Results 1 to 4 of 4
Thread: 2012 VW Passat TDI need help
    Mar 2019
    since April 2019, I have replaced water pump, timing belt, thermostat, radiator fan, transmission temperature sensor and it is still not fixed!
    the latest problems with the vehicle is as soon as I turn on the AC the vehicle will start overheating, and by overheating I mean that the temp gauge will begin rising above the middle divider where it should be. There is no leak of antifreeze, the level is in the norm when vehicle is cold.
    Also, the transmission would drive perfectly, but only when vehicle is cold. If I need to make a quick stop at the gas station to pump and turn off the vehicle as soon as I start it - it will go into Nutural and then if I turn off the vehicle and start it once more it will drive perfect again.
    What the hell is wrong?! any recommendations would be appreciated.
    Thursday,05,September,2019,17:54:23:42313
    VCDS Version: 19.6.1.0 (x64)
    VIN: 1VWCN7A35CC060811   License Plate: 7KQP428
    Mileage: 389670km-242129mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
              52 56 62 72 77
    VIN: 1VWCN7A35CC060811   Mileage: 389670km-242129miles
    Address 01: Engine (J623-CKRA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 997 009 J    HW: 03L 907 309 S
       Component: R4 2.0l TDI   H21 9982
       Revision: 71H21---    Serial number:
       Coding: 001D0012042400008000
       Shop #: WSC 26061 444 00000
       ASAM Dataset: EV_ECM20TDI01103L997009J 004005
       ROD: EV_ECM20TDI01103L997009J.rod
       VCID: 3B74BECFB2C0E9978C-806E
    8215 - Exhaust Gas Recirculation System
              P2457 00 [236] - Insufficient Cooling Performance
                        Mileage: 389419 km
                        Date: 2019.08.31
                        Time: 10:19:36
                        Engine speed: 1411.50 /min
                        Normed load value: 97.3 %
                        Vehicle speed: 46 km/h
                        Coolant temperature: 104 C
                        Intake air temperature: 42 C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 14.000 V
                        Sensor for engine block temperature: raw value: 103.9 C
                        Exh.gas temp.sen 4: 380.2 C
                        Exhaust mass flow of low-pressure EGR: 23.6 kg/h
                        Temp sensor for low-pressure EGR after cooler: raw value: 217.8 C
                        Low-pressure EGR cooling: model temperature: 172.2 C
                        Low-pressure EGR cooling: request status-Bits 0-7: 1
                        Low-pressure EGR cooling: request status-Bits 0-7: 255
    38303 - NOx Sensor 1 Bank 1
              P2201 00 [096] - Implausible Signal
                        Mileage: 388565 km
                        Date: 2019.08.23
                        Time: 16:58:29
                        Coolant temperature: 98 C
                        Intake air temperature: 46 C
                        Voltage terminal 30: 12.880 V
                        Air mass: actual value (mg/stroke): 0.0 mg/stroke
                        Mean injection quantity: 0.00 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                        NOx Emission NOx-Sensor: 0 ppm
                        Air mass for release of NOx sensor 1 offset test: 0.0 g
                        Calculated efficiency of NOx conversion: 0.950
    Readiness: 1 1 0 0 0
       Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 9435
       Revision: 05551213    Serial number: 00001112090944
       Shop #: WSC 40321 001 1048576
       VCID: 26427FBB9142447FC3-8072
       Revision: 00H31001
       Coding: C54BC0F5492800FAA31303E5921A0042A71000
       Shop #: WSC 09003 957 00200
       VCID: 7DF070D7E45427A7F2-8028
       Revision: 00085000    Serial number: 0161487923
       Coding: 130C0C
       VCID: 346695F39F9E26EF4D-8060
    1057547 - Antenna for Keyless Entry System; Interior Antenna 1
              B1172 13 [008] - Open Circuit
                        Reset counter: 90
                        Mileage: 388714 km
                        Date: 2019.08.24
                        Time: 09:33:11
       Part No SW: 561 907 044 H    HW: 561 907 044 H
       Component: Climatronic   043 0202
       Revision: 00001001
       Coding: 0010001012
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 1C365D53170E8EAF65-8048
       Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
       Component: BCM PQ35 H+   121 0164
       Revision: BL121001
       Coding: 6F200E3B982B08D4088802013600814800710086458005F0648060009C70
       VCID: 74E655F3D71E66EF8D-8020
       Component: RLS 030212 05  54  0403
       Coding: 06300A
                        Fault Status: 00101010
                        Reset counter: 94
