Results 1 to 10 of 10
Thread: Audi A3 DSG7 OAM DQ200 Harsh down Shift to 3rd
    Jul 2019
    Australia
    Hi, Audi A3 DSG 7 dry clutch.
    Vehicle arrived with codes - 05981 = clutch 1 opens unintentionally & 05982 = clutch 1 closes unintentionally.
    Shifts from cold start were very poor, slipping clunking. Was 80% better at running temp but not perfect.
    Remove trans & replaced clutches, No sign of oil leaks. Order series 1 clutch via vin & installed with Luk special tools , Refit to vehicle warm, preform basic settings & Defined test drive.
    when slowing for a corner and the trans shifts down 5-4 And I accelerate out of the corner at normal throttle it thumps harshly back to 3rd. Ive done about 50km driving and redone basic settings 3 x with no improvement.
    The upshift in to 5th & 7th are firm, not harsh, nothing the customer would complain about.
    And some times the 3 to 4 up shift has a very minor flare like the clutch for 3rd let go before 4th clutch applied - that's being fussy though.
    Running temp makes these issues less, They are more obvious from cold start.
    There are no codes logging.
    Might I have a faulty Mechatronic unit?
    Chassis Type: 8P-AU35 (8P0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 61 62 72
              77
    VIN: WAUZZZ8P3BA010700   Mileage: 119910km-74508miles
    This is not an auto-scan!
    +1
    It's just an installation list, we NEED the full unedited VCDS Auto-Scan
    Jun 2016
    Guyana
    in the mean time you find your auto scan, sounds like you may have faulty solenoid valves in the mech unit, common problems with the DSG7 05981 /082 , im assuming Basic settings were successful? was it??, however did you changed or renewed mech unit fluid?? , also the Gearbox fluid? are the levels correct?
  5. Likes Jack@European_Parts liked this post
    Jul 2019
    Australia
    My apologies guys, Autoscan below
    Basic settings were successful and I have done this 3x
    Mech oil level not checked but I will be doing so now.
    Thursday,05,September,2019,15:53:46:25814
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name:
    VIN: WAUZZZ8P3BA010700   License Plate:
    Mileage: 119930km-74521mi   Repair Order: Nick B
              77
    VIN: WAUZZZ8P3BA010700   Mileage: 119930km-74521miles
    Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW: 8P7 907 115 K    HW: 8P0 907 115 Q
       Component: 1.8l R4/4V TFSI     0020
       Revision: AAH17---    Serial number: AUX7Z0J5FNA0MK
       Coding: 0143000C24070160
       Shop #: WSC 06314 000 00000
       VCID: 41CAB9CF18ED1C47D6-8014
       Part No SW: 0AM 300 050 E    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 2673
       Revision: 00043014    Serial number: CU501307307157
       Shop #: WSC 41308 000 1048576
       VCID: 2B16FB678A61E6171C-807E
       Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
       Component: ESP MK60EC1   H30 0105
       Revision: 00H30001
       Coding: 13424012092300FAC81202E490190081390800
       VCID: 044470DB877FC96FBD-8050
       Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
       Component: KlimavollautomatH09 0150
       Revision: 000158      Serial number: 8P0820043BM
       VCID: 78BC142B0BB79D8FA1-802C
       Part No SW: 8P0 907 063 G    HW: 8P0 907 063 G
       Component: BCM PQ35  M   107 0615
       Revision: 00107 AF
       Coding: 4E000A2FA0051AC0207040E00100015C407A29AA106DC928E4000E800041
       VCID: 383CD42B8B375D8F61-806C
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
       Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 024C2D
                        Fault Status: 00101110
                        Fault Frequency: 27
                        Reset counter: 197
                        Mileage: 119473 km
                        Date: 2019.08.12
                        Time: 12:04:19
                            Term 15 On
                        Voltage: 14.45 V
                            Term 50 Off
                        Fault Status: 00101010
                        Reset counter: 191
                        Mileage: 119475 km
                        Date: 2019.08.12
                        Time: 13:25:12
                            Term 15 On
                        Voltage: 12.20 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
       Part No SW: 8P0 919 475 G    HW: 8P0 919 475
       Component: PARKHILFE 4K  H06 0120
       Revision: 11001001    Serial number: 93641016100879
       Coding: 000103
       VCID: 42C8B6C3DDEB075FCF-8016
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
       Component: Airbag AU1042 H07 0200
       Revision: --------    Serial number: 003FB007HXZZ
       Coding: 30314238303830303037554A305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 4FEE8FF716B9FA3750-801A
       Serial number: 3572DRB40000B79C7A10
       Serial number: 3582DRB40000B7C4CB34
       Serial number: 35128RB40000594C27FT
       Serial number: 35228RB4000058DCD7A1
       Serial number: 35547RB400005A3F050I
       Serial number: 35647RB400005A3F4D4Z
       Component: J0527           H37 0070
       Coding: 0014142
       VCID: 46C0AAD331C33B7FE3-8012
       Component: E0221           H02 0100
       Part No SW: 8P0 920 932 K    HW: 8P0 920 932 K
       Component: KOMBIINSTR. VDO H01 0080
       Revision: D0H01002    Serial number: 2245J002003900
       Coding: 0256728
       Shop #: WSC 27509 003 1048576
       VCID: 3C34C83B7F0F71AF85-8068
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 8P0 907 530 A    HW: 1K0 907 951
       Component: J533  Gateway   H33 0302
       Revision:   H33       Serial number: 260510F1000947
       Coding: EDA07F0610060204002103
       VCID: 312AE90FA84D8CC726-8064
       Revision: D0H01002    Serial number: AUX7Z0J5FNA0MK
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0000660
       VCID: 49DAA1EF20DDD4070E-801C
    00912 - Window Regulator Switch; Front Left (E40)
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 232    3001
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158068209130
       VCID: 3620DA134123ABFF73-8062
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0000660
       VCID: 4AD89EE325DBDF1F07-801E
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 186 S    HW: 8P0 035 186 S
       Component: R Concert2+     H03 0280
       Revision: 00H03000    Serial number: AUZ1Z3K6052098
       Coding: 0710111
       VCID: 42C8B6C31DEB075FCF-8016
       Part No SW: 8P0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H33 0302
       Coding: 0302085A
       VCID: 74A4201BD7DFF9EF8D-8020
       Subsystem 1 - Part No SW: 1K0 915 181 E    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650222329
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 207
                        Mileage: 119929 km
                        Date: 2019.08.28
                        Time: 11:25:27
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0000144
       VCID: 43C6B3C702F10E57C4-8016
       Part No SW: 8P1 862 335     HW: 8P1 862 335
       Component: FSE_256x BT     H41 0650
       Revision: 00000000    Serial number: 00000005208646
       Coding: 0001222
       Shop #: WSC 21200 822 59815
       VCID: 74A4201B17DFF9EF8D-8020
    End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.2V)-----------
    You mean you didn't check vital signs of this patient yet?
  9. #8
    Jul 2019
    Australia
    .[/COLOR]
    Recovered 800ml of clean green oil from mech, Specification says dry fill is 1 litre but to measure correctly mech should be removed and turned around to empty.
    Gearbox oil was replaced at the time of clutch swap.
  10. #9
    Sounds like someone has a case of the Mechtronic clap, no?
  11. #10
    Jul 2019
    Australia
    That's my thoughts as well, A second opinion is appreciated these Mechtronic units cost us $2100 AUD I will replace it & report back.
    Thanks.
