Results 1 to 10 of 11
Thread: North America Tiguan MK2 MQB Easy Open Retrofit
    Apr 2019
    Hello All,
    I'm preparing for a easy open retrofit on a 2019 Tiguan SEL . The car has kessy system and automatic lift gate already. I have all the additional parts for easy open as well as wiring diagrams.
    The last thing is to figure out adaptation changes.
    So far I correlated 6D(trunk electronics) module and 5C(KESSY module) off a SEL Premium which came with Easy Open from factory
    6D - Trunk Electronics:
    I did not find any differences between SEL and SEL-P adaptations. Seems identical
    5C - Kessy Module:
    SEL Premium 5C adaptations had multiple entries for tailgate related things(see below) . Those channels don't even comeup in my adaptation. I wondering if something else need to be enabled for the additional channels to show up. Maybe
    something in 09 Electronic Module? I'm planning to redo adaptation channels and make sure security access is enabled.
    If you have any insight on the correct approach to code easy open, let me know.
    As always, I will make sure to document(parts, procedures, coding) the whole retrofit for others. Thanks!
    Here are the additional things I found in SEL Premium 5C module but no it SEL:
    IDE09735-CU tailgate opener: sensor 1: threshold value 1	69	1
    IDE09736-CU tailgate opener: sensor 1: threshold value 2	16	1
    IDE09737-CU tailgate opener: sensor 1: threshold value 3	16	1
    IDE09738-CU tailgate opener: sensor 1: threshold value 4	16	1
    IDE09739-CU tailgate opener: sensor 1: threshold value 5	16	1
    IDE09740-CU tailgate opener: sensor 2: threshold value 1	2	1
    IDE09741-CU tailgate opener: sensor 2: threshold value 2	31	1
    IDE09742-CU tailgate opener: sensor 2: threshold value 3	2	1
    IDE09743-CU tailgate opener: sensor 2: threshold value 4	31	1
    IDE09744-CU tailgate opener: sensor 2: threshold value 5	224	1
    IDE09745-CU tailgate opener: sensor 1: timer value 1	170	1
    IDE09746-CU tailgate opener: sensor 1: timer value 2	0	1
    IDE09747-CU tailgate opener: sensor 1: timer value 3	9	1
    IDE09748-CU tailgate opener: sensor 1: timer value 4	34	1
    IDE09749-CU tailgate opener: sensor 1: timer value 5	34	1
    IDE09750-CU tailgate opener: sensor 2: timer value 1	11	1
    IDE09751-CU tailgate opener: sensor 2: timer value 2	165	1
    IDE09752-CU tailgate opener: sensor 2: timer value 3	147	1
    IDE09753-CU tailgate opener: sensor 2: timer value 4	204	1
    IDE09754-CU tailgate opener: sensor 2: timer value 5	24	1
    IDE09755-CU tailgate opener: sensor 1: burst length	16	1
    IDE09756-CU tailgate opener: sensor 1: active screening	16	1
    IDE09757-CU tailgate opener: sensor 2: burst length	2	1
    IDE09758-CU tailgate opener: sensor 2: active screening	31	1
    IDE09759-CU for tailgate opener: reset all counters	Unknown (224)	1
    IDE09760-CU for tailgate opener: check sum	170	1
    IDE09829-CU tailgate opener: foot gestic recognition: timer value 1	2	1
    IDE09830-CU tailgate opener: foot gestic recognition: timer value 2	31	1
    IDE09831-CU for tailgate opener: play protection increments	6	1
    IDE09832-CU for tailgate opener: play protection decrements	25	1
    IDE09833-CU for tailgate opener: play protection threshold active	255	1
    IDE09834-CU for tailgate opener: play protection threshold inactive	5	1
    IDE09835-CU for tailgate opener: play protection decrement interval	60	1
    IDE09836-CU tailgate opener: sensor 1: control parameter	16	1
    IDE09837-CU tailgate opener: sensor 2: control parameter	16	1
    IDE09838-CU tailgate opener: foot gestic recognition: evaluation	0	1
    IDE09839-CU for tailgate opener: parameter set version	30	2
    And one more group of tailgate related channels:
    ENG153707-IDE00047-Rear_lid_power_opening_control_unit_data_set_upload-Parameter set version	0	37
    ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1	1	37
    ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2	1	37
    ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3	0	37
    ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4	1	37
    ENG153707-IDE80005-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 5	16	37
    ENG153707-IDE80006-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 6	16	37
    ENG153707-IDE80007-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 7	16	37
    ENG153707-IDE80008-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 8	16	37
    ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9	2	37
    ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10	31	37
    ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11	2	37
    ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12	31	37
    ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13	224	37
    ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14	10	37
    ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15	10	37
    ENG153707-IDE80016-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 16	0	37
    ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17	0	37
    ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18	9	37
    ENG153707-IDE80019-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 19	0	37
    ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20	not active 	37
    ENG153707-IDE80021-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 21	active 	37
    ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22	not active 	37
    ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23	Bottom 	37
    ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24	Dynamic 	37
    ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25	3	37
    ENG153707-IDE80026-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 26	not active 	37
    ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27	Dynamic 	37
    ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28	5	37
    ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29	6	37
    ENG153707-IDE80030-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 30	active 	37
    ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31	19	37
    ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32	2	37
    ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33	12	37
    ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34	4	37
    ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35	Do not reset 	37
    ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36	16	37
    ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37	16	37
    ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38	16	37
    ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39	16	37
    ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40	2	37
    ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41	31	37
    ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42	2	37
    ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43	31	37
    ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44	224	37
    ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45	10	37
    ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46	10	37
    ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47	0	37
    ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48	0	37
    ENG153707-IDE80049-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 49	0	37
    ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50	0	37
    ENG153707-IDE80051-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 51	6	37
    ENG153707-IDE80052-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 52	25	37
    ENG153707-IDE80053-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 53	255	37
    ENG153707-IDE80054-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 54	5	37
    ENG153707-IDE80055-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 55	60	37
    ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56	24	37
    ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type	34	37
    ENG153707-MAS14087-Rear_lid_power_opening_control_unit_data_set_upload-time delay activation	Activation after 2s 	37
    Apr 2019
    I just found this through some google magic and help of google translate.
    https://www.drive2.ru/l/473843608034738656/
    Looks promising....
    Looks like I first need to enable "Virtual Pedal" in 09 Central Electronics Module then go to B7 Access Authorization.
    I believe B7 Access Authorization is for ROW modules. NAR uses 5C???
    Anyone can confirm?
    Apr 2018
    EU
    VCDS HEX NET | VCP | O...S online | VAS 6154 | O...S E online | SVM Coding | IMMO | Keys | CP
    Touran 5T 2018 2.0TDI 190
    Dec 2016
    Amsterdam
    Easy open from the factory, scans and maps are here.
