Results 1 to 6 of 6
Thread: Audi A4 2003 coding questions
    Feb 2019
    Hello. I have few questions about 2003 A4
    1) I it possible to remove brake bad alert from cluster?
    2) Is it possible to remove oil level sensor from cluster?
    3) There is big screen in cluster, but only one function. Can I code there all the info (range and so on..)? There is MF washer wiper.
    Saturday,07,September,2019,18:00:58:19148
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WAUZZZ8E13A269637   License Plate: A4
    Mileage: 334810km-208041mi   Repair Order:
              67 69 75 76 77
    VIN: WAUZZZ8E13A269637   Mileage: 334810km-208041miles
    Address 01: Engine        Labels: 06B-906-018-AVJ.lbl
       Part No SW: 8E0 909 518 AA    HW: 8E0 909 018 A
       Component: 1.8L R4/5VT     G   0004
       Coding: 0011501
       Shop #: WSC 00000 000 08192
       VCID: 6FBBD3AB5B89A0BF233-5160
    16618 - Boost Pressure Regulation
                P0234 - 001 - Limit Exceeded (Overboost Condition)
       Part No: 8E0 614 517
       Component: ABS/ESP front       1726
       Coding: 04475
       Shop #: WSC 00011
       VCID: 6597B1838C756AEF59F-51F2
       Part No: 8E0 820 043 J
       Component:   A4 Klimaautomat   1116
       Coding: 00000
       Shop #: WSC 63351
       VCID: 2809F8B7BBE7B787A29-513C
    6 Faults Found:
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
                30-00 - Open or Short to Plus
       Part No: 8E0 907 279 E
       Component: int. Lastmodul  NDL 0305
       Coding: 00002
       Shop #: WSC 63351
       VCID: 34311CC7772FC3671E1-4B00
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 B
       Component: Airbag 8.4EP        2000
       Coding: 0011602
       Shop #: WSC 06435 000 00000
       VCID: 363526CF6453D177205-5184
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0308
       Coding: 00041
       Shop #: WSC 50359
       VCID: 3E253EEF49631937F85-4B00
       Part No: 8E0 920 900 L
       Component: KOMBI+WEGFAHRS. RB4 D36
       Coding: 00100
       Shop #: WSC 00006
       VCID: 2D0709A3940592AF51F-5160
       WAUZZZ8E13A269637     AUZ6Z0B0373513
    Address 46: Central Conv.        Labels:. 8E0-959-433-MIN.clb
       Part No: 8E0 959 433 AR
       Component: Komfortgerát T85    1210
       Coding: 06720
       Shop #: WSC 63351
       VCID: 015F8513781DA6CFC57-4B00
       Subsystem 1 - Part No: 8E1959801B
       Component: Tőrsteuer.FS BRM 0002
       Subsystem 2 - Part No: 8E1959802B
       Component: Tőrsteuer.BF BRM 0002
    01561 - Rear left door
                61-10 - Won't De-Safe - Intermittent
    End----------(Elapsed Time: 05:49, VBatt start/end: 12.0V/12.0V)-----------
    1) On that cluster, it would appear the answer is no. But it's trivially easy to jumper out the circuit.
    2) Not that I am aware. And why would you want to?
    3) I don't think so. I expect you would need a cluster with the appropriate software in it.
    Feb 2019
    'cause someone had change oil pan and In the new oil pan there isn' t place for the oil lever sensor 🤔
    Feb 2019
    I quess that the original oil pan was too expensive and thats why there is chinese copy oil pan.
    Well, if it were mine, I would either get the correct/proper oil pan for it, or I would have a look at the the wiring diagrams and try to figure out what electrical components were needed to fool the car into believing the sensor is present and the oil level is OK.
    Apr 2018
    ITALY
    and make sure you check the actual oil level quite often
    my Golf came out of the factory with 13 ECUs. now she has 19. and counting
  7. Likes Uwe, PetrolDave liked this post
