Results 1 to 10 of 10
Thread: Centr. Electr. II faults. What's this stuff mean!
    Verified VCDS User carboncow's Avatar
    Central Ohio
    2011 JSW SE 2.5L
    While chasing some HVAC gremlins (AC intermittent, solenoid fix installed, then it didn't work for a month...now it works even when switched off!). Did a scan an finally got the scan off the laptop. Mentions one fault in circuit intermittent and another about the module incorrectly coded. Now although I have a VCDS I have never tried custom codes on this ride. I noted the fault stamps were 1.10.2014 which is prior to my ownership too...so maybe another coded.
    How does one identify these concerns (primarily the coding comment) and find the correct code? I'm assuming Cent Elect II is a who list of functionality from pano roof to wipers from what I can tell? Can someone educate me to Cent Elec II?
    Monday,09,September,2019,19:24:57:39593
    VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
    VIN: 3VWPZ7AJ5BM612681   License Plate:
    Mileage: 202720km-125964mi   Repair Order:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
    VIN: 3VWPZ7AJ5BM612681   Mileage: 202720km-125964miles
    Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 BE    HW: 07K 906 055
       Component: 2,5l R5/4V      G01 9213
       Revision: T4H04---    Serial number:
       Coding: 0000075
       Shop #: WSC 08151 444 84507
       VCID: 72A8117A6D3588DF9F-8026
       Part No SW: 09G 927 750 LM    HW: 09G 927 750 LM
       Component: AQ 250 6F           1734
       Revision: 00H90000    Serial number:
       Coding: 0000840
       Shop #: WSC 00066 000 00000
       VCID: 075E50AE76B79D77D8-8052
       Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
       Component: ESP MK60EC1   H30 0106
       Revision: 00H30001
       Coding: 114B400C492300FC881102EC921A0041B70000
       VCID: 74A41762D72186EF8D-8020
    02214 - Tire Pressure Warning
                        Reset counter: 239
                        Mileage: 201917 km
                        Date: 2014.01.18
                        Time: 21:08:34
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 50946
                        Count: 511
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       Shop #: WSC 00066 000 00146
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 75A22A66D45B9FE7BA-8020
       Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
       Component: BCM PQ35 B    011 0035
       Revision: BG011001
       Coding: 2D380E1F902F3EC400080081600000C401000086435D8D60648020000040
       VCID: 3424D76297A1C6EF4D-8060
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 29071  21  0512
       Coding: 009795
    Address 15: Airbags
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90440JFE000BG
       Coding: 188A140000
       Shop #: WSC 00066 000 00186
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76A02D6AC95D94FFB3-8022
       Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H05 0010
       Serial number: 0002241
       Coding: 820000
       Part No SW: 5K0 920 971 B    HW: 5K0 920 971 B
       Component: KOMBI         H03 0406
       Coding: 270F01
       VCID: 2E10C50A718DEC3F3B-807A
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530 A    HW: 1K0 907 951
       Component: J533  Gateway   H25 5603
       Revision:   H25       Serial number: 03081001200958
       Coding: ED807F0600160300002002
       Shop #: WSC 00066 123 12345
       VCID: 2E10C50AB98DEC3F3B-807A
       Revision: 00001000    Serial number: 1225223R99HH06
       VCID: 7EB0354A296DDCBFEB-802A
       Component: IMMO          H03 0406
       VCID: 6A98091A8DE5401F27-803E
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0001235618
       Coding: 0004B5
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 271E302E5E77BD77F8-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005011784
       Coding: 000490
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 312ADE76A8B3F3C726-8064
       Component: EZE_2         H25 5603
       Coding: 000B0500
       VCID: 6FAE180EBE07A53770-803A
    02071 - Local Databus
                        Fault Status: 00101100
                        Reset counter: 244
                        Mileage: 201104 km
                        Date: 2014.01.10
                        Time: 20:20:02
                        Fault Frequency: 12
                        Reset counter: 210
                        Mileage: 201103 km
                        Date: 2014.01.10
                        Time: 07:40:59
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0307
       Revision: 15101005    Serial number: 0001230716
       Coding: 0004B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW32.rod
       VCID: 281C33125369B20FF1-807C
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005027190
       Coding: 000490
       Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
       Component: MIB2-S-R-CN   036 0317
       Revision: -----001    Serial number: VWZ6Z2Q7005543
       Coding: 1700040004000A
       Shop #: WSC 00081 790 00117
       VCID: 46C09DAAF13D447FE3-8012
                        Reset counter: 73
                        Mileage: 190529 km
                        Date: 2013.08.26
                        Time: 07:45:38
    00856 - Radio Antenna
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 142
                        Mileage: 179714 km
                        Date: 2013.04.26
                        Time: 07:52:04
                        Reset counter: 18
                        Mileage: 151271 km
                        Date: 2012.08.04
                        Time: 21:11:44
                        Reset counter: 142
                        Mileage: 179714 km
                        Date: 2013.04.26
                        Time: 07:52:04
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668217051
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 3228D17A65B5C8DF5F-8066
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Reset counter: 210
                        Mileage: 170325 km
                        Date: 2018.09.09
                        Time: 18:03:06
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 15
                        Mileage: 170325 km
                        Date: 2018.09.09
                        Time: 18:03:06
    End----------(Elapsed Time: 01:19, VBatt start/end: 12.2V/12.1V)-----------
    2008 V6 Lux+ Pkg with factory towing
    Alaska Grey in Delaware, Ohio
    VCDS-Mobile
    16.4905 S, 151.7375 W
    QA
    It would appear that the [Address 4F: Centr. Electr. II (J520)] is not coded correctly for the equipment this vehicle has installed as per the VIN.