    Current:
  5. Likes Dana liked this post
    Mar 2014
    Europe
    After succesful coding and adaptations there you will have an "incorrect basic settings" in the trunk lid module. At least this was my case retrofitting Easy Open (Virtual Pedal) in Skoda Superb MY2019. The trunk lid was working as before, I could see the related measurement values even of VIP, just the Easy Open was not working.
    Getting rid of the basic settings error was impossible, no procedure in VCDS or VCP could do that. Only using OD!S but this reverted the coding and adaptations back to factory settings without VIP and Easy Open was obviously not working... I didn't solve it.
    Dec 2016
    Amsterdam
    Did you open and close the lid completely a few times? That usually stores a basic setting.
    Current:
  8. Likes Uwe liked this post
    Apr 2019
    Quote Originally Posted by icardiag View Post
    This sounds scary... Have you just tried reverting all codes using VCDS?
  10. #8
    Apr 2019
    Ok so I completed easy open hardware installation(DIY with pictures coming if I get this coding resolved). I'm 99% confident everything is wired correctly, I took my time and double checked my every step. Also this is not my first retrofit either but first one on the MQB platform.
    I need little help finish coding. Here is what I have done after everything was installed.
    09 - Central Electronics:
    Security Access with VCDS provided code, success
    Then went to adaptation set following channels
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal active
    ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar active
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau installed
    Success, read channels again and verified everything set
    Next, 05 Acc/Start Auth. [Special note, NAR Tiguan uses 05 Address for Acc/Start Auth. while ROW models use 07 address. Don't know why, just an observation]
    Then went to adaptation and set following channels
    ENG126956-ENG126976-Byte9_VIP-active_vip activated
    Made sure following channels are set to correct value which I got off a Tiguan with factory installed Easy Open. If a value matched I left it alone.
    IDE10844-Control module rear lid opening: duration status query 4960 ms
    IDE10845-Control module rear lid opening: vehicle type 22
    Then I went to the Infotainment system and found Easy Open option tick box. I enabled it but nothing happened keep reading.
    There is a fault stored in 05 module (see autoscan for the full print out):
    221445 - Sensor for Rear Lid/Hatch Opening
    B1303 54 [009] - Missing Calibration / Basic Setting
    I guess I need to calibrate the sensor but no idea how.
    One more piece of information which might or might not be useful. If I enable "easy open" in the infotainment system VCDS becomes super slow communicating to 05 module in general. Also reading easy open adaptation channels throw "Error channel not available". Once easy open is turned off in the infotainment system I'm able to read every adaptation channel.
    Ok here are some data for you to chew on
    Full 09 Module Adaptation with my changes mentioned above.
    ;SW:5Q0-937-087-BB   HW:5Q0-937-087-BB ---  Cent. Elect. --- SA: 31347
    ;Component:BCM PQ37BOSCH 036 0265	 Coding:000000000000000000000000000000000000000000000000000000000000
    ;EV_BodyContrModul1UDSBosc	19001	EV_BCMBOSCH_019_VW37.rod
    ;Monday	9	September	2019	20:06:48:18133
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 7CA1F7F0666F0AB7961-8028
    IDE00001-ENG99061-Production mode-Access control	not active 	3
    IDE00001-ENG115730-Production mode-Exterior lighting	not active 	3
    IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
    IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
    IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
    IDE00002-Transport mode	active 	1
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE01550-Service position	178.999822 °	2
    IDE02152-Characteristics in production mode	2000 ms	4
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	10
    IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	active 	10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms	10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms	10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms	10
    IDE02332-Deactivate production mode	0	3
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
    IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
    IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
    IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert 	8
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.3 °	16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	16
    IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
    IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	16
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	80 °	16
    IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h	16
    IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	16
    IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
    IDE03787-Activate left/right hand drive switch-over	not active 	1
    IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	11
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
    IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
    IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
    IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
    IDE04927-ENG126845-Window heater-FSH Automatik	active 	11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	11
    IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
    IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
    IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage	not installed 	11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
    IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv	-2.0 °C	11
    IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
    IDE04927-ENG154810-Window heater-window heating front activation time pause	320 s	11
    IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	8
    IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	active 	8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	activ 	8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active 	8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active 	8
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	Horn_verbaut 	8
    IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed 	8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm	not_active 	8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	activ 	8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No 	8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme 	8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
    IDE05143-MAS02985-Writing parameter-Value	130	5
    IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00 	5
    IDE05144-Read parameter address	FE 00 00 	3
    IDE05145-Light configuration	0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1A 12 06 9A 00 00 00 04 4C 00 4C 14 00 64 08 0A 1A 13 07 9A 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 	224
    IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler	0	30
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	21.00 °C	30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	20.00 °C	30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	21.00 °C	30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	20.00 °C	30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	35.50 °C	30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	35.50 °C	30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	49.00 °C	30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	48.00 °C	30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	49.00 °C	30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	48.00 °C	30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung 	30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
    IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.7 V	30
    IDE06425-Roller test bench mode: functional	not active 	1
    IDE06507-MAS13125-Button in center console-Function of button 1	Start-stop 	8
    IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
    IDE06507-MAS13132-Button in center console-Function of button 3	not coded/not installed 	8
    IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed 	8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
    IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start	installed 	8
    IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut	not installed 	8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
    IDE07356-Position during interval mode	40.999959 °	2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit 	6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	active 	6
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
    IDE08786-ENG141956-Assistance light functions-Humidity sensor	installed 	9
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active 	9
    IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	DISKRET 	9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	7	19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	active 	19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	19
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	50%	19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2	19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	50%	19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	50%	19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	50%	19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	50%	19
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	not active 	19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active 	19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active 	19
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
    IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	installed 	19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	0	5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed 	5
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	5
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
    IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	30%	17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	30%	17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	50%	17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	50%	17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	50%	17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	50%	17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	75%	17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	75%	17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	80%	17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	installed 	17
    IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
    IDE10298-Alternating park position 1	19.999980 °	2
    IDE10299-Alternating park position 2	34.999965 °	2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.2	256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	0.4	256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0	256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	70%	256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%	256
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	70%	256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	70%	256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%	256
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	70%	256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%	256
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	70%	256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	0%	256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	70%	256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%	256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	70%	256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	0%	256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%	256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	70%	256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	0%	256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	0%	256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%	256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	70%	256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%	256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	70%	256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%	256
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	70%	256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	0%	256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	70%	256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	70%	256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	0%	256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%	256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	70%	256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	0%	256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	0.0 s	256
