Results 1 to 5 of 5
Thread: Retrofitted Direct TPMS to a NA Passat TDI 2016, but no car image icon on the cluster
    New User
    Sep 2019
    Mexico
    Question Retrofitted Direct TPMS to a NA Passat TDI 2016, but no car image icon on the cluster
    So I retrofitted Direct TPMS to VW NAR Passat TDI 2016.
    All is working fine, but somehow in the cluster the car icon is not showing up.
    Parts:
    3AA 907 275 F. Wheel Sensors: Quantity 4 (Should use 3AA 907 275 B but revision F worked for me)
    3AA 907 273 D. Antenna: (Also 3AA 907 273 F works but has different tire parametrization not for NA Passat)
    8E0 971 934 A. Antenna connector.
    3AA 907 538. Antenna support.
    000 979 009 E. Cables. Qty 2
    3C0 972 741. Grommets.Qty 4
    Antenna Connector------------> Gateway (with Extended Can Bus feature)
    Pin 1 ---------------------------> Pin 7 Gateway CAN Extended +
    Antenna Connector------------> Fuse Panel +
    Pin 2 ---------------------------> 10A + Switched Power (I connected to FUSE# 10)
    Pin 3 ---------------------------> Pin 17 Gateway CAN Extended -
    Antenna Connector------------> Any good ground connection.
    Pin 4 ---------------------------> Ground -
    VCDS:
    19 Address: Gateway add address on the installation list, tick 65.
    17 Address: Instruments and tick TPMS Byte 2.
    Monday,09,September,2019,21:04:38:32969
    VCDS Version: 19.6.1.0 (x64)
    VIN: 1VWCV7A3XGC005566   License Plate:
    Mileage: 36560km-22717mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 36 3C 42 44 46 47
              4F 52 5F 62 65 72 75 A5
    VIN: 1VWCV7A3XGC005566   Mileage: 36560km-22717miles
    Address 01: Engine (J623-DEKA)       Labels: None
       Part No SW: 04L 906 016 NP    HW: 04L 907 309 K
       Component: R4 2.0l TDI   H20 4790
       Revision: 8AH20---
       Coding: 011D0012034410089000
       Shop #: WSC 20200 993 00000
       ASAM Dataset: EV_ECM20TDI01104L906016NP 004003
       ROD: EV_ECM20TDI01104L906016NP.rod
       VCID: 840DADB70F9B566F3D-80D0
       Part No SW: 02E 300 063 J    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4915
       Revision: 06253104    Serial number: 00001507050398
       Shop #: WSC 09003 957 00200
       VCID: 9D3BF8D3443187A712-80C8
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: C54BC0F5492200FFA31003EA921F004201F1F01A
       VCID: F5EBC0735C417FE73A-80A0
       Part No SW: 5K0 959 434 F    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 093 1202
       Revision: 00093000    Serial number: 0376496207
       Coding: 130C0C
       VCID: B875094703D3C28FE1-80EC
       Part No SW: 561 907 044 AM    HW: 561 907 044 AM
       Component: Climatronic   H07 0910
       Revision: 00001K04
       Coding: 0050019012
       VCID: E2C18B2FF5CFF85F6F-80B6
       Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
       Component: BCM PQ35 H++  122 0183
       Revision: BN122001
       Coding: EF200E3BD82B08D4098806093400854806F1000645B005B0E4806000BC70
       Shop #: WSC 13385 003 104857
       VCID: FF07225B6E7D35B760-80AA
       Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 150915 03  37  0059
       Coding: 0038DD
       Part No SW: 1K8 919 475 B    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0479
       Revision: --------    Serial number: 39411433601309
       Coding: 0031165011
       ASAM Dataset: EV_EPHVA2CVW364GP00 001010
       ROD: EV_EPHVA2CVW364GP00_VW36.rod
       VCID: B9730C4338D9DB871E-80EC
       Part No SW: 7N0 907 572 B    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0120
       Serial number: 13081577031458
       Coding: 01001002FE0739
       ASAM Dataset: EV_ACCBEGVW361 001005
       ROD: EV_ACCBEGVW361_VW32.rod
       VCID: B56B007314C13FE7FA-80E0
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    001 0207
       Serial number: 003RXM00ZVBX
       Coding: 8CCCCC00000000005000001A020800000065
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411_VW41.rod
       VCID: E3CF8E2BEAD5F15764-80B6
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003GT6O
       Coding: 30324A
       Subsystem 2 - Part No SW: -----------    HW: 480 000 708 15
       Serial number: 35700000000EC109E51S
       Subsystem 3 - Part No SW: -----------    HW: 480 000 708 15
       Serial number: 3580000000075664F51M
       Subsystem 4 - Part No SW: -----------    HW: 480 022 108 15
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001B91BE60638665
       Subsystem 5 - Part No SW: -----------    HW: 480 022 408 15
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001C31BE606337A1
       Subsystem 6 - Part No SW: -----------    HW: 480 022 807 15
       Component: FrontSensor_D  000 0189
       Serial number: 3550001B11B2C525773
       Subsystem 7 - Part No SW: -----------    HW: 480 020 508 15
       Component: FrontSensor_P  000 0189
