Results 1 to 5 of 5
Thread: Fresh Air Blower
    Dec 2018
    Fresh Air Blower
    My fresh air blower does not turn on sometimes, especially when it is very hot outside. I can open up the shroud and give it a little help with a screwdriver and it always starts. I have read this is most likely due to poor connection on the internal motor components due to wear. I plan to replace it, but understand there is also a starter. Should I replace that as well while I have everything opened up or is it unlikely to need replacement? Thanks.
    Sunday,25,August,2019,16:52:58:43616
    VIN: WAULFAFR9AA0XXXXX   License Plate: 7PNXXXX
    Mileage: 244650km-152018mi   Repair Order:
    Chassis Type: FR-AU48 (8T0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56
              77
    VIN: WAULFAFR9AA0XXXXX   Mileage: 244650km-152018miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H15 0001
       Revision: E1H15---
       Coding: 0114010A190F0160
       Shop #: WSC 09211 444 182470
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79AFEFA0A953F4CF8D7-802C
    4106 - Bank 1; System too Rich at Idle
              P2188 00 [096] - -
                        Mileage: 243961 km
                        Date: 2019.08.01
                        Time: 16:26:22
                        Engine speed: 798.00 /min
                        Normed load value: 10.2 %
                        Coolant temperature: 93 °C
                        Intake air temperature: 46 °C
                        Voltage terminal 30: 14.041 V
                        Unlearning counter according OBD: 21
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 J    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H05 0008
       Revision: --H05---
       Coding: 001012
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMAL651 A01006
       ROD: EV_TCMAL651.rod
       VCID: 3D273BB0FDFB08EFE1F-8068
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 150D18
       VCID: 7AADF0ACACD5FFD784D-802E
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0324
       Coding: 090000
       VCID: 78A9EAA492D9EDC7F29-802C
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Serial number: 0509000049953018
       Serial number: 0209000063527007
       Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
       Component: MEM-BFS       H10 0074
       Revision: AA000000    Serial number: 00001010004295
       Coding: 08017025002400001000
       VCID: 43D34D489B9F7E1F97B-8016
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01150920090294
       Coding: 64022000
       VCID: 00598244CA09A507CA9-8054
                        Reset counter: 64
                        Mileage: 241740 km
                        Date: 2019.07.01
                        Time: 18:06:35
                        Temperature: 35.0°C
                        Voltage: 13.60 V
                        Output: 0 W
                        Output: 0 W
                        Temperature: 34.0°C
    01273 - Fresh Air Blower (V2)
                        Fault Status: 00101001
                        Fault Frequency: 21
                        Reset counter: 100
                        Mileage: 241740 km
                        Date: 2019.07.01
                        Time: 18:06:35
                        Temperature: 35.0°C
                        Voltage: 13.80 V
                        Current: 0.000 A
                        Voltage: 13.80 V
    01844 - Control Module for Fresh Air Blower (J126)
                        Fault Status: 00101110
                        Reset counter: 98
                        Mileage: 241740 km
                        Date: 2019.07.01
                        Time: 18:08:58
                        Temperature: 34.0°C
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000340407
       Coding: 26001091063CAF010000080300003D3D0F1C528800010161000000
       VCID: 3C2136B4E66101E7D61-8068
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 120909  H14 0070
       Serial number: SWF09090125441
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10596177
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002807091472
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H37 0520
       Serial number: 003EGD02CYY%
       Coding: 303333334330303030304A55304C38543053
       VCID: 42DD484C840577179CD-8016
       Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
       Component: BF-Gewichtss.  H01 0050
       Serial number: 5810000R0900004E33
       Serial number: 6334MSME4B754319H
       Serial number: 6344MSME4B4101511
       Serial number: 6352QSME6A3A0D02L
       Serial number: 6362QSME153B1228B
       Serial number: 63732SME0D390C2E9
       Serial number: 63832SME0539240AX
       Revision: --------    Serial number: 90319II8000EE
       Coding: 000036
       VCID: 3D273BB0FD7B08EFE1F-8068
       Part No SW: 8T0 920 950 Q    HW: 8T0 920 950 Q
       Component: KOMBIINSTR.   H33 0255
       Revision: 00000000    Serial number: CHU22J299
       Coding: 8B1701000300D705020000
       VCID: 46D5545CA8AD4B37B05-8012
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G0990383BB
       Coding: 00C303
       VCID: 50F972045AE995871A9-8004
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0170
       Serial number: 1908C051250809
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0280
       Revision: 00000000
       Coding: 020302
       VCID: 392F2FA0E95334CFCD7-806C
       Component: MEM-FS        H10 0074
       Revision: AA000000    Serial number: 00001010004226
       Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
       Component: TSG FA        H07 1301
       Coding: 011C03224000120102
       Shop #: WSC 09211 444 175787
       Revision: 00002001    Serial number: 0121269251
       Coding: 0106029A007A440400B0000000000000
       Shop #: WSC 06342 000 00000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000166955
       Component: J245EE19SKB12  H01 0220
    00218 - Humidity Sensor (G355)
                        Reset counter: 229
                        Mileage: 241389 km
                        Date: 2019.06.24
                        Time: 17:32:42
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 96
                        Mileage: 244161 km
                        Date: 2019.08.13
                        Time: 07:30:34
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
       Component: DSP Prem      H17 0320
       Revision: 00017001    Serial number: 34834004493702
       Coding: 0203010302
       VCID: 7EA5FCBCB0FDD3F7B85-802A
       Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
       Component: TSG BF        H07 1301
       VCID: 4FFB717847D78A7F033-801A
       Revision: 00000003    Serial number: 10000000312954
       VCID: 34311E94CE31C9A71E1-8060
       Part No: 8K5 907 357
       Shop #: WSC 06324 000 00000
       VCID: 77ABE99893C7E2BFFB3-8022
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H04 0351
       Revision: 00000006    Serial number: AUZ5Z6I1267629
       Coding: 040300020104850043D9070800
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
                        Reset counter: 229
                        Mileage: 241389 km
                        Date: 2019.06.24
                        Time: 17:31:51
                        Fault Frequency: 19
                        Reset counter: 101
                        Mileage: 241389 km
                        Date: 2019.06.24
                        Time: 17:43:02
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
       Component: FSE_256x BT     H37 0600
       Revision: 00000000    Serial number: 00000005051481
       Coding: 0010370
       VCID: 3C2136B4EA6101E7D61-8068
    End----(Elapsed Time: 01:39, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
    The blower motor always used to be a permanent magnet DC motor that uses brushes and a commutator, with this type of motor low starting torque is most often down to worn brushes.
  3. Likes Uwe, Gmickey liked this post
    Dec 2018
    So the starter likely does not need replacing? Does the motor lend itself to replacing the brushes or should I just replace the entire unit?
    Quote Originally Posted by Gmickey View Post
    I can't recall anyone replacing the brushes, once you've got the motor out it's easier/simpler just to replace the whole motor.
    New User
    Sep 2019
    Denton, Texas, USA
    I'm afraid, that the replacement is the only option here.
