Results 1 to 4 of 4
Thread: How to enable Auto-dimming Mirror on USA Arteon SE?
    Sep 2019
    A few of us over at VW Vortex have been trying to enable the drivers side auto-dimming mirror, which is not standard on the SE model.
    This is what we have discovered:
    a. the actual dimming mirror IS fitted
    b. The wiring to the mirror is in place and the colors correspond to the dimming function Y20 in the VW wiring diagram
    c. One person has an SE model where the dimming function does work.
    d. Comparing the long coding of address 42, byte 9 we found that:
    00345B42800020000000000 is the long coding without auto-dimming enabled (my car)
    00345B428000020000010000 is the long coding with the auto-dimming feature working.
    This corresponds to byte 9 bit 0=1 "electro chromatic mirror active"
    When I enable this bit on my car, it does not cause the mirror glass to darken.
    When I use VCDS to run an output test IDE10164-automatic day/night exterior mirror - I get the status "not running", however, when I use VCDS to look at the advanced measuring values, I see
    automatic day/night mirror-status - active
    automatic day/night mirror- dimming 30%
    I check the mirror glass and there is no sign of dimming. I block off the interior mirror sensor and the interior mirror goes black, but nothing on the drivers side.
    So it appears that there is an additional step or steps needed?
    Does anyone know what are the dependencies between modules? If the door mirrors are using sensor information from the interior mirror, what coding or adaption needs to be made/checked.
    Here is a full scan of my vehicle with byte 9 bit 1 =1.
    Any help would be most appreciated or clues for us to help solve this apparent mystery
    Sunday,08,September,2019,14:47:52:42457
    VIN: WVWBR7AN5KE000387   License Plate:
    Mileage: 6010km-3734mi   Repair Order: mirrorautodim question
    Chassis Type: AN-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 13 14 15 17 19 22 2B 3C 42 44 4B 52 5F 65
              6C 6D BB BC CF D6 D7
    VIN: WVWBR7AN5KE000387   Mileage: 6010km-3734miles
    Address 01: Engine (J623-DLRB)       Labels: None
       Part No SW: 3G0 906 259 G    HW: 06K 907 425 J
       Component: R4 2.0l TFSI  H13 0004
       Revision: --H13---
       Coding: 092A00122426010E3004
       Shop #: WSC 05311 115 00175
       ASAM Dataset: EV_ECM20TFS0203G0906259G 001006
       ROD: EV_ECM20TFS0203G0906259G.rod
       VCID: 303911285AA90E177A9-8064
    Readiness: 1110 0101
       Part No SW: 09G 927 158 L    HW: 09G 927 158
       Component: AISIN AQ8     206 3504
       Coding: 0000000100000000000000000000000000000000
       Shop #: WSC 05311 000 00030
       ROD: EV_TCMAQ450031_VW48.rod
       VCID: 3C21351886E1FA77D61-8068
       Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
       Component: ESC           H25 0424
       Revision: 00000000    Serial number: 60338000000026
       Coding: 0DFA6B9A5420236CC57A0308A0CA69B0D62AC4A3C0059674104150884289420B00000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       VCID: 76B5E730F84D6027E05-8022
       Part No SW: 3Q0 959 435 J    HW: 3Q0 959 435 J
       Component: VWKESSYMQB    037 1104
       Revision: 00037000    Serial number: 0477916684
       Coding: 132C0C0723
       Shop #: WSC 05311 115 00311
       ASAM Dataset: EV_KessyHellaMQBAB 004043
       VCID: 41DF44ECE103979F857-8014
       Part No SW: 5G0 907 044 EG    HW: 5G0 907 044 EG
       Component: Climatronic   H04 2009
       Revision: 00001K10
       Coding: 1402000420011000101500009210180A
       ASAM Dataset: EV_ACClimaBHBVW37X 006148
       VCID: 70B9D1289A294E173A9-8024
       Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
       Component: BCM PQ37BOSCH 036 0265
       Revision: --------    Serial number: 865827041801ME
       ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7BA3F604C36F3D4F9FB-802E
       Component: WWS    180510  042 0607
       Serial number:         180525161633
       Component: RLHS  052 0107
       Serial number: S2Y18M06D18H23M51S23
       Coding: 01E8DD
       Light switch:
       Subsystem 3 - Part No SW: 3G0 941 633 N    HW: 3G0 941 633 N
       Serial number: 27 07 2018  10000644
       Steering Column Switch:
       Subsystem 5 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0160
       Serial number: 0100150620180C100825
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Component: ACC BOSCH MQB H11 0682
