Results 1 to 9 of 9
Thread: How can i adapt an steering gear from an audi s3 to tt8s ???
    Mar 2017
    Peru
    i have an audi tt 8s that i have replace the steering gear with one from an audi s3, how can i adapt this.
    Chassis Type: FV-AU37 (8S0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 47 52 55 5F A9
    VIN: TRUZZZFV1F1003700   Mileage: 8063km-5010miles
    Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8S0 906 259     HW: 06K 907 425 B
       Revision: --H13---
       Coding: 0A1D00324406010B3002
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208S0906259 001003
       ROD: EV_ECM20TFS0208S0906259.rod
       VCID: 7AAEFB7D5C532CF784D-802E
    20277 - Terminal 15 Voltage
              P151B 00 [032] - Implausible
       Part No SW: 0D9 300 012 E    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4504
       Revision: 05853104    Serial number: TFK01408310100
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 186AC1F5421FDEE7129-804C
    21222 - Steering Column Control Module
              U0212 00 [011] - No Communications
                        Mileage: 6630 km
                        Date: 2017.12.18
                        Time: 10:50:05
       Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
       Component: ESC           H31 0504
       Revision: 00000000    Serial number: 62654000000153
       Coding: 32AA608D0A9915AC4098006442918306444C0650A8020042C16022
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
       ROD: EV_Brake1UDSContiMK100IPB_052.rod
       VCID: 40DA49957A0FB6278A9-8014
    0295 - Steering angle sensor
                        Reset counter: 244
                        Date: 2017.12.18
                        Time: 10:51:28
    8277 - Databus
              U1122 00 [009] - Implausible Message
              [FCAN: EPS_DSR_Status signal is invalid]
                        Reset counter: 244
                        Date: 2017.12.18
                        Time: 10:51:28
                        Reset counter: 244
                        Mileage: 6630 km
                        Date: 2017.12.18
                        Time: 10:51:37
    32951 - Control Module for Electronic Parking Brake
              C10E2 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 244
                        Date: 2017.12.18
                        Time: 10:51:28
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0346499341
       Coding: 000F0F1720
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77A8E2496F41319FFB3-8022
       Part No SW: 8S0 820 043     HW: 8S0 820 043
       Component: AC Automat    H05 0020
       Revision: 20008000    Serial number: 89300000003403
       Coding: 400040140011141000
       ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
       ROD: EV_AirCondiVAPrehAU33x.rod
       VCID: 6C82CD2526078247061-8038
       Serial number: 19C84C47000000000001
       Operating and display unit 2 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H06 0010
       Serial number: 00000000000000000683
       Operating and display unit 3 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H06 0010
       Operating and display unit 4 for air conditioning:
       Subsystem 4 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H06 0010
       Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0136
       Serial number: 01011426700426
       Coding: 04055C42C20106FD03044004B31807A80080000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 094C94B109B5376F9D7-805C
       Subsystem 1 - Part No SW: 8S1 955 119 A    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
       Component: 43x LL 140605  032 0371
       Serial number: 00000001406030704791
       Coding: 1BC7F7
       Serial number: 23251043
       Coding: 00005D
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 30 07 2014  00000638
       Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY142170415
       Serial number: 00000000000060629435
    197904 - Central Locking
              B140A 4B [008] - Over temperature
                        Reset counter: 167
                        Mileage: 7846 km
                        Date: 2019.08.17
                        Time: 08:11:03
    267030 - Siren / Alarm Horn for Anti-Theft Alarm System
              U1137 00 [008] - Implausible Message
              [Sirene-DWA->unplausible Botschaft]
                        Reset counter: 174
                        Time: 00:00:00
    787462 - Relay for Headlight Washer System
              B1262 15 [009] - Open or Short to Plus
                        Reset counter: 52
                        Mileage: 7128 km
                        Date: 2018.04.21
                        Time: 17:35:55
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39331426803488
       Coding: 0070051051
       VCID: 42DE439D7403A4379CD-8016
    13637426 - Databus
                        Reset counter: 242
                        Mileage: 6630 km
                        Date: 2017.12.17
                        Time: 16:26:00
       Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
       Component: AirbagVW20    009 0870
       Serial number: 003M7R002Z9J
       Coding: 88CCC000008000005C000000004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4DC460A1BD5D6B4F71F-8018
       Subsystem 1 - Part No SW: -----------    HW: 480 002 909 14
       Serial number: 357000000006A7B8F01U
       Subsystem 2 - Part No SW: -----------    HW: 480 002 909 14
       Serial number: 35800000000FA7B8F01/
       Subsystem 3 - Part No SW: -----------    HW: 480 012 708 14
       Component: SideSensor_Dr  004 0108
