Results 1 to 3 of 3
Thread: Audi 4F AllroadTrailer Hitch Retrofitting - Westfaila Electronic Module Coding
    Mar 2014
    Australia
    Hi All,
    Hopes everyone had have a great & wonderful New Year celebrations.
    I've justing finished retrofitting a westfaila trailer hitch & made several attemptes to configure module as per retrofitting configuration list.
    I don't seem to be able to config module with correct codes, Can anyone help please?
    Steps I taken below
    Register the newly added Trailer Control Module (J345/#69) to Gateway module (J533/#19)
    [69] Trailer Module (J345/#69) config to 0300000000000000
    [01] Engine Control Module (J623/#01) No coding required as it uses 7 digits coding - Please correct me if i missed understood
    [03] ABS Brake Electronics (J104/#03) Subtract 0016384 from 0016776? New code 0000392
    [34] Level Control (J197/#34) 0000210 - What would be the correct code?
    [76] Parking Aid (J446/#76) 0221416 - What would be the correct code?
    [6C] Rear View Camera (J772/#6C) 1020305 - What would be the correct code?
    Saturday,03,January,2015,15:57:46:50635
    VCDS Version: 14.10.0.0
    Data version: 20141022
    VIN: WAUZZZ4FX8N0xxxxx   License Plate:
    Mileage: 72110km-44807mi   Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 34 37 42 46 47 4F 52
              53 55 56 61 62 67 69 6C 72 76 77
       Mileage: 72110km-44807miles
    67-Voice Control -- Status: Cannot be reached 1100
       Part No SW: 4F9 910 401 L    HW: 4F0 907 401 C
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H05---    Serial number:
       Coding: 0011372
       Shop #: WSC 02334 758 00200
       VCID: 2E5920EEB9D28E51CD7-807B
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 002 -
                        Fault Status: 01100010
                        Fault Frequency: 14
                        Mileage: 72110 km
                        Date: 2007.05.16
                        Time: 12:18:38
                        Duty Cycle: 1.0 %
                        Voltage: 11.78 V
                        Bin. Bits: 00101000
                        Torque: 109.2 Nm
                        Bin. Bits: 00000100
       Part No SW: 4F5 910 156 C    HW: 09L 927 156 C
       Component: AG6 09L 3,0 TDI RdW 0020
       Revision: --H04---    Serial number:        4378581
       Shop #: WSC 02325 758 00200
       VCID: 2855D6F69B36D06107B-807D
       Part No SW: 4F0 910 517 AB    HW: 4F0 614 517 R
       Component: ESP 8.0 quattro H05 0040
       Coding: 0016776
       VCID: 64CD82C6A79E7401EB3-8031
    18055 - Check Coding of ECUs on Powertrain Data Bus
                P1647 - 000 -
                        Reset counter: 100
                        Mileage: 72110 km
                        Date: 2007.05.16
                        Time: 12:41:12
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0014
                        Hex Value: 0x07A8
                        Hex Value: 0x00FF
    01517 - Control Module for Trailer/Towing Sensor (J345)
                        Reset counter: 100
                        Mileage: 72110 km
                        Date: 2007.05.16
                        Time: 12:41:12
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0014
                        Hex Value: 0x08A8
                        Hex Value: 0x00FF
                        Reset counter: 100
                        Mileage: 72110 km
                        Date: 2007.05.16
                        Time: 12:41:43
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0024
                        Hex Value: 0x01A8
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H31 0230
       Revision: 09010701    Serial number: 10601500899793
       Coding: 0000147
       Shop #: WSC 02323 758 00200
       VCID: 63CF81DAA2907339129-8036
       Subsystem 1 - Part No: 4F0 910 131 A
       Subsystem 2 - Part No: 4F0 910 220
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 732 B    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4220
       Revision: 00000000    Serial number: 351J$077552688
       Coding: 0003002
       Shop #: WSC 02335 785 00200
       VCID: 2241C4DEFD0A3A3159F-8077
       Subsystem 2 - Serial number: 00000001438112
       Subsystem 3 - Serial number: 0105.11.090000000100010101ˇ
       Subsystem 4 - Serial number: 010101ˇ
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043 A    HW: 4F2 820 043 Q
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000052    Serial number: 00000030290851
       Coding: 0001366
       VCID: 1C3DFA26DF6E0CC1933-8049
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H18 0250
       Coding: 0003121
       VCID: 31633B92A8EC91A9D05-8064
       Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0190
       Coding: 00064784
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0100
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1 (R192)       Labels: 4E0-035-785.lbl
       Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
       Component: SG ext.Player H15 0700
       Revision: 00000000
       VCID: 2757D5CA5628DF190E1-8072
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4F AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0UADBM
       Coding: 0013382
       VCID: 2953D3F2803CE969185-807C
       Subsystem 1 - Serial number: 6332CSME2823047F2
       Subsystem 2 - Serial number: 6342CSME2973601D3
       Subsystem 3 - Serial number: 6352QSME3D2E4C2F%
       Subsystem 4 - Serial number: 6362QSME3C530D63N
       Subsystem 5 - Serial number: 63734SME41682C191
       Subsystem 6 - Serial number: 63834SME3D314001R
       Revision: 00H03000    Serial number: 90025072630567
       Coding: 0102142
       VCID: 2757D5CA9628DF190E1-8072
