Results 1 to 10 of 18
Thread: Audi Q7 2014 S-Line; how to disable all lights and minimize power consumption
    Sep 2019
    Seattle, USA
    I am using this car for camping often. That means we often need to open / close doors and lid without starting the car. Unfortunately every time a door or lid is opened, the light comes on and stays that way for a long time. Also opening doors likely powers up bunch of other subsystems. On the last trip the car ended up with drained battery after 3 days (hence bunch of error codes in the scan data). We ended up charging it from another car for an hour and then jump starting.
    Since then I have used the button above the mirror to turn off the dome lights. But it does not help with the red lights on the door and the lid lights. Then I have enabled "green" MMI menu and reduced "Standby delay (Min)", "Power down delay (Min)", "BEM shutdown delay (Min)" from 10,15,2 to 2,3,1. (this was after I run the vcds scan). But I still see that the lid light and the red door light stay ON for longer then 3 minutes, so I am not sure if “green menu” settings take effect.
    When opening doors / lid with the engine off, I would like no lights or illumination to come up. Also I’d like to reduce the subsystems current usage to further slow down battery drain. Ideally there would be a toggle in MMI, (or ability to hook it up to one of existing hardware buttons) where I can put the car in the “low power consumption mode” and turn it off when I am back to the city. Is this possible?
    Thank you!
    Wednesday,04,September,2019,15:38:39:64963
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WA1DGAFE1ED0XXXXX   License Plate:
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
              55 56 5F 62 69 6C 6D 6F 72
    VIN: WA1DGAFE1ED0XXXXX   Mileage: 73390km-45602miles
    4C-Tire Pressure II -- Status: Malfunction 0010
    Address 01: Engine (CTW)       Labels:. 06E-907-551-CAJ.clb
       Part No SW: 4L0 910 551 Q    HW: 4L0 907 551 A
       Component: 3.0l V6 TFSI        0030
       Revision: --H08---    Serial number:
       Coding: 0121000A290F0128
       Shop #: WSC 31414 790 00001
       VCID: 3635DA133448A187205-8062
                   U1017 - 000 -  - Intermittent
                        Mileage: 72023 km
                        Date: 2019.08.18
                        Time: 11:36:02
                        RPM: 1504 /min
                        Mass Air / Rev.: 223.5 mg/str
                        Temperature: 22.5°C
                        Bin. Bits: 00000010
                        Load: 23.1 %
    012371 - Starter Control; Returned Message
                   P3053 - 000 - 50 Short to Ground - Intermittent
                        Fault Status: 00100001
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 18:07:05
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 24.0°C
                        Bin. Bits: 00000000
                        Voltage: 6.22 V
       Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
       Component: AL1000 AISIN  002 2443
       Coding: 001378
       Shop #: WSC 46136 001 1048576
       ROD: EV_TCMAL991031_002.rod
       VCID: 3A2DCE230CD045E7C4D-806E
       Revision: 00H02001
       Coding: 0099409
       VCID: 3431E01B2234B3971E1-8060
                        Reset counter: 203
                        Mileage: 72023 km
                        Date: 2019.08.18
                        Time: 11:36:01
                        Count: 128
                        Count: 10561
                        Count: 128
                        Count: 34048
                        Reset counter: 188
                        Mileage: 73238 km
                        Count: 192
                        Count: 9029
                        Count: 297
                        Count: 36352
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702088268
       Coding: 0000135
       VCID: 25170D5F99EEDA1F99F-8070
       Component: FBSAUDIC6 EZS   H04 0020
    10 Faults Found:
                007 - Short to Ground
                        Fault Status: 01110111
                        Fault Frequency: 13
                        Reset counter: 62
                        Mileage: 62440 km
                        Date: 2018.11.01
                        Time: 08:19:43
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Fault Frequency: 23
                        Reset counter: 188
                        Mileage: 62764 km
                        Date: 2018.12.01
                        Time: 10:53:45
                        Fault Status: 00111000
                        Fault Frequency: 78
                        Reset counter: 227
                        Mileage: 61867 km
                        Date: 2018.10.15
                        Time: 07:21:51
                        Fault Status: 00111011
                        Reset counter: 209
                        Mileage: 63095 km
                        Date: 2018.12.29
                        Time: 13:42:35
                        Reset counter: 157
                        Mileage: 66564 km
                        Date: 2019.03.05
                        Time: 08:37:11
    01176 - Key
                        Fault Status: 00110100
                        Reset counter: 228
                        Mileage: 69413 km
                        Date: 2019.05.16
                        Time: 08:35:37
    00190 - Driver's Door Handle Touch Sensor (G415)
                        Reset counter: 188