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.0 s	256
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	installed 	3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy	installed 	3
    IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber	not active 	3
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	not active 	3
    IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit	not active 	3
    IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit	not active 	3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	3
    IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor	Not available 	6
    IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor	Not available 	6
    IDE12302-SFT271875-Identification of sub-bus participant-Light switch	Not available 	6
    IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module	Not available 	6
    IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit	Not available 	6
    IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System	Not available 	6
    IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn	Not available 	6
    IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof	Not available 	6
    IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module	Not available 	6
    IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind	Not available 	6
    IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender	Not available 	6
    IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left	Not available 	6
    IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right	Not available 	6
    IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left	Not available 	6
    IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left	Not available 	6
    IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right	Not available 	6
    IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right	Not available 	6
    IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control	Not available 	6
    IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch	Not available 	6
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
    IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
    MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
    MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
    MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
    MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
    MAS01490-ENG141978-Energy management-Recuperation	active 	5
    MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
    MAS05055-lower turn position	42.999957 °	2
    MAS05056-upper turn position	178.999822 °	2
    MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
    MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	2512 lx	24
    MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
    MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
    MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 50 	24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx	24
    MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
    MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
    MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
    MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
    MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	4500 mV	24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	6000 lx	24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	2000 mV	24
    MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	active 	4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	active 	4
    ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	Panoramic roof 	30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Keine_Spannungsanforderung 	23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active 	10
    ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
    ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
    ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	not active 	10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	not active 	10
    ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
    ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
    ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
    ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
    ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
    ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
    ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	not active 	10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	not active 	10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	not active 	10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	not active 	10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	not active 	10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active 	10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	not active 	10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
    ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max	120 min	10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	not active 	10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	not active 	10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	not active 	10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	not active 	10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
    ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren	not active 	9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
    ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h	9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	active 	9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active 	9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active 	9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active 	9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
    ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
    ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active 	9
    ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	Yes 	5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h	5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
    ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active 	5
    ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed 	18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
    ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung 	18
    ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf	0 ms	18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam 	18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
    ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis 	18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten 	18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx	18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
    ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	true 	18
    ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	No 	18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
    ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
    ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete 	18
    ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	not installed 	18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	10 seconds 	18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	10 seconds 	18
    ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
    ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
    ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	not active 	18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	6 s	18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
    ENG126647-ENG98399-debug_light_function-Activation	0	11
    ENG126647-ENG101417-debug_light_function-Adresse	0	11
    ENG126647-ENG126820-debug_light_function-Bitmask	0	11
    ENG126647-ENG126821-debug_light_function-Divisor	0	11
    ENG126647-ENG98827-debug_light_function-Offset	0	11
    ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
    ENG246955-ENG246967-digital_key-central_locking_digital_key_general	not installed 	3
    ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle	not active 	3
    ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion	not active 	3
    ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer	not active 	3
    ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle	not active 	3
    ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion	not active 	3
    ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer	not active 	3
    ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
    ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
    ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
    ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
    ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
    ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
    ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	Basis 	6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	not active 	6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	6
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	not active 	6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms	6
    ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active 	6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung 	6
    ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
    ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
    ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
    ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms	6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Not deactivated 	6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
    ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active 	6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
    ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
    ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
    ENG99457-ENG117394-Head area heater-blower_speed	1	2
    ENG99457-ENG98971-Head area heater-Temperature	-2	2
    ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
    ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed 	8
    ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
    ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
    ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
    ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
    ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
    ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active 	8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	100.00%	30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	100.00%	30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	100.00%	30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	100.00%	30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	83.00%	30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	67.00%	30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	50.00%	30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	33	30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	17.00%	30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	0.00%	30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	64.00%	30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	64.00%	30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	64.00%	30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	64.00%	30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	57.00%	30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	50.00%	30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	42.00%	30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	27.00%	30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	22.00%	30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	15.00%	30
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten 	16
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
    ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
    ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
    ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
    ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
    ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
    ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
    ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
    ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
    ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Warnblinktaster_Suchbeleuchtung 	16
    ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
    ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
    ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
    ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
    ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
    ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
    ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100	16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer 	16
