Results 1 to 9 of 9
Thread: Skoda Octavia lost its coding after pump and module change
    Sep 2019
    Unhappy Skoda Octavia lost its coding after pump and module change
    Hi guys,
    So my friend's car now has a similar problem to mine. His brake pedal kept sinking to the floor so after some diagnostics, we changed his abs pump and module. Problem is, I didn't take any coding before doing so *duh* and now the car's lost its coding for the ABS module and the dashboard has lit up like a Christmas tree.
    Can anyone help me with the coding? I attached the autoscan below:
    Thanks in advance.
    Tuesday,10,September,2019,22:04:19:61881
    VIN: TMBBJ7NE0F0039103   License Plate: FL64 ZFC
    Mileage: 351649km-218504mi   Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: TMBBJ7NE0F0039103   Mileage: 351649km-218504miles
    Address 01: Engine (J623-CKFC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 7544
       Revision: 83H22---
       Coding: 11190012030501090000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 79AFEDF9D956495F8D7-802C
    18111 - Oxygen (Lambda) Sensor B1 S1
              P2237 00 [237] - Pump Current Open Circuit
                        Mileage: 351649 km
                        Date: 2019.09.02
                        Time: 04:23:25
                        Engine speed: 889.50 /min
                        Normed load value: 44.7 %
                        Vehicle speed: 16 km/h
                        Coolant temperature: 81 °C
                        Intake air temperature: 72 °C
                        Voltage terminal 30: 14.120 V
                        Oxyg.sens.bank 1 before oxi cat: sign. qual. pump curr.regul.: 14
                        Oxyg.sensor bank 1 before oxi cat: signal quality temp regulat.: 6
                        O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current: 0.0000000 A
                        Oxygen sensor bank 1 before oxi cat: heater activation: 0.000 %
                        O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value: 0.3754 V
                        Oxygen sensor bank 1 before oxi cat: adjustable resistor: 85.3 Ohm
                        Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0000
    13865 - Coolant Pump for Intercooler
              P023A 00 [175] - Open Circuit
                        Mileage: 351648 km
                        Date: 2019.09.02
                        Time: 04:19:39
                        Engine speed: 769.50 /min
                        Coolant temperature: 78 °C
                        Intake air temperature: 65 °C
                        Air mass at air mass meter 1: 25.5 kg/h
                        Extern.temp.sens.1 bank 1: raw value: 21.5 °C
                        Intake air temperature before throttle valve: calculated: 0.0 K
                        Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 95.00 %
              U0428 00 [032] - -
                        Mileage: 351648 km
                        Date: 2019.09.02
                        Time: 00:19:48
                        Engine speed: 891.00 /min
                        Normed load value: 24.3 %
                        Coolant temperature: 46 °C
                        Intake air temperature: 42 °C
                        Voltage terminal 30: 12.220 V
    Readiness: 1 2 0 0 0
       Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
       Component: ESC           H31 0371
       Revision: 00000000    Serial number: 61854000002397
       Shop #: WSC 00049 770 00107
       ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
       VCID: 44D14C0DEE14C4B7AE1-8010
    10 Faults Found:
    0195 - Control module not coded
              U1013 00 [137] - -
              [ECU marked as Not Configured because vehicle ID is invalid]
                        Reset counter: 50
                        Date: 2019.09.11
                        Time: 09:31:46
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 50
                        Date: 2019.09.11
                        Time: 09:31:46
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 50
                        Date: 2019.09.11
                        Time: 09:31:46
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 50
                        Date: 2019.09.11
                        Time: 09:31:46
    0295 - Steering angle sensor
                        Reset counter: 50
                        Date: 2019.09.11
                        Time: 09:31:46
    4161 - Coding invalid
              U10DA 00 [008] - -
              [mismatch between VIN on CAN and VIN in coding word]
                        Reset counter: 50
