Results 1 to 2 of 2
Thread: TPMS Flashing Continuously
    Oct 2014
    Singapore
    We removed the steering module of this 2005 GTI Mk5 and after replacing/doing adaptation of the various G85/200/201 sensors, the TPMS kept flashing even though the vehicle did not have any error code.
    During initial drive, the G85 Steering Angle Sensor came up with an intermittent error of no communication but after clearing it, the error never appear again.
    Did a test to confirm the TPMS switch is supply the required 12 volts to the ABS when triggered. Doing a reset with ignition on, cannot cancel the flashing thought the light staged steady for the duration of the switch resetting. The flashing started once the switch is released.
    Anybody have any idea ?
    PHP Code:
    Wednesday,31,December,2014,13:59:08:24118
    -- Windows Based VAG/VAS Emulator
    VCDS Version
    14.10.0.0 (x64)
    Data version20141022
    Dealer
    /Shop NameCBX Auto Services
    Workshop Code
    305 91777 027292
    VINWVWZZZ1KZ5U019380   License PlateGTI MK5 2005 BEN FLASHING TPMS
    Mileage
    145630km-90490mi   Repair Order
    Chassis Type1K (1K0)
    Scan01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
    VIN
    WVWZZZ1KZ5U019380   Mileage145630km-90490miles
    01
    -Engine -- StatusOK 0000
    02
    -Auto Trans -- StatusOK 0000
    03
    -ABS Brakes -- StatusOK 0000
    04
    -Steering Angle -- StatusOK 0000
    08-Auto HVAC -- StatusOK 0000
    09-CentElect. -- StatusOK 0000
    15
    -Airbags -- StatusOK 0000
    16
    -Steering wheel -- StatusOK 0000
    17
    -Instruments -- StatusOK 0000
    19
    -CAN Gateway -- StatusOK 0000
    25
    -Immobilizer -- StatusOK 0000
    42
    -Door ElectDriver -- StatusOK 0000
    44
    -Steering Assist -- StatusOK 0000
    46
    -Central Conv. -- StatusOK 0000
    52
    -Door ElectPass. -- StatusOK 0000
    55
    -Headlight Range -- StatusOK 0000
    56
    -Radio -- StatusOK 0000
    62
    -DoorRear Left -- StatusOK 0000
    72
    -DoorRear Right -- StatusOK 0000
    Address 01Engine        Labels06F-907-115-AXX.lbl
       Part No SW
    1K0 907 115 A    HW1K0 907 115 A
       Component
    2.0l R4/4V TFSI G00 0070
       Revision
    : --H01---    Serial numberVWZ7Z0D1249491
       Coding
    040300031C070160
       Shop
    #: WSC 10000 742 13315
    VCID244D03AAE785C9012B3-8071
    No fault code found
    Readiness0110 0001
    Address 02Auto Trans        Labels02E-927-770.lbl
       Part No SW
    02E 300 042 M    HW02E 927 770 AD
       Component
    GSG DSG         041 0824
    Revision04004010    Serial number00000412030473
       Coding
    0000020
       Shop
    #: WSC 44551 111 44551
    VCID1D3B364EC4EFF8C964D-8048
    No fault code found
    Address 03ABS Brakes        Labels1K0-907-379-MK60-F.lbl
       Part No
    1K0 907 379 K
       Component
    ESP FRONT MK60      0104
       Coding
    : 0004738
    Shop #: WSC 00046 412 00000
    VCID3A71DDD27501AFF161F-806F
    No fault code found
    Address 08: Auto HVAC        Labels1K0-907-044.lbl
       Part No
    1K0 907 044 AC
       Component
    ClimatronicPQ35 066 0404
       Shop
    #: WSC 00000 000 00000
    VCID68D5579A5B2DED61C7B-803D
    2 Faults Found
    01317 Control Module in Instrument Cluster (J285
                008 -
    Implausible Signal Intermittent
    01274
    Air Flow Flap Positioning Motor (V71
    000 -  -  - Intermittent
    Address 09: CentElect.        Labels3C0-937-049-23-H.lbl
       Part No SW
    1K0 937 049 N    HW1K0 937 049 N*
    ComponentBordnetz-SG     H34 0803
    Revision00H34000    Serial number: 00000001368534
    Coding678F8F0600041800001400001400000000087F075C
       Shop
    #: WSC 10000 742 58069
       Subsystem 1
    Part No1K2 955 119 B  Labels1KX-955-119.CLB
       Component
    Wischer VW350  012  0401
       Coding
    : 00049109
    Shop #: WSC 10000
    Subsystem 2 Part No1K0 955 559 M  Labels1K0-955-559-AF.CLB
       Component
    RegenLichtSens 005  0605
       Coding
    : 00218142
    Shop #: WSC 10000
    No fault code found.
