Results 1 to 2 of 2
Thread: 1Z TDi Timing
    Aug 2018
    Ireland
    1Z TDi Timing
    I've been asked to check timing on an OLD 1Z 1995 A80.
    Is the TDi timing checker built into VCDS now or do I have to go and find/install the plugin?
    Many thanks.
    Lansdale, PA
    Yes, the TDI timing checker is included with VCDS.
    https://www.ross-tech.com/vag-com/cars/tdi.html
    Setting Injection Timing:
    The current Release of VCDS contains the TDI Timing Checker. See this page for more information.
    This procedure does NOT apply to the PD engines!
    • Engine has to be warm (coolant above 85șC)
    • Go to Engine Measuring Block 000 (Group 004 for V6 TDI)
    • Switch to Basic Settings
    • Take note of the values in fields 2 (timing) and 9 (fuel temp)
    • Report in the following graph
    • Specification is within the shaded area between the blue and red lines
    • To slightly advance timing, you need to be in the upper portion of the shaded area.
    • Setting is done mechanically, slightly rotating the pump shaft once its three screws have been loosened.
    • It is strongly discouraged to set your timing outside of the specification!
  3. Likes BavarianCare liked this post
