Results 1 to 10 of 14
Thread: Door locking issue GTI mk7
    Sep 2019
    Texas
    Lightbulb Door locking issue GTI mk7
    Hello, new to the forum and VCDS.
    I tends to have lock and unlock door issue on the driver door, for the past days I was not able to unlock the door with the remote. Tonight playing with the central lock button on the internal trim helps, then I was able to unlock the door with the following sequence (Push unlock, then push lock, then push unlock) in a repeatable manner with the remote.
    My autoscan result give me several errors :
    Wednesday,11,September,2019,02:31:34:04572
    VIN: 3VW4T7AUXFM008869   License Plate:
    Mileage: 41250km-25632mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
    VIN: 3VW4T7AUXFM008869   Mileage: 41250km-25631miles
    Address 01: Engine (J623-CNTA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 091D00124424000F0000
       Shop #: WSC 00066 790 00224
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C010484568A2AA7461-8078
    Readiness: 1010 1101
       Part No SW: 0D9 300 040 S    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H52 4315
       Revision: 05852204    Serial number: TFK01403310368
       Shop #: WSC 00066 790 07031
       ROD: EV_TCMDQ250021.rod
       VCID: 270BFBA84F6C09FFAB3-8072
    6 Faults Found:
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21159 - Gear R
              P072B 00 [002] - Not Selectable
    10731 - Valve 3 in Transmission Part 1
              P174A 00 [002] - Electrical malfunction
    10657 - RPM Signal from ECU
              P0726 00 [002] - Implausible Signal
    10906 - Cooling Oil Valve
              P179D 00 [002] - Electrical Malfunction
              P1734 00 [002] - -
       Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
       Component: ESC           H31 0371
       Revision: 00000000    Serial number: 51344000000311
       Coding: 01FA6BA134200974007F020681CC2980D62C9000408194B400430050C009
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
       VCID: 44D14C24DE1AC2E7AE1-8010
       Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
       Component: AC Manuell    H01 0705
       Revision: 00001K06
       Coding: 00020004200100000000000000000000
       VCID: 363526EC98C66077205-8062
       Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
       Component: BCM PQ37BOSCH 026 0097
       Revision: --------    Serial number: 86580905141371
       Coding: 000018464041804969E44000001407201000000000000000000000000000
       ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
       ROD: EV_BCMBOSCH_012.rod
       VCID: 43D34F38DB14C5DF97B-8016
       Component: WWS    140330  043 0581
       Serial number:         140610073753
                        Reset counter: 25
                        Mileage: 41219 km
                        Date: 2019.09.08
                        Time: 21:23:02
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM009W8R
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 51FF75701168274F157-8004
       Occupant Detection:
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  H05 0016
       Serial number: IBH0000J140000UVEB0R
       Coding: 30325A
       Subsystem 2 - Part No SW: -----------    HW: 480 000 504 14
       Serial number: 35700000000E34BC9F0/
       Subsystem 3 - Part No SW: -----------    HW: 480 000 504 14
       Serial number: 35800000000FE62C9F03
       Subsystem 4 - Part No SW: -----------    HW: 480 401 504 14
       Serial number: 35100029D157E9D5C14I
       Subsystem 5 - Part No SW: -----------    HW: 480 401 704 14
       Serial number: 3520002C1157E9D302C5
       Subsystem 6 - Part No SW: -----------    HW: 480 402 104 14
       Serial number: 3550002AD157E99182DL
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 104 14
       Serial number: 3560002AD157E993A32G
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Component: Lenks.Modul   075 0155
       Revision: FF028028    Serial number: 20140426500283
       Coding: 0410
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FDB43C8B7FCA13FF33-806A
    617752 - Selector Lever Park Position Lock Switch
              B1162 29 [008] - Signal Implausible
                        Reset counter: 25
                        Mileage: 41240 km
                        Date: 2019.09.10
                        Time: 18:10:00
                        Ubat 30 Voltage: 13.70 V
                        Ignition State: On
                        Terminal 15: 12.90 V
                        A/D #1: 0.00 %
                        A/D #2: 0.00 %
                        A/D #3: 0.00 %
       Part No SW: 5G6 920 970 C    HW: 5G6 920 970 C
       Component: KOMBI         316 2210
       Coding: 0BBD090A2180CF0502086A00000000
       Shop #: WSC 00066 790 00201
       VCID: 303910F47AA24E477A9-8064
       Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2163
       Revision: --------    Serial number: 16021410001206
       Coding: 0101000820085900EF000028180F00000001000000000000000000000000
       ASAM Dataset: EV_GatewConti 010015
