Results 1 to 3 of 3
Thread: Transporter T5 Facelift 2013. MFA Display not as good as Golf. Functions missing.
    Pontefract, United Kingdom
    Question Transporter T5 Facelift 2013. MFA Display not as good as Golf. Functions missing.
    Hi
    I've a 2013 Multivan Highline with lots of extras.
    But much of the MFA System is not available. Perhaps it is locked out in coding.
    I would like to see the Lights/Vision option.
    Any ideas how to get it showing???
    Below is my original delivery coding.
    Friday,11,October,2013,16:24:16:07396
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: WV2ZZZ7HZEH028455   License Plate: YT63OXV
    Mileage: 39   Repair Order:
    Chassis Type: 7H (6N0)
    Scan: 01 02 03 08 09 0D 10 15 17 18 19 25 3C 55 56 61 69 6E 78
    0D-Slide Door, Left -- Status: OK 0000
    6E-Ctrl Head Roof -- Status: OK 0000
    78-Slide Door, Right -- Status: OK 0000
    Address 01: Engine (J623-CFCA)       Labels: 03L-906-022-CFC.clb
       Part No SW: 03L 906 019 HL    HW: 03L 907 309 L
       Component: R4 2,0L EDC   H38 5617
       Revision: 22H38---    Serial number: 00000000000000
       Coding: 0125401A233401080000
       Shop #: WSC 02756 790 50316
       ASAM Dataset: EV_ECM20BTD01103L906019HL 003003
       ROD: EV_ECM20BTD01103L906019HL.rod
       VCID: 7CF73E8DF7F783FEC8B-8029
    Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
       Part No SW: 0BT 300 045 R    HW: 0BH 927 711 C
       Component: DSG DQ500-7F  H08 2245
       Revision: 00H08V01
       ROD: EV_TCMDQ500021.rod
       VCID: 4487866DCF873B3EF0B-8011
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0110
       Revision: 00H43001
       Coding: 108764AD09A6089D26A69076AA6390
       Shop #: WSC 02756 790 49152
       VCID: 3A7BF895B5437DCE9A7-806F
    Address 08: Auto HVAC (J255)       Labels: 7E5-907-040.clb
       Part No SW: 7E5 907 040 AC    HW: 7E5 907 040 AC
       Component: ClimatronicT5 H19 0407
       Revision: 00001004
       Coding: 0000000103
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: 69D977D98865065623D-803C
       Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
       Component: Heckbedienung  H10 0202
       Serial number: BHB-0010708130015269
    Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
       Part No SW: 7H0 937 090 B    HW: 7H0 937 090
       Component: BCM PQ25 Max4 H74 0712
       Revision: B9074001    Serial number: 0571 220132425
       Coding: A0F2793A0A612413932089716EAB8FD40290662F7E855841320003020000
       Shop #: WSC 02756 790 00000
       VCID: 2D51C3C9740DDA760F5-8078
       Component: RLS 120813 05  54  0403
       Coding: 02252E
       Subsystem 2 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-801.CLB
       Component: J386__TSG_FT  003 3313
       Coding: 450000
       Subsystem 3 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-802.CLB
       Component: J387__TSG_BT  003 3313
       Coding: 440000
       Subsystem 4 - Part No: 7E1 951 171
       Subsystem 5 - Part No: 1K0 951 605 C
       Subsystem 6 - Part No: 7E1 951 171
    Address 0D: Slide Door, Left        Labels: Redir Fail!