       Coding: 3204009111FFC728949C810400401600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       ROD: EV_ACCBOSCHVW416_002_VW48.rod
       VCID: 44D14DF8FE1182B7AE1-8010
       Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0130
       Serial number: 30051841351007
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 392F2C0C89D3CF5FCD7-806C
       Part No SW: 3Q0 959 655 CK    HW: 3Q0 959 655 CK
       Component: Airbag VW21   006 0711
       Revision: --------    Serial number: 003WTP789TT%
       Coding: 9DCCFCC00C0000005000001AC20840000065
       Shop #: WSC 05311 000 08193
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 094F9CCC99B31FDF9D7-805C
       Occupant Detection:
       Component: Occ.Detection  H13 0022
       Serial number: IBH0000J180008ZPNZ0S
       Coding: 303030
       Subsystem 2 - Part No SW: -----------    HW: 454 000 406 18
       Serial number: 35700000000442848F2J
       Subsystem 3 - Part No SW: -----------    HW: 454 000 406 18
       Serial number: 3580000000059865303C
       Subsystem 4 - Part No SW: -----------    HW: 454 800 406 18
       Serial number: 351005BCDF914000000-
       Subsystem 5 - Part No SW: -----------    HW: 454 800 306 18
       Serial number: 352002B4805150000003
       Subsystem 6 - Part No SW: -----------    HW: 454 802 205 18
       Serial number: 355003179B1140000007
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 454 802 205 18
       Component: FrontSensor_P  304 0149
       Serial number: 356003887B914000000M
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 454 801 704 18
       Component: PedP_Sensor_D  30D 014A
       Serial number: 2280036ED0714000000H
       Subsystem 9 - Part No SW: -----------    HW: 454 801 704 18
       Component: PedP_Sensor_P  30D 014A
       Serial number: 229007ECE0614000000S
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 454 801 704 18
       Component: PedP_Sensor_C  30D 014A
       Serial number: 23000A2EE0714000000E
       Subsystem 11 - Part No SW: -----------    HW: 454 002 605 18
       Component: PedP_Sens_D_2  008 0887
       Serial number: I0M00000000DD4797F2O
       Subsystem 12 - Part No SW: -----------    HW: 454 002 605 18
       Component: PedP_Sens_P_2  008 0887
       Serial number: I0N00000000621E8BF2E
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 3G5 920 850 A    HW: 3G5 920 850 A
       Component: KOMBI         311 2500
       Coding: 03B4109DBA88CF0502802B0D10000000A0000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009065
       VCID: 2809F948627946D7A29-807C
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   439 4344
       Revision: --------    Serial number: 0007954250
       Coding: 030300047F085900FB0002489C0F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF.rod
       VCID: 3D27381C9DFBF37FE1F-8068
       Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0052
       Serial number: 39170002880120117526
       Coding: 28FFFF
       Serial number: 75886000001806160E79
       Analog clock:
       Component: Analoguhr  111 1004
       Component: Haldex4Motion H52 7084
       Serial number: HA1-00023.05.18
       Coding: 0301
       VCID: 4CC165D8D6414AF7661-8018
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 18000196761016
       Coding: 0800000000000000
       Shop #: WSC 05311 115 00065
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 33331E24ABBF350F07B-8066
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
       Component: MRR1Rear      H23 0530
       Revision: --------
       Coding: 040000
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS001 0287
       Serial number: YE007QKG1825C
       Coding: 00345B428000020000010000
    Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
       Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
       Component: MQB_VWBS_GEN2 212 2211
       Serial number: 818028 00
       Coding: 0100001000C00110
       Shop #: WSC 00015 115 00311
       ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
       ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
       VCID: 2B030644738F6DCF4FB-807E
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0342
       Serial number: 24041810523638
       Coding: 000000070900045206210100030000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002004
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 3537203CA5CB2B3F29F-8060
