Results 1 to 10 of 11
Thread: Wrong settings from factory in Long Coding?
    Sep 2019
    Hello all,
    I have a 2019 Mk7.5 Golf R, US-spec, and I'm wondering if anyone with a similar car (or anyone at all) might be able to shed some light on this. While following the steps here to enable Adaptive Lane Tracking, I looked over the meaning of the other bytes in the Long Coding interface for the "A5-Frt Sens. Drv. Assist" module, and I noticed two things I have questions/concerns about. I chose NOT to show experimental coding options if that matters.
    First, Byte 6 (Country Variant) is set to 00000010 on my car, which doesn't correspond to any of the 3 options shown in the VCDS dropdown. The only options in VCDS are:
    01 - Rest of World
    04 - Europe
    06 - China
    Second, Byte 7 (Suspension) is set to 00000001, which according to VCDS means "Steel Suspension". But my car has DCC, and VCDS even shows an option for DCC in its dropdown menu for this byte. I decided not to change anything here, but I'm curious why it would be this way from the factory (I bought the vehicle new). Is there anyone here with a Mk7.5 Golf that has DCC and Lane Assist who can check this value on their own vehicle? Is it possible this was a coding error at the factory? Or if this coding is correct for a vehicle with DCC, is it possible that the descriptions for the possible values in the dropdown are backwards?
    Full auto-scan below. By the way, in terms of the fault codes, are any of those normal or sometimes expected? The car is a little over a week old and this was my first time using VCDS with it.
    Wednesday,11,September,2019,13:33:50:06899
    VIN: WVWVA7AU3KW224506   License Plate: JOHNH
    Mileage: 869km-539mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
              4B 52 5F 75 A5 A9 D6 D7
    VIN: WVWVA7AU3KW224506   Mileage: 869km-539miles
    4B-Multifunc. Module -- Status: Malfunction 0010
    Address 01: Engine (J623-DLRA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
       Component: R4 2.0l TFSI  H13 0002
       Revision: --H13---
       Coding: 092500122466010E3004
       ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
       ROD: EV_ECM20TFS0208V0906259Q.rod
       VCID: 4EC56E8630568A47085-801A
    23079 - Control unit for information electronics 1
              U1054 00 [036] - No Communication
                        Mileage: 844 km
                        Date: 2019.09.11
                        Time: 11:39:34
                        Coolant temperature: 28 °C
                        Intake air temperature: 31 °C
                        Voltage terminal 30: 12.226 V
                        Engine: operating status: ES
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 27.0 °C
                        Time since engine start: 0.0 s
                        T_ES: 2464 min
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        T_AST_SAE: 0 s
       Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2405
       Revision: 00H06V08
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 2411EC2E0E5A50178E1-8070
       Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
       Component: ESC           H35 0108
       Revision: 00000000    Serial number: 61429000000153
       Coding: 01FA6BA150222170457C030060C96980D60A84A2C0069677384250D8D2A84B0B0000000012121212B835351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD: EV_Brake1UDSContiMK100IPB_038.rod
       VCID: 065596A698A68207F05-8052
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 6103275986
       Coding: 132C0C0723
       VCID: 43D34FB2EB14772F97B-8016
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 0002000420010000110500001211140A
       VCID: 6D87C90A9D10515F11F-8038
       Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H38 0273
       Serial number: 01001916500071
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 0B43A79283C4FF6FAFB-805E
       Component: WWS    190527  043 0551
       Serial number:         190604063926
       Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
       Component: RLHS  051 0205
       Serial number: SBY19M06D17H11M45S03
       Coding: 0008DD
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
       Component: J527 SMLS MQB  004 0070
       Serial number: 00000026041904220842
       Serial number: 000308418319173
       Coding: 0471155811
       VCID: 4CC1648EC64AB857661-8018
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Component: ACC BOSCH MQB H11 0682
       Coding: 330000C159FFC728949C810580401600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: 44D14CAEEE1A7017AE1-8010
    1127 - Databus
              [FAULT_TIMEOUT_PSD_04]
                        Reset counter: 70
                        Mileage: 844 km
                        Date: 2019.09.11
                        Time: 11:44:27
                        Control Module temperature: 38 °C
                        Voltage terminal 15: 12.1 V
    1218 - Databus
              [FAULT_TIMEOUT_PSD_05]
                        Reset counter: 70
                        Mileage: 844 km
                        Date: 2019.09.11
                        Time: 11:39:34
                        Control Module temperature: 34 °C
    1219 - Databus
              [FAULT_TIMEOUT_PSD_06]
                        Reset counter: 70
                        Mileage: 844 km
                        Date: 2019.09.11
                        Time: 11:39:34
       Serial number: 29051941350960
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 3829285EA2D224F7329-806C
       Serial number: 003GCR0C2JUZ
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB5BA2DF2C5B0F4B3-8012
       Occupant Detection:
       Serial number: IBH00000000000BKQM62
       Coding: 303344
       Subsystem 2 - Part No SW: -----------    HW: 480 001 506 19
       Serial number: 35700000000C99BCDC3A
       Subsystem 3 - Part No SW: -----------    HW: 480 001 506 19
       Serial number: 35800000000D659DDC34
       Subsystem 4 - Part No SW: -----------    HW: 480 402 106 19
       Component: SideSensor_Dr  005 6149
       Serial number: 3510001BAF027B83E82F
       Subsystem 5 - Part No SW: -----------    HW: 480 401 906 19
       Component: SideSensor_Pr  005 6149
       Serial number: 3520001B2EFDF5B528B.
