Hello there,
I got an AUDI A8 from 2004 and after i remain without battery the car wouldn't start.
As i press the start button it doesn't do anything only the instrument dash turn on.
I attached here the code for the car.
Can somebody help me?
Thanks!
Monday,09,September,2019,21:44:35:32554
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
Workshop Code: 022 21992 002029
VIN: WAUZZZ4EX4N003873 License Plate:
Mileage: 320340km-199050mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1D 1E 25 28 34
36 37 38 42 46 47 4F 52 53 55 56 57 61 62 72 76 77
VIN: WAUZZZ4EX4N003873 Mileage: 320340km-199050miles
1D-Driver Ident. -- Status: OK 0000
Part No SW: 4E0 910 409 C HW: 4E0 907 409 B
Component: 4.0L 4V/TDI G000AGMª0020
Revision: <> Serial number: AUX3Z0C4315847
Coding: 0010773
VCID: 23061A6AE2AAD257A4-8076
19591 - Intake Manifold Runner Control
P3135 - 000 - Lower Stop not Reached
Torque: 23.4 Nm
Duty Cycle: 87.9 %
Duty Cycle: 20.7 %
Duty Cycle: 0.4 %
Temperature: 24.3°C
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Torque: 23.4 Nm
Duty Cycle: 0.4 %
Voltage: 11.63 V
Bin. Bits: 00101100
Temperature: 24.3°C
Bin. Bits: 10010000
Readiness: 0 0 X X X
Part No SW: 4E0 910 156 J HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0040
Revision: 00000001 Serial number: 0014301
Shop #: WSC 00579 210 82600
VCID: 291A084280860807EE-807C
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008557
Shop #: WSC 53061 000 00000
VCID: 210A1062F8B6C047B6-8074
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0C4315847
Coding: 0412672
Shop #: WSC 00006 210 89738
VCID: 58FC7D86EB6C418F81-800C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 729 H HW: 4E0 035 729 A
Component: Interfacebox H43 0770
Revision: 00000000 Serial number: 300F8037520451
Shop #: WSC 02313 785 00200
VCID: 2D12FC52B46E142702-8078
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 318EH037504621
Subsystem 3 - Serial number: ÿÿ22.05.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000017 Serial number: 00000000018075
Coding: 1071153
VCID: 5AF8678E9560539FB7-800E
01858 - Air Outlet Sensor; Right Center (G348)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 20
Mileage: 320340 km
Date: 2003.02.27
Time: 00:03:16
Reset counter: 20
Mileage: 320340 km
Date: 2003.02.27
Time: 00:03:16
00066 - Rear Right Footwell Heater (Z43)
Fault Frequency: 14
Reset counter: 20
Mileage: 320340 km
Date: 2003.02.27
Time: 00:03:18
Voltage: 12.00 V
014 - Defective
Fault Frequency: 14
Reset counter: 20
Mileage: 320340 km
Date: 2003.02.27
Time: 00:03:18
Address 09: Cent. Elect.
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L 4V/TDI G000AGSª0020
Coding: 0010773
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0940
Coding: 0431707
Shop #: WSC 21992 022 02029
VCID: 63865A6AA22A9257E4-8036
01217 - Side Airbag Igniter; Driver Side (N199)
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
011 - Open Circuit - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Coding: 0112041
Shop #: WSC 00006 210 89785
VCID: 65824472AC1EEC670A-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 A
Component: KOMBIINSTR. VDO H42 0070
Revision: D08 Serial number: AUDID3C5000315
Coding: 0000403
Shop #: WSC 00011 888 96745
VCID: 5CF461969F54ADAFA5-8008
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 815 069 D
Component: Heizgeraet H06 0290
Revision: 0000000F Serial number: 00000009001484
VCID: 59FA788290665887BE-800C
02251 - Heater Unit Locked
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0050
Revision: 07 Serial number: 110030352100B9
Coding: FCFFFFDE2B3504
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E2 905 218
Component: FPI_1 H04 0060
Revision: 06000104 Serial number: 02042003121124
VCID: 5EF06B9E8948BFBFCB-800A
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Serial number: AUZ5ZBC1015280
VCID: 197A3882D0E698877E-804C
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158
Component: KLIMA-STG. FOND 015 0200
Revision: 00000012 Serial number: 00000000007165
Coding: 0000000
VCID: 618A5062B8368047F6-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 00579 210 08335
VCID: 25020472EC9E2C67CA-8070
Fault Status: 11101000
Reset counter: 20
Mileage: 320340 km
Date: 2003.03.02
Time: 21:39:53
Component: Sitzmemory FS H06 0060
Coding: 4063342
Part No SW: 4E0 910 887 D HW: 4E0 919 887 C
Component: MNS ECE H41 0550
Revision: 00000000 Serial number: 305EI037535073
VCID: 2E10FB5EB9686F3F3B-807A
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000429200053
Coding: 0036032
VCID: 1D722C92C4CEE4A792-8048
02138 - Control Circuit for Front Right Interior Lights
Reset counter: 20
Mileage: 262136 km
Date: 2003.02.27
Time: 00:34:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM004 0080
Coding: 0028454
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040306020066
Coding: 0004345
Shop #: WSC 02311 785 00200
VCID: 271E0E7A96923E77F8-8072
Component: Heckdeckel P14H06 0070
Component: Neigungssensor H02 0020
01134 - Alarm Horn (H12)
Reset counter: 222
Mileage: 247477 km
Date: 2016.05.09
Time: 10:55:13
Reset counter: 222
Mileage: 247477 km
Date: 2016.05.09
Time: 10:55:13
00985 - Right Tail Light (M2)
Reset counter: 20
Mileage: 310186 km
Date: 2003.05.21
Time: 18:28:32
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 G HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0360
Revision: PROD_01 Serial number: 00000000057618
Coding: 0000013
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000063975
Coding: 0010101
VCID: 1E702B9EC9C8FFBF8B-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM004 0080
Coding: 0028454
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
Shop #: WSC 80093 222 183701
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 4
Voltage: 9.94 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
VCID: 62885F6EBD309B5FEF-8036
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304ED037526501
VCID: 200C1566F3BCC94FB9-8074
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 C HW: 4E0 919 146
Component: TV analog TUNER H12 0210
Revision: 00000037 Serial number: 00000000000000
Coding: 0001003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000001703956
Shop #: WSC 00186 785 00200
VCID: 1F0E169ACEC2F6B780-804A
Subsystem 1 - Part No: 000 915 105 DK
Component: von VA0 300910A1UQ
Coding: 303030393135313035444B56413033303039313041315551
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0090
Coding: 0028454
VCID: 5DF26C92844EA4A7D2-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028454
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0101008
VCID: 608C5566B33C894FF9-8034
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 D HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0650
Revision: 00000003 Serial number: T2AUDX0307H5RF
Coding: 0000004
End----(Elapsed Time: 02:32, VBatt start/end: 11.5V/11.6V. VIgn 11.6V)-----
Thanks!
