Results 1 to 10 of 17
Thread: Unable to perform SRI
    Verified VCDS User Gremling's Avatar
    Dec 2017
    Norway, Nordland
    Hi, Gremling here,
    Last evening I tried to help out a friend with his VW Jetta, 2011 1,6 tdi, it had just been to service at a Toyota dealer/workshop ( we do not have a VAG dealer within a few hundre km). Anyway, the Toyota workshop, and also I was unable to reset the Service Reminder Indicator. Using my HexNet-V2 (VCDS) I got the message in my vag that the control module (for SRI system?) was not initialized. Tried to use the default values, to no avail. Tried according to a wici ross link, that also to no avail. Owner have had the car in for software update, regarding the environmental issue, at VAG workshop, prior to this service. He said last time the mentioned Toyota workshop also did the service, and that time they did not get problems resetting SRI. Any advices or tips?
    Will post scan later today, tomorrow or monday, unable to do so now
    Regards
    Gremling
    Posted from i-phone
    Oct 2016
    Stockholm Sweden
    If you are still using VagCom I suggest uppdating to VCDS release 19.6 for a start... and the SRI performance may be different to a Jetta I 161 (launched 1979 in europe) or a Jetta 1K3 (launched 2010) or other models in between...
    HQ
    2019 Jetta GLi? If not, please post an Auto-Scan so we can see what we are dealing with. And as noted, be sure you are running the latest version of VCDS, English version download page found here.
    Regards.
    Jef
    Dec 2017
    Norway, Nordland
    Its a 2011 1,6 tdi (although VIN has the C as 10th digit -> 2012.
    Have tried to, in the following order, and with test run in between:
    Reset SRI with Hexnet-V2 (VCDS), software version 19.6.0.6 (Have just gotten the 19.6.1 and installing it now, but scan has been done.
    Have tried to reset with a Delphi box / PC (but of course I prefer the VAGCom,
    Have tried the 0,0 Button followed by sign on, then the square Button and ignition of checked oil Says 1500km 731 days.
    Have tried to do it via MFD panel, service reset
    The symbol (looks like a spanner, if you have a good imagination) keeps coming back after a few km of driving.
    Auto scan here>
    Thursday,05,September,2019,03:09:00:27784
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VirtualBox)
    VCDS Version 19.6.0.6  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ16ZCM011561   License Plate: YE90921
    Mileage: 140990km-87607mi   Repair Order:
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 20 25 2E 42 44 46 4F 52 56 61
              62 69 72 77
    VIN: WVWZZZ16ZCM011561   Mileage: 140990km-87607miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 MQ    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9977
       Revision: --H43---    Serial number: 00000000000000
       Coding: 10254036032401080000
       Shop #: WSC 00066 000 00187
       ASAM Dataset: EV_ECM16TDI02103L906023MQ 003012
       ROD: EV_ECM16TDI02103L997557T.rod
       VCID: 015F7BB0618FC28FC5B-8055
       Part No SW: 0AM 300 051 T    HW: 0AM 927 769 D
       Component: GSG DSG AG7     421 2710
       Revision: 00042014    Serial number: TFK01105260709
       VCID: 3B23C9584F63685FDF7-806F
    006079 - Hydraulic Pump
                   P17BF - 000 - Play Protection - Intermittent
                        Fault Frequency: 13
                        Reset counter: 10
                        Mileage: 140786 km
                        Date: 2014.01.13
                        Time: 08:23:50
                   P17BF - 001 - Play Protection - Intermittent
                        Fault Frequency: 13
                        Reset counter: 10
                        Mileage: 140786 km
                        Date: 2014.01.13
                        Time: 08:23:50
    006300 - Function Restriction due to Insufficient Pressure Build-Up
                   P189C - 000 -  - Intermittent
                        Reset counter: 8
                        Mileage: 140940 km
                        Date: 2014.01.24
                        Time: 10:12:37
                   P17BF - 002 - Play Protection - Intermittent
                        Fault Frequency: 13
                        Reset counter: 10
                        Mileage: 140786 km
                        Date: 2014.01.13
                        Time: 08:23:50
    002113 - Transmission Fluid Pressure Sensor/Switch 1
                   P0841 - 000 - Implausible Signal - Intermittent
                        Reset counter: 9
                        Mileage: 140978 km
                        Date: 2014.01.25
                        Time: 13:13:50
       Revision: 00H31001
       Coding: A13B20F8092300FB851004EA901A0051210000
       VCID: 7BA3095803E3A85F9F7-802F
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Revision: 00001003
       Coding: 0000004003
       Shop #: WSC 00066 000 00119
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: 00597EB46A85CB87CA5-8055
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0046
       Revision: BC011001
       Coding: 00000A3A982D02C040080088140081E40371008860A085625CC087000041
       VCID: 3B23C9584363685FDF7-806F
       Component: RLS 300611 05  54  0403
       Coding: 02300A
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 5C6 919 475     HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H10 0005
       Revision: --------    Serial number: 84091115400251
       Coding: 118101
       Shop #: WSC 00185 218 94865
       ASAM Dataset: EV_EPHVA18VW3610000 001003
       ROD: EV_EPHVA18VW3610000.rod
       VCID: 71BF2B70512FD20F35B-8025
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Serial number: 003G6D059V74
       Coding: 00003242
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 323DE47C94A9A9170C1-8067
       Serial number: 3572MSME45310060ZZZC
       Serial number: 3582MSME6E04565FZZZ6
       Serial number: 3516KSME3B137410ZZZJ
       Serial number: 3526KSME43517B10ZZZM
