Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Whats the oil pressure at idle for a 2.0 engine?
    So was the pump more than a Erwin sub?
    So where are we now?
    Was this car not under useful life warranty or campaign?
    Hey you might benefit from this post since in California huh?
    https://forums.ross-tech.com/showthr...l=1#post178005
    That Erwin data is free too.....
    https://vag-flashinfo.de/index.php?p...906+026+AG&as=
  2. #12
  3. #13
    Jun 2019
    California, USA
    I have an oil pressure gauge attached with a "T" at the pressure switch port. In cold the oil pressure is 40 psi and after 5 miles there's no pressure at all.
    Engine have 134k miles, doesn't apply to this engine.
  4. #14
    How is that it doesn't or didn't apply, shouldn't it of been recalled for safety issue's?
    Did you complain to NHTSA yet?
    Why or where are you losing the oil PSI in the engine?
    Don't you realize that safety campaigns are for 15/150K even if self imposed?
  5. #15
    Jun 2019
    California, USA
    Why: that's what I'm asking help in this forum.
    Where: the "Low Pressure Light" came on, after troubleshooting decided to put a new oil pump; didn't fix the problem.
  6. #16
    How about inspecting the adjuster for cam & bridge for damage as a result from inadequate useful life failure & possible FOD?
    Did you change filter and inspect bypass or regulation for proper function?
  7. Likes NZDubNurd liked this post
  8. #17
    Jun 2019
    California, USA
    Does it have another name? I search on the Manual for "cam bridge", "camshaft bridge", "camshaft bracket", "adjuster" with no results.
    Wastegate Bypass Regulator Valve?