       Serial number: 351001A01544A6C35E53
       Subsystem 4 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_D  --- ----
       Serial number: -------------------$
       Front Sensor Passenger:
       Subsystem 5 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_P  --- ----
    20 Faults Found:
    9437201 - Igniter for Driver's Airbag
              B1000 11 [136] - Short to Ground
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:34:00
    9437713 - Igniter for Passenger's Airbag
              B1002 11 [137] - Short to Ground
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
    9438481 - Igniter for Driver head airbag
              B1005 11 [136] - Short to Ground
                        Fault Frequency: 7
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
    9438225 - Igniter for Front passenger's Head Curtain Airbag
              B1004 11 [136] - Short to Ground
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
    9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
              B1007 1A [137] - Resistance Too Low
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
    9438491 - Igniter for Driver head airbag
              B1005 1B [137] - Resistance Too High
                        Fault Frequency: 13
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 00:01:12
    9438235 - Igniter for Front passenger's Head Curtain Airbag
              B1004 1B [137] - Resistance Too High
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:59
    9442587 - Igniter for battery interrupt
              B1015 1B [137] - Resistance Too High
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
    9443093 - Driver's Side Airbag Crash Sensor
              B1017 15 [136] - Open or Short to Plus
                        Mileage: 6232 km
                        Date: 2015.08.22
                        Time: 00:00:34
    9451029 - Crash sensor side airbag; passenger side
              B1036 15 [136] - Open or Short to Plus
                        Mileage: 6232 km
                        Date: 2015.08.22
                        Time: 00:00:34
    9443857 - Driver's Front Airbag Crash Sensor
              B101A 11 [137] - Short to Ground
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 03:13:13
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 00:01:21
    9444117 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:46
    9682162 - Multiple collision brake
              B13BC F2 [008] - No function
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 00:01:25
              U1101 00 [008] - Active
              [ATP Wrong IKA]
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 00:52:45
    9466352 - Crash Data from Belt Tensioner Stored
              B1071 F0 [137] - Unknown Error Elaboration
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:38
    9447424 - Front crash data stored
              B1028 00 [137] - -
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:38
    16712515 - Internal Control Module Memory Check Sum Error
              B2000 00 [137] - -
              [Electronic Control Unit Malfunction]
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:40
       Part No SW: 8S0 907 129 R    HW: 8S0 907 129 R
       Component: Lenks. Modul  H06 0140
       Revision: --------    Serial number: 91335NJ300038
       Coding: 0018
       ASAM Dataset: EV_SMLSKLOMQB 019002
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 49CC54B14935776F5D7-801C
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8S0 920 790     HW: 8S0 920 790
       Component: FBenRDW       H32 0221
       Coding: 04050050298000080520A8809000800000000000
       ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
       ROD: EV_DashBoardBOSCHAU33X.rod
       VCID: 76B6EF4D684B4897E05-8022
       Part No SW: 8S0 907 468     HW: 8S0 907 468
       Component: GW MQB TT3    012 0184
       Revision: --------    Serial number: 06091410801350
       Coding: 030100042F025A004B0002683C0000000000000000000000000000000001
       ASAM Dataset: EV_GatewContiAU33X 011002
       ROD: EV_GatewContiAU33X_011.rod
       VCID: 7DA4F0614D7D1BCFA1F-8028
       Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
       Component: J453 MFL  H06 0001
       Serial number: 20140821124851 RD001
       Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
       Serial number: 0326444303
       Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7742
       Serial number: HA1-00010.08.14
       Coding: 0101
       VCID: 45D45881652D930FB9F-8010
       Serial number: 14000140131006
       Coding: 0900000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BCDC5101256FAF357-8024
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 20091402090270
       Coding: 001F46225C00040100001402
       Coding: 0002
       Shop #: WSC 06314 790 00021
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 3534284135CD038F29F-8060
    15873 - Steering angle sensor
                        Reset counter: 244
                        Mileage: 6630 km
                        Date: 2017.12.18
                        Time: 10:37:42
                        Motor status: 00
                        Supply voltage: 12.50 V
                        Temperature: 37.0 °C
                        KFC: 3E
                        KFA: 00 01
                        Environmental conditions: 5B
                        uioUdNotFilt_xdu16: 12.63 V
                        uAdSensI_SwitchedKl30_xdu16: 12.64 V
       Part No SW: 8S0 035 465     HW: 8S0 035 465
       Component: MIB2_amp_P_TT H06 0170
       Revision: 00000001    Serial number: AUZ8ZAEH7001BV.
