Have a golf R that we’ve stripped caged etc for dirt track and short course rally
Want to make car drive like my modified street car does on dirt when I pull the rear abs sensor.
Can I just code out modules I don’t want in? Airbags? maybe the abs? the doors and a Fair few internal electrics? I still need to retain the working abs circuit for the Haldex system.
If just pulling abs fuse the drive is all messed up and fwd perhaps.
Sun,Sep,08,2019,13:27:09
VCDS Mobile 0.4436.0.4
VIN: WVWZZZ1KZDW096487
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 52 55 56 62
72 77
08-Auto HVAC -- Status: Communication Error 17010
09-Cent. Elect. -- Status: Malfunction 16010
16-Steering wheel -- Status: Communication Error 17010
17-Instruments -- Status: Malfunction 16010
25-Immobilizer -- Status: OK 16000
42-Door Elect, Driver -- Status: Cannot be reached 17100
44-Steering Assist -- Status: Communication Error 1010
46-Central Conv. -- Status: OK 16000
52-Door Elect, Pass. -- Status: Cannot be reached 17100
55-Xenon Range -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 17100
72-Door, Rear Right -- Status: Cannot be reached 17100
Address 01: Engine Labels: 06F-907-115-CDL.clb
Part No SW: 1K8 907 115 D HW: 8P0907115B
Component: 2.0l R4/4V TFSI 0030
Revision: 5BH21--- Serial Number:
Coding: 0403000C1C0F0160
VCID: 2F2180BFF8DA5C3487C85C-807A
No fault codes found.
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 014 S HW: 02E927770AL
Component: GSG DSG AG6 512 3526
Revision: 05551213 Serial Number: 00001208270251
VCID: 2207798BBB08E15C18462D-8077
12 Faults Found:
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
28775 - No Communication with Gear Selector Module
U0103 - 000 - - - Intermittent
18097 - Powertrain Data Bus
P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - - Intermittent
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
18288 - Powertrain Data Bus
P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
01196 - Engine-Transmission Data Bus
18262 - Powertrain Data Bus
P1854 - 000 - Hardware Malfunction - Intermittent
18202 - Selector Lever
P1794 - 000 - Incorrect Usage - Intermittent
29076 - Implausible Data Received from Gear Shift Control Module
U0404 - 000 - - - Intermittent
00653 - Selector Lever/Auto Trans Plausibility
Address 03: ABS Brakes (J104) Labels: 1K-03.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 163BE00D092B8000680F07EC90200181350000
VCID: 7DBD6AF76236FEA445F436-8028
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 GK HW: 5K0 907 044 GK
Component: Climatronic H19 1313
Revision: 00001004
Coding: 0010002002
ROD: EV_Climatronic_VW36.rod
VCID: 7AB761EB7318D19C60D615-802F
15 Faults Found:
9475093 - Position Sensor for Left Temperature Flap Motor
B1094 15 [009] - Open or Short to Plus
9475349 - Position Sensor for Right Temperature Flap Motor
B1095 15 [009] - Open or Short to Plus
9476117 - Position Sensor for Defrost Flap Motor
B1098 15 [009] - Open or Short to Plus
9474417 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
9476373 - Position Sensor for Front Air Distribution Flap Motor
B1099 15 [009] - Open or Short to Plus
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [009] - Open or Short to Plus
9470741 - Temperature Sensor for Left Footwell Vent
B1083 15 [009] - Open or Short to Plus
9470997 - Temperature Sensor for Right Footwell Vent
B1084 15 [009] - Open or Short to Plus
9471765 - Temperature Sensor for Left Vent
B1087 15 [009] - Open or Short to Plus
9472021 - Temperature Sensor for Right Vent
B1088 15 [009] - Open or Short to Plus
9472533 - Temperature Sensor for Evaporator Vent
B108A 15 [009] - Open or Short to Plus
9481748 - High Pressure Sensor
B10AE 14 [008] - Open or Short to Ground
U8E6550 F0 [009] - Too Low
9496597 - Sunlight Photo Sensor
B10E8 15 [009] - Open or Short to Plus
9496613 - Sunlight Photo Sensor
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 H HW: 1K0 937 084 H
Component: BCM PQ35 B 111 0709
Revision: AC111709
Coding: 48180A3A8825F1C0408800C0340008644BD50488736D8D20E48400240040
VCID: 33298CCF14F2F8D4E31060-8066
Subsystem 1 - Part No SW: 5K2-955-119 Labels: 5K-09-01.clb