                        Mileage: 71731 km
                        Date: 2019.08.11
                        Time: 12:01:59
                        Fault Frequency: 9
                        Reset counter: 227
                        Mileage: 72718 km
                        Date: 2019.08.27
                        Time: 15:03:40
    00532 - Supply Voltage B+
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:42:23
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:41:26
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
       Revision: 00---031    Serial number: 00000030302278
       Coding: 000AC026
       VCID: 25170D5F95EEDA1F99F-8070
       Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0074061564
       Coding: 070000
       Subsystem 2 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
       Serial number:           0073959558
       Coding: 070000
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0133123
       VCID: 6E8532730C98D947285-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                        Reset counter: 228
                        Mileage: 73236 km
                        Date: 2019.09.02
                        Time: 17:39:00
                        Reset counter: 228
                        Mileage: 73236 km
                        Date: 2019.09.02
                        Time: 17:39:00
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55931326000526
       Coding: 24011F
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 3431E01B2EB4B3971E1-8060
       Component: 73 AIRBAG AUDI8RH44 0230
       Revision: 08H44000    Serial number: 0038QD0CC4RJ
       Coding: 0014131
       VCID: 2B03FB67FF0AEC6F4FB-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME7F37244EV
       Subsystem 3 - Serial number: 6342QSME79373156H
       Subsystem 4 - Serial number: 6352QSME76375140A
       Subsystem 5 - Serial number: 6362QSME7C375674T
       Subsystem 6 - Serial number: 63734SME13335762V
       Subsystem 7 - Serial number: 63834SME76334262Z
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H09000    Serial number: 90026131730218
       Coding: 0012142
       VCID: 2809046BEEFCC777A29-807C
       Component: E0221           H03 0040
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 18:07:10
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 18:08:05
       Part No SW: 4L0 920 985 S    HW: 4L0 920 985 S
       Component: KOMBIINSTR.   H35 0317
       Revision: 00000000    Serial number: VJ350MR9E
       Coding: 8BD663040900CF05020205
       VCID: 44D1B0DB7E940317AE1-8010
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB700037    Serial number: 3700M138310AD6
       Coding: 00C303
       VCID: 3FDBBF37177260CFF33-806A
       Component: J367-BDM  H07 0125
       Serial number: 40255715024121017527
                        Reset counter: 228
                        Mileage: 72023 km
                        Date: 2019.08.18
                        Time: 09:57:42
                        Bin. Bits:    00000
                        Voltage: 11.10 V
                        Count: 8
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 18:03:20
                        Bin. Bits:    00000
                        Voltage: 7.90 V
                        Count: 12
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AD
       Revision: 00---011    Serial number: 00000030302382
       Coding: 0000006
       VCID: 6889446B2E7C0777629-803C
    00003 - Control Module
                        Fault Status: 00100011
                        Fault Frequency: 7
                        Mileage: 48455 km
                        Date: 2017.08.21
                        Time: 14:18:48
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0064
       Revision: AA000000    Serial number: 00000073518967
       Coding: 00581B00000011110000
       VCID: 323DE603D420BDA70CD-8066
                        Fault Frequency: 13
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:48:51
       Component: J0769_SWA_MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 009 014-10
       VCID: 2E05F273CC189947685-807A
       Component: J0770_SWA_Slave_H02 0050
       Subsystem 3 - Serial number: 5F11.09.1300H02000AMS14909˙
       Subsystem 4 - Serial number: S14909˙
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000076445950
       Coding: 011F57205E40440004
       VCID: 48C9A4EB42BC2777429-801C
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:49:45
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 18:03:48
    01705 - Selection Switch for Mirror-Adjust (E48)
                        Reset counter: 189
                        Mileage: 73393 km
                        Date: 2019.09.03
                        Time: 20:15:11
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01938057620000
       Coding: 3569949
       VCID: 3829D42B3E5C57F7329-806C
    03073 - Rear Lid Closed Sensor 1
                        Reset counter: 202
                        Mileage: 72023 km
                        Date: 2019.08.18
                        Time: 08:51:11
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H04 0160
       Revision: CH004001    Serial number: 00000000014057
       Coding: 030000
       VCID: 290F016FF9F6FE7FBD7-807C
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005191024654
       Coding: 0693965
       VCID: 2313134797DA242FF7B-8076
                        Fault Status: 00101101
                        Reset counter: 229
