Results 1 to 10 of 10
Thread: 2019 Audi RS3 output for fan circuit
    Nov 2014
    Trying to manually turn my radiator fan on with key on engine off, which works on my Golf R and S5. However, on my RS3 nothing happens and I get a message "request denied by controller". In fact, this message occurs when trying to activate any system using the output function on the RS3. I have the HEX-NET dongle and latest software (19.6 I believe). TIA.
    Todd
    Near Philadelphia, PA, USA
    and where do we find a recent autoscan of the car?
    We need help to help you.
    Jun 2017
    Did you have the hood opened?
  4. Likes Uwe liked this post
    Nov 2014
    No, does it need to be?
    Nov 2014
    Here is the Autoscan:
    Monday,16,September,2019,12:00:55:30244
    VIN: WUABWGFF2KA905917   License Plate:
    Mileage: 708km-439mi   Repair Order:
    Chassis Type: FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 14 15 17 19 22 29 2B 39 3C 42 44 47 4B
              52 5F 65 6C BB BC CF D6 D7
    VIN: WUABWGFF2KA905917   Mileage: 708km-439miles
    29-Left Light -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    Address 01: Engine (------DAZA)       Labels: None
       Part No SW: 8V0 907 404 J    HW: 07K 907 309 E
       Component: R5 2.5l TFSI  H22 0002
       Revision: 53H22000
       Coding: 0A250032242600053620
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM25TFS0118V0907404J 001003
       ROD: EV_ECM25TFS011_AU37.rod
       VCID: 40CC5445DBF5E74FD9-8014
       Part No SW: 0DL 300 013 E    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 3023
       Revision: 00H06V07
       VCID: 2C1410F5477D132F15-8078
    10679 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [040] - -
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        Coolant temperature: 69 °C
                        Clutch: primary stat: New
                        selected gear: GANG_R
                        Driving position: P
                        Engine torque: 200 Nm
                        Control Module temperature: 49 °C
                        Accelerator position: 14.8 %
                        DTC memory status: 66
       Part No SW: 8V0 614 517 D    HW: 8V0 614 517 C
       Component: ESC           H25 0640
       Revision: 00000000    Serial number: 61299000000741
       Coding: 2EAA6B7DD4990BAE899A0B6540986974D62BD091D0029636024150840288420000000012121212B835351919323200
       Shop #: WSC 06335 790 00021
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
       ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
       VCID: 3A3826ADBD29BD9F97-806E
    7 Faults Found:
    8246 - Databus
              [FCAN: Motor_Code_01 message is not received]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
    8250 - Databus
              [FCAN: Motor_07 message is not received]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
    8252 - Databus
              [FCAN: Motor_11 message is not received]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:12
    8254 - Databus
              [FCAN: Motor_12 message is not received]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:12
    8256 - Databus
              [FCAN: Motor_14 message is not received]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
    8258 - Databus
              [FCAN: Motor_20 message is not received]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
    8264 - Databus
              [FCAN: Tsk_06 message is not received]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0516734542
       Coding: 030C0C1720
       VCID: 43C65B49CAE3FC57C4-8016
    12716804 - Databus
              [Message Motor_14 missing]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        ZAT_pressed: OFF
                        Enabling immobilizer: Condition not met
                        Control Module Voltage: 12.096 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: Open
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
    12718343 - Databus
              [Message Motor_07 missing]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
                        ZAT_pressed: OFF
                        Control Module Voltage: 12.073 V
                        Driver door: Open
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
    12718344 - Databus
              [Message Motor_09 missing]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
                        ZAT_pressed: OFF
                        Driver door: Open
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
    12718345 - Databus
              [Message Motor_code_01 missing]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
                        ZAT_pressed: OFF
                        Control Module Voltage: 12.084 V
                        Driver door: Open
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
       Component: AC Automat    H03 0150
       Revision: 20003000    Serial number: 00000001832631
       Coding: 03000015010000000000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
       VCID: 76A0F29DC9B119FFB3-8022
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 72A1DBA900PAG0MUFU03
    459023 - Databus
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:12
       Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H38 0273
       Serial number: 01001914900022
       Shop #: WSC 06324 790 00021
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 0B56B369A2337417FC-805E
       Component: WWS371 190424  043 0585
       Serial number:         190507143751
       Coding: 0A47F7
       Serial number: 21909266X81A955547A0
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 15 03 2019  20000703
       Serial number: 00000000000047165008
       Sun Roof:
       Component: J245 PS73.404  H04 0005
       Serial number: 0000FST002C7HUW00000
