Results 1 to 5 of 5
Thread: FUEL FUEL FUEL :-) and introductions!
    Sep 2019
    hello all!
    Jim hailing from the Charlotte NC Area. been in Audi's for several years with 0 issues.
    Recently purchased a used '13 Q5 PP to haul my dogs around in. Ran fine first few months. then developed a pretty severe stutter/hesitation at 1900-2200 RPM with a load on the engine. if no load there's was very little of it. no codes first few months. finally threw a misfire on one cylinder. I changed all plugs and coil packs and it reduced hesitation/stutter by like 80%. changed out the fuel pump/filter assembly about a month ago with an Audi unit from ECSTuning and it reduced it a further 10-15%. 2 days ago, driving to town and after 5 minutes of driving she stuttered REAL BAD and shut off. current bad codes from VCDS are as follows:
    P2294 Fuel Pressure Regulator Valve (N276) Open Circuit
    P261A Coolant Pump 2 Open Circuit (coolant temp at time of failure was only 98C)
    P310B Low Pressure Fuel Regulation - Fuel Pressure Outside Spec - MIL on - Confirmed- Tested since memory clear
    P2539 Fuel Pressure Sensor (G410) Open Circuit Intermittent - Not Confirmed - Tested Since Memory Clear
    P0087 FuelRail/System Pressure - Too Low Intermittent - Not Confirmed - Tested Since Memory Clear
    Right now its hit or miss, sometimes she will start right up and run for 3-8 minutes, sometimes she just urns over and never fires...
    Im thinking its going to be a loose wire somewhere...Also, I'm still able to get like 500+ miles per tank so I never saw any reduction in fuel economy
    Thanks ahead of time for any expert opinions I may find here!!
    Sep 2019
    Wednesday,11,September,2019,18:01:02:51651
    VIN: WA1LFAFPXDA072839   License Plate:
    Mileage: 123000km-76428mi   Repair Order:
    Chassis Type: FP-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
              6C 6D 72
    VIN: WA1LFAFPXDA072839   Mileage: 123000km-76428miles
    Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8R1 907 115 B    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0005
       Revision: ECH09---
       Coding: 6A2A0013242600062000
       Shop #: WSC 40763 001 1048576
       ASAM Dataset: EV_ECM20TFS0118R1907115B 001006
       ROD: EV_ECM20TFS0118R1907115B.rod
       VCID: 342405EE9FF2ACEF4D-8060
    4608 - Fuel Pressure Regulator Valve (N276)
              P2294 00 [032] - Open Circuit
                        Mileage: 123007 km
                        Date: 2019.09.07
                        Time: 10:29:52
                        Coolant temperature: 54 ∞C
                        Intake air temperature: 30 ∞C
                        Voltage terminal 30: 12.345 V
    18062 - Coolant Pump 2
              P261A 00 [047] - Open circuit
                        Mileage: 121856 km
                        Date: 2019.07.25
                        Time: 16:39:10
                        Coolant temperature: 99 ∞C
                        Intake air temperature: 47 ∞C
                        Voltage terminal 30: 12.557 V
    2636 - Low Pressure Fuel regulation
              P310B 00 [237] - Fuel Pressure Outside Specification
                        Mileage: 123007 km
                        Date: 2019.09.07
                        Time: 10:22:20
                        Engine speed: 1251.00 /min
                        Normed load value: 7.5 %
                        Vehicle speed: 27 km/h
                        Coolant temperature: 98 ∞C
                        Voltage terminal 30: 14.112 V
                        Median injection timing: 0.710 ms
                        Driver-side belt buckle status-Bits 0-7: 31
                        Engine torque: 19.2 Nm
    5650 - Low Pressure Fuel Sensor (G410)
              P2539 00 [096] - Open Circuit
                        Mileage: 123007 km
                        Date: 2019.09.07
                        Time: 10:30:15
                        Voltage terminal 30: 12.392 V
    2838 - Fuel Rail/System Pressure
              P0087 00 [096] - Too Low
                        Mileage: 123007 km
                        Date: 2019.09.07
                        Time: 10:22:31
                        Engine speed: 833.50 /min
                        Normed load value: 48.2 %
                        Vehicle speed: 14 km/h
                        Intake air temperature: 44 ∞C
                        Voltage terminal 30: 14.182 V
                        Median injection timing: 13.015 ms
                        Engine operating condition: Part. load
                        Engine operating condition-Test_Program_Channel 87: 6
    Check the wiring diagram for that engine to see what the things that show "Open Circuit" might have in common. A fuse? A connector? A ground point?
    Sep 2019
    Well, as embarrassing as this is to admit, turns out the fuel tank was empty. I seem to have a problem with the fuel level sending unit as it showed the tank as half full when in fact the tank was bone dry. I pulled the fuel filter pump assembly out of the tank so that I could doublecheck that everything was connected properly and saw that the tank was bone dry. after filling up, the car now starts again and runs still has a very very slight hesitation which will require more digging. And I will need to also troubleshoot why the Audi brand fuel pump/filter unit/fuel level is not working properly
  5. Likes Uwe liked this post
    Sep 2019