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 20:23:41
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0005
                        Voltage: 11.50 V
                        Temperature: 25.0°C
                        (no units): 0.0
                        Reset counter: 229
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 20:23:41
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0005
                        Voltage: 11.50 V
                        Temperature: 25.0°C
                        (no units): 0.0
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000154911
       Coding: 0012001
       VCID: 5EE562B3FC3849C7985-800A
                        Fault Status: 00110010
                        Reset counter: 228
                        Mileage: 73236 km
                        Date: 2019.09.02
                        Time: 18:08:00
                        Voltage: 6.800 V
                        Temperature: 25.0°C
                        Reset counter: 228
                        Mileage: 73236 km
                        Date: 2019.09.02
                        Time: 18:22:00
                        Voltage: 5.900 V
                        Temperature: 77.0°C
                        Reset counter: 228
                        Mileage: 73236 km
                        Date: 2019.09.02
                        Time: 17:49:00
                        Voltage: 8.200 V
                        Temperature: 77.0°C
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000076467256
       VCID: 47CBA7D74FA2280F4B3-8012
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:49:44
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:50:38
       Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
       Component: AFS 1           H01 0010
       Coding: 0000031
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156I00D7906344
       Coding: 020007010000000000
       VCID: 2411105B9ED423178E1-8070
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:49:11
                        Voltage: 8.70 V
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:40:21
                        Voltage: 9.30 V
                        Reset counter: 228
       Part No SW: 4L2 035 746 D    HW: 4L2 035 746 D
       Component: H-BNT-NA      H40 0738
       Revision: --------    Serial number: 224IX0D7528401
       Coding: 180200060004E1EF510023456F632003140000000100000000
       VCID: 2F3BEF77C712904F633-807A
       Subsystem 1 - Part No: 8R0 060 884 BD
       Component: NAR 2013/2014  0802
       Component: DU7 High  H42 0104
       Serial number: A130IX0D2827084
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002136672
       Component: CD-Database  5298
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 18:03:34
                        Voltage: 8.00 V
                        Reset counter: 228
                        Time Indication: 15
    03367 - Supply Voltage for Display Module
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:48:27
                        Voltage: 8.80 V
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000076485385
       Coding: 010E57204040230004
       VCID: 46D5AAD348A83107B05-8012
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:56:06
                        Reset counter: 189
                        Mileage: 73393 km
                        Date: 2019.09.03
                        Time: 20:55:26
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Component: Anhaenger     H12 0100
       Revision: 2A001001    Serial number: 00000375154401
       Coding: 0200000000000000
       VCID: 313FE90FD12686BF757-8064
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:48:43
       Revision: --H08---    Serial number: 525PA8-J3841HA
       Coding: 1021201
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:41:56
                            Term 15 Off
                            Reverse OFF
                        Count: 3
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 18:02:46
                            Term 15 Off
                            Reverse OFF
                        Count: 3
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C81387B3A842B57061-8038
    ó
       Subsystem 3 - Serial number: RD21.09.13--H57001002G0072˙
       Subsystem 4 - Serial number: 2G0072˙
                        Reset counter: 40
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 18:02:54
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 0076052460----
       Coding: 0003595
       VCID: 26150A53E4E8D107905-8072
       Component: J_245_EE16_SKB10H14 0220
       Component: J_394_EE16_SKB10H14 0220
       Component: J_392_EE16_SKB10H14 0220
                        Fault Frequency: 25
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:47:48
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000076485384
                        Reset counter: 228
                        Mileage: 73238 km
                        Reset counter: 228
                        Mileage: 73238 km
                        Date: 2019.09.02
                        Time: 17:48:30
    End----------(Elapsed Time: 02:30, VBatt start/end: 14.3V/14.3V)-----------
    Apr 2018
    ITALY
    I don't know the Q7 platform but what you're asking is very particular and I bet my ass it cannot be coded that way.
    you could install a hard switch that cuts all the lights you want, but then you'd be left with plenty of errors, with some probably visible on the dash.
