Audi TT battery coding
Bhel
Adelaide, Australia
C?ID=295254
I am trying to code my new battery and it is quite different to what is in the YouTube clip as it only allows me to insert the 18 digit number . I am using the VAO code only The Ross tech programme has the "0" in the VA0 as a number in the pop up screen but the "O" in the VAO printed on the battery is an alphabet . The question is - do I use the "O" which is on the battery or 0 (number) which pops up in the Ross Tech programme . It was mentioned that the O and 0 should not be interchanged .
I hope someone can assist as my new battery went flat within a month. Thank you
Bhel
Adelaide, Australia
C?ID=295254
Friday,13,September,2019,17:00:00:31727
VIN: TRUZZZ8J0C1900352   License Plate:
Chassis Type: 8J (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 2E 37 42 44 46 47 52 55
          56 57 61 6C 77
VIN: TRUZZZ8J0C1900352   Mileage: 33020km-20517miles
57-TV Tuner -- Status: Not registered 0011
6C-Back-up Cam. -- Status: Cannot be reached 1100
Address 01: Engine (CEP)       Labels:. 07K-907-404-CEP.clb
   Part No SW: 8J0 907 404 M    HW: 8J0 907 404 M
   Component: 2.5l R5/4V TFSI     0030
   Revision: F7H05---    Serial number: AUX7Z0K5FNS0K7
   Coding: 0113000C180F0160
   Shop #: WSC 30809 000 1048576
   VCID: 37282155734A3A4F3B3-8062
Readiness: 0010 0001
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 910 517 A    HW: 8J0 614 517 F
   Component: ESP MK60E1          0020
   Revision: 00H60001
   Coding: 0618391
   Shop #: WSC 01236 785 00200
   VCID: 2A0E0821B0F897A7B4D-807E
   Part No SW: 8J0 820 043 BA    HW: 8J0 820 043 BA
   Component: J255  Klima 1 Zone  0110
   Revision: 00H09006    Serial number: 00000001191520
   Coding: 1573957
   VCID: 6696BC11646073C7505-8032
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 R    HW: 8P0 907 063 R
   Component: BCM PQ35  H   110 0653
   Revision: 00110 AD
   Coding: 4E000B2FA8051A202070C0E00180084C50F658AA3020D928DC000E440045
   Shop #: WSC 01236 758 00200
   VCID: 43D045853B9266EF97B-8016
   Subsystem 1 - Part No SW: 8J2 955 119 A    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H09 0070
   Coding: 00FD10
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 02492C
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Fault Status: 00101110
                    Reset counter: 110
                    Mileage: 32955 km
                    Date: 2019.09.13
                    Time: 08:41:15
                        Term 15 Off
                    Voltage: 12.50 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 M    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0140
   Revision: 11001001    Serial number: 36891118603611
   Coding: 00000B
   VCID: 48CA52A902B445B7429-801C
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376 E    HW: 8J0 907 376 E
   Component: J250 Raddaempfung   0110
   Revision: --H22---    Serial number: 190DPH 1125262
   Coding: 0000072
   VCID: 313C1F4D9D2EE47F757-8064
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -r Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K005CUSI
   Coding: 0011634
   VCID: 79ACE76D05DEEC3F8D7-802C
   Subsystem 1 - Serial number: 6332DRB40DBDCBA7H
   Subsystem 2 - Serial number: 6342DRB40DBE1195
   Subsystem 3 - Serial number: 63747RB40642D63EV
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004041
   VCID: 46D65C9104A053C7B05-8012
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 931 B    HW: 8J0 920 931 B
   Component: KOMBIINSTR. VDO H02 0650
   Revision: D0H02002    Serial number: 2245K002000274
   Coding: 0069728
   Shop #: WSC 17229 002 1048576
   VCID: 2C020E39BA0C8997461-8078
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 300611F2002920
   Coding: 354101
   VCID: 372821557F4A3A4F3B3-8062
                    Mileage: 32955 km
                    Date: 2019.09.08
                    Time: 22:54:56
                    Reset counter: 68
                    Mileage: 32955 km
                    Date: 2019.09.08
                    Time: 22:55:00
   Part No SW: 2K0 907 554 D    HW: 2K0 907 554 D
   Component: Haldex 4Motion      5010
   Coding: 0000005
   Shop #: WSC 54872 000 1048576
   VCID: 2F3819358B1AF28F633-807A
   Revision: D0H02002    Serial number: AUX7Z0K5FNS0K7
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8P0 035 785     HW: 8P0 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020202
   VCID: 74B2D6592EBC9157DE1-8020
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8J0 035 193 D    HW: 8J0 035 193 D
   Component: RNS-E PU EU     H06 0220
   Revision: 0000012S    Serial number: AUZBZ7LD403236
   Coding: 0619725
   VCID: 2B000D25BF028EAF4FB-807E
                    Reset counter: 68
                    Mileage: 32955 km
                    Date: 2019.09.08
                    Time: 22:55:55
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8J8 959 801 J    HW: 8J8 959 801 J
   Component: Tuer-SG         004 0102
   Coding: 0000533
   VCID: 44D24699329C61D7AE1-8010
   Part No: 8J0 909 144 M
   Component: EPS_ZFLS Kl. 239    3201
   Revision: 00H20000
   VCID: 3A2E386140582727C4D-806E
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
   Component: J525 Amp High   H04 0160
   Revision: PROD_01     Serial number: 00000000028564
   Coding: 0246317
   VCID: 2514FB1DD9E6B8DF99F-8070
   Part No SW: 8J8 959 802 J    HW: 8J8 959 802 J
   Coding: 0000532
   VCID: 45D45B9D39A658DFB9F-8010
   Part No: 8P0 907 357 M
   Coding: 0000011
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0619725
                    Reset counter: 68
                    Mileage: 32955 km
                    Date: 2019.09.08
                    Time: 22:55:55
Address 57: TV Tuner
   Component: Batt.regelung H43 1620
   Coding: F322015A
   VCID: 71BCDF4D51AEA47F357-8024
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650824323
Address 6C: Back-up Cam.
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005417082
   Coding: 0011422
   VCID: 35342B5D6946C85F29F-8060
End----------(Elapsed Time: 01:30, VBatt start/end: 12.6V/12.6V)-----------
What type of battery is it that you've installed? In this battery regulation module (a fairly unusual one), there's a bit field in Byte 2 of the long coding that specifies the battery type.
As for the battery manufacturer code, I would use whatever is printed on the battery, assuming the module will take that. If it refuses to accept a '0' or an 'O', then I'd try the other one.
PS: Moving from Forum Support & Feedback to Car Repair Support.