       ROD: EV_GatewConti_010.rod
       VCID: 3E253ECCB0F6A837F85-806A
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H06 0101
       Serial number: 29140000106890044145
       Coding: 29FFFF
       Serial number: 240514060501L3
       Coding: 003E03200000040000000000
       VCID: 40D94034CA02DEC78A9-8014
       Serial number: 00000000000002499248
       Coding: 011000
              B122D 29 [008] - Signal Implausible
                        Fault Frequency: 32
                        Reset counter: 25
                        Mileage: 41229 km
                        Date: 2019.09.09
                        Time: 18:26:15
       Coding: 8102
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 353721E085C06B6F29F-8060
       Serial number: 1605140605037K
       Serial number: 00000000000002591878
       Coding: 191000
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     013 0645
       Serial number: V7B00305142805
       Coding: 02730000FF00000021220001001800001F0203040100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 6491ACA47EDAA2E74E1-8030
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS5005CU
              B11CF 53 [009] - Deactivated
                        Reset counter: 236
                        Mileage: 41219 km
                        Date: 2019.09.08
                        Time: 21:20:32
                        Voltage terminal 30: 13.5 V
       Part No SW: 5QE 035 285     HW: 5QE 035 285
       Component: OCULowMQBUS   006 0528
       ROD: EV_OCULowMQB.rod
       VCID: 025D8A3C848E0CD7DCD-8056
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 240
                        Time: 00:00:00
       Component: SAS-GEN 2     H06 0013
       Serial number: 140329200598
       VCID: 6B83C7989304ED9F0FB-803E
    End----------(Elapsed Time: 01:01, VBatt start/end: 13.8V/13.8V)-----------
    They are minor error : Satellite radio, car seat, one maybe related to the recent recall regarding to the P switch position and the "Switch for Central Locking - Signal Implausible"
    I found this topic : https://forums.ross-tech.com/showthr...ndow-regulator with the same error but not much info.
    I'm trying to figure out where is this Switch for Central Locking, from my understanding seems to be in the door latch system, is this statement correct ?
    Tonight, i've checked / pushed back some of the electrical connections : Door latch, J386 box, door to car frame, seems better however I still do have this fault (even after a clear). This week-end i'll try to check better the wiring.
    Any though ?
    Ernesst.
    ^^ here's a cut-down version of how the driver side door module and the central locking unit are wired together. Of course you car may not have a SAFELOCK feature (extra motor) - but I suggest that you pay particular attention to the integrity of the wires, connectors for the switches.
    PS: and in answer to your first question - the central locking system is integrated into the door lock
  3. Likes Uwe liked this post
    Sep 2019
    Texas
    Thanks DV52 for your answer and the diagram.
    My car is US so i believe it's not equipped with a SAFELOCK system.
    So far what i've done yesterday improved the situation but not the scan.
    Apr 2018
    ITALY
    as a side note, it looks like all Golfs come out of the factory with the SAFE option, wired and ready to go (they probably manufacture just one version of the door lock). it's not coded out if you didn't buy the car with the OEM alarm system. now, I don't know if the SAFE thing would work without retrofitting the whole alarm.
    my Golf came out of the factory with 13 ECUs. now she has 19. and counting
    I really doubt that's true of NAR models. They've historically not had the mechanical bits necessary for the SAFE function because that function is not allowed by the USA's FMVSS (Federal Motor Vehicle Safety Standards). The way I understand it, doors must be able to be opened from the inside no matter what, even with a total electrical failure.
  7. Likes darkchina811 liked this post
    Apr 2018
    ITALY
    oops, somehow I always forget this NAR / ROW separation. I was speaking for european cars.
  9. Likes Uwe liked this post
  10. #7
    Yep, and the OP is in Texas, so I think we must assume his car is NAR.
    PS: Stuff like this is why I'm fairly insistent that participant here has a location in their profile.
  11. #8
    Uwe: isn't it odd (well...... I think that's it's odd) that a facility in (almost?) every other place on this fragile blue planet where this feature is touted as enhancing passenger SAFEty - is viewed as quite the opposite in America. Clearly the sage folk @ FMVSS are streets ahead of their counterparts elsewhere - or maybe not
  12. #9
    Well, it's an enhancement if it prevents car-jackings, which I believe was the original intent of this feature, but after an accident, if it prevents you from exiting the vehicle, not so much...
  13. #10
    The crash signal from the airbag ECU is 'supposed' to unlock all the doors even if they are SAFE locked.
