Results 1 to 6 of 6
Thread: Audi Q5 2.0 Tdi, reductant pump 1, open circiut
    Apr 2015
    South Africa
    Checked relavent wiring up to control unit and found to be OK. No Is it possible for this pump to fail at this kilometer reading?
    Wednesday,11,September,2019,11:49:13:48706
    VIN: WAUZZZ8R4FA002533   License Plate: DBW 853 L
    Mileage: 66930km-41588mi   Repair Order:
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 62 69 6D 72
              77 AC
    VIN: WAUZZZ8R4FA002533   Mileage: 66930km-41588miles
    AC-Reductant Control -- Status: Malfunction 0010
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 JN    HW: 03L 906 018 JL
       Component: R4 2,0L EDC   H25 2929
       Revision: 45H25---
       Coding: 2A254012243601080000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM20TDI01103L906018JN 003003
       ROD: EV_ECM20TDI01103L906018JN.rod
       VCID: 7F4EE611E6433EB7E0-802A
    16928 - Control Circuit for Reductant Pump 1
              P208A 00 [039] - Open Circuit
                        Mileage: 66934 km
                        Date: 2019.09.11
                        Time: 11:27:11
                        Coolant temperature: 67 °C
                        Intake air temperature: 38 °C
                        Ambient air pressure: 930 mbar
                        Voltage terminal 30: 12.000 V
                        Outside air temperature: 28.0 °C
                        Pressure sensor for reducing agent: measured pressure: -25 hPa
                        Sensor for reducing agent tank temperature: temperature: 20.8 °C
                        Reducing agent pump: activation: 0.00 %
                        Sensor for reducing agent fill level: voltage: 3105.0 mV
       Part No SW: 8R1 927 156 J    HW: 0B5 927 156 K
       Component: 0B5 20 TDIRdW H02 0003
       Revision: --H02---
       Coding: 000001
       Shop #: WSC 06335 000 00000
       ROD: EV_TCMDL501021.rod
       VCID: 43C6AAE1CA2B9A57C4-8016
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
       Component: ESP8 quattro  H09 0020
       Coding: 21D54C01
       VCID: 0E504BD5D9E9273F1B-805A
       Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
       Component: BCM2 2.0      H14 0650
       Coding: 01B54000000000000000
       VCID: 7EB01B15E94937BFEB-802A
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0514000070887007
       Part No SW: 8K2 820 043 BA    HW: 8K2 820 043 BA
       Revision: D0000000    Serial number: 01150520141293
       Coding: 342502E000
       VCID: 699A584980C7A0072E-803C
       Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
       Revision: 07016001    Serial number: 00000818433701
       Coding: 2600C0108034AFC00081400000001D0D0F1D670827090201000008004401030100000024000000
       VCID: 77BE0E31C67306F7A8-8022
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 140411  H12 0050
       Serial number: 90243015140402125050
       Coding: 01DD13
       Serial number: 22645649
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000605143838
       Serial number: B9088927000000000001
    02988 - Left-Hand/Right-Hand Traffic Switchover Active
                        Reset counter: 137
                        Mileage: 66579 km
                        Date: 2019.07.05
                        Time: 15:11:51
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003JPDC0NH1R
       Coding: 30473431313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 48DCBDCDF30DB90F11-801C
       Serial number: 6334MSME447C445CP
       Serial number: 6344MSME447C4774N
       Serial number: 6352QSME10413C446
       Serial number: 6362QSME303F2172B
       Serial number: 63732SME2640046CX
       Serial number: 63832SME1A410340N
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NEH000FV
       Coding: 000037
       VCID: 48DCBDCDFB0DB90F11-801C
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 930 T    HW: 8R0 920 930 T
       Component: KOMBIINSTR.   H35 0564
       Revision: 00200000    Serial number: ZD433AH5F
       Coding: 3386220002010008010000
       VCID: 45C2B4F9CC1FA467EA-8010
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0060
       Revision: 1V090029    Serial number: 2941V144300740
       Coding: 80CF07FF00
       Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
       Component: J367-BDMHella  H07 8043
       Serial number: 5897323203
       Serial number: 14134001326011200410
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000102500668
       Coding: 011D02205C01440004
       VCID: 4FEE96D11E636E3750-801A
       Part No SW: 8R0 909 144 G    HW: 8R0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0003547796
       Coding: 100000000001
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3C34D11DB7D5E5AF85-8068
       Revision: 00002001    Serial number: 0335538290
       Coding: 013A0622A0B930808420053680040047