                        Mileage: 351649 km
                        Date: 2019.09.11
                        Time: 09:45:15
    8278 - Control Module Incorrectly Coded
              U1014 00 [137] - -
              [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                        Reset counter: 50
                        Date: 2019.09.11
                        Time: 09:31:46
    8290 - Coding Not Possible
              U10BC 00 [137] - -
              [FCAN: Unplausible VIN number]
                        Reset counter: 50
                        Mileage: 351648 km
                        Date: 2019.09.11
                        Time: 09:31:51
    8306 - Databus
              U1122 00 [137] - Implausible Message
                        Reset counter: 50
                        Mileage: 351648 km
                        Date: 2019.09.11
                        Time: 09:31:51
    8308 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                        Reset counter: 50
                        Date: 2019.09.11
                        Time: 09:31:46
       Part No SW: 5E0 907 044 K    HW: 5E0 907 044 K
       Component: Climatronic   H03 0907
       Revision: 00001K06
       Coding: 01110104000100011005000000101000
       Shop #: WSC 73430 031 00063
       VCID: 2D0709A95D9E25FF51F-8078
    263425 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Reset counter: 88
                        Mileage: 283658 km
                        Date: 2018.09.29
                        Time: 10:20:06
                        Voltage terminal 30: 12.2 V
                        Outside air temperature: 12.5 °C
                        System run time-Engine running time: 24 s
                        System run time-Terminal 15 on: 25 s
       Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
       Component: BCM MQBAB M   H18 0134
       Serial number: 01011416100610
       Coding: 0F000842424700DB07A04082B10407280000000000000000000000000000
       Shop #: WSC 73430 790 00000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7DA7F9E9CD7E757FA1F-8028
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 140603  041 0570
       Serial number:         140606170247
       Coding: 065DDD
       Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY1409701W7
       Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Serial number: 00000000000029588947
       Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Serial number: 20775739
    204290 - Remote key 1
              B1479 18 [008] - Current Too Low
                        Fault Frequency: 21
                        Reset counter: 76
                        Mileage: 320999 km
                        Date: 2019.04.06
                        Time: 09:15:57
       Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0048
       Revision: --------    Serial number: 39231417801925
       Coding: 0001050001
       VCID: 3A2D32F59CD08247C4D-806E
    13637426 - Databus
                        Reset counter: 50
                        Mileage: 350800 km
                        Date: 2019.08.09
                        Time: 00:35:57
       Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
       Component: Airbag VW20   012 0189
       Revision: --------    Serial number: 003P4PBPZ83A
       Coding: 98CCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F5B03E1C772676FB33-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 001 306 14
       Serial number: 3576U0000004186C3F0E
       Subsystem 2 - Part No SW: -----------    HW: 454 001 306 14
       Serial number: 3586U000000FFA010018
       Subsystem 3 - Part No SW: -----------    HW: 454 802 406 14
       Serial number: 3516R2576F303000000/
       Subsystem 4 - Part No SW: -----------    HW: 454 802 506 14
       Serial number: 3526R380EF0030000000
       Subsystem 5 - Part No SW: -----------    HW: 454 801 905 14
       Serial number: 3556VF4CF9C03000000Y
    9682162 - Multiple collision brake
              B13BC F2 [137] - No function
                        Mileage: 351644 km
                        Date: 2019.09.02
                        Time: 00:04:37
       Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
       Revision: --------    Serial number: 25061404221019
       Coding: 0600
       VCID: 76B5E6C5E8482627E05-8022
       Part No SW: 5E0 920 941     HW: 5E0 920 941
       Component: KOMBI         204 4290
       Coding: 27A402002180A60001082A001000000000000000
       VCID: 6393AF914BDAA38FB7B-8036
    16776973 - Databus
              [RKA_01 keine Kommunikation]
                        Reset counter: 50
                        Mileage: 351644 km
                        Date: 2019.09.02