       Coding: 101F00
       Steering Column Switch:
       Subsystem 6 - Part No SW: 82A 953 521 CG    HW: 5Q1 953 549
       Component: J527 SMLS MQB  004 0070
       Serial number: 00000024051904400530
    541973 - Databus
              [Motor_04 Datenbus fehlende Botschaft]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:12
    542229 - Databus
              [Motor_14 Datenbus fehlende Botschaft]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
    542485 - Databus
              [Motor_18 Datenbus fehlende Botschaft]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
    555541 - Databus
              [Motor_12_alt aktiv]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
    559125 - Databus
              [Motor_07 Datenbus fehlende Botschaft]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
       Serial number: 000308418019135
       Coding: 0470155011
       VCID: 4CD47075E7BD332F35-8018
    13637426 - Databus
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
    12648468 - Databus
              [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
       Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
       Component: DAEMPFUNGS-SG H11 0083
       Serial number:       090519084
       ASAM Dataset: EV_AudiMagneRide 003007
       ROD: EV_AudiMagneRide_003.rod
       VCID: 46C0425DF9D1C97FE3-8012
    10506241 - Databus
              [Motor_07_Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
                        COM: 0A FE 0A EF 00 0B 3A 14 00 00
                        Voltage terminal 30: 12.2 V
                        Terminal 15 status via CAN: Terminal 15 on
                        Engine run: Not available
                        Engine torque: Not available
                        AMR state: 6
                        Damping adjustment indicator lamp: OFF
                        ESP automatic engagement: not activated
                        Fall-back level: 01 B0 20 00
    10510337 - Databus
              [Motor_11_Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        COM: 0A DF 0A D0 00 0B 29 02 00 00
                        Engine run: 0
                        Engine torque: -4 Nm
                        AMR state: 0
                        Fall-back level: 00 00 00 00
    10514433 - Databus
              [Motor_14_TimeOut]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        COM: 0A EF 0A DF 00 0B 2A BA 00 00
                        AMR state: 6
                        Fall-back level: 00 30 00 00
    10518529 - Databus
              [Motor_Code_01_Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
                        COM: 0A EF 0A EF 00 0B 37 BC 00 00
                        AMR state: 6
                        Fall-back level: 01 30 20 00
       Serial number: 003GCR0C1CA7
       Coding: 9DCCFCC0008000005000001AC248000000C5
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47DE4F59FEDBD07718-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34258931A22051930173
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34258932A17051920562
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001WC0M0
       Coding: 303433
       Subsystem 4 - Part No SW: -----------    HW: 480 002 405 19
       Serial number: 35700000000CB6483C3V
       Subsystem 5 - Part No SW: -----------    HW: 480 002 405 19
       Serial number: 35800000000B5341CC3O
       Subsystem 6 - Part No SW: -----------    HW: 480 402 305 19
       Component: SideSensor_Dr  005 6149
       Serial number: 3510001A4F001356B74X
       Subsystem 7 - Part No SW: -----------    HW: 480 402 105 19
       Component: SideSensor_Pr  005 6149
       Serial number: 3520001C4F051DB61698
       Subsystem 8 - Part No SW: -----------    HW: 480 401 805 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001A4F001352B74X
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 401 805 19
       Component: FrontSensor_P  005 6149
       Serial number: 3560001A4F00135347C-
    1053952 - Databus
              [NWD: 0x121 Motor_20 Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 890 B    HW: 8V0 920 890 B
       Component: FBenUSA       H19 0108
       Coding: 086F18D33A88CF050204EC041800001000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001032
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 3C3420B5B71D83AF85-8068
    16776971 - Databus
              [Motor_04 communication error can_error_timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   442 4368
       Revision: --------    Serial number: 0009592959
       Coding: 0301000434085D005B00800EB80B00000001010000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 6E90DAFDB1E1213F7B-803A
       Component: 1-01-09-01-04
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0004
       Serial number: 20190517155441 31809
       Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
       Serial number: 1271461305
    131702 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
              [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:15
                        Terminal 15: On
       Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
       Component: Haldex4Motion H55 7762
       Serial number: HA1-00025.04.19
       Coding: 0601
       Shop #: WSC 06325 790 00021
       VCID: 4DD27D711CA73A2722-8018
    6 Faults Found:
    17506 - Databus
              [Motorsteuergerät - TO -- Mot_07]
                        Fault Priority: 8
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:16
    17473 - Databus
              [Motorsteuergerät - TO -- Mot_11]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:12
    16657 - Databus
              [Motorsteuergerät - TO -- Mot_12]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:12
    17474 - Databus
              [Motorsteuergerät - TO -- Mot_14]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:12