    Address 15Airbags        Labels1K0-909-605.lbl
       Part No SW
    1K0 909 605 C    HW1K0 909 605 C
       Component
    35 AIRBAG VW8   013 2100
       Revision
    02013000    Serial number0033HD03JRPO
       Coding
    : 0013109
    VCID2C5DEB8A8F550141E33-8079
       Subsystem 1
    Serial number6332MSME08273B406
       Subsystem 2
    Serial number6342MSME073432494
       Subsystem 3
    Serial number6351HSME054D0D49F
       Subsystem 4
    Serial number6361HSME05111667
    No fault code found
    Address 16Steering wheel        Labels1K0-953-549-MY8.lbl
       Part No SW
    1K0 953 549 G    HW1K0 953 549 G
       Component
    Lenks鋟lenmodul 021 0050
    Coding0012142
       Shop
    #: WSC 27292 650 91777
    VCID3669C9E241194B91857-8063
       Subsystem 1
    Part NoXXXXXXXXXXX
       Component
    Lenkradmodul    007 0050
    No fault code found
    Address 17Instruments        Labels1K0-920-xxx-17.lbl
       Part No
    1K6 920 860 E
       Component
    KOMBIINSTRUMENT VDD 0812
    Coding0007103
       Shop
    #: WSC 30001 810 85052
    VCID3065FFFAA37D65A1DFB-8065
    No fault code found
    Address 19CAN Gateway        Labels1K0-907-530-V4.clb
       Part No SW
    1K0 907 530 AD    HW1K0 907 951
       Component
    J533  Gateway   H16 0233
       Revision
    :   H16       Serial number4590K112270109
       Coding
    ED817F06000202001003
       Shop
    #: WSC 30001 810 102870
    VCID69D3529E4027D469D85-803C
    No fault code found
    Address 25Immobilizer        Labels1K0-920-xxx-25.clb
       Part No
    1K6 920 860 E
       Component
    IMMO            VDD 0812
    Shop #: WSC 30001 810 85052
    No fault code found
    Address 42Door ElectDriver        Labels1K0-959-701-MAX1.lbl
       Part No
    1K0 959 701 G
       Component
    Tuersteuergeraet 09 0148
    Coding0000054
       Shop
    VCID3261F5F2AD7157B1A9F-8067
    1 Fault Found
    01552 Motor for Central LockingDrivers Door (V56); Lock
                012
    Electrical Fault in Circuit
    Address 44Steering Assist        Labels1Kx-909-14x-44.clb
       Part No
    1K2 909 144 H
       Component
    EPS_ZFLS Kl.0       1502
       Shop
    VCID3163FAFEA8776CA9D05-8064
    No fault code found
    Address 46Central Conv.        Labels1K0-959-433-MIN.clb
       Part No
    1K0 959 433 BL
       Component
    01 KSG              0301
       Coding
    91C802087F2D8404085F018010
       Shop
    VCID7BFF18D63ABB56F93A9-802E
       Subsystem 1
    Component:   Sounder n.mounted
       Subsystem 2
    Component:       NGS n.mounted
       Subsystem 3
    Component:      IRUE n.mounted
    No fault code found
    Address 52Door ElectPass.        Labels1K0-959-702-MAX1.lbl
       Part No
    1K0 959 702 G
       Component
    Coding0000054
       Shop
    VCID336FF0F6526B5EB9A29-8066
    No fault code found
    Address 55Headlight Range        Labels1T0-907-357.lbl
       Part No
    1T0 907 357
       Component
    Dynamische LWR      0002
       Coding
    0000003
       Shop
    VCID74ED33EA17E519817B3-8021
    No fault code found
    Address 56Radio (J0503)       Labels5M0-035-1xx-56.clb
       Part No SW
    3C8 035 195     HW3C8 035 195
       Component
    Radio RCD510  036 0130
       Revision
    00000001    Serial numberVWZ1Z3I4235856
       Coding
    0500040004
       Shop
    #: WSC 01357 011 00200
    VCID65CB5EAE6C3FF009FCD-8030
    No fault code found
    Address 62DoorRear Left        Labels1K0-959-703-GEN1.lbl
       Part No
    1K0 959 703 C
       Component
    Tuersteuergeraet 06 0213
       Coding
    0000016
       Shop
    No fault code found
    Address 72DoorRear Right        Labels1K0-959-704-GEN1.lbl
       Part No
    1K0 959 704 C
       Component
       Coding
    0000016
       Shop
    No fault code found
    End-------------------------(Elapsed Time01:58)--------------------------
    I would power down...... reboot and try the ADP again while observing the steering angle sensor and for any DTC's.
    Interesting how the gateway shows OK but there are in fact DTC's present in 0x08 and 0x42