                        Mileage: 388558 km
                        Date: 2014.01.13
                        Time: 16:49:02
                        Voltage: 13.65 V
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   013 0809
       Serial number: 003ENM01EMZ5
       Coding: 00003548
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 6FEC5A9FB638453770-803A
       Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
       Component: BF-Gewichtss.  H10 0045
       Serial number: 6940000Y120000AUAB0V
       Coding: 303047
       Serial number: 3572MSME326F3068ZZZ-
       Serial number: 3582MSME47507466ZZZX
       Serial number: 3516KSME574E1417ZZZW
       Serial number: 3526KSME23681F16ZZZW
       Serial number: 3556LSME3A201414ZZZJ
       Serial number: 3566LSME34051414ZZZH
       Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
       Revision: FF010040    Serial number: 20110729100513
       Coding: 000A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DF070D7EC5427A7F2-8028
       Component: E221__MFL-YVJ  H06 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 970 C    HW: 561 920 970 C
       Component: KOMBI         H07 0507
       Coding: 231E01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
       VCID: 1A3A5B4B1D3AF09F77-804E
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 07021201290602
       Coding: 461000
       VCID: 3D70B0D7A4D4E7A7B2-8068
       Component: IMMO          H07 0507
       Coding: 000007
       VCID: 6ADA4B8B8DDAA01F27-803E
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000274387004
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E52879B71B20C3F3B-807A
       Revision: A1001003    Serial number: 7661543498
       VCID: 29587487405C6B07EE-807C
       Part No SW: 561 959 760     HW: 561 959 760
       Component: MEM-FS        H04 0181
       Revision: AA000000    Serial number: 00000022806321
       Coding: 0000000000000000000000000000000000000000000000
       VCID: 60CE29A373E6EA4FF9-8034
       Part No SW: 3C8 035 684 E    HW: 3C8 035 684 E
       Component: RNS-MID       H61 3690
       Revision: AB001001    Serial number: VWZ6Z7M4047073
       Coding: 04090002010000A6000B
       VCID: 2D50809774B4772702-8078
                        Fault Frequency: 22
                        Reset counter: 94
                        Mileage: 388512 km
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0525
       Revision: 12110009    Serial number: 0003494557
       Coding: 0405FD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  004 4472
       Coding: 800000
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 92
                        Mileage: 388517 km
                        Date: 2019.08.21
                        Time: 19:14:28
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 95
                        Mileage: 388517 km
                        Date: 2019.08.21
                        Time: 19:14:28
       Part No: 1K0 909 144 N
       Component: EPS_ZFLS Kl. 290    3301
       Revision: 00H22000
       VCID: 3560A8F75CE43FE77A-8060
       Part No SW: 5C6 035 456     HW: 5C6 035 456
       Component: KonzernAmp10K H07 0468
       Revision: --------    Serial number: EAA083A0006189
       VCID: 65C038B764C48F670A-8030
       Component: EZE_2         H40 1623
       Coding: 01030108
       VCID: 6FEC5A9FBE38453770-803A
       Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
       Component: J245 P05 FFD7  H07 0004
       Serial number: 53388786011134400591
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0004
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0525
       Revision: 14110009    Serial number: 0003546138
       Coding: 0405FC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1D3050570C1487A792-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  004 4472
       Coding: 800000
                        Fault Frequency: 22
                        Reset counter: 94
                        Mileage: 388512 km
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661523680
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 275C72BF5E485D77F8-8072
    End-------------------------(Elapsed Time: 03:32)--------------------------
    Apr 2015
    South Africa
    Try do read temperatues on engine & gearbox with vehicle idling and aircon off until the rad fan switches on/off? Then switch the aircon on and monitor the temps again? Is there any difference? Also monitor gearbox temperature at idle and after driving a distance?
    Does turning on the AC produce the expected/appropriate behavior from the radiator fans?
    As for the DSG: It has almost 1/4 million miles on it. What maintenance/ repairs have been done?
    Do radiator fans come on and high speed when AC is turned ON and temp rises?