       Subsystem 6 - Part No SW: -----------    HW: 480 401 706 19
       Component: FrontSensor_D  005 6149
       Serial number: 35500019EF001347554
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 706 19
       Component: FrontSensor_P  005 6149
       Serial number: 35600019EF00134777B7
       Part No SW: 5G1 920 891 B    HW: 5G1 920 891 B
       Component: KOMBI         403 4191
       Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
       VCID: 2C01040E668A9857461-8078
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 03061911601883
       Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 6E85CE069016AA47285-803A
       Component: 0-01-0d-01-04
       Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
       Component: E221__MFL-MD9  H12 0052
       Serial number: 29190001202500079221
       Coding: 2DFFFF
       Serial number: 6062501505
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00021.05.19
       Coding: 0001
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H08 0021
       Serial number: 19000162295012
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 313F157A41A8F5BF757-8064
       Component: HRE_Master    H12 0081
       Serial number: 0518970496
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D27394A8DF001DFE1F-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0081
       Serial number: 0518489593
       Coding: 020111
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS002 0287
       Serial number: YE007SEJ06806
       Coding: 003E13208000040000000000
       Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
       Component: FOND_FHSG_DRV  007 0010
       Serial number: 00000000000031062255
       Coding: 111000
       Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5082
       Coding: 911F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 3C21344E96EA08D7D61-8068
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
       Component: MIB2_lite_amp H40 0200
       Revision: 00000001    Serial number: VWZ8Z1KMD05AV8-
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: 2E050E065096EA47685-807A
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 09061910804233
       Coding: 000000050900165206710F01020000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 3537216AB5C0D99F29F-8060
    13705489 - Databus
              [PSD_04 data bus missing message]
                        Reset counter: 70
                        Mileage: 844 km
                        Date: 2019.09.11
                        Time: 11:44:27
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS002 0287
       Serial number: YE007SDR02869
       Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
       Component: FOND_FHSG_PSG  007 0010
       Serial number: 00000000000031175699
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    853 0890
       Coding: 027310020000000041220002001808009F0507F401200405C6
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 33331F72BBB4C7AF07B-8066
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H60 8214
       Serial number: VWZ6ZJW1431865
       Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
    6678 - Digital sound System control module
              U106A 00 [008] - No Communication
              [Control module for sound system: no communication]
                        Reset counter: 54
                        Mileage: 453 km
                        Date: 2019.09.01
                        Time: 20:37:50
                        Voltage terminal 30: 13.6 V
       Component: OCULowMQBUS   009 0570
       Coding: 02730002C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H11 0610
       Serial number: 05021915K11797
       Coding: 0003070000000201002213548150A90084000E20012000
       ASAM Dataset: EV_MFKBoschMQBB 002041
       ROD: EV_MFKBoschMQBB_002_VW37.rod
       VCID: 40D940BEFA026C378A9-8014
    1122664 - Databus
              [TIMEOUT_PSD_04]
                        Reset counter: 70
                        Mileage: 844 km
                        Date: 2019.09.11
                        Time: 11:44:27
                        Control Module temperature: 36 °C
                        Outside air temperature: 27.5 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 596.5 s
                        Voltage terminal 15: 12.0 V
                        mid: 01 F0
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Serial number: 190419202206
       VCID: 2F3B1302579CE34F633-807A
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392F2D5A99D83DFFCD7-806C
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxRKEBODVW481.rod
    End----------(Elapsed Time: 02:01, VBatt start/end: 12.3V/12.3V)-----------
    Dec 2016
    DE
    Quote Originally Posted by jphughan View Post
    01 - Rest of World
    04 - Europe
    06 - China
    Your 02 is NAR, which is correct. The normal (non-experimental) labels are done by Ross-Tech and sometimes lack variants (often because they are not yet confirmed), while including others, that might not be as intuitive in the experimental labels.