                        Time: 00:04:27
       Part No SW: 5Q0 907 530 R    HW: 5Q0 907 530 D
       Component: GW MQB Low    126 1188
       Revision: --------    Serial number: 0002184428
       Coding: 030000040F087300EF000248080F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear_011.rod
       VCID: 40D9401DFA0CD8978A9-8014
       Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Serial number: 4804203703
    131602 - Power Steering Control Module
              U101D 00 [008] - No Communication
              [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                        Reset counter: 83
                        Mileage: 341366 km
                        Date: 2019.06.28
                        Time: 12:06:02
                        Supply voltage: Terminal 30: 12.8 V
                        Terminal 15: OFF
       Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
       Component: TSG FS        009 0014
       Serial number: 0000108584197
       Coding: 001000208001040000001100
       VCID: 42DD4A15F400CA879CD-8016
       Serial number: 00000000000003056276
       Coding: 1D0200
       Coding: 8102
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DF4519F106D19F857-8014
    19204 - Databus
              [ESP_02 Botschaft - SNA_Check]
                        Reset counter: 90
                        Mileage: 351644 km
                        Date: 2019.09.02
                        Time: 00:06:15
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 11.75 V
                        Temperature: 22.0 °C
                        KFC: 4B
                        KFA: 00 04
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 11.88 V
                        uAdSensI_SwitchedKl30_xdu16: 11.89 V
       Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
       Component: TSG BFS       009 0014
       Serial number: 0000108550810
       Serial number: 00000000000003057237
       Coding: 050200
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
       Part No SW: 5E0 035 842 A    HW: 5E0 035 842 A
       Component: MU-S-D-ER     041 0435
       Serial number: S7E02806141408
       Coding: 03730100FF0000001111120100A800002F0000860100010002
       Shop #: WSC 73430 790 00063
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 211FE5991146F19FE57-8074
       Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
       Component: ABT_Std_Plus  H50 0022
       Serial number: SKZ8Z9PK601974
              B1066 13 [009] - Open Circuit
              [Hochtonlautsprecher Kanal 4: Unterbrechung]
                        Reset counter: 224
                        Mileage: 280847 km
                        Date: 2018.09.16
                        Time: 13:24:13
                        Voltage terminal 30: 12.6 V
    7175 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 50
                        Mileage: 351644 km
                        Date: 2019.09.02
                        Time: 00:04:28
                        Voltage terminal 30: 12.1 V
                        BAP-BAP_Function_ID: 02
    7206 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 50
                        Mileage: 351644 km
                        Date: 2019.09.02
                        Time: 00:04:28
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.3V)-----------
    Jan 2018
    Cheshire UK
    Have you never scanned his car before? No saved logs etc?
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  3. Likes Jack@European_Parts, Dana liked this post
    Sep 2019
    Unfortunately not. He got his diagnostics done using a different diagnostic scanner. I got asked to take a look after the coding was lost.
    Jun 2014
    Swansea, UK
    Does he still have the old parts to plug back in?
    Sep 2019
    Yep. He said he tried plugging the old parts back in but it made no difference.
    Sep 2019
    Decided to try plugging the old module back in once more and what do you know, coding was present. Copied and pasted into the module and everything spot on now. Thank you.
  8. Likes Dana, Mike@Gendan liked this post
    Oct 2014
    You might want to post an autoscan now it's fixed. If nothing else, it might help others or even yourself in future
  10. Likes Uwe, Dana, Mike@Gendan, PetrolDave liked this post
  11. #8
    Jan 2018
    Cheshire UK
    Lesson learnt.. And always do an autoscan and save save save!!
    A6 BiTdi Avant MTM
  12. Likes PetrolDave, Uwe liked this post
  13. #9
    Sep 2019
    No longer have the car with me but the correct coding was:
    1A078A91242309750078060041C6245851249000608224F000630070C002
    in case that helps.
  14. Likes Dana, Uwe liked this post