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20110603201004
       Coding: 0892140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76B5186C3841F537E09-8023
       Component: E221__MFL-TAS  H08 0010
       Coding: 830000
       Part No SW: 5C6 920 871 A    HW: 5C6 920 871 A
       Coding: 171E00
       VCID: 2A0DFC1CBC79E1D7B41-807F
       Part No SW: 7N0 907 530 K    HW: 1K0 907 951
       Component: J533  Gateway H40 1620
       Revision:   H40       Serial number: 11071101290183
       Coding: 351002
       VCID: 3829D65472554347325-806D
       Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
       Component: FLA           H04 0006
       Revision: AA001002
       Coding: 0101006B74745D545420363E00
       VCID: 2D07F7008D17F6EF513-8079
       VCID: 6A8D3C1C7CF921D7741-803F
       Revision: A1001003    Serial number: 7660166335
       VCID: 290F0310B9FFEACFBDB-807D
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Revision: 12110009    Serial number: 0002924440
       Coding: 0210B7
       Shop #: WSC 01383 790 50316
       VCID: 1C612AC4E62D0F6736D-8049
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1508
       Serial number: 00000005872643
       Coding: 000090
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 70     3201
       Revision: 00H20000
       VCID: 3431E264623DA7271ED-8061
       Component: EZE_2         H40 1620
       Coding: 01030100
       VCID: 6FBB2D08479BC4FF23F-803B
       Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.019  H08 0006
       Serial number:     WRH0002GG9D
       Coding: 180000
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Revision: 14110009    Serial number: 0002864234
       Coding: 0210B6
       VCID: 1D6727C0FD37066FC13-8049
       Slave Passenger:
       Component: J389__TSG-HR  006 1508
       Serial number: 00000005871449
       Coding: 000090
       Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
       Component: Radio RCD510  050 0207
       Revision: 00000001    Serial number: VWZ1Z3L1549163
       Coding: 01000400040006
       VCID: 2C01FA04B60DFFE746D-8079
       Component: Batt.regelung H40 1620
       Coding: 030B185A
       VCID: 71BF2B7051AFD20F35B-8025
       Subsystem 1 - Part No SW: 5C0 915 181     HW: 5C0 915 181
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370755755
       Revision: 3A001001    Serial number: 00000148599580
       Coding: 410D000100000000
       VCID: 3039EE749A259B077A5-8065
    00532 - Supply Voltage B+
                011 - Open Circuit - MIL ON
                        Fault Status: 11101011
                        Reset counter: 74
                        Mileage: 139847 km
                        Date: 2013.12.08
                        Time: 12:45:40
       Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
       Component: TELEFON       H09 2730
       Revision: 1B001001    Serial number: 00007660119543
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA A01015
       ROD: UHVNA.rod
       VCID: 3431E2646EBDA7271ED-8061
    End----------(Elapsed Time: 01:32, VBatt start/end: 11.9V/11.8V)-----------
    Fault code for Trailer has now been cleared, and was caused by worn replaced battery. Auto GB has been changed or overhauled previously, and i have now deleted fault code
    Regards
    Gremling
    Gremling: hi. Have you followed the nifty Ross-Tech video ?
    OK, so that's a UDS cluster.
    Current versions of VCDS should allow you to use the SRI Reset button on that. It will give you some options for "NAR only" (or something like that) but they actually do work world-wide.
    Worst case, post a Adaptation Channel Map.
    Dec 2017
    Norway, Nordland
    Have tried all above tip for SRI reset, no difference, car is driven for a few km, and maintenance spanner comes up again (alternating spanner and gear indicated).
    S this has been tested, but no difference:
    Reset SRI with Hexnet-V2 (VCDS), software version 19.6.1, with Reset SRI
    Have tried to reset with a Delphi box / PC (but of course I prefer the VAGCom)
    Reset SRI with Hexnet-V2 (VCDS), software version 19.6.1, controller 17, and thereafter as shown 1/2 out in above video.
    Since this type of problem with his car started after the environmental upgrade, I have told my friend to take car back to the VAG workshop, where upgrade was done. I do not believe they will be much helpful there, as they are known for being both greedy and arrogant, but one never knows, they have just gotten a few new in management.
    Regards
    Gremling
  9. #8
    HQ
    Just laying this down here...
    Start VCDS, click on [SRI Reset], VCDS goes in and gathers data... user selects what action they want to perform from the drop down menu at the top of the screen. For a UDS like OP's case, it is always safe to select the "Reset FIX & ESI" option as shown below:
    All UDS clusters have the ESI option, but not all early UDS clusters have the FIX option, so VCDS will try and get a report back from the cluster along the lines of vales could not be saved since it doesn't know what FIX means.
    Once a selection is made from the drop down menu, click on [Perform SRI] at the bottom to have the request carried out.
    If one wants to go in an manually reset the service on a UDS cluster, you can follow the example shown on our wiki site for the 7P Touareg (it is all the same):
    http://wiki.ross-tech.com/wiki/index...ter#Adaptation
    Jef
  10. Likes Jack@European_Parts, Uwe liked this post
  11. #9
    Dec 2017
    Norway, Nordland
    Tried, all the above, no luck, drives car a few km and spanner shows up again.
    Seems like a module will not take/handle commands properly. When using VCDS and
    In control module 17 i see:
    Oil quality good
    Oil service done 1050km ago
    Max dist to next service 14050
    Service/inspection performed 44 days ago
    Time to service 371 days
    Regards
    Gremling
  12. #10
    Please post an Adaptation Channel Map from the instrument cluster in this car.
