: 3E73F263A15519BF95-806A
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008002
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F6DDF27763FE0370E-807A
       Revision: AA000000    Serial number: 00000134991470
       VCID: 77FD2747C6EFE8F796-8022
       Revision: --------    Serial number: EJ1BPA8208YMK2
       ROD: EV_SARA2.rod
       VCID: 3663EA438965D1FF4D-8062
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H06 0060
       Serial number: 0359728000
       Coding: 040311
       VCID: 3979E17FB87B3E87A0-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0060
       Serial number: 0359764049
       Coding: 040311
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F17015E00628002080013
       VCID: 45819D8FCC834A67D4-8010
       Revision: 00001000    Serial number: 0003377862
       Coding: 101001010001
       Revision: 00002001    Serial number: 0359688463
       Coding: 013B0E38A0B93081C32009840C030F470000000000000000000000000000
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00011201926
       Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93426172
       Coding: 011F17015E00628002080002
       VCID: 46839A83F185417FDD-8012
       Revision: --------    Serial number: 00000001354866
       VCID: 2D51C52F7C3392273C-8078
       Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0081
       Coding: 04FA02102A630200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
       Coding: E01E00
       Coding: E01E00
       Part No SW: 4G1 035 018 B    HW: 4G1 035 021
       Component: MU-H-LND-EU   041 0924
       Serial number: A588B0F7504738
       Coding: 017502010000000013111102000A00102F0006E5F1700100DF
       VCID: 1F4D2FE7069F70B7BE-804A
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Serial number: AUZ8Z9FY8011U1
       Serial number: 90349OB20011V
       VCID: 499991BFE09BAE0730-801C
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
       Component: D4-PA RVC Mid H07 0050
       Coding: 027502010201000300
       ASAM Dataset: EV_CamSysRearPANAAU914 002002
       ROD: EV_CamSysRearPANAAU914_VW51.rod
       Revision: 14005001    Serial number: 019500891
       Coding: 093205C030
       Coding: EA060000
       VCID: 2C57C82B47299B2F2B-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 275D37075ECFB877C6-8072
       Serial number: 005000620302157
       Coding: 04C0BA181111
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ROD: EV_RGS_L.rod
       VCID: 3169D95F600BF6C718-8064
       ROD: EV_RGS_R.rod
       Revision: 00000000    Serial number: 150090267
    End-------------------------(Elapsed Time: 07:02)--------------------------
  10. #9
    Sep 2018
    Spain
    VCP....need to parameterize
  11. #10
    Oct 2019
    Quote Originally Posted by torrebasetez View Post
    thnx for your answer. Parametrize which component exactly?