    16727 - Databus
              [Motorsteuergerät - TO -- Mot_20]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:12
    17475 - Databus
              [Motorsteuergerät - TO -- Mot_Code]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:16
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H07 0022
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42C85E4DD5F9F55FCF-8016
    0279 - Databus
              [databus - message missing]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H08 0021
       Serial number: 19000152588009
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_AU37.rod
       VCID: 312A0181605F7EC726-8064
    12666369 - Databus
              [Timeout Message Motor_14]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        Result lock conditions: invalid
                        ESCL locked: No
                        ESCL unlocked: Yes
                        Lock sensor: not activated
                        Unlock sensor: operated
                        Error mode 1: not active
                        Error mode 2: not active
                        Clamp S: On
                        Clamp 15: On
                        Clamp 15 Status: valid
                        Remote Start: not active
                        Driver door: Open
                        Central locking locked external: unlocked
                        Central locking safed external: Vehicle not secured
                        Clamp Request: No
                        Request highside lock: No
                        HW highside lock: OFF
                        Highside unlock: No
                        Motor break: not active
                        Activation lowside unlock: OFF
                        Activation lowside lock: OFF
                        I2C overflow: No
                        I2C error pathflags: No
                        I2C resetinfo: No
                        I2C error cpu: No
                        I2C error rom: No
                        I2C error ram: No
                        I2C length failure: No
                        I2C error sda: No
                        I2C communication failure: i2c no comm failure
                        I2C state esp 10: i2c cnd true
                        I2C cnd haco message: valid
                        Coco reset: No
                        Coco supply: On
                        Password IMS OK: Yes
                        Signature IMS OK: Yes
                        IMS responded: Yes
                        Positive authentification in current KL15 cycle: Yes
                        Lifestate: Immobilizer download obtained
                        Learn mode: Adapted
                        Authentication valid (T1): No
                        State of authentication state machine: WFS_AUTH_INIT_e
                        Vehicle speed: 0.00 km/h
                        UBat internal: 11.3 V
                        UMotorBridge: 6.2 V
                        Lock condition engine speed: Condition met
                        Lock condition clamp S: Condition not met
                        Lock condition clamp 15: Condition not met
                        Lock condition E2E clamp status: Condition not met
                        Lock condition timeout clamp status: Condition met
                        Lock condition vehicle speed: Condition met
                        Lock condition E2E vehicle speed: Condition met
                        Lock condition timeout vehicle speed: Condition met
                        Lock condition Mode1: Condition met
                        Lock condition drive readiness: Condition met
                        Lock condition selector lever position parking: Condition met
                        Clamp enable ESCL: not enabled
                        Lock condition timeout distance pulse: Condition met
                        Lock condition E2E distance pulse: Condition met
                        Lock condition difference distance pulse: Condition met
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    0279 - Databus
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 H    HW: 3Q0 907 566
       Component: MRR1Rear      H25 0630
       Revision: --------
       Coding: 040002
       VCID: 3D322DB1AC078AA7B2-8068
    1183750 - Databus
              [databus message missing - Motor]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        Control Module temperature: 46 °C
                        Voltage terminal 30: Measured value not available
                        Terminal 15 status: Measured value not available
                        Voltage terminal 15: 11.90 V
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS002 0287
       Serial number: YE007SEE23082
       Coding: 005E1B205000008000000002
       VCID: 44C45855CFEDFB6FFD-8010
    524339 - Databus
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
       Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5082
       Coding: 811E0000
       ROD: EV_SteerAssisMQB_015.rod
    7 Faults Found:
    22272 - Databus
              [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        Motor status: 00
                        Supply voltage: 12.00 V
                        Temperature: 40.0 °C
                        KFC: 57
                        KFA: 00 00
                        Environmental conditions: 20
                        uioUdNotFilt_xdu16: 12.03 V
                        uAdSensI_SwitchedKl30_xdu16: 12.04 V
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    22528 - Databus
              [MOTOR_12 Botschaft - CAN-Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        Motor status: 00
                        KFC: 58
                        KFA: 00 00
    23040 - Databus