       Revision:             Serial number: 0000102391535
       Coding: 011D02205E01440004
       VCID: 4ED08BD51969673F5B-801A
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 00000001481173
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A38D705BDE1DB9F97-806E
       Part No SW: 8R2 035 186 N    HW: 8R2 035 186 N
       Component: Concert3      H05 0470
       Revision: 00000003    Serial number: AUZ5Z6N2041742
       Coding: 0500048204058D00035B071000
       VCID: 41CAA0E9D8378847D6-8014
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000103281719
       Coding: 010C02204001240004
       VCID: 46C0B3F5F119AF7FE3-8012
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
       Revision: 1G001001    Serial number: 00008200328159
       Coding: 0109080000000000
       Shop #: WSC 25397 000 00000
       VCID: 3522C4399CFF34E77A-8060
       Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
       Component: J605  Master  H53 0330
       Revision: --------    Serial number: 8R0827851D
       VCID: 3D32DC19A4CFECA7B2-8068
       Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
       Component: J756  Slave  H53 0330
       Serial number: 8R0827852D
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000103281764
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005770060
       Coding: 0010390
       VCID: 3D32DC1964CFECA7B2-8068
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 141191565
       ROD: EV_RDCMA00100_008.rod
       VCID: 2D12EC597CAF7C2702-8078
    196867 - Control Circuit for Reductant Pump 1
              P208A 00 [009] - Open Circuit
                        Reset counter: 140
                        Mileage: 66934 km
                        Date: 2019.09.11
                        Time: 11:27:07
                        Voltage terminal 30A: 12.0 V
                        Voltage terminal 30B: 12.0 V
                        Voltage terminal 87: 12.0 V
                        Reductant_pwm_duty_cycle: 0.0 %
                        Reductant_speed_pump_motor: 0 /min
                        Reductant_pump_output_stage_temperature: 29 °C
                        Reductant_heater_control_1_output_stage_temperature: 29 °C
                        Reductant_tank_temperature_sensor_actual_value: 21 °C
                        Reductant_temperature_ambient: 23 °C
                        Reductant_current_pump_motor_A: 0.0 A
                        Reductant_current_pump_motor_B: 0.0 A
                        Reductant_current_pump_motor_C: 0.0 A
                        Reductant_heater_control_1_actual_power_value: 0.0 A
                        Reductant_heater_control_2_actual_power_value: 0.0 A
                        Reductant_transfer_pump_current: 0.0 A
                        Reductant_pressure_sensor_actual_value: -50 mbar
                        Reductant_voltage_sensor_supply: 5.0 V
                        Reductant_voltage_sensor_gnd: 0.0 V
                        Reductant_level_sensor_actual_raw_voltage: 3.1 V
                        KL15 on: On
                        DIAG_Opt_H: On
                        Tank_L_SC: OFF
                        Lines_L_SC: OFF
                        DIAG_Lines_H: On
                        DIAG_Lines_L: On
                        DIAG_Tank_H: On
                        DIAG_Tank_L: On
                        MO_SCR_Dosierpumpe_Zustand: 00
                        MO_SCR_Tankheizung: OFF
                        MO_SCR_Leitungsheizung: OFF
                        MO_SCR_Transferpumpe: OFF
                        reserviert 1 0: On
                        Reserviert 2: OFF
                        Can signal MO_SCR_Dosierpumpe_Soll: 0.0 %
    End----------(Elapsed Time: 01:40, VBatt start/end: 12.2V/12.2V)-----------
    Why are voltages so low?
    Explain how you qualified current and wiring?
    Apr 2015
    South Africa
    As per Elsa diagram wiring checked. Fault code cannot be erased, comes back after start up. Will connect battery charger and rerun scan and post.
    Either pump is faulty, wiring or ECU, did you simulate sensors/pump with decade box to verify wiring & ECU will vacate the DTC & did you measure resistance of pump?
    FUSES?
    Ground connections?
    Apr 2015
    South Africa
    Also think pump or ECU? Don’t have a decade box. Not allowed to buy any type of equipment from VW/Audi in South Africa. Will need to source equipment overseas and import. No function on VCDS to activate pump. The contr unit is part of the pump (pump) inside reductant tank! Will have to remove the contr unit/pump from the tank (draining tank), and then disconnect pump to check resistance.
    A decade box is just a variable resistor/capacitance etc. and can be bought as a generic tool, it doesn't have to be bought from VAG.
    Example.......not endorsed!
    https://www.ebay.com/itm/323759943469
  7. Likes Uwe liked this post
