Results 21 to 30 of 33
Thread: 5Q0 614 517 CF 46 BYTES PLA 3.0 CODING
  1. #21
    Apr 2018
    ITALY
    in my Golf, the automatic braking when manouvering was working with PLA 2.0 and indeed stayed with 3.0
  2. #22
    May 2017
    ^ That is not possible. Only the newer PLA3.0 modules support maneuvre braking. I’ve had all three (2.0, old 3.0, new 3.0) and I still have all three modules in my garage so easy to test
  3. #23
    Jun 2014
    noot only
    even simple PDC 8k with 5QA module also stop car when reversing
  4. Likes downtime liked this post
  5. #24
    May 2017
    Yes true, good clarification. Thank you
    But the key is exactly that you need to have 5QA module or 3Q0 newer module for the maneuvre brake. I’ve never seen that on PLA2.0 module.
  6. #25
    Apr 2018
    ITALY
    I might simply remember wrong.
    as a side note, can you elaborate on "old 3.0 vs new 3.0"?
  7. #26
    May 2017
    The new modules are for example maneuvre brake capable.
    5Q0 is older module without maneuvre brake. 5QA is able to do it. Also 3Q0 919 298 module that is for example in new Tiguan is able to do maneuvre brake.
    And also I think for area view you need the newer module. Otherwise the overlay doesn't work correctly.
  8. #27
    Sep 2019
    Istanbul, Turkey
    I installed pla2.0 on my 2015 vw golf 7 vehicle. Parkasist activated when braking is automatic. my current vehicle is the 2017 audi a3 5QA 919 298 D module, but the brake is not fitted. I wonder what coding error?
  9. #28
    May 2017
    do you have maneuvre brake activated in pla module adaptation channel?
  10. #29
    Sep 2019
    Istanbul, Turkey
    Unfortunately, the maneuver brake option in the adaptation channel cannot be selected ..
  11. #30
    May 2017
    I have the same module in our Leon and it has maneuvre brake working and activated. So coding problem.
    I looked at your ABS coding, that's correct. Did you change the instrument cluster coding? Byte 13 bit 0 enabled. That is PLA3 coding for instrument cluster.
