Results 1 to 2 of 2
Thread: 1.4 tsi squeaks/funny noise on acceleration
    Jun 2016
    Guyana
    Hey Guys i have an annoying squeak on acceleration maybe around 1500 - 2000 rpm. around the time magnetic clutch engages, have anyone experienced this on the dual charge systems(CAVD,CTHD) ,if so may anyone point me in the right direction, i was thinking the coolant pump? any help needed.
    VW tiguan 1.4 TSI dual charger CTHD engine
    thanks in advance
    Auto scan
    Tuesday,27,August,2019,10:34:42:17560
    VCDS Version: 19.6.1.0
    VIN: WVGZZZ5NZDW103592   License Plate: TIGUANRLINE
    Mileage: 135560km-84233mi   Repair Order:
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 53 55 61 62
              72
    VIN: WVGZZZ5NZDW103592   Mileage: 135560km-84233miles
    Address 01: Engine (J623-CTHA)       Labels:. 03C-907-309-V1.clb
       Part No SW: 03C 906 026 BD    HW: 03C 907 309 M
       Component: 1.4l R4 TSI   H02 5724
       Revision: LKH02---    Serial number: 00000000000000
       Coding: 001D0032002401000000
       ASAM Dataset: EV_ECM14TSI01103C906026BD 001005
       ROD: EV_ECM14TSI01103C906026BD.rod
       VCID: 63CF828A6A112057E4-8036
    4172 - Manifold Pressure / Boost Sensor (G31)
              P0236 00 [237] - Implausible Signal
                        Mileage: 135500 km
                        Date: 2019.08.26
                        Time: 22:17:02
                        Engine speed: 1556.00 /min
                        Normed load value: 40.4 %
                        Vehicle speed: 16 km/h
                        Coolant temperature: 89 C
                        Intake air temperature: 59 C
                        Voltage terminal 30: 13.758 V
                        Adjustment requirements for basic setting-Bits 0-7: 139
                        Charge press. ctrl.: spec. value: 99.6 %
                        Charge air pressure: actual value: 1006.25 hPa
                        Charge air pressure specified value: 2064.69 hPa
                        Intake manifold pressure before 2nd compressor: raw value: 1021.02 hPa
                        Engine torque: 112.0 Nm
    Readiness: 0000 0101
       Part No SW: 02E 300 058 R    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3505
       Revision: 05651213    Serial number: 00001303130462
       VCID: 2953D0A280BDBA07EE-807C
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
       Component: J104   C6 450M VDCF 0011
       Revision: --H07---    Serial number: 00000006896290
       Coding: 0056397
       VCID: 6ED9E3BE79D39D3F7B-803A
       Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010003003
       VCID: 79F3C0E2F89DCA87DE-802C
       Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
       Component: BCM PQ35 M    021 0068
       Revision: BJ021001
       Coding: 40180A3B88251AC0408800C0340009244B55AB08636D8960648487000041
       VCID: 3F876EFAAE3924B7A0-806A
       Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 09041  013 0204
       Serial number: N2955119   204!
       Coding: 009795
       Component: RLS 090413 05  54  0403
       Coding: 03304D
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 200
                        Mileage: 135356 km
                        Date: 2014.01.15
                        Time: 14:50:12
                        Voltage: 12.75 V
                        Fault Status: 00101010
                        Fault Frequency: 10
                        Reset counter: 246
                        Mileage: 135357 km
                        Date: 2014.01.15
                        Time: 16:23:14
                            Term 15 Off
                        Voltage: 12.60 V
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 5N0 919 475 D    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0045
       Revision: --------    Serial number: 32961309401641
       Coding: 308102
       ASAM Dataset: EV_EPHVA14VW3680000 001005
       ROD: EV_EPHVA14VW3680000.rod
       VCID: 3A711FEEBD1B019F97-806E
       Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
       Component: J234__209 VW10 HI   2318
       Revision: 27019000    Serial number: 003N5P5K1DCL
       Coding: 0012345
       VCID: 0005AD0653479B4F99-8054
       Subsystem 1 - Serial number: 6332MTS627420893
       Subsystem 2 - Serial number: 6342MTS662390893
       Subsystem 3 - Serial number: 6351HTS60DIASBKJ
       Subsystem 4 - Serial number: 6361HTS6HHIASBKR
       Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
       Revision: FF010041    Serial number: 20130405101561
       Coding: 1882140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7EF9D3FEE1B3EDBFEB-802A
       Component: E221__MFL-TAS  H31 0033
       Coding: 820000
       Part No SW: 5N0 920 873     HW: 5N0 920 873
       Component: KOMBI         H06 0705
       Coding: 511F01
       VCID: 70E5FDC6ABE78BCF69-8024
       Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
       Component: J533  Gateway H53 1634
       Revision:   H53       Serial number: 030413F2000058
       Coding: 356003
       VCID: 75EBCCD2DC85AEE7BA-8020
       Component: IMMO          H06 0705
       VCID: 6AD1EFAE8D3B711F27-803E
       Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0504
       Revision: 12110009    Serial number: 0006727387
       Coding: 0212BE
       VCID: 397300E2B81D0A879E-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1504
       Serial number: 00000007798975
       Coding: 000090
       Part No: 5N0 909 144 P
       Component: EPS_ZFLS Kl. 201    3305
       Revision: 00H22000
       Shop #: WSC 01324 785 00200
       VCID: 3E7913FE69332DBFAB-806A
       Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0504
       Revision: 14110009    Serial number: 0006721768
       Coding: 0213BE
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1504
       Serial number: 00000007796200
       Coding: 000090
       Revision:   H19       Serial number: 00000000892167
       Coding: 0026167
       VCID: 36690BDE4103E5FF73-8062
       Component: AFS-ECU       H04 0111
       Coding: 049600000B000200
       Shop #: WSC 22138 002 1048576
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       VCID: 377706DA8E091CF768-8062
       Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
       Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
    5275648 - Left/Right Driving Switch-Over Active
              C1080 00 [009] - -
                        Reset counter: 204
                        Mileage: 135417 km
                        Date: 2019.08.26
                        Time: 20:13:06
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
       Component: Batt.regelung H53 1634
       Coding: 032F7864
       VCID: 71E3F8C2A8ED82C766-8024
       Component: J367-BDM  H07 0180
       Serial number: 30093D02571491177644
    End-------------------------(Elapsed Time: 02:49)--------------------------
    Address 01: DTCs cleared
    Address 09: DTCs cleared
    Jul 2017
    Kenya
    You may have a boost leak,actually the squeaking is whistling....check boost hoses to/from intercooler and intake manifold gasket etc
