Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Audi Q7 2014 S-Line; how to disable all lights and minimize power consumption
    It's quite possible to design a battery with tiny capacity but huge CCA
    Or vice-versa. In fact, it's a trade-off the in the design of almost any battery.
    And of course a test for one characteristic tells us little or nothing about the another one. One can have an old battery that still tests OK for CCA but has lost much of its capacity.
  2. Likes PetrolDave liked this post
  3. #12
    Sep 2019
    Seattle, USA
    Are you guys saying that the “Battery Aging” as reported by the Q7 should not be relied upon when determining whether to replace the battery or not? Would not this be a value that the Audi dealership would use to recommend whether to replace the battery or not?
    In my case it is not practical to use the best method (charge it fully then discharge it while measuring amp hours). So what is the next best method?
    Do we mean that is is better to just use actual age and if it is more then 5 years, then replace the battery irrespective of what “Battery Aging” value is being reported?
  4. #13
    Quote Originally Posted by andremi View Post
    IMHO "Battery Aging" cannot be relied upon as an accurate indication of battery condition (ability to start and hold charge), any dealership that used only this parameter is not a dealership that I would take my car to!
    Actual age isn't a good guide either, battery condition is subject to how it's been used/abused, temperatures it's been subject to, etc.
    I prefer to rely upon old fashioned methods - does the battery hold charge and/or does the battery have trouble starting the car on cold mornings as a guide when to change the battery.
  5. Likes Uwe liked this post
  6. #14
    Yup, and lead-acid batteries hate to be deep-cycled, especially those that are primarily designed as "starter" batteries. Worse is if you let them sit for any length of time in a deeply discharged state.
    That said, a typical car battery "should" last 5-8 years, but there are always exceptions. I've seen batteries go bad in 2-3 years that have no apparent excuse for it (never abused), and others that have been abused last 7-8 years anyway.
    Yeah, and in the OP's use case, does the battery still have the Ah capacity to do what he needs it to do when he's camping?
  8. #15
    Dec 2016
    Amsterdam
    CCA = ability to provide lots of peak current
    Capacity = ability to store lots of energy
    Any Lithium-Ion starter battery designed for use in vehicles will fit that description.
    Current:
  9. Likes PetrolDave liked this post
  10. #16
    Sep 2019
    Seattle, USA
    Thanks guys. I will keep my current battery for now. It does not show any problems during normal use. During camping use I do not think I am using the car in a way it was design for. So no matter how much stored capacity it would have I would eventually depleted it. Ideally the car could just hibernate by persisting all its settings into nvram and I could simply disconnect the battery and reconnect when needed. I will put the car into transport mode and will monitor battery use more carefully next time (or let the car run idle for an hour once a day).
    The Interstate battery I got has a higher CCA and lower aH then the OEM one ([850,80] vs [520,110]), so I am returning it. When the time is to replace the battery, I will go with OEM, or “lifetime autonation” which is also sold by the dealer and has the same specs, but offers lifetime warranty.
  11. #17
    Maybe you should also consider a solar battery charger? There's a zillion of them out there, this is just an example:
    https://www.amazon.com//dp/B0722XB3VQ/
    Note that the lighter plug may no work on your car; I'm guessing the power outlets are switched power? VW/Audi used to have some that had an OBD-II plug. Not sure how much juice they made though.
  12. #18
    Sep 2019
    Seattle, USA
    Hmm, solar is very interesting, I was not aware such thing existed but feels like it would work great for my case. I think the lighter plug should work on Q7 — when I lock the car I can see that the phone is still charging from that plug (as an experiment). So I gather solar panel should be able to trickle charge the battery.