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links 	16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links 	16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100	16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer 	16
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts 	16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts 	16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	127	16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	48	16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	37 - allgemeine LED bis 12W 	16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	127	16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	47	16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	37 - allgemeine LED bis 12W 	16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	0	16
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0	16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	0	16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	not active 	16
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	not active 	16
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	0	16
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0	16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	0	16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	not active 	16
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	not active 	16
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten 	16
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize 	16
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	13	16
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	35 - kombinierte LED Blink-Bremsleuchten 	16
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	Blinken links Hellphase 	16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Blinken links Dunkelphase 	16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize 	16
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	13	16
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	35 - kombinierte LED Blink-Bremsleuchten 	16
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	Blinken rechts Hellphase 	16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Blinken rechts Dunkelphase 	16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100	16
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active 	16
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	127	16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0	16
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	35	16
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	32 - allgemeine LED bis 12W 	16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	only_if_closed 	16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active 	16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active 	16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	127	16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0	16
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	36	16
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	32 - allgemeine LED bis 12W 	16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	only_if_closed 	16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active 	16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active 	16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	127	16
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	54	16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0	16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED 	16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	0	16
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	0	16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0	16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	not active 	16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	not active 	16
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	32 - allgemeine LED bis 12W 	16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	32 - allgemeine LED bis 12W 	16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize 	16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	minimize 	16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	26	16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	26	16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A 	16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48	16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal 	16
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights 	16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Nebellicht links 	16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	Blinken links aktiv (beide Phasen) 	16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89	16
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung 	16
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize 	16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	minimize 	16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	26	16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	26	16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C 	16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C 	16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal 	16
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights 	16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	Parking light right 	16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Nebellicht rechts 	16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	Blinken rechts aktiv (beide Phasen) 	16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize 	16
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127	16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127	16
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49	16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A 	16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung 	16
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen) 	16
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize 	16
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127	16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127	16
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B 	16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44	16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung 	16
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen) 	16
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	Parking light right 	16
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht 	16
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht 	16
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C 	16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	10 - allgemeine Scheinwerfer 	16
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam 	16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell 	16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active 	16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D 	16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	10 - allgemeine Scheinwerfer 	16
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam 	16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell 	16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active 	16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 08 00 0D 00 00 00 23 23 00 3E 18 04 64 05 00 80 08 00 0D 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 	192
    ENG141662-Leuchtenkonfiguration_Sonstiges	25 00 00 48 08 00 7F 00 00 00 00 00 00 00 00 00 25 00 00 47 08 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
    ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	0 mm	62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active 	62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	100.00%	62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	0.00%	62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-101.5 ms	62
    ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
    ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	-8.00 mm/%	62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	-8.00 mm/%	62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	-8.00 mm/%	62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	-8.00 mm/%	62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	-8.00 mm/%	62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	-8.00 mm/%	62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1 	62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	0.00%	62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.00 Hz	62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal 	62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	0 mm	62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	0 mm	62
    ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	2.50%	62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h	62
    ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.00 Hz	62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed 	62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active 	62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	1.00%	62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active 	62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	10.0 %/s	62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%	62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	1.00 s	62
    ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1	2.0 s	7
    ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang	10 s	7
    ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion	active 	7
    ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik	active 	7
    ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS	Nicht_verbaut 	7
    ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark	not active 	7
    ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze	100 m	7
    ENG246957-ENG246981-Lichttaster-Lichttastermodul	lds 	7
    ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config	1	7
    ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle	30 km/h	7
    ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig	not active 	7
    ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter	active 	7
    ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig	active 	7
    ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig	not active 	7
    ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter	active 	7
    ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig	active 	7
    ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig	not active 	7
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
    ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen	40 ms	27
    ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen	40 ms	27
    ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit	100 ms	27
    ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt	10 ms	27
    ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen	40 ms	27
    ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen	40 ms	27
    ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v	1 km/h	27
    ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen	40 ms	27
    ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen	500 ms	27
    ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i	0.4	27
    ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset	5 °C	27
    ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p	18.00%	27
    ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh	110 W	27
    ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen	40 ms	27
    ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh	25 Hz	27
    ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg	0	27
    ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0	34 °C	27
    ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1	39 °C	27
    ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2	44 °C	27
    ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen	40 ms	27
    ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus	50 °C	27
    ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen	0 ms	27
    ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung	0 ms	27
    ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen	40 ms	27
    ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen	40 ms	27
    ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung	60 s	27
    ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh	30 s	27
    ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display	not installed 	2
    ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation	Always 	2
    ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper	installed 	2
    ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock	not installed 	2
    ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation	not installed 	2
    ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button	not installed 	2
    ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch	not installed 	2
    ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch	not installed 	2
    ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn	not active 	2
    ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked	not active 	2
    ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation	not active 	2
    ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st	not installed 	2
    ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button	not installed 	2
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-5.00%	20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-5.00%	20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-5.00%	20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-5.00%	20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-5.00%	20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-5	20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-5	20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-5	20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-5	20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-5	20
    ENG122979-ENG141954-Networking-A/C electronics	installed 	8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
    ENG122979-ENG99457-Networking-Head area heater	not installed 	8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
    ENG122979-ENG141969-Networking-UGDO	not installed 	8
    ENG124714-ENG142044-OCU-DWA_push	active 	8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	active 	8
    ENG124714-ENG246970-OCU-IAA -Nutzer_management	not installed 	8
    ENG124714-OCU-	installed 	8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock	Via ZV-Absicherung Light 	8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
    ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv	not active 	16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_inactive 	16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG142030-Personalization-Profil_Variante	Schluessel 	16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
    ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW 	5
    ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	active 	5
    ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
    ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed 	5
    ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10	10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed 	10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	active 	10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	2000 ms	10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	800 ms	10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms	10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms	10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	800 ms	10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung 	10
    ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss	200 ms	48
    ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung	1000 ms	48
    ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus	5000 ms	48
    ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein	300 s	48
    ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus	5000 ms	48
    ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein	300 s	48
    ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus	5000 ms	48
    ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein	300 s	48
    ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel	200 ms	48
    ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus	0 ms	48
    ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein	0 ms	48
    ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel	0 ms	48
    ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung	90000 ms	48
    ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung	90000 ms	48
    ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error	200 ms	48
    ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss	200 ms	48
    ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung	1000 ms	48
    ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus	5000 ms	48
    ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein	300 s	48
    ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel	200 ms	48
    ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis	2000 ms	48
    ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus	5000 ms	48
    ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein	60 s	48
    ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen	20 ms	48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen	0 ms	48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen	0 s	48
    ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt	0	48
    ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle	16.5 V	48
    ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr	15.5 V	48
    ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle	8.5 V	48
    ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr	8.5 V	48
    ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss	0 ms	48
    ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus	0 ms	48
    ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein	0 ms	48
    ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus	0 ms	48
    ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein	0 s	48
    ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss	200 ms	48
    ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung	1000 ms	48
    ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus	0.0 s	48
    ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein	0 s	48
    ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus	5000 ms	48
    ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein	300 s	48
    ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel	200 ms	48
    ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus	5000 ms	48
    ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein	300 s	48
    ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus	5000 ms	48
    ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein	300 s	48
    ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG	not installed 	4
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	MFG 	4
    ENG116588-Sonderfunktionen-	not enabled 	4
    ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by convenience operation via remote control key 	5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	not active 	5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	not active 	5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	active 	5
    ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	not active 	5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	250	10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	LIN 	10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	1000 ms	10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
    ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
    ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
    ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
    ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
    ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
    ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
    ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
    ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
    ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
    ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
    ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
    ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
    ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
    ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
    ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
    ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
    ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
    ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
    ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
    ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
    ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
    ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
    ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
    ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	HMI 	21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s	21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s	21
    ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active 	21
    ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	2	21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	50%	21
    ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
    ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1	21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	6.00%	21
    ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
    ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
    ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
    ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
    ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
    ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
    ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
    ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
    ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
    ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
    ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
    ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
    ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
    ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
    ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
    ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
    ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
    ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
    ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
    ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
    ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
    ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
    ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
    ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
    ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
    ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
    ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
    ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
    ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
    ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
    ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
    ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
    ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	500 lx	8
    ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
    ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
    ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
    ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
    ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
    ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
    ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
    ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
    ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
    ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
    ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
    ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
    ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
    ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
    ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
    ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
    ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
    ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
    ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
    ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
    ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
    ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
    ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
    ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
    ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
    ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
    ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
    ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	50 lx	10
    ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
    ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
    ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
    ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
    ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	16	10
    ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	25	10
    ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	30	10
    ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	50	10
    ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
    ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50	12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100	12
    ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
    ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.00%	12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.00%	12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.00%	12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.00%	12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.00%	12
    ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
    ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
    ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
    ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
    ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
    ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
    ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
    ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
    ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
    ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
    ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
    ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
    ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
    ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
    ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
    ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
    ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
    ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
    ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
    ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
    ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
    ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
    ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
    ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx	12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx	12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx	12
    ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
    ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
    ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20	12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	80	12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180	12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300	12
    ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
    ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
    ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
    ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
    ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
    ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
    ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
    ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
    ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
    ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
    ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	active 	4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	active 	4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	installed 	4
    ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	installed 	4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	CAN 	4
    ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	active 	9
    ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active 	9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	active 	9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	active 	9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	active 	9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active 	9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	active 	9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	nur wenn mind. 1 Raste zu 	9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always 	9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	installed 	9
    ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	active 	9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	active 	9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	active 	9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	active 	9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	active 	9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	active 	9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	active 	9
    ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar	active 	9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	installed 	9
    ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version	Version_1_2 	9
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
    ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
    ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
    ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	active 	7
    ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
    ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
    ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active 	7
    ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
    ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
    ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
    ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
    ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
    ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	not active 	3
    ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	not active 	4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	active 	4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	active 	7
    ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
    ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	via_CAN 	7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	not active 	7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	active 	7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Kontaktsteuerung mit Mindestansteuerzeit 	7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	7
    ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
    ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
    ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
    ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
    ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
    ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
    ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active 	8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
    ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
    ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
    ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	not active 	8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	not active 	8
    ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
    ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
    ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
    ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
    ENG141681-ENG246991-ZV Komfort-pa_Two_Keys	not active 	8
    ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
    ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	not active 	8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	not active 	8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser 	5
    ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
    ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
    ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
    ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
    ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
    ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
    ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
    ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
    ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
    Elapsed Time: 01:45
    Full Adaptation map of 05 module with my changes
    ;SW:3Q0-959-435-L   HW:3Q0-959-435-L ---  Acc/Start Auth. --- SA: 20103
    ;Component:VWKESSYMQB    037 1204	 Coding:132C0C0723
    ;EV_KessyHellaMQBAB	4046	EV_KessyHellaMQBAB_004_VW37.rod
    ;Monday	9	September	2019	20:05:02:18133
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: 43D34C0C5B11B54F97B-8016
    IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15	not active 	3
    IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening	not active 	3
    IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request	not active 	3
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE02332-Deactivate production mode	0	3
    IDE03251-Stop release for start-stop function	According to function requirements 	1
    IDE04159-Deactivation of start-stop function	not active 	1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min	2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min	2
    IDE09735-CU tailgate opener: sensor 1: threshold value 1	69	1
    IDE09736-CU tailgate opener: sensor 1: threshold value 2	16	1
    IDE09737-CU tailgate opener: sensor 1: threshold value 3	16	1
    IDE09738-CU tailgate opener: sensor 1: threshold value 4	16	1
    IDE09739-CU tailgate opener: sensor 1: threshold value 5	16	1
    IDE09740-CU tailgate opener: sensor 2: threshold value 1	2	1
    IDE09741-CU tailgate opener: sensor 2: threshold value 2	31	1
    IDE09742-CU tailgate opener: sensor 2: threshold value 3	2	1
    IDE09743-CU tailgate opener: sensor 2: threshold value 4	31	1
    IDE09744-CU tailgate opener: sensor 2: threshold value 5	224	1
    IDE09745-CU tailgate opener: sensor 1: timer value 1	170	1
    IDE09746-CU tailgate opener: sensor 1: timer value 2	0	1
    IDE09747-CU tailgate opener: sensor 1: timer value 3	9	1
    IDE09748-CU tailgate opener: sensor 1: timer value 4	34	1
    IDE09749-CU tailgate opener: sensor 1: timer value 5	34	1
    IDE09750-CU tailgate opener: sensor 2: timer value 1	11	1
    IDE09751-CU tailgate opener: sensor 2: timer value 2	165	1
    IDE09752-CU tailgate opener: sensor 2: timer value 3	147	1
    IDE09753-CU tailgate opener: sensor 2: timer value 4	204	1
    IDE09754-CU tailgate opener: sensor 2: timer value 5	24	1
    IDE09755-CU tailgate opener: sensor 1: burst length	16	1
    IDE09756-CU tailgate opener: sensor 1: active screening	16	1
    IDE09757-CU tailgate opener: sensor 2: burst length	2	1
    IDE09758-CU tailgate opener: sensor 2: active screening	31	1
    IDE09759-CU for tailgate opener: reset all counters	Unknown (224)	1
    IDE09760-CU for tailgate opener: check sum	170	1
    IDE09829-CU tailgate opener: foot gestic recognition: timer value 1	2	1
    IDE09830-CU tailgate opener: foot gestic recognition: timer value 2	31	1
    IDE09831-CU for tailgate opener: play protection increments	6	1
    IDE09832-CU for tailgate opener: play protection decrements	25	1
    IDE09833-CU for tailgate opener: play protection threshold active	255	1
    IDE09834-CU for tailgate opener: play protection threshold inactive	5	1
    IDE09835-CU for tailgate opener: play protection decrement interval	60	1
    IDE09836-CU tailgate opener: sensor 1: control parameter	16	1
    IDE09837-CU tailgate opener: sensor 2: control parameter	16	1
    IDE09838-CU tailgate opener: foot gestic recognition: evaluation	0	1
    IDE09839-CU for tailgate opener: parameter set version	30	2
    IDE10844-Control module rear lid opening: duration status query	4960 ms	1
    IDE10845-Control module rear lid opening: vehicle type	22	1
    ENG153713-ENG129122-Byte12_diverse-environment_scan_step1	not activated 	1
    ENG153713-ENG126978-Byte12_diverse-environment_scan_step2	not activated 	1
    ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan	activated 	1
    ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept	activated 	1
    ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan	not activated 	1
    ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart	activated 	1
    ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin	not activated 	1
    ENG244871-ENG245033-Byte13_vit_lf-toggle_active	not activated 	1
    ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door	not activated 	1
    ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit	not activated 	1
    ENG244871-ENG129125-Byte13_vit_lf-vit_exit	not activated 	1
    ENG126956-ENG126976-Byte9_VIP-active_vip	activated 	1
    ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking	not activated 	1
    ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function	not activated 	1
    ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP	not activated 	1
    ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation	not activated 	1
    ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15	not activated 	1
    ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine	not activated 	1
    ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning	1.00 s	1
    ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff	1.00 s	1
    ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off	10.00 s	1
    ENG105462-CAN-timeout service-key message	260 ms	1
    ENG105634-Correction value LED dimming	1	1
    ENG114301-Cycletime for voltage monitoring during sleepmode	100 ms	1
    ENG120046-Cyclic interior scan during clamp 15 on	10 s	1
    ENG126961-deactivation_time_vip_slidingdoor	15 s	1
    ENG126960-Debounce_time_detection	500 ms	2
    ENG126959-Debounce_time_driver_presence	200 ms	1
    ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle	300 ms	1
    ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM	60.00 s	1
    ENG105791-Delta value LED dimming curve first point 40 percent dimming	30.00%	1
    ENG105792-Delta value LED dimming curve forth point 100 percent dimming	5.00%	1
    ENG105793-Delta value LED dimming curve second point 60 percent dimming	15.00%	1
    ENG105794-Delta value LED dimming curve third point 80 percent dimming	10.00%	1
    ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open	not activated 	1
    ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open	not activated 	1
    ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery	not activated 	1
    ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go	activated 	1
    ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start	activated 	1
    ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted	not activated 	1
    ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation	activated 	1
    ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door	activated 	1
    ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive	activated 	1
    ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection	not activated 	1
    ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv"	activated 	1
    ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT	activated 	1
    ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on	activated 	1
    ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load	not activated 	1
    ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt	not activated 	1
    ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt	not activated 	1
    ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible	not activated 	1
    ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk	not activated 	1
    ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles	not activated 	1
    ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel	left-hand drive 	1
    ENG105825-Diagnostic: wait time after power on	500 ms	1
    ENG126943-Display_duration_emergency_off	3000 ms	1
    ENG126944-Display_duration_error_mode_2_SPN	10 s	1
    ENG126941-Display_duration_please_engage_P	10 s	1
    ENG105898-Doorknob contact sensor disconnecting time	5400 min	1
    ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up	2000 ms	1
    ENG126955-duration_to_ZAT_continuous_actuation_detection	1000 ms	1
    ENG129005-duration_to_ZAT_multi_actuation_detection	3000 ms	1
    ENG126950-duration_ZAT_debounce	50 ms	1
    ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose	10%	9
    ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear	2.00 s	9
    ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose	7.00 s	9
    ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose	20	9
    ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk	50%	9
    ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate	400 ms	9
    ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active	20.00 s	9
    ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step	4	5
    ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step	2	5
    ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4	220 mV/m	5
    ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area	40 mV/m	5
    ENG126966-environment_scan_cyclic_step1	700 ms	1
    ENG126967-environment_scan_cyclic_step2	2000 ms	1
    ENG126965-environment_scan_duration_step1	300 min	1
    ENG126971-environment_scan_duration_step2	24 H	1
    ENG126969-environment_scan_level_bem	2	1
    ENG126968-environment_scan_responselevel_reduction	500	1
    ENG126970-environment_scan_startdelay_time	5 s	1
    ENG126958-Ignition_For_Immobilizer	Default 	1
    ENG129016-Initialization_diagnostics_switching_terminal	not activated 	4
    ENG107050-Interior scan: deceleration after comfort closing	3200 ms	1
    ENG107051-Interior scan: max. engine speed for standing engine	10 km/h	1
    ENG107052-Interior scan: opening threshold sliding roof	1%	1
    ENG107053-Interior scan: opening threshold window lifter	5.00%	1
    ENG107054-Interior scan: Speed - threshold	20 km/h	1
    ENG153724-Interior_scans_clamp15_break_at_active_message	5000 ms	1
    ENG153725-Interior_scans_clamp15_retry_at_active_message	5	1
    ENG98656-internal	0 B	1
    ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv	not activated 	1
    ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys	not activated 	1
    ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found"	not activated 	1
    ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening	activated 	1
    ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking	activated 	1
    ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted	installed 	1
    ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go	activated 	1
    ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate	activated 	1
    ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior	activated 	1
    ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing	activated 	1
    ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling	not activated 	1
    ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate	activated 	1
    ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery	not activated 	1
    ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc	not activated 	1
    ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open	activated 	1
    ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open	not activated 	1
    ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock	not activated 	1
    ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown	activated 	1
    ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger	not activated 	1
    ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed	activated 	1
    ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit	activated 	1
    ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL	activated 	1
    ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1	not activated 	1
    ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept	not activated 	1
    ENG107211-Key Minder: delay reunlocking tailgate	500 ms	1
    ENG107212-Key Minder: p_keyless_eventsearch_holding_time	10 s	1
    ENG107213-Key Minder: p_keyless_eventsearch_retries	2	1
    ENG107363-LED dimming curve first point 20 percent dimming	40.00%	1
    ENG153886-lf_shutdown_timeout_2nd_operation	5 s	1
    ENG107592-MCTX Pause	1 B	1
    ENG107593-MCTX pause for Go / Key Minder	20 ms	1
    ENG107594-MCTX pause for Go authentification	14 B	1
    ENG107595-MCTX settling phase	10 B	1
    ENG129013-min_receptiontime_vit	0 ms	1
    ENG126945-min_time_for_Terminal_50_request	200 ms	1
    ENG244880-Minimum_holdtime_ak	500 ms	1
    ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff	2	1
    ENG126940-Number_of_ZAT_activations_to_DTC	10	1
    ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout	2.00 s	1
    ENG108166-Passive Entry Exit: entry request e-sliding door active time	500 ms	1
    ENG108167-Passive Entry Exit: minimum activity time locking sensor	140 ms	1
    ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY	220 ms	1
    ENG108169-Passive Entry Exit: T_ACT_OP_2	5000 ms	1
    ENG108297-Proximity Sensor: Comfort Exit-Enlargement	200 ms	1
    ENG108298-Proximity Sensor: duration of proximity Signal	10 s	1
    ENG108299-Proximity Sensor: lower limit Impuls	2000 µs	1
    ENG108300-Proximity Sensor: lower limit proximity-Impuls	12200 µs	1
    ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle	10.0 km/h	1
    ENG108302-Proximity Sensor: max. Impulslength	75 ms	1
    ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls	20400 µs	1
    ENG108304-Proximity Sensor: max. intermission-length Diagnostic	14 ms	1
    ENG108305-Proximity Sensor: max. length of Diagnosticimpuls	71 ms	1
    ENG108306-Proximity Sensor: max. length of Entryimpuls	10400 µs	1
    ENG108307-Proximity Sensor: max. length of Exitimpuls	40400 µs	1
    ENG108308-Proximity sensor: max. length of signal hall sensor	100 s	1
    ENG108309-Proximity Sensor: max. signal-length	120 s	1
    ENG108310-Proximity sensor: max. tolerance data bit length	200 µs	1
    ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle	20.0 km/h	1
    ENG108312-Proximity Sensor: min. enginespeed for a running engine	300 /min	1
    ENG108313-Proximity Sensor: min. length of Diagnosticimpuls	42 ms	1
    ENG108314-Proximity Sensor: min. length of Entryimpuls	6200 µs	1
    ENG108315-Proximity Sensor: min. length of Exitimpuls	24200 µs	1
    ENG108316-Proximity sensor: min. tolerance data bit length	120 µs	1
    ENG108317-Proximity Sensor: SP_X2	10 min	1
    ENG108318-Proximity Sensor: SP_X3	1	1
    ENG108319-Proximity Sensor: SP_X4	80	1
    ENG108320-Proximity Sensor: SP_X5	1	1
    ENG108321-Proximity Sensor: SP_X6	30 min	1
    ENG108322-Proximity Sensor: SP_X7	1	1
    ENG108323-Proximity Sensor: Time Power On	1960 ms	1
    ENG123035-Proximity Sensor: Timervalue for ExitReverseOption	0 ms	1
    ENG108325-Proximity sensor: turn-off limit from battery-manager	2	1
    ENG108326-Proximity Sensor: upper limit intermission-length	10 ms	1
    ENG153707-IDE00047-Rear_lid_power_opening_control_unit_data_set_upload-Parameter set version	0	37
    ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1	1	37
    ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2	1	37
    ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3	0	37
    ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4	1	37
    ENG153707-IDE80005-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 5	16	37
    ENG153707-IDE80006-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 6	16	37
    ENG153707-IDE80007-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 7	16	37
    ENG153707-IDE80008-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 8	16	37
    ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9	2	37
    ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10	31	37
    ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11	2	37
    ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12	31	37
    ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13	224	37
    ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14	10	37
    ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15	10	37
    ENG153707-IDE80016-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 16	0	37
    ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17	0	37
    ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18	9	37
    ENG153707-IDE80019-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 19	0	37
    ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20	not active 	37
    ENG153707-IDE80021-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 21	active 	37
    ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22	not active 	37
    ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23	Bottom 	37
    ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24	Dynamic 	37
    ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25	3	37
    ENG153707-IDE80026-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 26	not active 	37
    ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27	Dynamic 	37
    ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28	5	37
    ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29	6	37
    ENG153707-IDE80030-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 30	active 	37
    ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31	19	37
    ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32	2	37
    ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33	12	37
    ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34	4	37
    ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35	Do not reset 	37
    ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36	16	37
    ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37	16	37
    ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38	16	37
    ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39	16	37
    ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40	2	37
    ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41	31	37
    ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42	2	37
    ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43	31	37
    ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44	224	37
    ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45	10	37
    ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46	10	37
    ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47	0	37
    ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48	0	37
    ENG153707-IDE80049-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 49	0	37
    ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50	0	37
    ENG153707-IDE80051-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 51	6	37
    ENG153707-IDE80052-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 52	25	37