       Part No SW: 4F0 910 930 C    HW: 4F0 920 933 J
       Component: KOMBIINSTR. M73 H21 0240
       Revision: 00700000    Serial number: 6XX13Y0A7
       Coding: 7273758
       Shop #: WSC 31250 822 00001
       VCID: 234FC1DAE2103339529-8076
    Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0060
       Revision: 00H06000    Serial number: 1100B0792584EC
       Coding: F751DE7F70720600
       VCID: 2D5B27E2B4D4F549F4D-8078
    01301 - Control Module for Voice Recognition (J507)
                        Reset counter: 100
                        Mileage: 72110 km
                        Date: 2007.05.16
                        Time: 12:43:56
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
       Component: MP3-Changer     H46 0350
       Revision: 00046006    Serial number: AUZ5ZBG3488469
       VCID: 1835E6362B5660E1B7B-804D
    Address 34: Level Control        Labels: None
       Part No SW: 4F0 910 553 A    HW: 4F0 907 553 A
       Component: J197 LUFTFEDER  H17 0060
       Serial number: 00619003920500
       Coding: 0000210
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Reset counter: 100
                        Mileage: 72110 km
                        Date: 2007.05.16
                        Time: 13:35:57
                        Fault Status: 11101101
                        Reset counter: 100
                        Mileage: 72110 km
                        Date: 2007.05.16
                        Time: 13:35:57
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H50 1060
       Revision: 00000000    Serial number: 364J.077721666
       Shop #: WSC 03002 959 06940
       VCID: 3B7F19BA7AA06BF97A9-806E
       Part No SW: 4F0 910 793 F    HW: 4F0 959 793 F
       Component: TSG FA          H21 0210
       Coding: 0001562
       Shop #: WSC 02327 758 00200
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H26 0210
       Revision: 02100026    Serial number: 01070434870000
       Coding: 0394121
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 99
                        Mileage: 63685 km
                        Date: 2014.09.01
                        Time: 16:55:05
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H10 0240
       Revision: PROD_01     Serial number: 00000000065830
       Coding: 0000123
       Shop #: WSC 50620 822 999999
       VCID: 254BDFC2EC24CD093CD-8070
       Part No SW: 4F0 910 280     HW: 4F0 907 280 C
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000076857
       Coding: 0001013
       VCID: 5EB9B02E89F25ED13D7-800B
       Part No SW: 4F0 910 792 F    HW: 4F0 959 792 F
       Component: TSG BF          H21 0210
       Coding: 0001562
       VCID: 2C5D2AE68FCEFC41E33-8079
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000321
       Shop #: WSC 02324 758 00200
       VCID: 2045CED6F30628214FB-8075
       Coding: 0000017
       Subsystem 1 - Part No: 4F0 941 329 D
       Component: AFS-Modul links H01 0010
       Subsystem 2 - Part No: 4F0 941 329 D
       Component: AFS-Modul rechtsH01 0010
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 304AA037512408
       Shop #: WSC 02312 785 00200
       Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
       Component: J0644 BEM       H12 0760
       Revision: 00000000    Serial number: 00000000021398
       VCID: 244DC2C6E71E34012B3-8071
       Component: von VA0  320410A08B
       Coding: 344630393135313035442056413033323034313041303842
       Shop #: WSC 55163 000 1048576
       Part No SW: 4F0 910 795 F    HW: 4F0 959 795 F
       Component: TSG HL          H21 0210
       Coding: 0001026
       VCID: 2F673DEABED88759C61-807A
    Address 67: Voice Control
    Address 69: Trailer (J345)       Labels: 4F0-907-383.clb
       Part No SW: 4F0 907 383 D    HW: 4F0 907 383 D
       Component: Anhaenger     H10 0080
       Revision: 2B001001    Serial number: 00000325428571
       Coding: 0300000000000000
       VCID: 2C5D2AE64FCEFC41E33-8079
       Part No SW: 4F0 910 441 A    HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J7930AA
       Coding: 1020305
       Shop #: WSC 02335 758 00200
       VCID: 1E39F02EC9721ED17D7-804B
    03006 - Back-up Camera System not calibrated
                        Reset counter: 100
                            Invalid
                            Invalid
                            Invalid
                        Fault Status: 01101101
                        Reset counter: 100
                        Mileage: 72110 km
                        Date: 2007.05.16
                        Time: 14:22:25
                            Reverse OFF
                        Count: 3
       Part No SW: 4F0 910 795 F    HW: 4F0 959 794 F
       Component: TSG HR          H21 0210
       Coding: 0001026
       Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
       Component: Parkhilfe 8-Kan H12 0080
       Revision: 00H12000    Serial number: 06340726801378
       Coding: 0221416
       Shop #: WSC 131071 102 209715
       Part No SW: 4E0 910 336 K    HW: 4E0 862 335
       Component: Handyvorb2      H18 0950
       Revision: 00000000    Serial number: 00000005035159
       Coding: 0010900
       VCID: 2A512CFE853AE27111F-807F
    End-------------------------(Elapsed Time: 04:06)--------------------------
    Quote Originally Posted by AKL R36 View Post
    Hi All,
    Steps I taken below
    Should be right
    Correct
    Correct
    0000220
    0231416
    1030305
  3. Likes Uwe, AKL R36 liked this post
    Mar 2014
    Australia
    Hi NEtech, many many thanks for your codes, it config all module & cleared all faults, except Rear View Camera (J772/#6C) with code 03006 - Back-up Camera System not calibrated, somehow it lost it calibration, can we calibrate with VCDS?
