Results 1 to 8 of 8
Thread: P02CB00 fault code, limp mode
    Sep 2019
    Transporter 2011, 2.0 biTdi 4motion CFCA engine. 171000 miles.
    Had dpf light and coil light come on whilst driving to airport (150miles). Limp mode.
    Had vw roadside assistance come out, ws blocked dpf filter ( and dpf pressure differential sensor pipe), turbo pressure too low. Fault codes p02cb00 and P246300.
    He cleared pipe, tested G450 sensor, manual regen of dpf. Has new MAP sensor.
    It cleared the dpf fault but the low boost still returns after about 1/2 a mile.
    Full auto scan
    Saturday,07,September,2019,07:53:24:16358
    VCDS Version: 19.6.0.2
    VIN: WV1ZZZ7HZBH070165   License Plate: ND60RJO
    Mileage: 275630km-171268mi   Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 02 03 04 08 09 15 17 19 22 25 56 69 0B
    VIN: WV1ZZZ7HZBH070165   Mileage: 275630km-171268miles
    Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 906 022 JE    HW: 03L 907 309 H
       Component: R4 2,0L EDC   H34 9970
       Revision: 22H34---    Serial number: 00000000000000
       Coding: 01254012231600080000
       Shop #: WSC 81903 210 00000
       ASAM Dataset: EV_ECM20BTD01103L906022JE 002009
       ROD: EV_ECM20BTD01103L906022JD_002.rod
       VCID: 71E9A2EDA096FCC76E-8024
    11895 - Turbo / Supercharger B
              P02CB 00 [101] - Pressure too Low
                        Mileage: 275624 km
                        Date: 2019.09.06
                        Time: 13:40:49
                        Engine speed: 2638.00 /min
                        Normed load value: 89.4 %
                        Vehicle speed: 74 km/h
                        Coolant temperature: 98 C
                        Intake air temperature: 35 C
                        Voltage terminal 30: 13.780 V
                        Charge air pressure specified value: 2532 hPa
                        Charge air pressure: actual value: 2427.6 hPa
                        Air mass: actual value (mg/stroke): 1033.6 mg/stroke
                        Air cleaner degree of soiling: 18.27 %
                        Throttle valve adapter: actual value: 64.50 %
                        Bypass valve f high press turboch turbine inlet: actual value: 98.01 %
                        Mean injection quantity: 52.89 mg/stroke
       Part No SW: 0BT 300 011 Q    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H08 2258
       Revision: 00H08V01
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 3C7743D9B75441AF8D-8068
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0105
       Revision: 00H43001
       Coding: 508764AD99AB0A9526A39977A96316
       Shop #: WSC 02736 790 49152
       VCID: 366351F181789BFF7B-8062
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E5 907 047 AL    HW: 7E5 907 047 AL
       Component: Climatic-T5   H11 0203
       Revision: 00005001
       Coding: 0000000002
       Shop #: WSC 02737 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: 79F99ACDF8E6B487D6-802C
       Part No SW: 7H0 937 087 F    HW: 7H0 937 087
       Component: BCM T5GP H+4  H47 0230
       Revision: BO047001    Serial number: 0396 321100593
       Coding: A0A0393A0E212013002008102C2B8C540000430F60044000300000000000
       Shop #: WSC 02734 790 00000
       VCID: 377D5CF5867262F760-8062
       Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  003 3311
       Coding: 050000
       Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  003 3311
       Coding: 040000
    03303 - Response Closing Status of Rear Left Door
                        Reset counter: 27
                        Mileage: 275632 km
                        Date: 2014.01.27
                        Time: 21:28:05
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H06 0013
       Revision: --------    Serial number: 003HL002H9WF
       Shop #: WSC 02734 790 50316
       VCID: 356156FD947E90E772-8060
       Part No SW: 7E0 920 960 CX    HW: 7E0 920 960 CX
       Component: KOMBI         H04 0204
       Coding: 460300
       Shop #: WSC 51034 001 1048576
       VCID: 0109F22D9036EC479E-8054
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 0230
       Coding: 042300
       VCID: 70EFA7E9A39CF5CF61-8024
       Part No SW: 09N 907 554 B    HW: 09N 907 554 B
       Component: Haldex 4Motion      6008
       Shop #: WSC 02748 790 00000
       VCID: 377D5CF5467262F760-8062
       Component: IMMO          H04 0204
       VCID: 6ADBB5818D400F1F2F-803E
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 01000000    Serial number: VWZ1Z2K8556967
       Coding: 0500020002
       VCID: 6BD5B0858ABA161754-803E
       Revision: 3A001001    Serial number: 00000137824167
       Coding: 410D000100000000
       Shop #: WSC 02736 790 00000
       VCID: 306F67E9631CB5CF21-8064
    End-------------------------(Elapsed Time: 03:05)--------------------------
    scan of fault code
    Saturday,07,September,2019,12:45:54:16358
                    Address 01: Engine       Labels: 03L-906-022-CFC.clb
    Control Module Part Number: 03L 906 022 JE    HW: 03L 907 309 H
      Component and/or Version: R4 2,0L EDC   H34 9970
               Software Coding: 01254012231600080000
                Work Shop Code: WSC 81903 210 00000
                  ASAM Dataset: EV_ECM20BTD01103L906022JE 002009 (VN75)
              P02CB 00 [167] - Pressure too Low
                        Mileage: 275633 km
                        Date: 2019.09.07
                        Time: 11:11:59
                        Engine speed: 2601.50 /min
                        Normed load value: 77.6 %
                        Vehicle speed: 67 km/h
                        Coolant temperature: 51 C
                        Intake air temperature: 31 C
                        Voltage terminal 30: 14.180 V
                        Charge air pressure specified value: 2625 hPa
                        Charge air pressure: actual value: 2363.2 hPa
                        Air mass: actual value (mg/stroke): 1044.7 mg/stroke
                        Air cleaner degree of soiling: 18.08 %
                        Throttle valve adapter: actual value: 99.62 %
                        Bypass valve f high press turboch turbine inlet: actual value: 99.08 %
                        Mean injection quantity: 44.33 mg/stroke
    Readiness: N/A
    Was thinking it could be clogged up wastegate with soot or issue with wastegate actuator?
    Gonna try and get under van today and check both actuators move from end to end using
    hand vacuum pump.
    Whats your thinkings?
    Sep 2019
    Dont really wanna have to take biturbo off as absolute nightmare due to 4motion. Means taking out driveshaft, catalytic converter and bevel box....
    What other tests can i do?
    What else could it be?
    Need van everyday so struggling....
    Checked all the pipes around turbo to inlet for leaks?
    Sep 2019
    Nothing obvious, may have to try and rig up a smoke test.
    Sep 2019
    Any help anyone?
    Jun 2014
    Swansea, UK
    Quote Originally Posted by H-bus guy View Post
    I can't help with your issue I'm afraid, but as a side-note you should update VCDS. There were some bugs in 19.6.0.x
    19.6.1 has been out since late June / early July
  7. Likes Uwe liked this post
    Sep 2019
    Yes i have updated to the latest version the day after that scan was taken.
    Many thanks.
  9. Likes Mike@Gendan liked this post
  10. #8
    Sep 2019
    Tested both actuators with vacuum pump today, both move freely.