    I believe the car already has power management features, and most (if not all) lights are LEDs, which draw very little current.
    are you sure you just didn't have a weak/old battery?
    my Golf came out of the factory with 13 ECUs. now she has 19. and counting
  3. Likes Uwe liked this post
    Sep 2019
    Seattle, USA
    I thought that battery is an issue, but the vcds battery test shows it’s 21% used (has 79% to go before depleting “Battery Aging”), see the image link below
    https://www.amazon.com/photos/shared...bnY7n_MxU1y1ae
    Q7 had the doors open most of the last day with multiple people opening / closing them all the time. We had the other car was with us which was used in the same way and it did not have any problems with starting. I do not know if Q7 lights are LED, but I remember people posting that leaving Q7 dome lights overnight via open doors will drain the battery.
    If I cannot code this to the switch, can I at least turn off the red lights and lid lights with vcds so I would configure that before camping trip and restore to original settings when I am back.
    Quote Originally Posted by andremi View Post
    Is the battery the original one supplied with the Q7 in 2014?
  6. Likes Uwe liked this post
    Jun 2014
    Newcastle, England
    One of the first things I'd do; would be to activate Transport Mode. This should kill the lights operating on each door opening.
    However, there's a double-edged sword with what you're trying to do. The car is at its most frugal on power, when BCM knows it's locked. It can't (and doesn't really) shut-down whilst a door is open. Here's a bit of current draw testing I did on my car a few years ago. You'll see when locked, current draw drops down to the mA level of the alarm LED flashing. I never did track down what that 8-10A draw was before it went to sleep; but my hunch is the BCM2 and sound equipment.
    The advanced level would be to dig around in the Wiring Diagrams to see what you could either intercept or alter to allow the BCM to shut down.
    The quickest and easiest thing to do will be Transport Mode, ([Applications] > [Activate Transport Mode]) so please try that first and report back.
  8. Likes Uwe, jyoung8607 liked this post
  9. #6
    Quote Originally Posted by Zenerdiode View Post
    Are you sure it cares whether it's locked or not? I park cars in my garage all the time w/o locking them and never have a problem with battery drain. I guess it's possible it goes to sleep faster if you lock it, but I think it will go to sleep properly even if it's not locked.
    Agreed. Leaving doors open is bad.
    I like the Transport Mode suggestion. I also suspect the OP's battery is in worse shape than he thinks it is.
  10. Likes jyoung8607 liked this post
  11. #7
    +1
    Why I asked if the battery is the original one
  12. #8
    Sep 2019
    Seattle, USA
    Guys,
    I have enabled transport mode and happy to report that the lid lights and “under the seat” lights are off. Also the car does not start the MMI when turned on. The interior handle red lights and red door lights are still on. But this is already a huge improvement: I can probably manage with having lid open and do not open doors. Thanks a lot!
    As a side note, the key reason for this door / lid closing/opening was that we were off the paved roads in the “bear country” where all the food, cooler, trash, utensils, cooking stove, etc has to be packed back into the car any time we leave the camp or for the night and retrieved back on return.
    I also think a part of drain is attributed to lid motor operations, as this one was used to open/close a lot. Previously, on a shorter but similar trip in July the lid stopped working just before we were departing and had to be opened / closed manually. During that July trip, when I started the car on, the MMI said that the car was trying to save energy and thus entered into power saving mode. Within an hour of driving MMI restored it’s function. During the most recent trip lid motor also stopped working at some point, but I foolishly assumed that I do not have to worry about it and the car will figure out how to save the energy. Is there a way to turn off lid motor pre-emptively with vcds?
    Regarding the battery question: I purchased the car when it was one year old, so I think it is safe to assume that it has the original battery. With 5 years on it, it seems like a good time to replace it and a few days ago I purchased Interstate battery with the intent of replacing my battery. (the sales person had 3 models for Q7 with different CCAs and was asking me which one I need. I had no idea so picked the 900 CCA one and if my car would have a different CAA, I'd go back to Interstate and get the right one). But then I run vcds tests (link that I posted above) which shows the battery being healthy. Also the battery does not exhibit usual “worn battery” problems – no slow window rolling with engine off, starts fine below freezing (6 month ago), etc. I am contemplating on purchasing battery CCA meter to test it for sure, but have not done that yet.
  13. #9
    CCA is not the determining factor in this type of scenario, Ah capacity is. The only way to determine that on a used battery is to charge it fully and then discharge it over a long period of time while measuring the actual amp-hours that you can get out of it.
  14. Likes PetrolDave liked this post
  15. #10
    CCA = ability to provide lots of peak current
    Capacity = ability to store lots of energy
    It's quite possible to design a battery with tiny capacity but huge CCA