              [MOTOR_20 Botschaft - CAN-Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        Motor status: 00
                        KFC: 5A
                        KFA: 00 00
    22784 - Databus
              [MOTOR_14-Botschaft - CAN-Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
                        Motor status: 03
                        System status: Driving mode
                        KFC: 59
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 12.19 V
                        uAdSensI_SwitchedKl30_xdu16: 12.21 V
    19460 - Databus
              [ESP_05 Botschaft - SNA-Check]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:14
                        Motor status: 03
                        KFC: 4C
                        KFA: 00 04
                        Environmental conditions: 21
    23296 - Databus
              [MOTOR_CODE_01 Botschaft - CAN-Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
                        Motor status: 03
                        KFC: 5B
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 12.16 V
                        uAdSensI_SwitchedKl30_xdu16: 12.16 V
    28672 - Databus
              [MOTOR_07 Botschaft - CAN-Timeout]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
                        Motor status: 03
                        KFC: 70
                        KFA: 00 00
       Part No SW: 81A 035 466 B    HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0440
       Revision: 00000001    Serial number: AUZ8ZAK5F02GR97
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 2404F8D52FADDB6FDD-8070
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 18051910521011
       Coding: 000000050900143206112300040000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW41.rod
       VCID: 35223591943752E77A-8060
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS002 0287
       Serial number: YE007SEF1530E
       Coding: 005E13205C00008000000002
    524339 - Databus
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:13
       Part No SW: 8V1 035 880 C    HW: 8V1 035 880 C
       Component: MU-P-LNS-US   055 1363
       Serial number: A702E0KS017399
       Coding: 017361020000000011220002041A00332F0028E4017001047E
       Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
       Component: NAR 2018/2019  --- 0066
       Component: DU High  H49 0014
       Serial number: AUZ8Z9K1Y0J216
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BT    HW: 8V0 919 614 BT
       Component: ControlUnit_H  H85 0858
       Serial number: ALJAL114121800050325
       Component: Gracenote2  --- 3013
    6708 - Databus
              [Engine: no communication]
                        Reset counter: 54
                        Mileage: 178 km
                        Date: 2019.08.12
                        Time: 16:16:17
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 8S0 907 273     HW: 4M0 907 273 B
       Component: RDKHUFAU736   H05 0002
       Serial number: 30000000008637
       ASAM Dataset: EV_RDKHUFAU736 002007
       ROD: EV_RDKHUFAU736_AU37.rod
       VCID: 77BEFF99CEBB60F7A8-8022
       Component: RVC Compact   H18 0231
       Coding: 0273010102002001400040
       VCID: 393A39A1B82FB6879E-806C
       Part No SW: 8W1 959 395 D    HW: 8W1 959 395 D
       Component: TSG HFS004 0189
       Serial number: YE007SE219375
       Coding: 000C13204000008000000002
       Component: TSG HBFS004 0189
       Serial number: YE007SE219372
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 H    HW: 3Q0 907 590
       Revision: --------
       Coding: 040002
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 177EDF19EEFB80F748-8042
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.1V/12.1V)-----------
    Based on the above fault codes, one might speculate the ECU in that car had been flashed and whoever flashed it didn't bother to clear out the fault codes that all the other modules set while the ECU was off-line.
    As far as opening the hood, some of the latest cars, especially Audis do require that in order for anything that isn't strictly a "read data" kind of operation.
    It's been discussed here off and on:
    https://duckduckgo.com/?q=diagnostic....ross-tech.com
    Jun 2017
    Quote Originally Posted by forcefedjunkie View Post
    What?
    Audi RS3 2019?
    Why does the Scan say its a "FF-AU37" Chassis? Audi A3 should be 8V.
    And you have the DAZA Engine in a MY19 car. That is strange! DAZA was the engine in MY18.
    Here in Germany MY19 RS3 do have another engine.
    Do you not have these Particulate Filters for Gasoline Engines over there since MY19???
  9. #8
    What?
    Audi RS3 2019?
    US requirements for VINs apply:
    https://en.wikipedia.org/wiki/Vehicl..._year_encoding
    "In order to identify the exact year in passenger cars and multipurpose passenger vehicles with a GVWR of 10,000 or less, one must read position 7 as well as position 10. For passenger cars, and for multipurpose passenger vehicles and trucks with a gross vehicle weight rating of 10,000 lb (4,500 kg) or less, if position seven is numeric, the model year in position 10 of the VIN refers to a year in the range 1980–2009. If position seven is alphabetic, the model year in position 10 of VIN refers to a year in the range 2010–2039."
    Thus VAG uses different characters for the 7th and 8th digits in the NAR market than in RDW.
    The NAR market does not (yet?) have a requirement for particulate filters on gasoline engines.
  10. #9
    Nov 2014
    Should I take from this that I should go back to where it was flashed and get the fault code situation rectified?
    I have not tried opening the hood but will today.
    Todd
  11. #10
    If it was mine, I would just clear the faults myself. I mean you have VCDS, right?
  12. Likes PetrolDave liked this post
