Saturday,13,July,2019,09:30:55:22246
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUZZZ8V6H1******   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V6H1******   Mileage: 30442km-18915miles
01-Engine -- Status: OK 0010
03-ABS Brakes -- Status: OK 0010
5F-Information Electr. -- Status: OK 0010
Address 01: Engine (J623-CYVB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 GR    HW: 04E 907 309 BL
   Component: R4 1.2l TFS   H23 2394
   Revision: R4H23---
   Coding: 02250012230400082000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
   ROD: EV_ECM12TFS01104E906027GR.rod
   VCID: 7AADF10E2C5A37B7841-802E
   CAN Converter 01:
   Part No SW: 0CW 300 048 K    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0614
   Revision: 00005026    Serial number: CU501707306347
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 44D14FF61E1EB147AED-8010
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 60046000000245
   Coding: 13F16AA22420126C017A060341C525C8562448806082A4B2002100040208
   VCID: 79AFEE02295C3CAF8DB-802C
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000190444
   Coding: 03000004100000000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 372B283A5FC8EADF3BF-8062
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061536200743
   Coding: 04041A42C041227D03A04004B10807000000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9EC279BC2C2F9DB-805C
   Component: WWS371 151215  043 0585
   Serial number:         160108091318
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0004
   Serial number: 50034753
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 23 10 2015  00000948
   Serial number: 000000000ZY15327330F
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000034289651
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    015 0388
   Serial number: 003MMR1BHL61
   Coding: 98CCC000000000005C540000004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 005983E64A866D67CA5-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 001 101 16
   Serial number: 3576700000022150981D
   Subsystem 2 - Part No SW: -----------    HW: 480 001 101 16
   Serial number: 35867000000A4D60981.
   Subsystem 3 - Part No SW: -----------    HW: 480 400 901 16
   Serial number: 35165029F1E85EB1328R
   Subsystem 4 - Part No SW: -----------    HW: 480 400 901 16
   Serial number: 3526502A31E85EB32019
   Subsystem 5 - Part No SW: -----------    HW: 480 401 509 15
   Serial number: 3556502A31CB0C25F25I
   Part No SW: 8V0 953 521 EM    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 08011604400077
   Coding: 8018
   ASAM Dataset: EV_SMLSKLOMQB 020001
   Part No SW: 8V0 920 860 N    HW: 8V0 920 860 N
   Component: KOMBI         H03 6423
   Coding: 07841A082A8000080500A8001000000000000000
   VCID: 45D752F21524884FB93-8010
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 09011610801327
   Coding: 01010008300864005B000208100B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 05 01 2016  A0007048
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 241015BJN09277
   Coding: 00100A204100040000001002
   VCID: 41DF46E2010CA46F85B-8014
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000008392064
   Coding: 110000
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0102
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 121015BJA09753
   Coding: 001002204100040000001002
   VCID: 40D943E60A06AD678A5-8014
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000008379083
   Coding: 090000
   Coding: 010A000001000000
   VCID: 75B7E232054458CFE93-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 840 C    HW: 8V0 035 840 B
   Component: MU-S--ER      042 0461
   Serial number: A3E01301160805
   Coding: 01730100FF0A000021220001001A00002F0001040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 3537223245C418CF293-8060
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30G2DL
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: ALJAL125111500030342
End----------(Elapsed Time: 01:22, VBatt start/end: 12.4V/12.4V)-----------
