- Joined
- Dec 3, 2014
- Messages
- 68
- Reaction score
- 6
- Location
- Central Ohio
- VCDS Serial number
- C?ID=266014
2011 JSW SE 2.5L
While chasing some HVAC gremlins (AC intermittent, solenoid fix installed, then it didn't work for a month...now it works even when switched off!). Did a scan an finally got the scan off the laptop. Mentions one fault in circuit intermittent and another about the module incorrectly coded. Now although I have a VCDS I have never tried custom codes on this ride. I noted the fault stamps were 1.10.2014 which is prior to my ownership too...so maybe another coded.
How does one identify these concerns (primarily the coding comment) and find the correct code? I'm assuming Cent Elect II is a who list of functionality from pano roof to wipers from what I can tell? Can someone educate me to Cent Elec II?
Monday,09,September,2019,19:24:57:39593
VCDS Version: 19.6.1.0 HEX-NET CB: 0.4508.4
VIN: 3VWPZ7AJ5BM612681 License Plate:
Mileage: 202720km-125964mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 3VWPZ7AJ5BM612681 Mileage: 202720km-125964miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 BE HW: 07K 906 055
Component: 2,5l R5/4V G01 9213
Revision: T4H04--- Serial number:
Coding: 0000075
Shop #: WSC 08151 444 84507
VCID: 72A8117A6D3588DF9F-8026
Part No SW: 09G 927 750 LM HW: 09G 927 750 LM
Component: AQ 250 6F 1734
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 075E50AE76B79D77D8-8052
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B400C492300FC881102EC921A0041B70000
VCID: 74A41762D72186EF8D-8020
02214 - Tire Pressure Warning
Reset counter: 239
Mileage: 201917 km
Date: 2014.01.18
Time: 21:08:34
Count: 32768
Count: 4608
Count: 16401
Count: 50946
Count: 511
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00146
ROD: EV_ClimaBasis_VW36.rod
VCID: 75A22A66D45B9FE7BA-8020
Part No SW: 5K0 937 084 E HW: 5K0 937 084 E
Component: BCM PQ35 B 011 0035
Revision: BG011001
Coding: 2D380E1F902F3EC400080081600000C401000086435D8D60648020000040
VCID: 3424D76297A1C6EF4D-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 29071 21 0512
Coding: 009795
Address 15: Airbags
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JFE000BG
Coding: 188A140000
Shop #: WSC 00066 000 00186
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76A02D6AC95D94FFB3-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0002241
Coding: 820000
Part No SW: 5K0 920 971 B HW: 5K0 920 971 B
Component: KOMBI H03 0406
Coding: 270F01
VCID: 2E10C50A718DEC3F3B-807A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 03081001200958
Coding: ED807F0600160300002002
Shop #: WSC 00066 123 12345
VCID: 2E10C50AB98DEC3F3B-807A
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R99HH06
VCID: 7EB0354A296DDCBFEB-802A
Component: IMMO H03 0406
VCID: 6A98091A8DE5401F27-803E
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001235618
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 271E302E5E77BD77F8-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005011784
Coding: 000490
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 312ADE76A8B3F3C726-8064
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 000B0500
VCID: 6FAE180EBE07A53770-803A
02071 - Local Databus
Fault Status: 00101100
Reset counter: 244
Mileage: 201104 km
Date: 2014.01.10
Time: 20:20:02
Fault Frequency: 12
Reset counter: 210
Mileage: 201103 km
Date: 2014.01.10
Time: 07:40:59
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001230716
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 281C33125369B20FF1-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005027190
Coding: 000490
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0317
Revision: -----001 Serial number: VWZ6Z2Q7005543
Coding: 1700040004000A
Shop #: WSC 00081 790 00117
VCID: 46C09DAAF13D447FE3-8012
Reset counter: 73
Mileage: 190529 km
Date: 2013.08.26
Time: 07:45:38
00856 - Radio Antenna
007 - Short to Ground
Fault Status: 01100111
Reset counter: 142
Mileage: 179714 km
Date: 2013.04.26
Time: 07:52:04
Reset counter: 18
Mileage: 151271 km
Date: 2012.08.04
Time: 21:11:44
Reset counter: 142
Mileage: 179714 km
Date: 2013.04.26
Time: 07:52:04
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668217051
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 3228D17A65B5C8DF5F-8066
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Reset counter: 210
Mileage: 170325 km
Date: 2018.09.09
Time: 18:03:06
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 15
Mileage: 170325 km
Date: 2018.09.09
Time: 18:03:06
End----------(Elapsed Time: 01:19, VBatt start/end: 12.2V/12.1V)-----------