    The experimental labels don't mention DCC, the only options there are "steel springs", "air chassis" and "magnetic ride". When only considering these possibilities "steel springs" is the correct selection, as DCC is neither air powered nor has magnetic dampers. I expect this to be wrong in the normal labels.
  3. Likes jyoung8607, Uwe liked this post
    Sep 2019
    TBAx, thanks for the quick reply! I have experience coding BMWs and a bit coding Porsches, but I'm new to VCDS. Can you go into a bit more detail about normal vs. experimental value labeling? I didn't even consider looking at experimental at this point since this is Day 1 on VCDS for me. If Ross-Tech does the normal labels, who's doing the experimental labels? When I was using the normal mode, the last option read "Dynamic Chassis Control (DCC) / Magnetic Ride (MR)", hence the confusion.
    And you mentioned you expect this to be wrong on the normal labels. Why is that?
    Apr 2018
    ITALY
    I would be VERY surprised if the factory coded something wrong. let's say I just wouldn't believe it.
    it is much more possible that VCDS labels are wrong, or better, non-mature, non-exact.
    submit your scan and all admaps, it will help Uwe and friends to correct labels for a newer release.
    my Golf came out of the factory with 13 ECUs. now she has 19. and counting
  6. Likes Uwe, PetrolDave liked this post
    Sep 2019
    Thanks! I figured a factory error was unlikely, but I didn't want to make assumptions about an application I was brand new to using either.
    The full auto-scan is in my original post, and below is an admap of the A5 module I'm referring to. If you want admaps for everything, that might take a while to get because I don't have a way to keep the battery powered for these, and I don't want to end up with a dead battery. I'm also going out of town tomorrow for a few days. But hopefully this helps in the meantime!
    ;SW:3Q0-980-654-L   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
    ;Component:MQB_B_MFK     H11 0610, Coding:0003070000000201002213548150A90084000E20012000
    ;EV_MFKBoschMQBB,002041,EV_MFKBoschMQBB_002_VW37.rod
    ;Wednesday,11,September,2019,16:17:55:06899
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 40D940BEFA026C378A9-8014
    IDE00001-Production mode,Deactivating ,3
    IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
    IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
    IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
    IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
    IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
    IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
    IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
    IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
    IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
    IDE04733-Road sign detection fusion mode,Road sign fusion ,1
    IDE07358-Distance to calibration field,1500 mm,2
    IDE09375-IDE05717-Axle offset-Front axle transverse position,1.00001 mm,4
    IDE09375-IDE05718-Axle offset-Rear axle transverse position,1.00001 mm,4
    IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,662 mm,8
    IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,663 mm,8
    IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,672 mm,8
    IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,674 mm,8
    IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2460 mm,24
    IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,742 mm,24
    IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1397 mm,24
    IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2460 mm,24
    IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-742 mm,24
    IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1397 mm,24
    IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2460 mm,24
    IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,742 mm,24
    IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,803 mm,24
    IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2460 mm,24
    IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-742 mm,24
    IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,803 mm,24
    IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
    IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
    IDE10872-Warning intensity: lane depart. warning,Medium ,1
    IDE10873-BAP personalization,activated ,1
    IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.244 °,8
    IDE10924-MAS05286-Initial calibration: result-Roll angle,0.281 °,8
    IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.208 °,8
    IDE10924-MAS10678-Initial calibration: result-Camera height,1313 mm,8
    ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
    ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
    ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
    ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
    ENG120319-Mask_error_reactions_for_development,not activated ,1
    ENG107577-Masked_fault_classes-,255 ,4
    ENG130777-standstill_mode,not activated ,1
    ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1 ,5
    ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20 ,5
    ENG130779-Xcp_interface,not activated ,1
    Elapsed Time: 00:07
    Apr 2018
    ITALY
    the files are not for me, Ross Tech will take inspiration to make VCDS better.
    I did all maps of my car several times, it takes less than ten minutes. if you switch all utilities off, you don't need a battery charger. if you did, you already have a battery problem.
    I actually flashed the A5 camera to a newer software without a charger, it took almost 45 minutes. unwise, yes, but it's just an example.
    of course, when you can and have time.
  9. Likes Uwe liked this post
  10. #7
    Jun 2014
    or you let the engine run idle...
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  11. Likes PetrolDave, Uwe liked this post
  12. #8
    jphuhan: Hi - Your question regarding normal and "experimental" "value labeling is an excellent one!!!
