Trouble with pop up's/baloons
vwparts
C?ID=76058
pretty sure it's a settings issue on my end. running windows 10 fwiw.
went to replace a G200 and had to do the log in. enter the log in code and never got the "log in accepted" pop up.
being a new user and not wanting to do anything bad, I had a friend link in with teamviewer to walk me thru the procedure. he said the pop up was working on his end, and that I ran the adaptation just fine.
what do I need to check to correct this? [redacted] is the license # I have. also, I get a communication error when trying to access NAV and Radio but my other scanner will get right in. I can watch the screen on the radio go into DIAG with VCDS, and it will get as far as a radio p/n before it aborts.
pretty sure it's a setting on my end causing this. I can post an autoscan if needed
Yes, an Auto-Scan and some screen-shots illustrating the problem would probably be useful.
vwparts
C?ID=76058
ok, thanks!
here's an auto scan
pay no attention to the codes in the engine controller...I was playing around causing issues just to play with VCDS
Saturday,07,September,2019,13:13:23:51893
VCDS Version: 19.6.1.0 (x64)
Dealer/Shop Name: Rizzo's Repair
Workshop Code: 444 00066 001022
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
   Mileage: 112650km-69997miles
Address 01: Engine        Labels: 06A-906-032-AMU.lbl
   Part No: 8N0 906 018 T
   Component: 1.8L R4/5VT     G   0003
   Coding: 06710
   Shop #: WSC 01236
   VCID: 428097554E45645FCF-50E6
16502 - Engine Coolant Temp. Sensor (G62)
            P0118 - 35-10 - Signal too High - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
            P1128 - 35-00 - System too Lean
            P1128 - 35-10 - System too Lean - Intermittent
Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
   Part No: 8N0 907 379 E
   Component: ESP     20    CAN  V004
   Coding: 18446
   Shop #: WSC 01236
   VCID: 3E78E3A53ABD00BFAB-4A9C
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 285425FDC839AE0FF1-2554
Address 15: Airbags        Labels: 8N8-909-601.lbl
   Part No: 8N8 909 601
   Component: Airbag Front+Seite 1005
   Coding: 10102
   Shop #: WSC 01236
   VCID: 77F636815507F1F7A8-513C
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 930 E
   Component: KOMBI+WEGFAHRS. M73 D08
   Coding: 07244
   VCID: 336EC29101FFDDD754-4A9C
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 B
   Component: HALDEX LSC  ECC     0006
   VCID: 1F463E219D7769B780-4AB4
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N7 962 267 A
   Component: Central Lock/Alarm  D04
   Coding: 15964
   Shop #: WSC 00066
   VCID: 3E78E3A53ABD00BFAB-4E78
Address 37: Navigation        Labels:
   VCID: 55AA5C09ACCBE3E79A-4A9C
   Note: Excessive Comm Errors
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8N7 951 177
   Component: Innenraumueberw.    D14
   Coding: 00001
   VCID: 7BFE2AB1692FD597CC-50AC
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00005
   Shop #: WSC 00066
   VCID: 65CA6CC9FFAB73670A-513C
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 8N0 035 186 A
   VCID: 2E58D3E5EADDF03F3B-4AB4
End-------------------------(Elapsed Time: 03:49)--------------------------
you can see the radio and nav have excessive comm issues...but I can get in using other scanners
here is where the login "bombs" with the pop up that says the controller accepted log in:
I can type in 40168, hit "do it!" and it just blinks and goes away, never telling me if it accepted the code or not.
not sure what's going on.
in terms of the nav/radio (which oddly still works fine) I am just nosey, and wanted to play around. I am not chasing an issue....yet :D
Ok, that's normal. When talking to a control module that uses the old KW1281 protocol (which this one does), there is no explicit acknowledgement from the module that a login was accepted. There can be a semi-explicit rejection in the form of an generic error in the next packet from the module, but most of the modules in using this protocol don't even do that; they just "hang up" the session. VCDS will then re-start a new session with the module and since it knows you tried a login, it will put a warning in one corner of the scree with the wording "Login lost due to dropped session" (or something very close to that).
As for the errors in the radio and nav (which are the same module, responding to two different addresses), what happens if you access them directly?
vwparts
C?ID=76058
if I do an auto scan and the radio is on, I will hear it cut out, it will try to get read...the radio will display "DIAG" and the fields will populate VAG # and component...then it will bomb. sometimes, it will only display VAG # and never get to component. happens radio on or off.
same thing happens if trying to do a log in with either NAV or radio.
last time I tried it, it went into diag on the screen and failed the same way. however, upon exiting the module the next key cycle all I had was radio static, could not use any of the buttons except for seek and the radio display was "frozen" in the cluster...radio on or off. hitting seek did nothing except "slot machine" the stations, and never stopped...it was like the antenna was disconnected.
the only way I got the radio back was to pull the fuse, re enter the radio code and it all came back to life.
autel, launch and strap-on all communicate just fine
That's quite strange/unique, and I'm not sure what's up with that.
What model year is this car?
vwparts
C?ID=76058
2001 TT 225 quattro.
like I said, not chasing any issues, I just wanted to "play" now that i'm a hack with VCDS and enough curiosity to get me in trouble :D
i'd be happy to let you do a teamviewer session so you can see what's happening if you'd like.
I'd like to suggest making a Debug file:
[Options] -> Set Debug Level to 1024
[Apply]
[Select]
[37-Nav] or [56-Radio]
Let VCDS try until it fails.
Exit VCDS as gracefully as you can.
Look in the Debug sub-folder and send the file(s) DEBUG-37.DLM and/or DEBUG-56.DLM to Support@...
Please include a link to this thread in your e-mail.
vwparts
C?ID=76058
[Apply]
[Select]
will do. I will try to do it asap. thanks for the help!
vwparts
C?ID=76058
email sent with link to thread. only had the 56 file, not the 37.
here is a screenshot of how far it will go. this is the farthest I have been able to get. sometimes it won't even populate the "radio" in the component field, just the p/n
vwparts
C?ID=76058
just checking in....
did my email/log go thru ok? no rush, I just wanted to make sure I pushed the right knobs and pull the correct levers
vwparts
C?ID=76058
just wanted to bump this up and see if there was any update. I understand you're busy and honestly would be surprised if you put any effort into a 01 audi haha
