Results 1 to 7 of 7
Thread: 2003 audi a6 transmission limp mode help!!!
    Sep 2019
    Maine, USA
    Monday,09,September,2019,11:31:39:57287
    VIN: WAULT64B83N010248   License Plate:
              75 76 77
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 E    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0004
       Coding: 0016752
       Shop #: WSC 08376 444 101330
       VCID: 372B2B69C35078CF3B3-5160
    16815 - Warm Up Catalyst; Bank 2
                P0431 - 001 - Efficiency Below Threshold - MIL ON
    18032 - MIL Request Signal Active (Check TCM for errors too!)
                P1624 - 008 -
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 4B0 927 156 FF
       Component: AG5 01V 3.0l5V  USA 1213
       Coding: 0001002
       Shop #: WSC 01115 444 59106
       VCID: 70B9D075E6BEEFF73A9-5160
    18164 - Tiptronic Recognition Switch (F189)
                P1756 - 003 - Open or Short to Plus
    17090 - Transmission Range Sensor (F125)
                P0706 - 003 - Implausible Signal - MIL ON
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 R
       Component: ABS/ESP allrad      2330
       Coding: 06497
       VCID: 30391075233EAFF77A9-51F2
    01119 - Gear Recognition Signal
                35-10 - - - Intermittent
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AD
       Component: A6-Klimavollautomat 0105
       Coding: 00110
       Shop #: WSC 02325
       VCID: 5CE194C51F067B97F61-2586
                57-00 - Electric Circuit Failure
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 Q
       Component: Airbag 8.4EP        2001
       Coding: 0000607
       Shop #: WSC 02325 785 00200
       VCID: 3E253E4DEC6A4987F85-5184
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01002
       Shop #: WSC 02325
       VCID: 2F3B13093E30B00F633-51F2
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 N
       Component: KOMBI+WEGFAHRS. VDO D11
       Coding: 02262
       Shop #: WSC 08376
       VCID: 313F15712834A6FF757-5184
       WAULT64B83N010248     AUZ7Z0B2160242
                29-10 - Short to Ground - Intermittent
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D37
       Coding: 15885
       Shop #: WSC 02325
       VCID: 33331F79D21894EF07B-4F50
    01560 - Passenger Door
    01561 - Rear left door
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0102
       Coding: 00001
       VCID: 2C0104050F26CB17461-4B1E
       Part No: 4Z7 907 357
       Component: dynamische LWR       D07
       Coding: 00050
       Shop #: WSC 02325
       VCID: 04518CA5C736E357EE1-4B5C
       Part No: 4B0 035 195 L
       Component: symphony II NP2    0051
       Coding: 00205
       Shop #: WSC 08376
       VCID: 290FFD1100D4DE3FBD7-4E62
    End----(Elapsed Time: 04:59, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    changed from donor car tcm,tiptronic,range selector, no evidence of water,upon shifting to d 0 voltage terminal 15
    any advice!!!
    Hello and welcome to the VCDS forum OP.
    Is TCU under water or corroded from water ingress?
    F125 can fail on the trans and is common buy not as common as water issue & especially when combined with F189 unless a flood car or you spilled you beverage into the shifter?
    If you need a TCU after inspecting this please let me know.
    https://www.ebay.com/itm/331956006689
    Did you JPPSG?
    Also there is a firmware update for the Engine ECU I believe & specifically for the CAT thresholds according to TSB's if you care to have a look at ERWIN via RTFB?
    Sep 2019
    Maine, USA
    Read notes below swapped all switches and tcm still limp mode goes to zero voltage terminal 15 upon shifting to drive
    Didn't see that note.......
    Did you load light all tracks from end to end and isolated, what is condition of ignition switch or terminal relays?
    You changed the F125 on the actual & attached to transmission and is it set correctly for gear offset to mechanical's whether be cable or the VB?
    Sep 2019
    Maine, USA
    Opened harness at tcm someone previously spliced in a different connector that was incorrect wrong color wires and missing my 02 parts car is correct will splice in today.
  6. Likes Jack@European_Parts, Uwe liked this post
    Never fails!
    Oh no FOD again.........?
    Sep 2019
    Maine, USA
    Problem solved spliced in correct tcm plug!!!