       Part No: 7E0 959 243 D
       Component: Schiebetuer-SG  407 0328
       VCID: 306FDABDA33FB79E243-8065
    Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
       Part No SW: 7E0 919 475 L    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0106
       Revision: --------    Serial number: 28261320000543
       Coding: 118102
       ASAM Dataset: EV_VW75XParkAssis8K 001003
       ROD: EV_VW75XParkAssis8K.rod
       VCID: 3B75FD91B27944C6811-806E
       Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
       Component: VW10Airbag00P H07 0013
       Revision: --------    Serial number: 003HM003MZV4
       Coding: 000000000000000000000000000000003050
       Shop #: WSC 02754 790 50316
       ROD: EV_AirbaVW10BPAVN750_VN35.rod
       VCID: 3663ECA5895B99AE7EF-8063
       Serial number: 3495ZRB400650GQ4OHUB
       Crash sensor for side airbag; passenger side:
       Serial number: 3505ZRB400650GQ4KPU7
       Part No SW: 7E0 920 980 J    HW: 7E0 920 980 J
       Component: KOMBI         H04 0509
       Coding: 460F01
       ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
       VCID: 326BD0B56533858E527-8067
       Part No: 7E0 815 071 C
       Component: J737__Standheizung  0605
       Revision: 00087000    Serial number: 09024900A00000
       Coding: 0020031
       Shop #: WSC 02757 790 00000
       VCID: 25413BE9ECFDE236C75-8070
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-19.lbl
       Part No SW: 6N0 909 901     HW: 7H0 937 090
       Component: GW-K-CAN TP20 H74 0712
       Revision: B9074001
       Coding: 042300
       VCID: F0EF9ABD23BF779EE43-80A5
       Component: IMMO          H04 0509
       ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
       VCID: EADB88D50D638D4EAA7-80BF
    Address 3C: Lane Change        Labels: None
       Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
       Component: J0769 SWA MasterH13 0120
       Revision: 00H13000    Serial number: 6PZ 009 014-07
       Coding: 0011161
       VCID: 2F6DD9C1BE01A8663D9-807A
       Subsystem 1 - Part No: 7E0 907 568 B
       Component: J0770 SWA Slave H10 0120
       Subsystem 2 - Serial number: 6PZ 009 014-27
       Subsystem 3 - Serial number: 5F28.06.1300H10000AMS14744
       Subsystem 4 - Serial number: S14744
    Address 55: Xenon Range (J431)       Labels: 6R0-907-357.clb
       Part No SW: 6R0 907 357     HW: 6R0 907 357
       Component: LWR-ECU       H02 0070
       Coding: 0286000001000000
       Shop #: WSC 02757 790 50316
       ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
       ROD: EV_HeadlRegulVWLWRPt.rod
       VCID: F7FDA1A14ED120A6259-80A2
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
       Component: Radio RCD310  004 0119
       Revision: 01000001    Serial number: VWZ1Z2N1885630
       Coding: 05000400040014
       Shop #: WSC 02754 790 00000
       VCID: 3561EBA99C5D92B6775-8060
    03138 - Input AUX IN
                        Fault Status: 01101011
                        Reset counter: 2
                        Mileage: 64 km
                        Date: 2001.14.18
                        Time: 16:11:14
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7H0 907 534     HW: 7H0 937 090
       Component: Batt.regelung H74 0712
       Coding: 330B1A73
       VCID: EBD58DD10A999446D11-80BE
       Subsystem 1 - Part No SW: 7E0 915 181 D    HW: 7E0 915 181 D
       Component: J367-BDM  H08 0182
    Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
       Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
       Component: Anhaenger     H10 0110
       Revision: 3B001001    Serial number: 00000194171236
       Coding: 410D000101000000
       VCID: 3169DFB96835BE962BD-8064
    Address 6E: Ctrl Head Roof (J702)       Labels: None
       Part No SW: 7E5 919 037 F    HW: 7E5 919 037 F
       Component: Dachdisplay   H16 0185
       Revision: 11100011    Serial number: 295793
       Coding: 000206
       VCID: 3467D6AD97278BBE40B-8061
    Address 78: Slide Door, Right        Labels: Redir Fail!
    Maybe you're expecting too much? It's a truck, not car. Also, the systems in the T5 are based on the Polo, not the Golf.
    Remember, VCDS can only tweak those things that the manufacturer made a provision to be tweaked.
    Magdeburg, Germany
    Check you car's manual, the T5/Polo simply doesn't support that. I am as disappointed by that as you - my 2014 T5 doesn't have that either.