       Coding: 0133040000AA2A2AAA0000010000
       ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
       ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
       VCID: 72BED35D042354B7CCD-8026
    0605 - Double Bass Speaker 2; Front Right
              B1348 13 [008] - Open Circuit
                        Fault Frequency: 9
                        Reset counter: 188
                        Time: 00:00:00
                        Voltage terminal 30: 12.4 V
    0600 - Double Bass Speaker 1; Front Right
              B1346 13 [008] - Open Circuit
                        Reset counter: 188
                        Mileage: 7061 km
                        Date: 2018.03.30
                        Time: 22:05:25
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 21091406071734
       Coding: 001F46225E00040100001402
       VCID: 41DC4C917105BF2F857-8014
       Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0090
       Coding: 03EA001E2B200200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005008
       VCID: 333016593BB91DBF07B-8066
       Coding: E01800
       Coding: E01800
       Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 S002
       Coding: E01800
       Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 S002
       Coding: E01800
    13705992 - Databus
              U1123 00 [137] - Received Error Message
              [Empfangener Fehlerwert im Signal LWI_Lenkradwinkel: CAN Message LWI_01]
                        Reset counter: 244
                        Mileage: 6630 km
                        Date: 2017.12.18
                        Time: 10:50:34
    5276209 - Power Output Module for Right Headlamp
              C1082 31 [008] - No Signal
                        Reset counter: 154
                        Mileage: 7712 km
                        Date: 2019.07.30
                        Time: 11:50:41
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8S0 035 028     HW: 8S0 035 028
       Component: MU-H-N-ER     H33 0117
       Serial number: A262I0E7507099
       Coding: 013304000000000011220002001800002F0000E0000000001A
       VCID: 6D84C0211D1D8B4F11F-8038
       Multimedia Operating Unit:
       Subsystem 1 - Part No SW: 8S0 919 614 A    HW: 8S0 919 614 A
       Component: ControlUnit_H  H21 0124
       Serial number: C1000015081400010077
       Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote  --- 1010
       Part No SW: 8S0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0002
       Serial number: 140904203546
    End----(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    Tweaks and Retrofits.............post a complete auto-scan
  3. Likes PetrolDave, nafg liked this post
    Quote Originally Posted by nafg View Post
    Impossible to answer until you post a full unedited VCDS Auto-Scan
  5. Likes nafg liked this post
  6. #4
    Moved to Retrofits.
  7. Likes nafg liked this post
  8. #5
    Mar 2017
    Peru
    any advice ?
  9. #6
    any advice ?
    Still waiting on the FULL Auto-Scan, what you have posted is an edited version
  10. #7
    Jan 2018
    Cheshire UK
    My question is: but why? Why not get the correct steering for your car in the first place?
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  11. Likes Uwe liked this post
  12. #8
    Mar 2017
    Peru
    here its the FULL Auto-Scan
    Thursday,12,September,2019,10:00:10:51026
    VIN: TRUZZZFV1F1003700   License Plate:
       Revision: --H13---
                        Mileage: 6630 km
                        Date: 2017.12.18
                        Time: 10:50:05
                        Reset counter: 244
                        Date: 2017.12.18
                        Time: 10:51:28
    8277 - Databus
                        Reset counter: 244
                        Date: 2017.12.18
                        Time: 10:51:28
                        Reset counter: 244
                        Mileage: 6630 km
                        Date: 2017.12.18
                        Time: 10:51:37
                        Reset counter: 244
                        Date: 2017.12.18
                        Time: 10:51:28
       Coding: 000F0F1720
       Coding: 1BC7F7
       Coding: 00005D
       Light switch:
                        Reset counter: 167
                        Mileage: 7846 km
                        Date: 2019.08.17
                        Time: 08:11:03
                        Reset counter: 174
                        Time: 00:00:00
                        Reset counter: 52
                        Mileage: 7128 km
                        Date: 2018.04.21
                        Time: 17:35:55
       Coding: 0070051051
    13637426 - Databus
                        Reset counter: 242
                        Mileage: 6630 km
                        Date: 2017.12.17
                        Time: 16:26:00
    20 Faults Found:
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:34:00
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Fault Frequency: 7
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Fault Frequency: 13
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 00:01:12
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:59
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:45
                        Mileage: 6232 km
                        Date: 2015.08.22
                        Time: 00:00:34
                        Mileage: 6232 km
                        Date: 2015.08.22
                        Time: 00:00:34
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 03:13:13
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 00:01:21
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:46
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 00:01:25
              [ATP Wrong IKA]
                        Mileage: 6232 km
                        Date: 2015.07.31
                        Time: 00:52:45
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:38
              B1028 00 [137] - -
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:38
              B2000 00 [137] - -
                        Mileage: 6234 km
                        Date: 2015.07.19
                        Time: 04:32:40
       Coding: 0018
       Coding: 0101
       Coding: 0002
                        Reset counter: 244
                        Mileage: 6630 km
                        Date: 2017.12.18
                        Time: 10:37:42
                        Motor status: 00
                        KFC: 3E
                        KFA: 00 01
              B1348 13 [009] - Open Circuit
                        Fault Frequency: 10
                        Reset counter: 149
                        Time: 00:00:00
              B1346 13 [009] - Open Circuit
                        Reset counter: 149
                        Mileage: 7061 km
                        Date: 2018.03.30
                        Time: 22:05:25
       Coding: E01800
       Coding: E01800
       Coding: E01800
       Coding: E01800
    13705992 - Databus
                        Reset counter: 244
                        Mileage: 6630 km
                        Date: 2017.12.18
                        Time: 10:50:34
                        Reset counter: 154
                        Mileage: 7712 km
                        Date: 2019.07.30
                        Time: 11:50:41
    in Select Chassis opción there is not my chassis 8S
  13. #9
    Jan 2018
    Cheshire UK
    The car has obviously been in a collision so you need to get the other faults cleared as well; mainly the steering angle sensor. Get that calibrated. Easy enough to do!
    What module are you in when looking for chassis 8S?
    Was the original steering rack too damaged to remove its attached ecu?
    A6 BiTdi Avant MTM
  14. Likes Uwe liked this post