    ENG153707-IDE80053-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 53	255	37
    ENG153707-IDE80054-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 54	5	37
    ENG153707-IDE80055-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 55	60	37
    ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56	24	37
    ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type	34	37
    ENG153707-MAS14087-Rear_lid_power_opening_control_unit_data_set_upload-time delay activation	Activation after 2s 	37
    ENG120045-Reduced current for transponder-ID request	0 Step	1
    ENG126939-rpm_threshold_engine_runnning	100 /min	1
    ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol	5 Step	1
    ENG108576-Scan Procedure: cycle convenience coverage limiting	65 ms	1
    ENG108577-Scan Procedure: Number of Repeats	1	1
    ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause	100 ms	1
    ENG108579-Scan Procedure: Timeout Authentification Result	150 ms	1
    ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go	190 ms	1
    ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi	700 ms	1
    ENG108582-Scan Procedure: Timeout LF Repetition	100 ms	1
    ENG108585-ScanProcedure: Timeout Entry Response	260 ms	1
    ENG108586-ScanProcedure: Timeout Response	100 ms	1
    ENG126963-settime_trigger_entry_vehicle	500 ms	1
    ENG126962-settime_trigger_exit_vehicle	500 ms	1
    ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG	not activated 	1
    ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted	activated 	1
    ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event	not activated 	1
    ENG129024-ENG98656-Sonstiges_byte1-internal	not activated 	1
    ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure	not activated 	1
    ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active	activated 	1
    ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data	not activated 	1
    ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold	not activated 	1
    ENG129025-ENG142122-sonstiges_byte2-sad_existing	activated 	1
    ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing	activated 	1
    ENG244883-Speed_ threshold_for_start_request_plausibilisation	10 km/h	1
    ENG129007-Speed_threshold_for_driving_cycle_detection	3.0 km/h	1
    ENG129006-Speed_threshold_for_moving_vehicle_detection	1.0 km/h	1
    ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff	7.0 km/h	1
    ENG109053-Standard dimming value ZAT	80%	1
    ENG126938-Terminal_15_adaption_body_control_module	Default 	1
    ENG126946-Terminal_S_Timeout	30 min	1
    ENG102207-Time Sensor Power Off Group 2	3600 min	1
    ENG129027-Time_frame_VIP_kick_forecast	5	1
    ENG126942-time_to_drive_cycle_detection	1.00 s	1
    ENG126947-time_to_ignore_ignition_trigger	35 s	1
    ENG126954-time_to_ZAT_Open_circuit_detection	1000 ms	1
    ENG126951-time_to_ZAT_Short_circuit_fault_detection	60 s	1
    ENG126949-time_ZAT_actuation_detection	3000 ms	1
    ENG126952-time_ZAT_lock_after emergency_shutoff	1000 ms	1
    ENG126953-time_ZAT_lock_after_normal_shutoff	500 ms	1
    ENG129009-Timeframe_request_immobilizer_terminal_approval	10000 ms	1
    ENG129019-timeout_convenience_coverage_limiting	75 s	1
    ENG129014-Timeout_trigger_terminal_deactivation_central_locking	1.00 s	1
    ENG244884-Toggle_offtime_other_doorhandle	2.00 s	1
    ENG244885-Toggle_offtime_same_doorhandle	2.00 s	1
    ENG109974-Voltage monitoring: overvoltage Delta	500 mV	1
    ENG109975-Voltage monitoring: overvoltage for KESSY ECU	16000 mV	1
    ENG109976-Voltage monitoring: overvoltage for Keyless Go	27000 mV	1
    ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta	0 mV	1
    ENG109978-Voltage monitoring: undervoltage Delta	500 mV	1
    ENG109979-Voltage monitoring: undervoltage for KESSY ECU	9000 mV	1
    ENG109980-Voltage monitoring: undervoltage for Keyless Go	6000 mV	1
    ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta	0 mV	1
    ENG120047-ZAT init value	0%	1
    ENG110364-ZAT nominal voltage	13.0 V	1
    ENG110365-ZAT post-carridge during clamp 15 off	10 min	1
    ENG153750-ZAT_clamp58xt_signal_factor	0.2	1
    ENG153751-ZAT_clamp58xt_signal_offset	3	1
    ENG153752-ZAT_first_fall_time_high_low_state	900 ms	1
    ENG153753-ZAT_first_rise_time_low_high_state	100 ms	1
    ENG153754-ZAT_motor_signal_timer_1	3000 ms	1
    ENG153755-ZAT_motor_signal_timer_2	3000 ms	1
    ENG153756-ZAT_pwm_offset_1_lower_limit	5%	1
    ENG153757-ZAT_pwm_offset_2_lower_limit	10%	1
    ENG153758-ZAT_pwm_peak1_upper_limit	90%	1
    ENG153759-ZAT_pwm_peak2_upper_limit	100%	1
    ENG153760-ZAT_second_fall_time_high_low_state	2000 ms	1
    Elapsed Time: 00:56
    Current Auto Scan
    Monday,09,September,2019,19:35:08:18133
    VIN: DontFeelLikeIt:)   License Plate:
    Mileage: 8129km-5051mi   Repair Order:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 52 5F 6C 6D 75
              CA
    VIN: DontFeelLikeIt:)   Mileage: 8129km-5051miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 83A 907 115     HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H31 0004
       Revision: 1DH31000
       Coding: 012A00122464012FB4000000000000000000000000000000
       Shop #: WSC 25016 444 00000
       ASAM Dataset: EV_ECM20TFS01183A907115 001006
       ROD: EV_ECM20TFS01183A907115.rod
       VCID: 6393AC8CFBD1D54FB7B-8036
    Readiness: 1010 0101
       Part No SW: 09G 927 158 DS    HW: 09G 927 158
       Component: AISIN AQ8     206 3550
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00442
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 074B981C2FA9596F8B3-8052
       Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
       Component: ESC           H25 0524
       Revision: 00000000    Serial number: 52518000000966
       Coding: 0BFA6BA454231B6CC57F0208A2C449D0D62AD8A34045927038415058C282420B002764121A1C230A35351919323200
       Shop #: WSC 01383 790 50316
       VCID: 77ABE8DC5F4929EFFB3-8022
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0490283687
       Coding: 132C0C0723
    221445 - Sensor for Rear Lid/Hatch Opening
              B1303 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 18
                        Mileage: 8129 km
                        Date: 2019.09.07
                        Time: 01:53:53
                        ZAT_pressed: OFF
                        Control Module Voltage: 12.634 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Status of vehicle locking: Vehicle unlocked at single door
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: closed
                        Front Passenger Door: Open
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
       Component: AC Automat    H35 4401
       Revision: 20K03000    Serial number: 00000D00238665
       Coding: 00020024200118001005010012111406
       ASAM Dataset: EV_ACClimaPrehVW37X 002025
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 4FFB703C8759412F033-801A
       Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
       Component: BCM PQ37BOSCH 036 0265
       Revision: --------    Serial number: C86421091803FA
       ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7CA1F7F0666F0AB7961-8028
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 180917  034 0373
       Serial number: 18091421039560
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0300151020180C202288
       Serial number: 000137088R18289
       Coding: 0471155811
       VCID: 4CC16730764F7A37661-8018
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3200000158FF8728749C8145304097
       Shop #: WSC 00066 790 00273
       VCID: 3E253DF830F3D8A7F85-806A
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    005 0338
       Serial number: 003NUM0BHRZ$
       Coding: 8CCCFC00000000005000001AC20800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 0557921415A54B7FF9F-8050
       Occupant Detection:
       Serial number: IBH00000000000ABQA7O
       Coding: 303351
       Subsystem 2 - Part No SW: -----------    HW: 480 002 407 18
       Serial number: 3570000000055C85933M
       Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
       Serial number: 358000000002B2843339
       Subsystem 4 - Part No SW: -----------    HW: 480 400 507 18
       Component: SideSensor_Dr  004 6149
       Serial number: 3510001142B6FB4485D8
       Subsystem 5 - Part No SW: -----------    HW: 480 400 507 18
       Component: SideSensor_Pr  004 6149
       Serial number: 3520001102B6FB4544A+
       Subsystem 6 - Part No SW: -----------    HW: 480 400 609 18
       Component: FrontSensor_D  004 6149
       Serial number: 3550001142B70FA244B%
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 609 18
       Component: FrontSensor_P  003 6149
       Serial number: 3560001A32BD5EC2E59T
       Part No SW: 5NA 920 891 C    HW: 5NA 920 891 C
       Component: KOMBI         403 4191
       Coding: 0BA4011A2788CF0502886A0954010000A0000000
       VCID: 44D14F105E1FB277AE1-8010
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5344
       Serial number: 16091800840285
       Coding: 030100347F085900FA000258180F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 3D273AF43DF5C3BFE1F-8068
       Component: 1-00-0d-00-04
       Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
       Component: E221__MFL-TAT  H06 0025
       Serial number: 2561814221201572FJ2B
       Coding: 2C0000
       Serial number: 8137026100
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 18000277352016
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 33331CCC0BB105CF07B-8066
       Component: HRE_Master    H12 0081
       Serial number: 0489763985
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0081
       Serial number: 0490546230
       Coding: 020111
       Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
       Component: TSG FS        006 0247
       Serial number: 50038828100576
       Coding: 00341B200000048000000000
       VCID: 4DC76A348D55733F71F-8018
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000000933052
       Coding: 011000
    196660 - Motor for Window Regulator
              B1487 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 18
                        Mileage: 8129 km
                        Date: 2019.09.07
                        Time: 07:27:38
       Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
       Component: EPS_MQB_ZFLS  173 1081
       Coding: 011F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50F973409A675ED71A9-8004
       Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
       Component: TSG BFS       006 0247
       Serial number: 54038827902458
       Coding: 003413200000048000000000
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000000951853
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    853 0890
       Coding: 02730602BE00000051220001001808001F0500E401200405C6
       Shop #: WSC 00066 790 00326
       ROD: EV_MUStd4CDELP_VW37.rod
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  252 8130
       Serial number: VWZ6ZMV2535287
       Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
       Coding: 0123060122002017300040
       VCID: 392F2EE429DDFF9FCD7-806C
       Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0266
       Revision: --------    Serial number: A2-C758-8680-2
       Coding: 0A08
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       VCID: 45D7521455258B7FB9F-8010
       Component: OCULowMQBUS   009 0570
       Coding: 02230602C2823A017F1E06000000
       ROD: EV_OCULowMQB.rod
       Coding: 00804073260C
    End----------(Elapsed Time: 02:47, VBatt start/end: 12.1V/12.2V)-----------
  11. #9
    Apr 2019
    I figured it out with big help from very nice vortex member. Only thing that was missing is an output test, which I did but did not run for long enough.
    After you finish all the coding mentioned in my post #8 go to OutputTest and run Control_Supply_Voltage_VIP. VCDS will not show you any special values and it will just show "Running" let it run for at least 1 minute and then hit stop .
    The no response from VCDS is what got me because I though that nothing was actually happening.
    The window looks like this for the whole time
    Once you are done with the output test, go to faults and clear the calibration fault.
    Now go to the infotainment system and tick Easy Open check box. You are officially done.
    Close the vehicle go away, come back and open the trunk with your foot
    Also after the output test VCDS was able to read All adaptations channel even if the Easy Open was enabled in the infotainment (see post #8).
    Lastly, the auto scan will now show the new module as a slave of the 05 Module
       Coding: 132C0C0723
       Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11055514
    Done you can close this thread as success. Thanks to everyone who helped out
  12. Likes Uwe, icardiag, jyoung8607, Dana, DrPeter, downtime liked this post
  13. #10
    Apr 2019
    Great job! Looking forward to the full install write up
