Results 1 to 10 of 17
Thread: Whats the oil pressure at idle for a 2.0 engine?
    Jun 2019
    California, USA
    Hi to all, I have a 2009 Passat, 2.0 TSI engine.
    I started to troubleshoot the low oil pressure light and I connected a mechanical oil pressure gauge; engine cold start I have 40 psi and then starts to gradually go down and remains steady at 12 psi (after 15 minutes). If I increase the RPMs to 2000 the pressure goes up to 40-45 psi.
    This last number is consistent with the manual, however, I couldn't find a value for the pressure at idle.
    Anybody knows this or flat out 12 psi is too low for the engine?
    Thanks in advance!!
    I don't have a spec handy, but 12 psi at idle with the oil hot strikes me as OK / adequate.
    Auto-scan with VIN number?
    New User
    Sep 2019
    Denton, Texas, USA
    Around 12 will be fine
    Jun 2019
    California, USA
    Heres the auto scan...
    Saturday,07,September,2019,09:31:55:28298
    VIN: WVWJK73C89P051618   License Plate:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
              72
    VIN: WVWJK73C89P051618   Mileage: 220680km-137124miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 026 AG    HW: 06J 906 026 AF
       Component: MED17.5 TFSI 2,0    3319
       Revision: AAH03---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 00028 067 57207
       VCID: 6FBBD3A87B9BE4DF233-803A
    8 Faults Found:
                   P0300 - 000 -  - Intermittent - MIL ON
                        Fault Status: 10100000
                        Fault Frequency: 11
                        Mileage: 220168 km
                        Date: 2014.01.08
                        Time: 06:06:14
                        RPM: 1197 /min
                        Load: 24.7 %
                        Temperature: 31.0C
                        Temperature: 21.0C
                        Absolute Pres.: 960.0 mbar
                        Voltage: 14.224 V
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected - Intermittent
                        Mileage: 220559 km
                        Date: 2014.01.18
                        Time: 17:42:39
                        RPM: 1209 /min
                        Load: 22.0 %
                        Temperature: 41.0C
                        Temperature: 33.0C
                        Voltage: 14.097 V
    000771 - Cylinder 3
                   P0303 - 000 - Misfire Detected - Intermittent
                        Mileage: 220318 km
                        Date: 2014.01.09
                        Time: 21:03:12
                        RPM: 904 /min
                        Load: 22.7 %
                        Temperature: 82.0C
                        Temperature: 56.0C
                        Voltage: 13.589 V
    000772 - Cylinder 4
                   P0304 - 000 - Misfire Detected - Intermittent
                        Fault Frequency: 10
                        Mileage: 220318 km
                        Date: 2014.01.09
                        Time: 21:03:12
                        RPM: 904 /min
                        Load: 22.7 %
                        Temperature: 82.0C
                        Temperature: 56.0C
                        Voltage: 13.589 V
    000770 - Cylinder 2
                   P0302 - 000 - Misfire Detected - Intermittent
                        Mileage: 220559 km
                        Date: 2014.01.18
                        Time: 17:42:39
                        RPM: 1209 /min
                        Load: 22.0 %
                        Temperature: 41.0C
                        Temperature: 33.0C
                        Voltage: 14.097 V
    000289 - Throttle Position Sensor (G69)
                   P0121 - 000 - Implausible Signal - Intermittent
                        Mileage: 220396 km
                        Date: 2014.01.11
                        Time: 16:10:36
                        RPM: 824 /min
                        Load: 29.4 %
                        Speed: 3.0 km/h
                        Temperature: 98.0C
                        Temperature: 57.0C
                        Voltage: 13.081 V
    000545 - Angle Sensor 2 for Throttle (G188)
                   P0221 - 000 - Implausible Signal - Intermittent
                        Mileage: 220636 km
                        Date: 2014.01.19
                        Time: 20:04:57
                        RPM: 1864 /min
                        Load: 51.0 %
                        Speed: 31.0 km/h