    [P75] = "Panoramic sunroof & 17-inch alloy wheelspackage"
    You should have a coding value of [050B0500] for the [4F], that is for the Panoramic sunroof/blind. Unless someone has sealed it up and preventing it from opening due to water leaks.
    The J520-Vehicle Electrical System Control Module 2 is part of the J533-Vehicle Electrical System Control Module and is primarily responsible for the following:
    J245-Power Sunroof Control Motor (with V1-Sunroof Motor)
    J394 Roof Blind Control Module (with V260-Sunroof Blind Motor)
    Please see the Volkswagen Self Study Program 892803-The 2009 Jetta SportWagen for more information about the J520 and a whole lot more.
    Your Auto-Scan is missing the information in the Address 4F: Centr. Electr. II (J520)
    Subsystem 1 - Part No SW: 8R0 959 591 A
    and
    Subsystem 2 - Part No SW: 8R0 959 591 A
    Was there any work to the Panoramic sunroof or any of it's components?
    Hope this helps,
    drpeter
  3. Likes Dana, Jack@European_Parts, Uwe liked this post
    Central Ohio
    Quote Originally Posted by DrPeter View Post
    and
    Hope this helps,
    drpeter
    Pano roof works fine and the sunshade did work til...
    I think you might be onto something. The panoramic roof blind self ejected last month and I have it in the full open position now and cut out the train wreck that self destructed. You think one of the sensors tossed a code and may have extended past a stop?
    It does mention wrong coding too...prob why you asked about previous work. The code will not reset.
    I thought I've seen in other examples the error actually mention pano roof.
    I'll do some reading on your link later and check the coding.
    VCDS-Mobile
    Central Ohio
    and
    Hope this helps,
    drpeter
    Looks like that self study guide is for people more important than me...is a subscription service? I see no option to create an account to login?
    VCDS-Mobile
    Quote Originally Posted by carboncow View Post
    You will need to Register and then subscribe(purchase) access to the repair information, then you can view and save that document.
    Pro-tip!! I would dedicate the time to grab ALL the documents I could during the subscription period! You can save (or print) wiring diagrams, component location, workshop repair manuals as pdf files not only for this vehicle but for other Volkswagen vehicles up to current models.
    erWin Online Registration
    drpeter
  7. Likes PetrolDave, Jack@European_Parts, Uwe, Dana liked this post
    I just wanted to add, you can can re-coded the [4F] controller and then clear ALL the fault codes and see what comes back.
    By the way, the other control module's coding looks okay.
    Also, if you could, post up a new Auto-Scan after the codes cleared, this would help others in the future.
    Thanks,
    drpeter
    Nov 2014
    address 15 airbags can not be reached..?
  10. #8
    Borrowed from Jef for accreditation............
    Time to JPPSG!
    https://forums.ross-tech.com/showthr...Wiring-Diagram
    https://forums.ross-tech.com/showthr...(final-version
  11. #9
    Quote Originally Posted by raf0468 View Post
    If you have a look at the Auto-Scan's Gateway installation List, you can see the Gateway does report the Airbag controller was [OK] at the time the information was gathered.
    So it would appear for what ever reason VCDS did not establish communication with this controller during the actual Auto-Scan, another scan would be a good test,
    drpeter
  12. Likes Uwe liked this post
  13. #10
    I used to rely on this method of checking the installation list too, but found that is not always the truth & FOD can be lurking!
    You are probably right here Peter & because the other modules's are not complaining of no 0x15.......
  14. Likes DrPeter, Dana liked this post
