Results 1 to 10 of 12
Thread: Trouble with pop up's/baloons
    Aug 2019
    pretty sure it's a settings issue on my end. running windows 10 fwiw.
    went to replace a G200 and had to do the log in. enter the log in code and never got the "log in accepted" pop up.
    being a new user and not wanting to do anything bad, I had a friend link in with teamviewer to walk me thru the procedure. he said the pop up was working on his end, and that I ran the adaptation just fine.
    what do I need to check to correct this? [redacted] is the license # I have. also, I get a communication error when trying to access NAV and Radio but my other scanner will get right in. I can watch the screen on the radio go into DIAG with VCDS, and it will get as far as a radio p/n before it aborts.
    pretty sure it's a setting on my end causing this. I can post an autoscan if needed
    Yes, an Auto-Scan and some screen-shots illustrating the problem would probably be useful.
    Aug 2019
    ok, thanks!
    here's an auto scan
    pay no attention to the codes in the engine controller...I was playing around causing issues just to play with VCDS
    Saturday,07,September,2019,13:13:23:51893
    VCDS Version: 19.6.1.0 (x64)
    Dealer/Shop Name: Rizzo's Repair
    Workshop Code: 444 00066 001022
    Chassis Type: 8N - Audi TT (1999 > 2007)
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
       Mileage: 112650km-69997miles
    Address 01: Engine        Labels: 06A-906-032-AMU.lbl
       Part No: 8N0 906 018 T
       Component: 1.8L R4/5VT     G   0003
       Coding: 06710
       Shop #: WSC 01236
       VCID: 428097554E45645FCF-50E6
    16502 - Engine Coolant Temp. Sensor (G62)
                P0118 - 35-10 - Signal too High - Intermittent
    17536 - Fuel Trim; Bank 1 (Mult)
                P1128 - 35-00 - System too Lean
                P1128 - 35-10 - System too Lean - Intermittent
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
       Part No: 8N0 907 379 E
       Component: ESP     20    CAN  V004
       Coding: 18446
       Shop #: WSC 01236
       VCID: 3E78E3A53ABD00BFAB-4A9C
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043 A
       Component: TT-KLIMAVOLLAUTOMAT D03
       Coding: 00140
       Shop #: WSC 01236
       VCID: 285425FDC839AE0FF1-2554
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 1005
       Coding: 10102
       Shop #: WSC 01236
       VCID: 77F636815507F1F7A8-513C
    Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
       Part No: 8N1 920 930 E
       Component: KOMBI+WEGFAHRS. M73 D08
       Coding: 07244
       VCID: 336EC29101FFDDD754-4A9C
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 B
       Component: HALDEX LSC  ECC     0006
       VCID: 1F463E219D7769B780-4AB4
    Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
       Part No: 8N7 962 267 A
       Component: Central Lock/Alarm  D04
       Coding: 15964
       Shop #: WSC 00066
       VCID: 3E78E3A53ABD00BFAB-4E78
    Address 37: Navigation        Labels:
       VCID: 55AA5C09ACCBE3E79A-4A9C
       Note: Excessive Comm Errors
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8N7 951 177
       Component: Innenraumueberw.    D14
       Coding: 00001
       VCID: 7BFE2AB1692FD597CC-50AC
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00005
       Shop #: WSC 00066
       VCID: 65CA6CC9FFAB73670A-513C
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 8N0 035 186 A
       VCID: 2E58D3E5EADDF03F3B-4AB4
    End-------------------------(Elapsed Time: 03:49)--------------------------
    you can see the radio and nav have excessive comm issues...but I can get in using other scanners
    here is where the login "bombs" with the pop up that says the controller accepted log in:
    I can type in 40168, hit "do it!" and it just blinks and goes away, never telling me if it accepted the code or not.
    not sure what's going on.
    in terms of the nav/radio (which oddly still works fine) I am just nosey, and wanted to play around. I am not chasing an issue....yet
    Quote Originally Posted by vwparts View Post
    Ok, that's normal. When talking to a control module that uses the old KW1281 protocol (which this one does), there is no explicit acknowledgement from the module that a login was accepted. There can be a semi-explicit rejection in the form of an generic error in the next packet from the module, but most of the modules in using this protocol don't even do that; they just "hang up" the session. VCDS will then re-start a new session with the module and since it knows you tried a login, it will put a warning in one corner of the scree with the wording "Login lost due to dropped session" (or something very close to that).
    As for the errors in the radio and nav (which are the same module, responding to two different addresses), what happens if you access them directly?
    Aug 2019
    if I do an auto scan and the radio is on, I will hear it cut out, it will try to get read...the radio will display "DIAG" and the fields will populate VAG # and component...then it will bomb. sometimes, it will only display VAG # and never get to component. happens radio on or off.
    same thing happens if trying to do a log in with either NAV or radio.
    last time I tried it, it went into diag on the screen and failed the same way. however, upon exiting the module the next key cycle all I had was radio static, could not use any of the buttons except for seek and the radio display was "frozen" in the cluster...radio on or off. hitting seek did nothing except "slot machine" the stations, and never stopped...it was like the antenna was disconnected.
    the only way I got the radio back was to pull the fuse, re enter the radio code and it all came back to life.
    autel, launch and strap-on all communicate just fine
    That's quite strange/unique, and I'm not sure what's up with that.
    What model year is this car?
  7. #7
    Aug 2019
    2001 TT 225 quattro.
    like I said, not chasing any issues, I just wanted to "play" now that i'm a hack with VCDS and enough curiosity to get me in trouble
    i'd be happy to let you do a teamviewer session so you can see what's happening if you'd like.
  8. #8
    I'd like to suggest making a Debug file:
    [Options] -> Set Debug Level to 1024
    [Apply]
    [Select]
    [37-Nav] or [56-Radio]
    Let VCDS try until it fails.
    Exit VCDS as gracefully as you can.
    Look in the Debug sub-folder and send the file(s) DEBUG-37.DLM and/or DEBUG-56.DLM to Support@...
    Please include a link to this thread in your e-mail.
  9. #9
    Aug 2019
    [Apply]
    [Select]
    will do. I will try to do it asap. thanks for the help!
  10. #10
    Aug 2019
    email sent with link to thread. only had the 56 file, not the 37.
    here is a screenshot of how far it will go. this is the farthest I have been able to get. sometimes it won't even populate the "radio" in the component field, just the p/n
  11. Likes Uwe liked this post