    I don't know the definitive answer, but I can share with you some very-amateur observations - but first I need to ask for Ross-Tech's indulgence, because I might be preaching heresy, or at the very least my comments might be at odds with Ross-Tech's views. So, I proceed carefully and without any intention what-so-ever to cast aspersion on what I consider to be an excellent product
    Let's start with the term "experimental" - it's an interesting word to use when referring to the alternative bunch of labels that populate the nifty long coding application in VCDS. I say "interesting" because the term "experimental" congers-up the notion that these labels are tentative, probative, or they are in some way unproven. There is even a warning message that is displayed by VCDS to reinforce the notion that these "other" labels are of lesser standing than the "normal" long coding labels. I prefer to lose these judgemental descriptors when talking about this matter - let's just collectively call these the "yellow " labels.
    So - I guess like many here, I have access to a number of diagnostic cables/dongles and each has it's advantages and disadvantages - but VCDS is definitely my favorite. For the long coding descriptor function (as distinct from the more basic Byte/Bit function for long coding), I've noticed a remarkable similarity between the "yellow" VCDS labels and the entries on my other manufacturer's devices. In fact, it's the so-called "normal" VCDS labels that are the oddities when comparing long coding results across diagnostic devices. This in no way is meant to diminish the quality of the normal labels - I simply make an observational statement of fact.
    And herein lies my dilemma with the way that VCDS treats the "yellow" long coding labels (which naturally generates the view amongst VCDS users that yellow labels are indeed "experimental" and to proceed-with-caution): ALL my other cables use yellow-like labels as their definitive descriptor for the long coding software switches - there are no warnings in these devices about these similar (and in nearly all cases - the same) labels. It is only VCDS that makes a judgemental comparison between the "yellow" and its own normal labels. Once more, no criticism is intended - again, just an observational statement of fact.
    Which brings me neatly to the pivotal question in this entire debate (in my mind at least) regarding the standing of the yellow labels; Why is it that ALL (including VCDS) cables are able to generate the same yellow-like labels for the descriptor function in long coding?
    I don't know the definitive answer to this question, but using pure logic, my guess is that these descriptors come from the modules themselves - how else is it possible for different manufacturer's devices to report the same values?
    If this is correct, then the characterization of yellow labels as being "experimental", or "risky" is interesting (and more than a tad confusing). To juxtapose this dichotomy- my belief is that all cable manufactures report (pretty-much) the same adaptation channel descriptors because these names also come from the modules themselves. But VCDS does not similarly warn users to proceed-with-care for these labels and there is no similar inference that these descriptors are "experimental".
    So, again without criticism of Ross-Tech and sans any judgement about the quality, or usefulness of either the normal, or the yellow labels - my plea is to remove the warning labels from the yellow screens. Let the user decide which labels to use without fear-or-favor from Ross-Tech, please.
    I will now step-down from my soap-box to spend quality time contemplating my indiscretion in the naughty corner!!
  13. #9
    I'm looking for a stake and pile of wood as I write this.
    I think we can safely assume that if the "yellow" coding labels in VCDS are real similar to the only coding label in other tools, that they likely do have a common source. However, that source is not from querying modules themselves, but rather a common source of "documentation" for those modules.
    The reason other tools don't warn that theirs are "unproven" is because that's all they have. They've never gone to the effort to cross-check that "documentation" with other sources, or to test it empirically, and we've done a combination of both for many (but by no means all) modules.
    This does not mean our "regular" labels are perfect; I'll readily admit that they're not. It's just that we have considerably more confidence in them than the stuff that's more widely available, which we present in yellow.
  14. #10
    ^^ Thanks Uwe for the correction - but with respect, I'm not sure that the fact that the "yellow" labels come from an external reference source and not from the module itself changes the point that I make
    Regardless of where the data resides, the information comes from a reference source that is commonly accepted by the diagnostic industry (except that its standing is questioned by Ross-Tech). Presumably the wide acceptance by industry of this information is because it comes with some authority from the manufacturer/supplier/of the module, or from the car manufacturer.
    Notwithstanding the possibility of error in data from any reference source, why is it reasonable to accept the veracity of a pin-out descriptor on a module (say) from an industry reference source and it then is not acceptable for the data in the yellow labels? Has Ross-Tech's experience with the reference source for these labels been so parlous that there is a real fear about their accuracy? And if the answer is "yes", why include the yellow labels at all (and why isn't there wide-spread condemnation by users of other cables of the same information in other forums like this?)
    I fully acknowledge that Ross-Tech might have "considerably more confidence" in the normal screens - but does this warrant the label "experimental" and the warning message on the Yellow screens?
    Ultimately however, I accept that this is a "captain's call". So I will retire from this debate -not convinced, but rather respectful of the Benevolent Dictator 's authority!!
    PS: you may now light the pyre - but be warned that the only pain that I can tolerate is someone else's