Component: Wischer 1409126 0512
Coding: 009795
Subsystem 2 -
Subsystem 3 - Part No SW: 1K8-951-171
Component: DWA-Sensor 00001 0104
Subsystem 4 -
30 Faults Found:
00532 - Supply Voltage B+
01134 - Alarm Horn (H12)
00061 - Footwell Lights
00834 - Signal for Activation of Heated Rear Window
03266 - Control Circuit for Signal Horn
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
00153 - Windshield Wiper Motor; Driver Side (V216)
01800 - Light Switch (E1)
007 - Short to Ground
03020 - Local databus 2
03156 - Sensor for Anti-Theft System (G578)
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: --------
Coding: 108104
VCID: 3833BBE30D941B8CD6223F-806D
02070 - Rear Parking Aid Sensors
02069 - Front Parking Aid Sensors
01549 - Supply Voltage for Parking-Aid Sensor
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Coding: 0000394C
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 312586C7EEEED2C491FC4A-8064
17 Faults Found:
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
9438491 - Igniter for Driver head airbag
B1005 1B [137] - Resistance Too High
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
B1007 1B [137] - Resistance Too High
9440283 - Driver side knee airbag igniter
B100C 1B [137] - Resistance Too High
9437713 - Igniter for Passenger's Airbag
B1002 11 [136] - Short to Ground
9443093 - Driver's Side Airbag Crash Sensor
B1017 15 [137] - Open or Short to Plus
9451029 - Crash sensor side airbag; passenger side
B1036 15 [137] - Open or Short to Plus
9443349 - Rear Side Airbag Crash Sensor (on driver's side)
B1018 15 [137] - Open or Short to Plus
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 15 [137] - Open or Short to Plus
U0155 00 [008] -
9447424 - Front crash data stored
B1028 00 [137] - -
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Address 16: Steering wheel (J527) Labels: 5K-16.lbl
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: --------
Coding: 1892140000
ROD: EV_SMLSNGKUDS_VW32.rod
VCID: 76AF75DB4700B5FC048E41-8023
11 Faults Found:
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] -
117012 - Databus
117028 - Databus
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
227395 - Windshield Wiper Switch
B1145 07 [009] - Mechanical Failure
332564 - Databus
332580 - Databus
332596 - Databus
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
365080 - Controls in Steering Wheel
617736 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
Part No SW: 5K6 920 873 B HW: 5K6 920 873 B
Component: KOMBI H05 0705
Coding: 170F01
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW36.rod
VCID: 352DB2D71A86FEE4CD041E-8060
9453842 - Oil Level Thermal Sensor
B1041 35 [008] - Signal high time > maximum
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] -
13635840 - Supply voltage
Address 19: CAN Gateway (J533) Labels: 7N-19.clb
Part No SW: 7N0 907 530 AB HW: 7N0 907 530 AB
Component: J533 Gateway H47 1633
Revision: H47
Coding: 350003
VCID: 70A343C3256483CCDE7287-8025
11 Faults Found:
Part No SW: 0BR 907 554 C HW: 0BR907554C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 45CDC2174A66F6645DA4AE-8010
7 Faults Found:
Component: IMMO H05 0705
VCID: EA97D1AB83B8E11C103645-80BF
Address 2E: Failed to respond
Address 42: Failed to respond
Part No SW: 5N0 909 144 P
Component: EPS_ZFLS Kl. 251 3305
Revision: 00H22000
VCID: 3E3FADFB2FB0A5BC1C7EF9-806B
Address 46: Failed to respond
Address 52: Failed to respond
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW:
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial Number:
Coding: 1475932
VCID: 342B8FD311FC7FECFA1A6B-8061
Subsystem 1 - Part No SW: ID--L Labels: ID-55-01.clb
Component: AFS-Lst.-Modul l ....
Coding: 0000255
Subsystem 2 - Part No SW: ID--R Labels: ID-55-02.clb
Component: AFS-Lst.-Modul r ....
Coding: 0000255
9 Faults Found:
000 - - - MIL ON
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
02233 - Left Headlight Power Output Stage (J667)
014 - Defective
014 - Defective
Address 56: Failed to respond
Address 62: Failed to respond
Address 72: Failed to respond
Address 77: Failed to respond
