Results 1 to 9 of 9
Thread: Bulb for License-Plate Light (X) 014 - Defective - Intermittent
    Verified VCDS User ak77's Avatar
    Jan 2015
    Australia
    Hi Team,
    Can someone please help me with this issue. I have had a bulb go off on my MK6 GTD I have replaced with new 12V as the one I removed. Only now I'm still getting the same error come up on dash asking to check the bulb for license plate. Both bulbs work. Also VCDS is still picking up the same error. It can not be cleared at all. Full scan below.
    Has anyone had this problem before?
       Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
       Component: BCM PQ35  M   110 0651
       Revision: 00110 AC
       Coding: 4C180A3A8025F1C0400800C0340001E449510488536D8560648000200040
       VCID: 3A7B01C8B5FCB29F97-806F
       Subsystem 1 - Part No: 5K2 955 119
       Component: Wischer 11071  26  0512
       Coding: 009795
       Component: RLS 160711 05  54  0403
       Coding: 0230AD
       Component: DWA-Sensor 00  00 0104
       Subsystem 4 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HO  H11 9005
                        Fault Status: 00101110
                        Reset counter: 88
                        Mileage: 96901 km
                        Date: 2014.01.29
                        Time: 19:17:21
                            Term 15 On
                        Voltage: 13.80 V
                            Term 50 Off
    __________Full Scan ______________________
    Sunday,08,September,2019,19:30:31:41771
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
    VCDS Version 19.6.1.0
    VIN: WVWZZZ1KZCW064629   License Plate: IGTD
    Mileage: 96900km-60210mi   Repair Order: Bul1
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZCW064629   Mileage: 96900km-60210miles
    Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 BC    HW: 03L 907 309 R
       Component: R4 2,0L EDC   H23 7819
       Revision: 42H23---    Serial number: 00000000000000
       Coding: 001D0012042500080000
       ASAM Dataset: EV_ECM20TDI01103L906018BC 003005
       ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
       VCID: 6CD7F7908728DC2F55-8039
       Part No SW: 02E 300 057     HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2701
       Revision: 05351113    Serial number: 00001107060358
       VCID: 56A3B578E1A476FF93-8003
       Revision: 00H31001
       Coding: 163B600D092880FE681106E690220182350800
       VCID: 7BF5C4CCFA464B97CC-802F
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Component: Climatronic   H18 1112
       Revision: 00001003
       Coding: 0000001002
       VCID: 000FB3209BA0284F99-8055
       Revision: 00110 AC
       Coding: 009795
       Coding: 0230AD
                        Reset counter: 88
                        Mileage: 96901 km
                        Date: 2014.01.29
                        Time: 19:17:21
                            Term 15 On
                        Voltage: 13.80 V
                            Term 50 Off
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Component: AirbagVW10    013 0613
       Serial number: 003G5RA7ZZGP
       Coding: 00003956
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 316926E4608A71C726-8065
       Serial number: 3572MSME25256661ZZZQ
       Serial number: 3582MSME75242361ZZZO
       Serial number: 3512QSME461D5B5CZZZ5
       Serial number: 3522QSME540B1D34ZZZX
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90422KGD000X5
       Coding: 1892140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76E3D5F8C96416FFB3-8023
       Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H08 0010
       Serial number: 0069287
       Coding: 830000
       Part No SW: 5K6 920 872 A    HW: 5K6 920 872 A
       Coding: 170B01
       VCID: 33652CEC9A9643D754-8067
       Part No SW: 7N0 907 530 H    HW: 1K0 907 951
       Component: J533  Gateway H42 1620
       Revision:   H42       Serial number: 140711F2003599
       Coding: 350003
       VCID: 356112F49CE25DE77A-8061
       Component: IMMO          H03 0607
       VCID: 6ADBF1888DDCC21F27-803F
       Revision: A1001003    Serial number: 7660458576
       VCID: 2959CE84405A0907EE-807D
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2106
       Coding: 0000692
       VCID: 377D18FC46EEAFF768-8063
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 70     3201
       Revision: 00H20000
       VCID: 34672FF0579844EF4D-8061
       Component: Tuer-SG         009 2120
       Coding: 0000692
       VCID: 326B29E8AD8C4ADF5F-8067
       Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
       Component: Radio RCD510  052 0208
       Revision: 00000001    Serial number: VWZ1Z3L1610091
       Coding: 01000400040005
       VCID: 2345DCAC2276D357A4-8077
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 356112F45CE25DE77A-8061
       Coding: 0000144
       VCID: 366315F841E456FF73-8063
       Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
       Component: TELEFON       H09 2730
       Revision: 1B001001    Serial number: 00007660438729
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA A01015
       ROD: UHVNA.rod
       VCID: 34672FF09F9844EF4D-8061
    End-------------------------(Elapsed Time: 04:50)--------------------------
    Bad BCM or wiring, maybe wrong bulbs to add up Resistance value BCM should see, did you try to vacate the DTC with a decade box.........?
    Quote Originally Posted by ak77 View Post
    Yes. Usually when people install the wrong type of bulb.
    Jan 2015
    Australia
    Jack, please elaborate in bit more detail... not sure what you mean, OZ land down under different terminology
    Jul 2014
    Hi ak77
    Let me translate Jack speak into English
    This could be a faulty Body Control Module or faulty wiring to it, an incorrect bulb may have a different resistance than the correct one and the module would recognise that and throw a fault code. You should substitute the bulbs with a variable resistance set to the correct resistance or use a tool with different resistances (decade box) to test.
    How is that?
    Regards HMC
  6. Likes Uwe, Jack@European_Parts liked this post
    Jan 2015
    Australia
    Hi team, thanks so much. I run diagnostics Body Control Module that seemed fine. After I replaced bulbs with more expensive ones and that seemed to fix the issue.
    I'm unsure why as both brands had same 5W rating. But hey its fixed. Thanks for the idea.
  8. Likes Uwe liked this post
    Jul 2014
    FOD strikes again!
    Oh no, not only am I beginning to understand Jack, I am starting to sound like him. Is there any cure?
    HMC
  10. Likes Uwe, Jack@European_Parts liked this post
  11. #8
    Jun 2014
    No cure needed... just shout FOD once or twice a week and everything will be ok...
    It seems that not all 5W bulbs have the same resistance... there will be some tollerance, but the one you used was way out of spec...
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  12. Likes Uwe, PetrolDave liked this post
  13. #9
    Dude I live my life by the FOD for thought.......... + FOOD!
    Such a deal on good spiral wrap...........MADE IN THE USA!
    https://www.ebay.com/itm/331950625004?ul_noapp=true
    Just bought this!
    To prevent THIS!
