2018 Skoda Octavia help with some codes and a coil light
hussain.ali15
C?ID=373132
First of all, first post, so... hi everyone! :)
Bought a 2018 Skoda Octavia from a salvage auction and was wondering if you guys can help me out with these codes. The main issue is the coil light that appears on the instruments. Tried clearing the fault codes but they just reappear instantly.
Thank you!
Saturday,07,September,2019,19:50:43:61881
VIN: TMBKG7NE5K0107582   License Plate: LA68 UFR
Mileage: 8288km-5149mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F
VIN: TMBKG7NE5K0107582   Mileage: 8288km-5149miles
Address 01: Engine (J623-DGTE)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 HT    HW: 04L 907 445 G
   Component: R4 1.6l TDI   H01 6591
   Revision: 22102001
   Coding: 01254832436519090000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM16TDI03004L906056HT 004006
   ROD: EV_ECM16TDI03004L906056HT.rod
   VCID: 0655960598A836A7F05-8052
25130 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:47
                    Coolant temperature: 68 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 12.539 V
                    Acceleration: 0.000 m/s²
                    Median vehicle speed: 0.00 km/h
                    Cruise Control System (CCS): status: ERROR
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: No
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Readiness: N/A
   Part No SW: 0CW 300 043 E    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1603
   Revision: 00005008    Serial number: CU501811258724
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 392F2DF999D6895FCD7-806C
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 63238000001874
   Coding: 25078A9110200973407C060860C524A451089002600624723641F070D0024B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79AFEDF9D956495F8D7-802C
0295 - Steering angle sensor
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:40:26
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:40:26
   Part No SW: 5E0 907 044 AP    HW: 5E0 907 044 AP
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 0211010400211001100500080010102A
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   VCID: 73B3DFD1FB3A330FC7B-8026
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
                    Outside air temperature: 14.5 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 29.0 °C
                    System run time-Terminal 15 on: 160 s
   Part No SW: 5Q0 937 084 DB    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H38 0273
   Serial number: 00001832400921
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3F7F1D36A7B4F9FB-802E
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 181109  051 0916
   Serial number: 887253F0401831300597
   Coding: 164DDD
   Component: RLHS  052 0107
   Serial number: SBY18M12D03H17M46S04
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1826127BD
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223982541005
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 AD    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000029111808490887
   Serial number: 000308418018318
   Coding: 0471051051
   VCID: 4CC1642DC6440CF7661-8018
13637426 - Databus
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:28:53
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 26031503211308
   Coding: 00000200FE0739
   VCID: 382928FDA2DC9057329-806C
6 Faults Found:
15360768 - Component Protection
          U1101 00 [009] - Active
          [FAULT_ATP_IKA_FAST_FAILED]
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
                    Control Module temperature: 33 °C
                    Voltage terminal 15: 12.5 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1071 - Databus
          [FAULT_CIS_AXV_INVALID]
                    Reset counter: 55
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
1054 - Databus
          [FAULT_CIS_GEAR_FAIL]
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PQCYVEA
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B43A73183CA4BCFAFB-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 001 311 18
   Serial number: 35700000000149917238
   Subsystem 2 - Part No SW: -----------    HW: 454 001 311 18
   Serial number: 35800000000DE991723V
   Subsystem 3 - Part No SW: -----------    HW: 454 801 311 18
   Serial number: 351002104D216000000
   Subsystem 4 - Part No SW: -----------    HW: 454 801 211 18
   Serial number: 3520063C9E216000000K
   Subsystem 5 - Part No SW: -----------    HW: 454 802 810 18
   Serial number: 3550055229F16000000F
   Part No SW: 5E0 920 981 F    HW: 5E0 920 981 F
   Component: KOMBI         202 3610
   Coding: 27A40A082580860001886B011001000080000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009009
   ROD: EV_DashBoardJCIMQBAB_009_VW48.rod
   VCID: 2D0709A95D9E25FF51F-8078
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4366
   Revision: --------    Serial number: 0008875623
   Coding: 030100045F087300EB0002581C0F00010001070000000000000000000000
   Shop #: WSC 73430 790 00000
   ROD: EV_GatewNF.rod
   VCID: 6E85CEA590181EE7285-803A
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0170
   Serial number: 000000000B0870261118
   Serial number: 75886002001811290990
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: On
8526363 - Crash Shut-Down
          B189C F0 [009] - Active
                    Reset counter: 15
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:24:45
                    Terminal 15: On
   Part No SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Component: TSG FS        006 0246
   Serial number: 0000353936237
   Coding: 001000208001020000001100
   VCID: 46D55605D828F6A7B05-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000025576200
   Coding: 1D0200
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 81170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1DCCDFE343437DE1-8020
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 55
                    Mileage: 8288 km
                    Date: 2019.08.19
                    Time: 04:29:31
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 31.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 25
                    uioUdNotFilt_xdu16: 12.48 V
                    uAdSensI_SwitchedKl30_xdu16: 12.41 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0246
   Serial number: 0000354908876
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: 45D75109E52EFDBFB9F-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000025622087
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0475
   Serial number: SKZAZ2U0969003
   Coding: 03730201FF00000041111201008800002F0208C601200500CF
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 34311CCDBEB474371E1-8060
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: SKZ6ZHV3431040
End----------(Elapsed Time: 01:16, VBatt start/end: 12.2V/12.2V)-----------
I would suggest the first thing that needs to be worked on is the Component Protection faults, and that requires an on-line connection to the VAG mothership, meaning a dealer or independent who has authorized access. Assuming that the correct parts are installed in the car, they should be able to deal with any coding issues at the same time. But if the parts are wrong, things will get complicated fast.
hussain.ali15
C?ID=373132
Thanks for your reply. I was wondering why the component protection code was there, especially because the car is almost brand new (minus the crash it had). So is there no way for me to recode the engine control module to get rid of the coil light? The Coil light is the main thing I’d like to get rid of.
Thanks again!
darkchina811
ITALY
C?ID=333184
+1
go to a Skoda dealer and ask for a "SVM spec/actual", that will bring the car to factory state. there is no way to know if anybody already attempted coding changes.
hussain.ali15
C?ID=373132
Well... wasn’t the outcome I was hoping for but I guess it’s a trip to the stealers *sigh*
Thank you everyone :)
PetrolDave
Westbury, UK
C?ID=1423
My suspicion is that someone has been (randomly?) replacing modules that failed or got damaged in the crash, hence the Component Protection.
BTW when you get the car back after the SVM, take an Auto-Scan and save it before doing anything else.
If you do plan coding/adaptation changes make sure you look at ones for a 2018 Octavia - LOTS changed in 2016 and again in 2018 and 2019 so there are many posts on the internet that will NOT apply to your 2018 model.