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS001 0287
       Serial number: YE007RD525388
       Coding: 003453428000020000010000
       VCID: 43D34EE4FB1F858F97B-8016
       Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
       Component: MU-S-S-US     722 0870
       Coding: 02840300FF00000051220001001808001F0500C40120050002
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2E050F50409D18E7685-807A
       Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
       Component: ABT_Std-2  H52 8130
       Serial number: VWZ6ZJV1601841
              B11CF 53 [009] - Deactivated
                        Reset counter: 213
                        Mileage: 6010 km
                        Date: 2019.09.06
                        Time: 14:47:29
                        Voltage terminal 30: 12.2 V
                        SDARS_tuner_status_2-Antenna current: 113 mA
                        SDARS_tuner_status_2-Reception quality: weak_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
       Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0009
       Serial number: 40000000167307
       ROD: EV_RDKBERU30_006_VW48.rod
       VCID: 34311D38AEB132371E1-8060
       Coding: 0184030160002017300040
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: 31972635200000
       Coding: 0B28
       Shop #: WSC 17873 123 50804
       VCID: 42DD4BE0E4058C879CD-8016
       Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
       Component: TSG HFS002 0187
       Serial number: YE007RDD0365D
       Coding: 000051420100020000000000
       VCID: 4EC56FD0205D78E7085-801A
       Component: TSG HBFS002 0187
       Serial number: YE007RDD03967
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 G    HW: 3Q0 907 590
       Revision: --------
       Coding: 040000
       Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
       Component: LED1L         H06 0005
       ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
       VCID: 7EA5FF10D07D2867B85-802A
       Component: LED1R         H06 0005
    End----------(Elapsed Time: 01:57, VBatt start/end: 12.3V/12.3V)-----------
  2. Likes Uwe liked this post
  3. #2
    Feb 2018
    Czech Republic
    As you almost suggested, I would check coding of RLS and maybe BCM and also filter adaptations(incl.42) for "mirror", etc. . If you are sure all is connected right (sound strange "block off interior mirros sensor and the interior mirror goes black" ...), it seems to be really the matter of "setting".
    Dec 2016
    DE
    There are a few things to consider when working with exterior mirror dimming.
    I hope everything applies to your Arteon as well, the statements come from my O3RS, which has losely the same hardware installed.
    • mirror dimming is normally controlled by the BCM (address 09)
    • the only sensor adjusting the dimming is the one on the interior mirror
    • the feature only seems to work when headlights are on...
    • ...and only when the rotary light switch is set to AUTO
    Since the measurement values you posted (IDE10164-MAS01632 and IDE10164-MAS03691) look good I would not see a reason why it would not work. However I am not sure, how you tested it. Where all requirements stated above fulfilled? Did the other mirrors dim, while the driver mirror did not?
  5. Likes Uwe liked this post
  6. #4
    Sep 2019
    Thanks to both for the responses.
    I think I understand the networking parts of it. The mirror sensor, and other "simple" sensors are on the low-speed LIN bus and are slaved to J519 Electronics control module. This module is likely responsible for multiplexing data from other sensors to form a CAN message for the things like the electronic door control module and changing the transmission rate to 500kbit/sec. The door module is on the Convenience/Comfort Higher speed CAN bus, which is reached via the CAN Gateway (J533).
    So the next check is to see what sensor/mirror adaption values are in J519 to allow the CAN message to be generated (with dimming sensor data included) and then to check that the CAN gateway passes it also (it may be transparent to such a low level sensor). Not sure why the output test did not work, but it will depend upon where the message was created... I think.
    So more homework on the J519 adaptions list. Any clues... always... will be appreciated. Let me know if my understanding is incorrect. I dug around various SSP and VW training materials.