       Serial number: 3560001B719BDF23375G
       Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20150727300040
       Coding: 2012C40008
       ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 8005A1A71B834A4F19-80D4
       Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 3461501192300065AE2B
       Coding: 2D0000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 981 A    HW: 561 920 981 A
       Component: KOMBI         H04 1008
       Coding: 231E090000
       VCID: 9A31F3CF9D1FF09FF7-80CE
       Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1663
       Revision:   H56       Serial number: 09091503000428
       Coding: 461010
       VCID: F2E1FB6F2D2F68DF1F-80A6
       Component: IMMO          H04 1008
       Coding: 000007
       VCID: EAD1E30F0DFFA01FA7-80BE
       Revision: 00000000    Serial number: 15000178363007
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: B0653167EBA31ACFA9-80E4
       Part No SW: 561 959 760 B    HW: 561 959 760 B
       Component: MEM-FS        H04 0183
       Revision: AA000000    Serial number: 00000159150901
       VCID: A241CB2FBD4FB85F2F-80F6
    Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
       Component: HRE_Master    H11 0071
       Serial number: 0377246863
       Coding: 02011102
       ROD: EV_HREntryHella_VW27.rod
       VCID: BC7D155737EBEEAF05-80E8
    No ASAM data for: "EV_HREntryHella" (VW41)
       Part No SW: 561 959 701 C    HW: 3C0 959 793 J
       Component: TUER-SG FT    002 0637
       Revision: 12100010    Serial number: 0009951391
       Coding: 3415FD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 9E39FFDF81379CBF0B-80CA
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14202630150928214210
       Coding: 800000
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 313    3501
       Revision: 00H22000
       VCID: B9730C43F0D9DB871E-80EC
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H08 6831
       Revision: --------    Serial number: EAA098C0069297
       VCID: A855D907D373520F71-80FC
       Component: EZE_2         H56 1663
       Coding: 01030108
       VCID: EFE7F21B3E1D4537F0-80BA
       Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
       Component: J245 P05 9BA3  H08 0005
       Serial number: 53388786011501401389
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
       Component: Analoguhr  001 0002
       Part No SW: 561 959 702 C    HW: 3C0 959 792 J
       Component: TUER-SG BT    002 0637
       Revision: 14100010    Serial number: 0009956559
       Coding: 3415FC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 9F47C2DB863D95B700-80CA
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14202631150928144824
       Coding: 800000
       Part No SW: 5C0 035 684     HW: 5C0 035 684
       Component: MU-S-NS-US    H21 0245
       Serial number: VWZAZ2R0379323
       Coding: 02140102AA00000051220003001808001F0100D400200105C6
       Shop #: WSC 13385 003 1048576
       ROD: EV_MUStd4CTSAT_VW41.rod
       Subsystem 1 - Part No SW: 3G0 919 866 B    HW: -----------
       Component: NAR 2015/16  --- 0220
       Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
       Component: RDKBERU30     H09 0010
       Serial number: 30000000014146
       ASAM Dataset: EV_RDKBERU30 003012
       ROD: EV_RDKBERU30_003.rod
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0156
       Serial number: 000003554140542
       Coding: 02140102C24232007F1606000000
       ASAM Dataset: EV_OCULow 002009
       ROD: EV_OCULow_002.rod
       VCID: 942D9DF77FFBC6EFAD-80C0
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
       Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
       Component: MQB_B_MFK     H04 0023
       Serial number: 070715null0565
       Coding: 000401010001020100201346C0804000D0000E230020
       ROD: EV_MFKBoschMQBB_001_VW27.rod
       VCID: B7770A7B0ECDCDF7E8-80E2
    No ASAM data for: "EV_MFKBoschMQBB" (VW41)
    End-------------------------(Elapsed Time: 04:03)--------------------------
    Not showing the car icon
    New User
    Sep 2019
    Mexico
    It should look like something like this: (Courtesy of Kufatec)
    Sep 2014
    The clusters look different. Does your cluster support this graphic? Sometimes only the higher spec clusters show all the graphics and others have a more basic screen.
  4. Likes Uwe, Mari liked this post
    New User
    Sep 2019
    Mexico
    The color cluster is from a North American Passat TDI Highline (SEL) 2016.
    I wonder same as you, but even the black/white Jetta/Polo cluster has them when they retrofit Maybe a tweak on the instrument cluster recode to a Passat CC/Tiguan maybe
    Polo
    Tiguan
    Jun 2014
    not all cluster SW support that unfortunatelly
    you can try edit eeprom to change logo , and then maybe you will have logo on that screen