                        Temperature: 99.0C
                        Temperature: 60.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.081 V
    005464 - Throttle Actuator (G186)
                   P1558 - 000 - Electrical Malfunction - MIL ON
                        Fault Status: 11100000
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 23.0C
                        Temperature: 24.0C
                        Voltage: 11.938 V
       Part No SW: 09G 927 750 GP    HW: 09G 927 750 GP
       Component: AQ 250 6F           1391
       Revision: 00H76000    Serial number:
       Coding: 0000840
       Shop #: WSC 00028 028 00001
       VCID: 055791004927CE8FF9F-8050
                013 - Check DTC Memory
                        Fault Status: 00101101
                        Reset counter: 201
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
       Component: J104    C4 440 V2   0013
       Revision: --025---    Serial number: 00000786382439
       Coding: 0000376
       VCID: 2F3B13A8BB1BA4DF633-807A
                        Fault Status: 01101101
                        Fault Frequency: 18
                        Reset counter: 180
                        Mileage: 220307 km
                        Date: 2014.01.09
                        Time: 15:51:47
                        Speed: 14.0 km/h
                        Hex Value: 0x002C
                        Voltage: 13.25 V
                        Bin. Bits: 00011111
                        Count: 217
                        Hex Value: 0x0000
       Part No SW: 1K0 820 047 JJ    HW: 1K0 820 047 JJ
       Component: Climatic PQ35   143 1313
       Revision: 00143033    Serial number: 00000000000000
       VCID: 75B7E1C019C7DE0FE9F-8020
       Revision: 00H54000    Serial number: 00000006016552
       Coding: 15848F0340041A00470000000F00000000285D435C000120000000000000
       VCID: 33331FD85733803F07B-8066
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 260908 004  0206
       Coding: 00046997
       Shop #: WSC 00028
       Revision: 00000000    Serial number: AUZ4Z7H0467065
       Coding: 0000100
                        Fault Frequency: 9
                        Reset counter: 10
                        Mileage: 216656 km
                        Date: 2013.10.21
                        Time: 15:03:34
       Part No SW: 5N0 959 655     HW: 5N0 959 655
       Component: J234__01F VW10 HI   1815
       Revision: 19013000    Serial number: 0039BPN4LW65
       Coding: 0012614
       VCID: 7AADF2FC30D9B17784D-802E
       Subsystem 1 - Part No: 3C0 959 339 D
       Component: BF-Gewichtsens. 001 0002
       Subsystem 2 - Serial number: 000000000029T8
       Subsystem 3 - Serial number: 0030.10.08000010000065006063
       Subsystem 4 - Serial number: 6500606333FTS614512908 63
       Subsystem 5 - Serial number: 12908 6343FTS609522748 63
       Subsystem 6 - Serial number: 22748 6353ETS6LIKOU5KJ 63
       Subsystem 7 - Serial number: OU5KJ 6363ETS6BBGOU5KJ 63
       Subsystem 8 - Serial number: OU5KJ 6374CTS6M52KVVNR 63
       Subsystem 9 - Serial number: KVVNR 6384CTS6H2HMVVNR
       Subsystem 10 - Serial number: MVVNR
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CN
       Coding: 0001111
       VCID: 74B1DCC412BDC707DE1-8020
       Part No SW: 3C0 920 971 S    HW: 3C0 920 971 S
       Component: KOMBI         H04 0110
       Coding: 260F00
       Shop #: WSC 00028 028 00021
       VCID: 353721C055C79E0F29F-8060
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P08A3002DA
       Coding: FD807F07001302001002
       VCID: 2A0D02BC80F9C1F7B4D-807E
       Part No SW: 3C8 919 965     HW: 3C8 919 965
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1614128T06YQ02
       Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 22138 444 999999
       VCID: 78A9E8F40ED5A367F29-802C
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
    01176 - Key
                        Reset counter: 181
                        Mileage: 198245 km
                        Date: 2012.09.23
                        Time: 06:50:56
    02811 - Control Module for Electronic Steering Column Lock (J764)
                        Fault Status: 00101110
                        Reset counter: 196
                        Mileage: 220167 km
                        Date: 2014.01.07
                        Time: 17:49:43
       Component: J386  TUER-SG FT    1517
       Revision: 72009005    Serial number: 00000768489007
       Coding: 0001205
       Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.082 0502
       Revision: 1AH02240    Serial number: 00082170130502
       Coding: 0000258
       VCID: 392F2DF0755F7A6FCD7-806C
       Component:    KSG PQ46 RDK 052 0412
       Coding: 13910F8001862E521004141FF08A0F0E085801
       Component: J387  TUER-SG BT    1517
       Revision: 72009005    Serial number: 00000626489004
       Coding: 0001204
       VCID: 70B9D0D466A5FB273A9-8024
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000189094
       Coding: 0000057
       VCID: 2809F8B49EF5F3E7A29-807C
       Part No SW: 1K0 035 180 N    HW: 1K0 035 180 N
       Component: Radio PM6       130 0046
       Revision: 00130000    Serial number: VWZ5Z7H2282132
       Coding: 0040402
       VCID: 2B0307B88F03D8FF4FB-807E
       Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
       Component: J388   TUER-SG HL   0308
       Revision: 42004101    Serial number: 00000000708029
       Coding: 0001168
       VCID: 72BDDADC68A9C937CCD-8026
       Component:    RDK              0453
       Coding: 0100101
       Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
       Component: J389   TUER-SG HR   0308
       Revision: 42004101    Serial number: 00000000712342
       Coding: 0001168
       VCID: 73B3DFD817B3C03FC7B-8026
    End----(Elapsed Time: 01:29, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
  6. Likes Uwe liked this post
    Jun 2019
    California, USA
    UPDATE.
    I manage to install a "T" with the switch and a mechanical pressure gauge attached. After aprox. 20 min the the warning light came on, I stop, open the hood and the pressure is CERO. Theres no weird sounds from the engine and it actually runs smooth. My questions are:
    1.- Can it be that a simple thing like an STP oil filter be causing this?
    2.- If I need to change the oil pump, do I have to remove the engine?
    At this point I'm considering selling the car as is if I need to remove the engine, but I'm hoping for a any suggestion that I'm missing to troubleshoot this issue.
    Thanks.
    What does Erwin say?
  9. #8
    Jun 2019
    California, USA
    Well erWin also says that I need a $200 equipment to test a $15 part.
    I got the oil pump out; does anybody rebuild them or is pretty much recycle can and buy a new one? a machine shop can rebuild it?
    Another question, what are the symptoms of a bad balance shaft?
  10. #9
    New User
    Aug 2019
    NJ, USA
    I would just throw a new pump in since there not that expensive and you have it out. But also pumps create flow, not pressure, its the restriction of flow/ restrictions/ tolerances technically that create the pressure. Side note, from a SSP there are if im not mistaken 2 or 3 different oil pumps for the tsi engines, vw to audi and maybe it was 2 for audi depending on year and engine code. Im interested in the outcome of this since oil pressure problems are becoming more apparent in these engines in all sorts of ways. A lot of times ive heard it'll come on when leaving or coming to a stop for a second and go away but also many other ways which is difficult to pinpoint, very intermittently. If anyone else has something to add on this, the balance shafts have little oil screens on them that clog up and can cause the light and or just lock the engine. The exhaust one has a plastic sleeve around it that can start breaking apart and block the oil screen also. The only real way to check the bearing play on them is to remove the lower timing cover and chains and physically check the play by hand, to check the oil screens you'd really have to remove them. (open to input) That being said these engines are very sensitive to oil pressure changes and the sensor picks it up, audi more so since it uses 2 sensors in the same spot as vw which has 1 on the gen 2 or 1 however technical you want to get. Also having so many little passages, screens, ports, seals, valves that can cause it, tracking it down can be difficult. I'm all ears to every oil pressure related thread with symptoms and solutions people find. Every piece of knowledge on this topic is worth knowing.
  11. #10
    Jun 2019
    California, USA
    Well I finally got to install the new oil pump and took the car for a test drive, same problem: almost 60 psi of pressure at cold, CERO after 5 miles.
    It's disappointing but it is what it is, not putting any more money in the car, will sell as is.
    Thanks all for the input and the help.
