- Joined
- Sep 5, 2019
- Messages
- 19
- Reaction score
- 0
- Location
- Istanbul, Turkey
- VCDS Serial number
- C?ID=352356
Trying to upgrade to the 2017 audi A3 pla 3.0. but 03 abs longcoding consists of 46 bytes, I couldn't find which bytes to change. Could you help. sorry for google translation
Thursday,05,September,2019,10:29:51:18632
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8V8HA090521 License Plate: 34XXXX
Mileage: 26291km-16336mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 5F BB BC
VIN: WAUZZZ8V8HA090521 Mileage: 26291km-16336miles
Address 01: Engine (J623-CHZD) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 AB HW: 04C 907 309 AE
Component: R3 1.0l TFS H25 3494
Revision: W1H25---
Coding: 02250032230401083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM10TFS01104C906026AB 002006
ROD: EV_ECM10TFS_VW37.rod
VCID: 619E50A631CD268FA57-8034
CAN Converter 01:
Readiness: 0110 0001
Part No SW: 0CW 300 040 S HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1004
Revision: 00005026 Serial number: CU501612067177
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW31.rod
VCID: 44D0B9328E1F53A7AE1-8010
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 63426000005699
Coding: 12F16AA22429126C8B7C0E0240C42448562448D1700224730021F0748208420000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
VCID: 78A81DC28257C747F29-802C
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0425282748
Coding: 030C0C
VCID: 3B22C2CEF3E12C5FDFB-806E
Part No SW: 8V0 820 043 M HW: 8V0 820 043 M
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001112247
Coding: 03000003000000001000000000001000
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 3C20C1D2F6EF2B67D61-8068
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: CC18C16800PAG0MUFU03
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001634301663
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5AF6DEA779F07FB33-802A
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160829 043 0580
Serial number: 160905181913
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62499567
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 28 09 2016 00000685
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417618240
Coding: 0271061011
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000.rod
VCID: 51FE8066416DB60F157-8004
13697025 - Control Module
U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
[Steuergerät für Lenkhilfe-J500 - LH_EPS_01.EPS_PLA_Status - PLA-Codierung in Lenkhilfe prüfen]
Reset counter: 170
Mileage: 26291 km
Date: 2019.09.05
Time: 10:25:24
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2EKAF4
Coding: 98CCC000000000005C5400CA004800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 107845628AE7FF075A9-8044
Subsystem 1 - Part No SW: ----------- HW: 480 000 712 16
Serial number: 35700000000B487D5F1-
Subsystem 2 - Part No SW: ----------- HW: 480 000 712 16
Serial number: 358000000000587D5F1R
Subsystem 3 - Part No SW: ----------- HW: 480 401 012 16
Serial number: 3510001C922CA562D2CB
Subsystem 4 - Part No SW: ----------- HW: 480 401 012 16
Serial number: 3520001C122CA561D582
Subsystem 5 - Part No SW: ----------- HW: 480 401 211 16
Serial number: 3550002A922C8EB53207
Part No SW: 8V0 953 521 JP HW: 5Q0 953 549 E
Revision: -------- Serial number: 05121604400904
Coding: 8418
VCID: 117E406681EDF60F557-8044
Part No SW: 8V0 920 872 N HW: 8V0 920 872 N
Component: KOMBI H04 8316
Coding: 0B8D0A182B8000081601BA001001000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 48C8AD02B23777C7429-801C
Part No SW: 3Q0 907 530 B HW: 3Q0 907 530 B
Component: GW MQB Mid 417 4286
Revision: -------- Serial number: 0005634520
Coding: 030100043F0857005B000248100B00000001010000000000000000000000
ROD: EV_GatewNF.rod
VCID: 2E04FB9A3093C9F7685-807A
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0003
Serial number: 20161125025749 20416
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001612075678
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000212777006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3430E9F2DEBFE3271E1-8060
Component: TSG FS 020 0041
Serial number: 251116EKO07236
Coding: 001C9B204000040000001002
VCID: 43D2BA2E8B11549F97B-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 0107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D6A43685256AAFB9F-8010
Component: TSG BFS 020 0041
Serial number: 271116EKR01536
Coding: 001C93204C00040000001002
VCID: 42DCBF2A940B5D979CD-8016
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 81A 035 824 A HW: 81A 035 824 A
Component: MU-S--ER 710 0771
Coding: 01730300FF00000011110001000A00002F0024940170010002
ASAM Dataset: EV_MUStd6C3DELP 001013
ROD: EV_MUStd6C3DELP_AU37.rod
VCID: 211E10A6714D668FE57-8074
Subsystem 1 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY2094WU
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 BB HW: 8V0 919 614 BB
Component: ControlUnit_B H50 0103
Serial number: ALJAL117101600020120
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 211116EKL11476
Coding: 000C93204000040000001002
Component: TSG HBFS 020 0041
Serial number: 211116EKL11336
End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
